[PATCH 2/2] moved common questions and answers to faq
Ayushman Mishra ayushvidushi01 at gmail.com
Tue Mar 23 18:45:03 UTC 2021
 user/start/faq.rst       | 87 ++++++++++++++++++++++++++++++++++++
 user/support/contrib.rst | 95 ----------------------------------------
 2 files changed, 87 insertions(+), 95 deletions(-)
diff --git a/user/start/faq.rst b/user/start/faq.rst
index da11ca4..4558bce 100644
--- a/user/start/faq.rst
+++ b/user/start/faq.rst
@@ -246,6 +246,93 @@ system initialization although task stacks and message buffer areas are also
 allocated from here.
+Why should we work with the RTEMS developers
+Our engineers understand our target environment better than anyone else, and
+we have a tight schedule. Why should we work with the RTEMS developers, when
+we can get the code out faster by whacking it out on our own?
+You understand your target environment better than anyone else.
+However, the RTEMS developers understand RTEMS better than anyone
+else; furthermore, the RTEMS developers tend to have a wide breadth
+of experience across a large number of processors, boards, peripherals,
+and application domains. It has been our experience that few problems
+encountered in embedded systems development are unique to a particular
+processor or application. The vast majority of the time an issue that
+arises in one project has also shown up in other projects.
+The intimate knowledge of RTEMS internals as well as a wide breadth of
+embedded systems knowledge means that there is a good chance that at
+least one RTEMS developer has already addressed issues you are likely
+to face when doing your port, BSP, or application. The developers can
+help guide you towards a workable long term solution, possibly saving
+you significant time in your development cycle.
+If getting the sources into the official RTEMS distributions is one of
+your goals, then engaging other RTEMS developers early will also likely
+shorten your development time. By interacting as early as possible you
+are more likely to write code which can be easily accepted into the official
+sources when you are finished. If you wait until you think you are done
+to begin interacting with the RTEMS team, you might find that you did
+some things wrong and you may have to rewrite parts of your RTEMS port,
+which is a waste of your valuable time.
+Why should we integrate our port into the official RTEMS sources?
+Why should we care if our port is integrated into the official RTEMS sources?
+We can distribute it ourselves to whoever is interested.
+Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
+having to maintain that code yourself; this can be a significant
+effort over time as the RTEMS sources change rapidly.
+You also lose the advantage of wider exposure by including your port
+in the official RTEMS sources maintained by the RTEMS Project.
+The wider exposure in the RTEMS developer and tester community will
+help keep your work up to date with the current sources. You may even
+find that volunteers will run the ever-growing test suite on your port
+and fix problems during the development cycle -- sometimes without your
+intervention.
+It has been our experience that integrated ports tend to ultimately
+be of better quality and stay up to date from release to release.
+Aspects of my target environment that my application exploits are still under NDA
+Nevertheless, if the target hardware is built of any commercial parts
+that are generally available including, but not limited to, the CPU
+or peripherals, then that portion of your work is still of general use.
+Similarly, if you have written software that adheres to existing API or
+interface standards, then that portion is also of general use.
+Our experience is that most embedded applications do utilize a custom
+mix of hardware and application, but they are built upon layers of hardware
+and software components that are in no way unique to the project.
+If you are porting to an unreleased CPU family or model, then just
+announcing it is important because other RTEMS users may be planning
+to use it and some of them may already be trying to port RTEMS on
+their own. Your customers might be happier to know that your port
+will eventually be available. Also, there is no requirement that RTEMS
+include all features or ports at any particular time, so you are encouraged
+to submit discrete pieces of functionality in stages.
+Assume that your processor has some new functionality or peripherals.
+However that functionality is still covered by NDA, but the basic core
+architecture is not. It is still to your advantage to go ahead and work
+with the developers early to provide a "base port" for the CPU family.
+That base port would only use the publicly available specifications
+until such time as the NDA is lifted. Once the NDA is lifted you can
+work with the developers to provide the code necessary to take
+advantage of the new functionality.
