rtems-test not running tests for leon3
Tue Mar 23 15:37:30 UTC 2021
On Tue, Mar 23, 2021 at 10:32 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> I’m on the master branch of rtems-tools, but the output is the same when I
> run it from the rtems-test included in tools/bin.
Just checking. sis was originally built into gdb. It was separated out and
this tester configuration just got missed. It needs to be removed.
> I got it to run with sparc-rtems6-sis, though.
That's what you should be using (or qemu)
--joel
> *From:* Joel Sherrill <joel.sherrill at gmail.com>
> *Sent:* Tuesday, March 23, 2021 9:22 AM
> *To:* Ryan Long <ryan.long at oarcorp.com>
> *Cc:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Re: rtems-test not running tests for leon3
> Are you sure this is the master for RTEMS test?
> The sis simulator has been out of gdb for a while. I would hope the tester
> configuration is gone. But apparently it isn't. You shouldn't use leon3. It
> Use leon3-sis or leon3-qemu
> On Tue, Mar 23, 2021, 9:07 AM Ryan Long <ryan.long at oarcorp.com> wrote:
> Hi,
> I’ve been trying to run the tests for leon3, but the only test that runs
> properly is the minimum test. All  of the others produce output like so in
> the log file.
> [334/597] p:0   f:0   u:0   e:0   I:0   B:0   t:0   L:0   i:329 W:0   |
> sparc/leon3: nsecs.exe
> Result: invalid    Time: 0:00:02.754956
> nsecs.exe
> =>  gdb: /home/rlong/rtems-work/tools/bin/sparc-rtems6-gdb -i=mi --nx
> --quiet rtems/build/sparc/leon3/testsuites/samples/nsecs.exe
> =>  Reading symbols from
> rtems/build/sparc/leon3/testsuites/samples/nsecs.exe...
> =>  target sim
> -leon3
> =>  Undefined target command: "sim -leon3".  Try "help
> target".
> =>  quit
> Does anyone know how to run these?
> And should I file a ticket for this and fix it in rtems-test?
> Thanks,
> Ryan
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/aca09f7d/attachment.html>
