[PATCH v6] cpukit/aarch64: Add ESR register decoding
Alex White
alex.white at oarcorp.com
Tue Mar 23 20:25:20 UTC 2021
.../aarch64/aarch64-exception-frame-print.c | 135 ++++++++++++++++--
1 file changed, 125 insertions(+), 10 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
index 59b5d06032..e207a5a81d 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
@@ -45,10 +45,113 @@
#include <inttypes.h>
#include <rtems/score/cpu.h>
+#include <rtems/score/io.h>
#include <rtems/bspIo.h>
+typedef struct {
+ char *s;
+ size_t n;
+} String_Context;
+static void _CPU_Put_char( int c, void *arg )
+ String_Context *sctx = arg;
+ size_t n = sctx->n;
+ if (n > 0) {
+ char *s = sctx->s;
+ *s = (char) c;
+ sctx->s = s + 1;
+ sctx->n = n - 1;
+static void _CPU_Binary_sprintf(
+ char *s,
+ size_t maxlen,
+ uint32_t num_bits,
+ uint32_t value
+ String_Context sctx;
+ uint32_t mask;
+ sctx.s = s;
+ sctx.n = maxlen;
+ mask = 1 << (num_bits - 1);
+ while ( mask != 0 ) {
+ _IO_Printf( _CPU_Put_char, &sctx, "%d", (value & mask ? 1 : 0) );
+ mask >>= 1;
+ s[num_bits] = '\0';
+static const char* _CPU_Exception_class_to_string( uint16_t exception_class )
+ /* The 80 character limit is intentionally ignored for these strings. */
+ switch ( exception_class ) {
+ case 0x01:
+ return "Trapped WFI or WFE instruction";
+ case 0x03:
+ return "Trapped MCR or MRC access with (coproc==0b1111)";
+ case 0x04:
+ return "Trapped MCRR or MRRC access with (coproc==0b1111)";
+ case 0x05:
+ return "Trapped MCR or MRC access with (coproc==0b1110)";
+ case 0x06:
+ return "Trapped LDC or STC access";
+ case 0x0c:
+ return "Trapped MRRC access with (coproc==0b1110)";
+ case 0x0e:
+ return "Illegal Execution state";
+ case 0x18:
+ return "Trapped MSR, MRS, or System instruction";
+ case 0x20:
+ return "Instruction Abort from a lower Exception level";
+ case 0x21:
+ return "Instruction Abort taken without a change in Exception level";
+ case 0x22:
+ return "PC alignment fault";
+ case 0x24:
+ return "Data Abort from a lower Exception level";
+ case 0x25:
+ return "Data Abort taken without a change in Exception level";
+ case 0x26:
+ return "SP alignment fault";
+ case 0x30:
+ return "Breakpoint exception from a lower Exception level";
+ case 0x31:
+ return "Breakpoint exception taken without a change in Exception level";
+ case 0x32:
+ return "Software Step exception from a lower Exception level";
+ case 0x33:
+ return "Software Step exception taken without a change in Exception level";
+ case 0x34:
+ return "Watchpoint exception from a lower Exception level";
+ case 0x35:
+ return "Watchpoint exception taken without a change in Exception level";
+ case 0x38:
+ return "BKPT instruction execution in AArch32 state";
+ case 0x3c:
+ return "BRK instruction execution in AArch64 state";
+ default:
+ return "Unknown";
void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+ uint32_t ec;
+ uint32_t il;
+ uint32_t iss;
+ char ec_str[7];
+ char iss_str[26];
+ int i;
+ const uint128_t *qx;
printk(
"\n"
"X0 = 0x%016" PRIx64 " X17 = 0x%016" PRIx64 "\n"
@@ -68,8 +171,7 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
"X14 = 0x%016" PRIx64 " SP = 0x%016" PRIxPTR "\n"
"X15 = 0x%016" PRIx64 " PC = 0x%016" PRIxPTR "\n"
"X16 = 0x%016" PRIx64 " DAIF = 0x%016" PRIx64 "\n"
- "VEC = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n"
- "ESR = 0x%016" PRIx64 " FAR = 0x%016" PRIx64 "\n",
+ "VEC = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n",
frame->register_x0, frame->register_x17,
frame->register_x1, frame->register_x18,
frame->register_x2, frame->register_x19,
@@ -83,23 +185,36 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
frame->register_x10, frame->register_x27,
frame->register_x11, frame->register_x28,
frame->register_x12, frame->register_fp,
- frame->register_x13, (intptr_t)frame->register_lr,
- frame->register_x14, (intptr_t)frame->register_sp,
- frame->register_x15, (intptr_t)frame->register_pc,
+ frame->register_x13, (intptr_t) frame->register_lr,
+ frame->register_x14, (intptr_t) frame->register_sp,
+ frame->register_x15, (intptr_t) frame->register_pc,
frame->register_x16, frame->register_daif,
- (intptr_t) frame->vector, frame->register_cpsr,
- frame->register_syndrome, frame->register_fault_address
+ (intptr_t) frame->vector, frame->register_cpsr
- const uint128_t *qx = &frame->register_q0;
- int i;
+ ec = frame->register_syndrome >> 26 & 0x3f;
+ il = frame->register_syndrome >> 25 & 0x1;
+ iss = frame->register_syndrome & 0x1ffffff;
+ _CPU_Binary_sprintf( ec_str, sizeof( ec_str ), sizeof( ec_str ) - 1, ec );
+ _CPU_Binary_sprintf( iss_str, sizeof( iss_str ), sizeof( iss_str ) - 1, iss );
+ printk(
+ "ESR = EC: 0b%s" " IL: 0b%d" " ISS: 0b%s" "\n"
+ " %s\n",
+ ec_str, il, iss_str, _CPU_Exception_class_to_string( ec )
+ printk( "FAR = 0x%016" PRIx64 "\n", frame->register_fault_address );
+ qx = &frame->register_q0;
printk(
"FPCR = 0x%016" PRIx64 " FPSR = 0x%016" PRIx64 "\n",
frame->register_fpcr, frame->register_fpsr
- for ( i = 0; i < 32; ++i ) {
+ for ( i = 0 ; i < 32 ; ++i ) {
uint64_t low = (uint64_t) qx[i];
uint64_t high = (uint64_t) (qx[i] >> 32);
2.27.0
