rtems-test not running tests for leon3
Tue Mar 23 21:25:47 UTC 2021
On 24/3/21 1:18 am, Richi Dubey wrote:
> Afaik minimum tests are supposed to fail.
This is something I am not sure about. It is minimal by definition and as a
result does not print anything so it is impossible to determine if the test runs
of fails. As an example to show how small RTEMS can be it is fine however as a
test in a strict theoretical sense it is like a cat in a box. Maybe it should
flagged no run however if it does crash we will never know because we do not run
it .... and so we circle the loop.
