[PATCH rtems-libbsd 3/3] STM32H7: Add SDMMC driver
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Mar 25 08:35:41 UTC 2021
libbsd.py | 2 +
rtemsbsd/include/bsp/nexus-devices.h | 2 +
rtemsbsd/include/bsp/st-sdmmc-config.h | 71 ++
.../include/machine/rtems-bsd-nexus-bus.h | 22 +
rtemsbsd/sys/dev/mmc/st-sdmmc-config.c | 46 +
rtemsbsd/sys/dev/mmc/st-sdmmc.c | 847 ++++++++++++++++++
6 files changed, 990 insertions(+)
create mode 100644 rtemsbsd/include/bsp/st-sdmmc-config.h
create mode 100644 rtemsbsd/sys/dev/mmc/st-sdmmc-config.c
create mode 100644 rtemsbsd/sys/dev/mmc/st-sdmmc.c
diff --git a/libbsd.py b/libbsd.py
index f8a35e6c6..befa1a1a5 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -228,6 +228,8 @@ class rtems(builder.Module):
'sys/dev/ffec/if_ffec_mcf548x.c',
'sys/dev/ffec/if_ffec_mpc8xx.c',
'sys/dev/input/touchscreen/tsc_lpc32xx.c',
+ 'sys/dev/mmc/st-sdmmc.c',
+ 'sys/dev/mmc/st-sdmmc-config.c',
'sys/dev/smc/if_smc_nexus.c',
'sys/dev/stmac/if_stmac.c',
'sys/dev/tsec/if_tsec_nexus.c',
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 53a22798b..efe4fcb4f 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -193,6 +193,8 @@ static const rtems_bsd_device_resource dwcotg_res[] = {
RTEMS_BSD_DEFINE_NEXUS_DEVICE(dwcotg, 0, RTEMS_ARRAY_SIZE(dwcotg_res),
dwcotg_res);
+RTEMS_BSD_DRIVER_ST_SDMMC(0, SDMMC1_BASE, DLYB_SDMMC1_BASE, SDMMC1_IRQn);
+RTEMS_BSD_DRIVER_MMC;
RTEMS_BSD_DRIVER_USB;
RTEMS_BSD_DRIVER_USB_MASS;
diff --git a/rtemsbsd/include/bsp/st-sdmmc-config.h b/rtemsbsd/include/bsp/st-sdmmc-config.h
new file mode 100644
index 000000000..b44159918
--- /dev/null
+++ b/rtemsbsd/include/bsp/st-sdmmc-config.h
@@ -0,0 +1,71 @@
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef BSP_ST_SDMMC_CONFIG_H
+#define BSP_ST_SDMMC_CONFIG_H
+#include <stdbool.h>
+#include <stdint.h>
+#include <stm32h7/hal.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+struct st_sdmmc_config {
+ * Number of data lines. Can be 1, 4 or 8
+ uint8_t data_lines;
+ * Polarity of the DIR pins. See "SDMMC_POWER" register in the
+ * STM32H7xx data sheet for that. If you don't have the lines, you can
+ * use any value.
+ bool dirpol;
+ * Possible OCR voltages. Should be something like
+ * MMC_OCR_290_300 | MMC_OCR_300_310 depending on card supply.
+ uint32_t ocr_voltage;
+ * Get hardware specific configuration for SDMMC.
+ * This function can be overwritten in the application to adapt to another board
+ * configuration. The sdmmc_base points to the base address of the SDMMC
+ * instance. The cfg structure is set to zero before calling this function so
+ * that only the necessary fields have to be initialized.
+void st_sdmmc_get_config(uintptr_t sdmmc_base, struct st_sdmmc_config *cfg);
+#ifdef __cplusplus
+#endif /* BSP_ST_SDMMC_CONFIG_H */
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index f1ca66d70..5902c58c6 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -243,6 +243,28 @@ extern "C" {
SYSINIT_DRIVER_REFERENCE(mmcsd, mmc)
#endif /* RTEMS_BSD_DRIVER_MMC */
+#if !defined(RTEMS_BSD_DRIVER_ST_SDMMC)
+ #define RTEMS_BSD_DRIVER_ST_SDMMC(_num, _base, _dlyb, _irq) \
+ static const rtems_bsd_device_resource st_sdmmc ## _num ## _res[] = { \
+ .type = RTEMS_BSD_RES_MEMORY, \
+ .start_request = 0, \
+ .start_actual = (_base) \
+ .start_request = 1, \
+ .start_actual = (_dlyb) \
+ .type = RTEMS_BSD_RES_IRQ, \
+ .start_actual = (_irq) \
+ RTEMS_BSD_DEFINE_NEXUS_DEVICE(st_sdmmc, 0, \
+ RTEMS_ARRAY_SIZE(st_sdmmc ## _num ## _res), \
+ &st_sdmmc ## _num ## _res[0])
+#endif /* RTEMS_BSD_DRIVER_ST_SDMMC */
* USB Drivers.
