[PATCH v2] bsps/sparc: Remove INI files using SIS in GBD
Gedare Bloom
gedare at rtems.org
Tue Mar 23 19:46:33 UTC 2021
On Tue, Mar 23, 2021 at 1:45 PM Ryan Long <ryan.long at oarcorp.com> wrote:
> Removed the INI files that use the "target sim" option
> since the SIS sparc simulator in GBD is no longer used
GDB
> with RTEMS. A newer version of SIS is built seperately.
while you're at it, separately
This can be pushed with the typo changes, also GDB in the first line
of the commit msg.
> Closes #4355
> tester/rtems/testing/bsps/erc32.ini | 41 -------------------------------------
> tester/rtems/testing/bsps/leon2.ini | 41 -------------------------------------
> tester/rtems/testing/bsps/leon3.ini | 41 -------------------------------------
> 3 files changed, 123 deletions(-)
> delete mode 100644 tester/rtems/testing/bsps/erc32.ini
> delete mode 100644 tester/rtems/testing/bsps/leon2.ini
> delete mode 100644 tester/rtems/testing/bsps/leon3.ini
> diff --git a/tester/rtems/testing/bsps/erc32.ini b/tester/rtems/testing/bsps/erc32.ini
> deleted file mode 100644
> index 7911a2f..0000000
> --- a/tester/rtems/testing/bsps/erc32.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> -# RTEMS Tools Project (http://www.rtems.org/)
> -# Copyright 2015 On-Line Applications Research Corporation (OAR).
> -# All rights reserved.
> -# This file is part of the RTEMS Tools package in 'rtems-tools'.
> -# Redistribution and use in source and binary forms, with or without
> -# modification, are permitted provided that the following conditions are met:
> -# 1. Redistributions of source code must retain the above copyright notice,
> -# this list of conditions and the following disclaimer.
> -# 2. Redistributions in binary form must reproduce the above copyright notice,
> -# this list of conditions and the following disclaimer in the documentation
> -# and/or other materials provided with the distribution.
> -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> -# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> -# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> -# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> -# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> -# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> -# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> -# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> -# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> -# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> -# POSSIBILITY OF SUCH DAMAGE.
> -# The erc32 BSP
> -[erc32]
> -bsp = erc32
> -arch = sparc
> -tester = %{_rtscripts}/gdb.cfg
> -gdb_script = bsp_gdb_script
> -bsp_gdb_script = target sim
> - load
> - run
> diff --git a/tester/rtems/testing/bsps/leon2.ini b/tester/rtems/testing/bsps/leon2.ini
> index 77fed49..0000000
> --- a/tester/rtems/testing/bsps/leon2.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> -# The leon2 BSP
> -[leon2]
> -bsp = leon2
> -arch = sparc
> -bsp_gdb_script = target sim -leon2
> - load
> - run
> diff --git a/tester/rtems/testing/bsps/leon3.ini b/tester/rtems/testing/bsps/leon3.ini
> index 74eafb7..0000000
> --- a/tester/rtems/testing/bsps/leon3.ini
> +++ /dev/null
> @@ -1,41 +0,0 @@
> -# The leon3 BSP
> -[leon3]
> -bsp = leon3
> -arch = sparc
> -bsp_gdb_script = target sim -leon3
> - load
> - run
> 1.8.3.1
> devel mailing list
> devel at rtems.org
