[PATCH v5] cpukit/aarch64: Add ESR register decoding
Gedare Bloom
gedare at rtems.org
Tue Mar 23 16:45:59 UTC 2021
On Tue, Mar 23, 2021 at 10:31 AM Alex White <alex.white at oarcorp.com> wrote:
> .../aarch64/aarch64-exception-frame-print.c | 133 ++++++++++++++++--
> 1 file changed, 123 insertions(+), 10 deletions(-)
> diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> index 59b5d06032..a8c492b1da 100644
> --- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> +++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> @@ -45,10 +45,111 @@
> #include <inttypes.h>
> #include <rtems/score/cpu.h>
> +#include <rtems/score/io.h>
> #include <rtems/bspIo.h>
> +typedef struct {
> + char *s;
> + size_t n;
> +} String_Context;
> +static void _CPU_Put_char( int c, void *arg )
> + String_Context *sctx = arg;
> + size_t n = sctx->n;
> + if (n > 0) {
> + char *s = sctx->s;
> + *s = (char) c;
> + sctx->s = s + 1;
> + sctx->n = n - 1;
> +static void _CPU_Binary_sprintf(
> + char *s,
> + size_t maxlen,
> + uint32_t num_bits,
> + uint32_t value
> + String_Context sctx;
> + uint32_t mask;
> + sctx.s = s;
> + sctx.n = maxlen;
> + mask = 1 << (num_bits - 1);
> + while ( mask != 0 ) {
> + _IO_Printf( _CPU_Put_char, &sctx, "%d", (value & mask ? 1 : 0) );
> + mask >>= 1;
should this function default to NUL-terminate s?
I'm not totally familiar with the usage, but usually that is the
expectation of an sprintf() kind of function.
> +static const char* _CPU_Exception_class_to_string( uint16_t exception_class )
> + switch ( exception_class ) {
> + case 0x01:
> + return "Trapped WFI or WFE instruction";
> + case 0x03:
> + return "Trapped MCR or MRC access with (coproc==0b1111)";
> + case 0x04:
> + return "Trapped MCRR or MRRC access with (coproc==0b1111)";
> + case 0x05:
> + return "Trapped MCR or MRC access with (coproc==0b1110)";
> + case 0x06:
> + return "Trapped LDC or STC access";
> + case 0x0c:
> + return "Trapped MRRC access with (coproc==0b1110)";
> + case 0x0e:
> + return "Illegal Execution state";
> + case 0x18:
> + return "Trapped MSR, MRS, or System instruction";
> + case 0x20:
> + return "Instruction Abort from a lower Exception level";
> + case 0x21:
> + return "Instruction Abort taken without a change in Exception level";
> + case 0x22:
> + return "PC alignment fault";
> + case 0x24:
> + return "Data Abort from a lower Exception level";
> + case 0x25:
> + return "Data Abort taken without a change in Exception level";
> + case 0x26:
> + return "SP alignment fault";
> + case 0x30:
> + return "Breakpoint exception from a lower Exception level";
> + case 0x31:
> + return "Breakpoint exception taken without a change in Exception level";
> + case 0x32:
> + return "Software Step exception from a lower Exception level";
> + case 0x33:
> + return "Software Step exception taken without a change in Exception "
> + "level";
This is a case where I would say allowing the string to spill over the
80c is better. I think that having a long string (say 40+ characters)
can justify violating this 80c limit. It would be best for someone to
agree with me though :)
Address the NUL termination, and decide how you want to proceed with
the line length for string breaks. It's a gray area in the rules.
> + case 0x34:
> + return "Watchpoint exception from a lower Exception level";
> + case 0x35:
> + return "Watchpoint exception taken without a change in Exception level";
> + case 0x38:
> + return "BKPT instruction execution in AArch32 state";
> + case 0x3c:
> + return "BRK instruction execution in AArch64 state";
> + default:
> + return "Unknown";
> void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> + uint32_t ec;
> + uint32_t il;
> + uint32_t iss;
> + char ec_str[7] = { 0 };
> + char iss_str[26] = { 0 };
> + int i;
> + const uint128_t *qx;
> printk(
> "\n"
> "X0 = 0x%016" PRIx64 " X17 = 0x%016" PRIx64 "\n"
> @@ -68,8 +169,7 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> "X14 = 0x%016" PRIx64 " SP = 0x%016" PRIxPTR "\n"
> "X15 = 0x%016" PRIx64 " PC = 0x%016" PRIxPTR "\n"
> "X16 = 0x%016" PRIx64 " DAIF = 0x%016" PRIx64 "\n"
> - "VEC = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n"
> - "ESR = 0x%016" PRIx64 " FAR = 0x%016" PRIx64 "\n",
> + "VEC = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n",
> frame->register_x0, frame->register_x17,
> frame->register_x1, frame->register_x18,
> frame->register_x2, frame->register_x19,
> @@ -83,23 +183,36 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> frame->register_x10, frame->register_x27,
> frame->register_x11, frame->register_x28,
> frame->register_x12, frame->register_fp,
> - frame->register_x13, (intptr_t)frame->register_lr,
> - frame->register_x14, (intptr_t)frame->register_sp,
> - frame->register_x15, (intptr_t)frame->register_pc,
> + frame->register_x13, (intptr_t) frame->register_lr,
> + frame->register_x14, (intptr_t) frame->register_sp,
> + frame->register_x15, (intptr_t) frame->register_pc,
> frame->register_x16, frame->register_daif,
> - (intptr_t) frame->vector, frame->register_cpsr,
> - frame->register_syndrome, frame->register_fault_address
> + (intptr_t) frame->vector, frame->register_cpsr
> - const uint128_t *qx = &frame->register_q0;
> - int i;
> + ec = frame->register_syndrome >> 26 & 0x3f;
> + il = frame->register_syndrome >> 25 & 0x1;
> + iss = frame->register_syndrome & 0x1ffffff;
> + _CPU_Binary_sprintf( ec_str, sizeof( ec_str ), sizeof( ec_str ) - 1, ec );
> + _CPU_Binary_sprintf( iss_str, sizeof( iss_str ), sizeof( iss_str ) - 1, iss );
> + printk(
> + "ESR = EC: 0b%s" " IL: 0b%d" " ISS: 0b%s" "\n"
> + " %s\n",
> + ec_str, il, iss_str, _CPU_Exception_class_to_string( ec )
> + printk( "FAR = 0x%016" PRIx64 "\n", frame->register_fault_address );
> + qx = &frame->register_q0;
> printk(
> "FPCR = 0x%016" PRIx64 " FPSR = 0x%016" PRIx64 "\n",
> frame->register_fpcr, frame->register_fpsr
> - for ( i = 0; i < 32; ++i ) {
> + for ( i = 0 ; i < 32 ; ++i ) {
> uint64_t low = (uint64_t) qx[i];
> uint64_t high = (uint64_t) (qx[i] >> 32);
> 2.27.0
> devel mailing list
> devel at rtems.org