diff --git a/rtemsbsd/sys/dev/mmc/st-sdmmc-config.c b/rtemsbsd/sys/dev/mmc/st-sdmmc-config.c
index 000000000..723a169b9
--- /dev/null
+++ b/rtemsbsd/sys/dev/mmc/st-sdmmc-config.c
@@ -0,0 +1,46 @@
+ * are met:
+#include <bsp/st-sdmmc-config.h>
+#include <dev/mmc/mmcreg.h>
+void
+st_sdmmc_get_config(uintptr_t sdmmc_base, struct st_sdmmc_config *cfg)
+ switch (sdmmc_base) {
+ case SDMMC1_BASE:
+ cfg->data_lines = 4;
+ cfg->dirpol = true;
+ * FIXME: Also the evaluation board could switch to 1.8V, the
+ * control for the level converter isn't implemented in the
+ * driver yet. So only signal 2.9V.
+ cfg->ocr_voltage = MMC_OCR_280_290 | MMC_OCR_290_300;
+ break;
diff --git a/rtemsbsd/sys/dev/mmc/st-sdmmc.c b/rtemsbsd/sys/dev/mmc/st-sdmmc.c
index 000000000..bf8831a47
--- /dev/null
+++ b/rtemsbsd/sys/dev/mmc/st-sdmmc.c
@@ -0,0 +1,847 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * are met:
+ * STM32H7xx SDMMC controller. Documentation: ST RM0433 (Rev 6), Chapter 54
+ * According to Linux DTS, the SDMMC is compatible with an ARM Primecell PL18X
+ * with peripheral ID 0x10153180.
+ * Note: This driver is inspired by the NetBSD pl181 driver written by Jared D.
+ * McNeill.
+ * Note regarding DMA on STM32H7:
+ * The STM32H7 SDMMC doesn't have an interrupt for few received data (less than
+ * half the FIFO size). So especially for short responses, it is not possible to
+ * use the SDMMC without DMA.
+ * On the STM32H7 SDMMC there are two DMAs: One IDMA integrated into the SDMMC
+ * and one MDMA that is a general purpose DMA. MDMA can only be used on first
+ * instance of the SDMMC. For the second instance, the trigger signals are not
+ * connected.
+ * The IDMA of SDMMC1 can only access AXI SRAM, QSPI and FMC (where SDRAM is
+ * located). The IDMA of SDMMC2 could access memory in other domains too.
+ * MDMA is designed to be a companion for IDMA. It seems that ST thought of a
+ * very specific software structure for that. It can be either used to change
+ * the IDMA buffer addresses (which would allow some kind of scatter gather
+ * functionality with fixed buffer sizes) or to refill IDMA buffers from some
+ * RAM that can't be accessed directly by the IDMA. Take a look at ST AN5200 Rev
+ * 1 "Getting started with STM32H7 Series SDMMC host controller" for more
+ * details.
+#include <rtems/malloc.h>
+#include <rtems/irq-extension.h>
+#include <stm32h7/memory.h>
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <sys/resource.h>
+#include <sys/rman.h>
+#include <sys/condvar.h>
+#include <pthread.h>
+#include <machine/resource.h>
+#include <dev/mmc/bridge.h>
+#include <dev/mmc/mmcbrvar.h>
+#define ST_SDMMC_LOCK(_sc) mtx_lock(&(_sc)->mtx)
+#define ST_SDMMC_UNLOCK(_sc) mtx_unlock(&(_sc)->mtx)
+#define ST_SDMMC_LOCK_INIT(_sc) \
+ mtx_init(&_sc->mtx, device_get_nameunit(_sc->dev), \
+ "st_sdmmc", MTX_DEF)
+#define SDMMC_INT_ERROR_MASK ( \
+ SDMMC_MASK_CTIMEOUTIE | \
+ SDMMC_MASK_CCRCFAILIE | \
+ SDMMC_MASK_DTIMEOUTIE | \
+ SDMMC_MASK_DCRCFAILIE | \
+ SDMMC_MASK_ACKFAILIE | \
+ SDMMC_MASK_RXOVERRIE | \
+ SDMMC_MASK_TXUNDERRIE | \
+ SDMMC_MASK_DABORTIE | \
+ SDMMC_MASK_ACKTIMEOUTIE )
+#define SDMMC_INT_DATA_DONE_MASK ( SDMMC_MASK_IDMABTCIE | SDMMC_MASK_DATAENDIE )
+#define SDMMC_INT_CMD_DONE_MASK ( SDMMC_MASK_CMDSENTIE )
+#define SDMMC_INT_CMD_RESPONSE_DONE_MASK ( SDMMC_MASK_CMDRENDIE )
+#define RES_MEM_SDMMC 0
+#define RES_MEM_DLYB 1
+#define RES_IRQ_SDMMC 2
+#define RES_NR 3
+#define DMA_BUF_SIZE CPU_CACHE_LINE_BYTES
+#if 0
+#define debug_print(sc, lvl, ...) \
+ if (lvl <= 1) device_printf(sc->dev, __VA_ARGS__)
+#else
+#define debug_print(...)
