[PATCH v2] bsps/sparc: Remove INI files using SIS in GBD
Chris Johns
chrisj at rtems.org
Tue Mar 23 22:08:58 UTC 2021
On 24/3/21 6:46 am, Gedare Bloom wrote:
> On Tue, Mar 23, 2021 at 1:45 PM Ryan Long <ryan.long at oarcorp.com> wrote:
>> Removed the INI files that use the "target sim" option
>> since the SIS sparc simulator in GBD is no longer used
> GDB
>> with RTEMS. A newer version of SIS is built seperately.
> while you're at it, separately
> This can be pushed with the typo changes, also GDB in the first line
> of the commit msg.
[ Just following up the discord chat ... ]
I am not so sure. This breaks the eco-system user interface the community may
depend on. If I wish to test the erc32 or leon2 then that is all I should use.
The original idea is the default or standard test name is the BSP name.
As discussed in discord the approach is not perfect because things change as
these patches show and it does not handle aliased BSPs (not sure how to handle
that). We need to find ways to handle these things.
I suggest we try the INI include support the rtemstoolkit provides to see if
these top level BSP test configs can reference the preferred implementation.