 What is the difference between autoconf and waf build system ?
diff --git a/user/support/contrib.rst b/user/support/contrib.rst
index c42d41b..d76fbbc 100644
--- a/user/support/contrib.rst
+++ b/user/support/contrib.rst
@@ -168,98 +168,3 @@ time, or have proven very hard to integrate. So, what we are asking
 is that, to the maximum extent possible, you communicate with us
 as early on and as much as possible.
-Common Questions and Answers
-Here are some questions RTEMS porters may have with our answers to
-them. While the focus here is on new ports and BSPs, we believe that
-the issues are similar for other RTEMS development efforts including
-student efforts to implement new algorithmic optimizations.
-    Our engineers understand our target environment better than anyone else, and
-    we have a tight schedule. Why should we work with the RTEMS developers, when
-    we can get the code out faster by whacking it out on our own?
-You understand your target environment better than anyone else.
-However, the RTEMS developers understand RTEMS better than anyone
-else; furthermore, the RTEMS developers tend to have a wide breadth
-of experience across a large number of processors, boards, peripherals,
-and application domains. It has been our experience that few problems
-encountered in embedded systems development are unique to a particular
-processor or application. The vast majority of the time an issue that
-arises in one project has also shown up in other projects.
-The intimate knowledge of RTEMS internals as well as a wide breadth of
-embedded systems knowledge means that there is a good chance that at
-least one RTEMS developer has already addressed issues you are likely
-to face when doing your port, BSP, or application. The developers can
-help guide you towards a workable long term solution, possibly saving
-you significant time in your development cycle.
-If getting the sources into the official RTEMS distributions is one of
-your goals, then engaging other RTEMS developers early will also likely
-shorten your development time. By interacting as early as possible you
-are more likely to write code which can be easily accepted into the official
-sources when you are finished. If you wait until you think you are done
-to begin interacting with the RTEMS team, you might find that you did
-some things wrong and you may have to rewrite parts of your RTEMS port,
-which is a waste of your valuable time.
-    Why should we care if our port is integrated into the official RTEMS
-    sources? We can distribute it ourselves to whoever is interested.
-Yes, the RTEMS licenses allows you to do that. But by doing so, you end up
-having to maintain that code yourself; this can be a significant
-effort over time as the RTEMS sources change rapidly.
-You also lose the advantage of wider exposure by including your port
-in the official RTEMS sources maintained by the RTEMS Project.
-The wider exposure in the RTEMS developer and tester community will
-help keep your work up to date with the current sources. You may even
-find that volunteers will run the ever-growing test suite on your port
-and fix problems during the development cycle -- sometimes without your
-intervention.
-It has been our experience that integrated ports tend to ultimately
-be of better quality and stay up to date from release to release.
-    Why should we communicate up front? We are happy to let the RTEMS developers
-    integrate our stuff later.
-See above. It will save work for you over both the short and the
-long term, and it is the right thing to do.
-    Aspects of my target environment that my application exploits are still
-    under NDA.
-Nevertheless, if the target hardware is built of any commercial parts
-that are generally available including, but not limited to, the CPU
-or peripherals, then that portion of your work is still of general use.
-Similarly, if you have written software that adheres to existing API or
-interface standards, then that portion is also of general use.
-Our experience is that most embedded applications do utilize a custom
-mix of hardware and application, but they are built upon layers of hardware
-and software components that are in no way unique to the project.
-If you are porting to an unreleased CPU family or model, then just
-announcing it is important because other RTEMS users may be planning
-to use it and some of them may already be trying to port RTEMS on
-their own. Your customers might be happier to know that your port
-will eventually be available. Also, there is no requirement that RTEMS
-include all features or ports at any particular time, so you are encouraged
-to submit discrete pieces of functionality in stages.
-Assume that your processor has some new functionality or peripherals.
-However that functionality is still covered by NDA, but the basic core
-architecture is not. It is still to your advantage to go ahead and work
-with the developers early to provide a "base port" for the CPU family.
-That base port would only use the publicly available specifications
-until such time as the NDA is lifted. Once the NDA is lifted you can
-work with the developers to provide the code necessary to take
-advantage of the new functionality.
-Ultimately, cooperating with the free software community as early as
-possible helps you by decreasing your development cycle, decreasing
-your long term maintenance costs and may help raise interest in your
-processor by having a free compiler implementation available to
-anyone who wants to take a look.
2.25.1
