[PATCH v2] bsps/sparc: Remove INI files using SIS in GBD
Ryan Long ryan.long at oarcorp.com
Tue Mar 23 19:44:47 UTC 2021
Removed the INI files that use the "target sim" option
since the SIS sparc simulator in GBD is no longer used
with RTEMS. A newer version of SIS is built seperately.
Closes #4355
 tester/rtems/testing/bsps/erc32.ini | 41 -------------------------------------
 tester/rtems/testing/bsps/leon2.ini | 41 -------------------------------------
 tester/rtems/testing/bsps/leon3.ini | 41 -------------------------------------
 3 files changed, 123 deletions(-)
 delete mode 100644 tester/rtems/testing/bsps/erc32.ini
 delete mode 100644 tester/rtems/testing/bsps/leon2.ini
 delete mode 100644 tester/rtems/testing/bsps/leon3.ini
diff --git a/tester/rtems/testing/bsps/erc32.ini b/tester/rtems/testing/bsps/erc32.ini
deleted file mode 100644
index 7911a2f..0000000
--- a/tester/rtems/testing/bsps/erc32.ini
+++ /dev/null
@@ -1,41 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2015 On-Line Applications Research Corporation (OAR).
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# The erc32 BSP
-[erc32]
-bsp            = erc32
-arch           = sparc
-tester         = %{_rtscripts}/gdb.cfg
-gdb_script     = bsp_gdb_script
-bsp_gdb_script = target sim
-                 load
-                 run
diff --git a/tester/rtems/testing/bsps/leon2.ini b/tester/rtems/testing/bsps/leon2.ini
index 77fed49..0000000
--- a/tester/rtems/testing/bsps/leon2.ini
+++ /dev/null
@@ -1,41 +0,0 @@
-# The leon2 BSP
-[leon2]
-bsp            = leon2
-arch           = sparc
-bsp_gdb_script = target sim -leon2
-                 load
-                 run
diff --git a/tester/rtems/testing/bsps/leon3.ini b/tester/rtems/testing/bsps/leon3.ini
index 74eafb7..0000000
--- a/tester/rtems/testing/bsps/leon3.ini
+++ /dev/null
@@ -1,41 +0,0 @@
-# The leon3 BSP
-[leon3]
-bsp            = leon3
-arch           = sparc
-bsp_gdb_script = target sim -leon3
-                 load
-                 run
1.8.3.1
