Recent rtems-tools patches status
Gedare Bloom
gedare at rtems.org
Wed Mar 24 15:52:34 UTC 2021
On Wed, Mar 24, 2021 at 7:56 AM Alex White <alex.white at oarcorp.com> wrote:
> Hi,
> Here is the status of the rtems-tools patches I have sent out over the past few weeks (an X means the latest patch revision has been reviewed):
> [ ] tester: Limit branch coverage percentage precision
> [ ] coverage: Fix option processing on FreeBSD
> [ ] coverage/symbol-sets.ini : Add libtrace
> [ ] covoar/Reports: Fix empty branch report
> [ ] covoar: Fix overflow of high PC address
> [ ] covoar: Catch exceptional case
> [ ] covoar: Add option to create named objdumps
> [X] covoar: Fix null pointer dereference
> [X] coverage: Give coverage bars red background
> [X] coverage/reports: Share common JS and CSS in reports
> [X] coverage/reports: Improve formatting and clarity
> [X] covoar/reports: Add new statistics to summary
> [ ] covoar: Handle periods in symbols from objdump
> [ ] covoar: Account for build path change
> [ ] covoar: Fix DWARF reading
> [ ] covoar/TargetBase: Fix QEMU branch info
> [ ] covoar/CoverageReaderQEMU: Fix infinite loop
> [ ] covoar/Target_arm: Add THUMB branch instructions
> [ ] covoar/Target_i386: Add NOP patterns
> [ ] covoar: Fix NOP execution marking
> [X] tester: Add coverage variants for a few BSPs
> [X] tester: Remove target from BSP coverage configs
> [X] tester: Update to support new build system
> [ ] covoar: Add aarch64 target
> [X] covoar/TargetBase: Rename branchInstructions to conditionalBranchInstructions
> [X] rld-process: Add named tempfile constructor
> [X] rld-dwarf: Fix file::get_source
> [X] rld-dwarf: Add function::has_entry_pc
> I sent these patches as a firehose, so I am not surprised that some didn’t get a response. :)
> My plan is to resend the patches that have not been reviewed and meter them out so I don’t overwhelm the list. Hopefully that will allow us to better work through this list. Is that ok?
Yes. You and Joel may also like to track these with a spreadsheet. I'd
be willing to open one when asked :)
> Thanks,
> Alex
> devel mailing list
> devel at rtems.org
