[PATCH v5] cpukit/aarch64: Add ESR register decoding
Alex White alex.white at oarcorp.com
Tue Mar 23 17:26:49 UTC 2021
On Tue, Mar 23, 2021 at 11:46 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 23, 2021 at 10:31 AM Alex White <alex.white at oarcorp.com> wrote:
> >  .../aarch64/aarch64-exception-frame-print.c   | 133 ++++++++++++++++--
> >  1 file changed, 123 insertions(+), 10 deletions(-)
> > diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> > index 59b5d06032..a8c492b1da 100644
> > --- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> > +++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
> > @@ -45,10 +45,111 @@
> >  #include <inttypes.h>
> >  #include <rtems/score/cpu.h>
> > +#include <rtems/score/io.h>
> >  #include <rtems/bspIo.h>
> > +typedef struct {
> > +       char *s;
> > +       size_t n;
> > +} String_Context;
> > +static void _CPU_Put_char( int c, void *arg )
> > +  String_Context *sctx = arg;
> > +  size_t n = sctx->n;
> > +  if (n > 0) {
> > +    char *s = sctx->s;
> > +    *s = (char) c;
> > +    sctx->s = s + 1;
> > +    sctx->n = n - 1;
> > +static void _CPU_Binary_sprintf(
> > +  char *s,
> > +  size_t maxlen,
> > +  uint32_t num_bits,
> > +  uint32_t value
> > +  String_Context sctx;
> > +  uint32_t mask;
> > +  sctx.s = s;
> > +  sctx.n = maxlen;
> > +  mask = 1 << (num_bits - 1);
> > +  while ( mask != 0 ) {
> > +    _IO_Printf( _CPU_Put_char, &sctx, "%d", (value & mask ? 1 : 0) );
> > +    mask >>= 1;
> should this function default to NUL-terminate s?
> I'm not totally familiar with the usage, but usually that is the
> expectation of an sprintf() kind of function.
I decided that the function should not NULL-terminate in this case
because it is only used in two places, and I zero-initialize the
character buffers before both calls.
I realize that NULL-termination would make the function more generally
useful, but I only wrote it as a quick static helper for this file.
Is it worth NULL-terminating to avoid a possible bug being introduced
in the future if someone assumes that it is NULL-terminating?
> > +static const char* _CPU_Exception_class_to_string( uint16_t exception_class )
> > +  switch ( exception_class ) {
> > +    case 0x01:
> > +      return "Trapped WFI or WFE instruction";
> > +    case 0x03:
> > +      return "Trapped MCR or MRC access with (coproc==0b1111)";
> > +    case 0x04:
> > +      return "Trapped MCRR or MRRC access with (coproc==0b1111)";
> > +    case 0x05:
> > +      return "Trapped MCR or MRC access with (coproc==0b1110)";
> > +    case 0x06:
> > +      return "Trapped LDC or STC access";
> > +    case 0x0c:
> > +      return "Trapped MRRC access with (coproc==0b1110)";
> > +    case 0x0e:
> > +      return "Illegal Execution state";
> > +    case 0x18:
> > +      return "Trapped MSR, MRS, or System instruction";
> > +    case 0x20:
> > +      return "Instruction Abort from a lower Exception level";
> > +    case 0x21:
> > +      return "Instruction Abort taken without a change in Exception level";
> > +    case 0x22:
> > +      return "PC alignment fault";
> > +    case 0x24:
> > +      return "Data Abort from a lower Exception level";
> > +    case 0x25:
> > +      return "Data Abort taken without a change in Exception level";
> > +    case 0x26:
> > +      return "SP alignment fault";
> > +    case 0x30:
> > +      return "Breakpoint exception from a lower Exception level";
> > +    case 0x31:
> > +      return "Breakpoint exception taken without a change in Exception level";
> > +    case 0x32:
> > +      return "Software Step exception from a lower Exception level";
> > +    case 0x33:
> > +      return "Software Step exception taken without a change in Exception "
> > +             "level";
> This is a case where I would say allowing the string to spill over the
> 80c is better. I think that having a long string (say 40+ characters)
> can justify violating this 80c limit. It would be best for someone to
> agree with me though :)
I agree that it would look better if I allowed this line to exceed the
80 character limit. Those darn coding conventions...