+#endif
+struct st_sdmmc_softc;
+typedef void (*st_sdmmc_dma_setup_transfer)(struct st_sdmmc_softc *, void *);
+struct st_sdmmc_softc {
+ device_t dev;
+ struct mmc_host host;
+ struct mtx mtx;
+ rtems_binary_semaphore wait_done;
+ int bus_busy;
+ struct resource *res[RES_NR];
+ SDMMC_TypeDef *sdmmc;
+ DLYB_TypeDef *dlyb;
+ rtems_vector_number irq;
+ uint32_t sdmmc_ker_ck;
+ struct st_sdmmc_config cfg;
+ uint32_t intr_status;
+ uint8_t *dmabuf;
+void st_sdmmc_idma_txrx(struct st_sdmmc_softc *sc, void *buf)
+ BSD_ASSERT(
+ (buf >= (void*) stm32h7_memory_sdram_1_begin &&
+ buf < (void*) stm32h7_memory_sdram_1_end) ||
+ (buf >= (void*) stm32h7_memory_sram_axi_begin &&
+ buf < (void*) stm32h7_memory_sram_axi_end) ||
+ (buf >= (void*) stm32h7_memory_sdram_2_begin &&
+ buf < (void*) stm32h7_memory_sdram_2_end) ||
+ (buf >= (void*) stm32h7_memory_quadspi_begin &&
+ buf < (void*) stm32h7_memory_quadspi_end));
+ sc->sdmmc->IDMABASE0 = (uintptr_t) buf;
+ sc->sdmmc->IDMACTRL = SDMMC_IDMA_IDMAEN;
+void st_sdmmc_idma_stop(struct st_sdmmc_softc *sc)
+ sc->sdmmc->IDMACTRL = 0;
+static void
+st_sdmmc_intr(void *arg)
+ struct st_sdmmc_softc *sc;
+ uint32_t status;
+ sc = arg;
+ status = sc->sdmmc->STA;
+ sc->sdmmc->ICR = status;
+ sc->intr_status |= status;
+ * There seems to be some odd combination where the status is zero but
+ * an interrupt occurred. In that case, the task shouldn't wake up.
+ * Therefore check for status != 0.
+ if (status != 0 &&
+ ((status & SDMMC_STA_BUSYD0) == 0 ||
+ (sc->sdmmc->MASK & SDMMC_STA_BUSYD0END) == 0)) {
+ rtems_binary_semaphore_post(&sc->wait_done);
+static int
+st_sdmmc_probe(device_t dev)
+ device_set_desc(dev, "STM32H7xx SDMMC Host");
+ return (0);
+static int
+st_sdmmc_set_clock_and_bus(
+ struct st_sdmmc_softc *sc,
+ uint32_t freq,
+ enum mmc_bus_width width
+ uint32_t clk_div;
+ uint32_t clkcr;
+ clkcr = SDMMC_CLKCR_NEGEDGE | SDMMC_CLKCR_PWRSAV | SDMMC_CLKCR_HWFC_EN;
+ clk_div = howmany(sc->sdmmc_ker_ck, freq) / 2;
+ if (clk_div > SDMMC_CLKCR_CLKDIV >> SDMMC_CLKCR_CLKDIV_Pos) {
+ clk_div = SDMMC_CLKCR_CLKDIV >> SDMMC_CLKCR_CLKDIV_Pos;
+ clkcr |= clk_div << SDMMC_CLKCR_CLKDIV_Pos;
+ switch (width) {
+ default:
+ BSD_ASSERT(width == bus_width_1);
+ clkcr |= 0 << SDMMC_CLKCR_WIDBUS_Pos;
+ break;
+ case bus_width_4:
+ clkcr |= 1 << SDMMC_CLKCR_WIDBUS_Pos;
