rtems-test not running tests for leon3
Richi Dubey
richidubey at gmail.com
Wed Mar 24 05:00:33 UTC 2021
The test does not execute TEST_END() and exits just like that:
https://git.rtems.org/rtems/tree/testsuites/samples/minimum/init.c#n31,
hence it is always flagged as a failure in rtems-test.
On Wed, Mar 24, 2021 at 2:55 AM Chris Johns <chrisj at rtems.org> wrote:
> On 24/3/21 1:18 am, Richi Dubey wrote:
> > Afaik minimum tests are supposed to fail.
> This is something I am not sure about. It is minimal by definition and as a
> result does not print anything so it is impossible to determine if the
> test runs
> of fails. As an example to show how small RTEMS can be it is fine however
> as a
> test in a strict theoretical sense it is like a cat in a box. Maybe it
> should
> flagged no run however if it does crash we will never know because we do
> not run
> it .... and so we circle the loop.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210324/f0f457bf/attachment.html>