Hopefully others agree to an exception here.
> Address the NUL termination, and decide how you want to proceed with
> the line length for string breaks. It's a gray area in the rules.
> > +    case 0x34:
> > +      return "Watchpoint exception from a lower Exception level";
> > +    case 0x35:
> > +      return "Watchpoint exception taken without a change in Exception level";
> > +    case 0x38:
> > +      return "BKPT instruction execution in AArch32 state";
> > +    case 0x3c:
> > +      return "BRK instruction execution in AArch64 state";
> > +    default:
> > +      return "Unknown";
> >  void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> > +  uint32_t ec;
> > +  uint32_t il;
> > +  uint32_t iss;
> > +  char     ec_str[7] = { 0 };
> > +  char     iss_str[26] = { 0 };
> > +  int      i;
> > +  const uint128_t *qx;
> >    printk(
> >      "\n"
> >      "X0   = 0x%016" PRIx64  " X17  = 0x%016" PRIx64 "\n"
> > @@ -68,8 +169,7 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> >      "X14  = 0x%016" PRIx64  " SP   = 0x%016" PRIxPTR "\n"
> >      "X15  = 0x%016" PRIx64  " PC   = 0x%016" PRIxPTR "\n"
> >      "X16  = 0x%016" PRIx64  " DAIF = 0x%016" PRIx64 "\n"
> > -    "VEC  = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n"
> > -    "ESR  = 0x%016" PRIx64  " FAR  = 0x%016" PRIx64 "\n",
> > +    "VEC  = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n",
> >      frame->register_x0, frame->register_x17,
> >      frame->register_x1, frame->register_x18,
> >      frame->register_x2, frame->register_x19,
> > @@ -83,23 +183,36 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> >      frame->register_x10, frame->register_x27,
> >      frame->register_x11, frame->register_x28,
> >      frame->register_x12, frame->register_fp,
> > -    frame->register_x13, (intptr_t)frame->register_lr,
> > -    frame->register_x14, (intptr_t)frame->register_sp,
> > -    frame->register_x15, (intptr_t)frame->register_pc,
> > +    frame->register_x13, (intptr_t) frame->register_lr,
> > +    frame->register_x14, (intptr_t) frame->register_sp,
> > +    frame->register_x15, (intptr_t) frame->register_pc,
> >      frame->register_x16, frame->register_daif,
> > -    (intptr_t) frame->vector, frame->register_cpsr,
> > -    frame->register_syndrome, frame->register_fault_address
> > +    (intptr_t) frame->vector, frame->register_cpsr
> > -  const uint128_t *qx = &frame->register_q0;
> > -  int i;
> > +  ec = frame->register_syndrome >> 26 & 0x3f;
> > +  il = frame->register_syndrome >> 25 & 0x1;
> > +  iss = frame->register_syndrome & 0x1ffffff;
> > +  _CPU_Binary_sprintf( ec_str, sizeof( ec_str ), sizeof( ec_str ) - 1, ec );
> > +  _CPU_Binary_sprintf( iss_str, sizeof( iss_str ), sizeof( iss_str ) - 1, iss );
> > +  printk(
> > +    "ESR  = EC: 0b%s" " IL: 0b%d" " ISS: 0b%s" "\n"
> > +    "       %s\n",
> > +    ec_str, il, iss_str, _CPU_Exception_class_to_string( ec )
> > +  printk( "FAR  = 0x%016" PRIx64 "\n", frame->register_fault_address );
> > +  qx = &frame->register_q0;
> >    printk(
> >      "FPCR = 0x%016" PRIx64 " FPSR = 0x%016" PRIx64 "\n",
> >      frame->register_fpcr, frame->register_fpsr
> > -  for ( i = 0; i < 32; ++i ) {
> > +  for ( i = 0 ; i < 32 ; ++i ) {
> >      uint64_t low = (uint64_t) qx[i];
> >      uint64_t high = (uint64_t) (qx[i] >> 32);
> > 2.27.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