+ break;
+ case bus_width_8:
+ clkcr |= 2 << SDMMC_CLKCR_WIDBUS_Pos;
+ break;
+ sc->sdmmc->CLKCR = clkcr;
+ return 0;
+static void
+st_sdmmc_host_reset(struct st_sdmmc_softc *sc)
+ sc->sdmmc->MASK = 0;
+ sc->sdmmc->ICR = 0xFFFFFFFF;
+static void
+st_sdmmc_hw_init(struct st_sdmmc_softc *sc)
+ st_sdmmc_set_clock_and_bus(sc, 400000, bus_width_1);
+ sc->sdmmc->POWER = 0;
+ if (sc->cfg.dirpol) {
+ sc->sdmmc->POWER |= SDMMC_POWER_DIRPOL;
+ /* ST example code just set it on. So do the same. */
+ sc->sdmmc->POWER |= SDMMC_POWER_PWRCTRL_0 | SDMMC_POWER_PWRCTRL_1;
+ * Wait at least 74 cycles; lowest freq is 400kHz
+ * -> 1/400kHz * 47 = 117us
+ usleep(120000);
+ st_sdmmc_host_reset(sc);
+static void
+st_sdmmc_board_init(void)
+ HAL_SD_MspInit(NULL);
+static int
+st_sdmmc_attach(device_t dev)
+ int error = 0;
+ static pthread_once_t once = PTHREAD_ONCE_INIT;
+ bool interrupt_installed = false;
+ sc = device_get_softc(dev);
+ memset(sc, 0, sizeof(*sc));
+ if (error == 0) {
+ sc->dev = dev;
+ if (error == 0) {
+ ST_SDMMC_LOCK_INIT(sc);
+ rtems_binary_semaphore_init(&sc->wait_done, "sdmmc-sem");
+ if (error == 0) {
+ int rid = 0;
+ sc->res[RES_MEM_SDMMC] = bus_alloc_resource(dev, SYS_RES_MEMORY,
+ &rid, 0, ~0, 1, RF_ACTIVE);
+ if (sc->res[RES_MEM_SDMMC] == NULL) {
+ device_printf(dev,
+ "could not allocate sdmmc resource\n");
+ error = ENXIO;
+ } else {
+ sc->sdmmc = (SDMMC_TypeDef *)
+ sc->res[RES_MEM_SDMMC]->r_bushandle;
+ if (error == 0) {
+ int rid = 0;
+ sc->res[RES_MEM_DLYB] = bus_alloc_resource(dev, SYS_RES_MEMORY,
+ &rid, 1, ~0, 1, RF_ACTIVE);
+ if (sc->res[RES_MEM_DLYB] == NULL) {
+ "could not allocate dlyb resource\n");
+ error = ENXIO;
+ } else {
+ sc->dlyb = (DLYB_TypeDef *)
+ sc->res[RES_MEM_DLYB]->r_bushandle;
+ if (error == 0) {
+ int rid = 0;
+ sc->res[RES_IRQ_SDMMC] = bus_alloc_resource(dev, SYS_RES_IRQ,
+ if (sc->res[RES_IRQ_SDMMC] == NULL) {
+ "could not allocate interrupt resource\n");
+ error = ENXIO;
+ } else {
+ sc->irq = sc->res[RES_IRQ_SDMMC]->r_bushandle;
+ if (error == 0) {
+ * FIXME: This memory should be in AXI SRAM, QSPI or FMC. In the
+ * configurations for our BSP, the heap is either in AXI SRAM or
+ * in the SDRAM. So that is OK for now. Only assert that the
+ * assumption is true. A better solution (like fixed AXI SRAM)
+ * might would be a good idea.
+ sc->dmabuf = rtems_heap_allocate_aligned_with_boundary(
+ DMA_BUF_SIZE, CPU_CACHE_LINE_BYTES, 0);
+ if (sc->dmabuf == NULL) {
+ device_printf(dev, "could not allocate dma buffer\n");
+ error = ENOMEM;
+ BSD_ASSERT(
+ ((void*) sc->dmabuf >= (void*) stm32h7_memory_sram_axi_begin &&
+ (void*) sc->dmabuf < (void*) stm32h7_memory_sram_axi_end) ||
+ ((void*) sc->dmabuf >= (void*) stm32h7_memory_sdram_1_begin &&
+ (void*) sc->dmabuf < (void*) stm32h7_memory_sdram_1_end) ||
+ ((void*) sc->dmabuf >= (void*) stm32h7_memory_sdram_2_begin &&
+ (void*) sc->dmabuf < (void*) stm32h7_memory_sdram_2_end) ||
+ ((void*) sc->dmabuf >= (void*) stm32h7_memory_quadspi_begin &&
+ (void*) sc->dmabuf < (void*) stm32h7_memory_quadspi_end));
+ if (error == 0) {
+ pthread_once(&once, st_sdmmc_board_init);
+ if (error == 0) {
+ sc->sdmmc_ker_ck = HAL_RCCEx_GetPeriphCLKFreq(
+ RCC_PERIPHCLK_SDMMC);
+ sc->host.f_min = 400000;
+ sc->host.f_max = (int) sc->sdmmc_ker_ck;
+ if (sc->host.f_max > 50000000)
+ sc->host.f_max = 50000000;
+ if (error == 0) {
+ st_sdmmc_get_config((uintptr_t)sc->sdmmc, &sc->cfg);
+ if (sc->cfg.data_lines == 0) {
+ device_printf(dev, "config not found!\n");
+ error = EINVAL;
+ if (error == 0) {
+ st_sdmmc_hw_init(sc);
+ if (error == 0) {
+ error = rtems_interrupt_handler_install(sc->irq, "SDMMC",
+ RTEMS_INTERRUPT_UNIQUE, st_sdmmc_intr, sc);
+ if (error != 0) {
+ "could not setup interrupt handler.\n");
+ } else {
+ interrupt_installed = true;
+ if (error == 0) {
+ sc->host.host_ocr = sc->cfg.ocr_voltage &
+ ((1 << (MMC_OCR_MAX_VOLTAGE_SHIFT + 1)) - 1);
+ sc->host.caps = MMC_CAP_HSPEED;
+ if (sc->cfg.data_lines >= 4) {
+ sc->host.caps |= MMC_CAP_4_BIT_DATA;
+ if (sc->cfg.data_lines >= 8) {
+ sc->host.caps |= MMC_CAP_8_BIT_DATA;
+ if (error == 0) {
+ device_add_child(dev, "mmc", -1);
+ error = bus_generic_attach(dev);
+ if (error != 0) {
+ /* Undo relevant parts */
+ if (interrupt_installed) {
+ rtems_interrupt_handler_remove(sc->irq,
+ st_sdmmc_intr, sc);
+ free(sc->dmabuf);
+ * FIXME: Should free resources but RTEMS doesn't implement
+ * bus_free_resource().
+ return error;
+static int
+st_sdmmc_detach(device_t dev)
+ /* Always attached. So this is not necessary. */
+ BSD_ASSERT(0);
+ (void)sc;
+ return (EBUSY);
+static int
+st_sdmmc_update_ios(device_t brdev, device_t reqdev)
+ struct mmc_ios *ios;
+ int err;
+ sc = device_get_softc(brdev);
+ ST_SDMMC_LOCK(sc);
+ ios = &sc->host.ios;
+ err = st_sdmmc_set_clock_and_bus(sc, ios->clock, ios->bus_width);
+ if (err != 0) {
+ return (err);
+ if (ios->power_mode == power_off) {
+ * FIXME: Maybe a reset of the module is necessary instead. But
+ * the ST samples use a power off too so it should work. But
+ * power saving hasn't been tested during development.
+ sc->sdmmc->POWER &= ~(SDMMC_POWER_PWRCTRL);
+ } else {
+ sc->sdmmc->POWER |= SDMMC_POWER_PWRCTRL;
+ ST_SDMMC_UNLOCK(sc);
+ return (EIO);
+static int
+st_sdmmc_wait_irq(struct st_sdmmc_softc *sc)
+ int error = 0;
+ error = rtems_binary_semaphore_wait_timed_ticks(&sc->wait_done,
+ RTEMS_MILLISECONDS_TO_TICKS(5000));
+ if (error != 0) {
+ error = MMC_ERR_TIMEOUT;
+ } else if ((sc->intr_status &
+ (SDMMC_STA_DTIMEOUT | SDMMC_STA_CTIMEOUT)) != 0) {
+ } else if ((sc->intr_status & SDMMC_INT_ERROR_MASK) != 0) {
+ error = MMC_ERR_FAILED;
+ return error;
+static void
+st_sdmmc_cmd_do(struct st_sdmmc_softc *sc, struct mmc_command *cmd)
+ uint32_t cmdval;
+ uint32_t xferlen;
+ uint32_t int_mask;
+ uint32_t arg;
+ void *data = NULL;
+ bool short_xfer = false;
+ debug_print(sc, 1, "cmd: %d, arg: %08x, flags: 0x%x\n",
+ cmd->opcode, cmd->arg, cmd->flags);
+ xferlen = 0;
+ sc->intr_status = 0;
+ sc->sdmmc->CMD = 0;
+ * There should be a delay of "at least seven sdmmc_hclk clock periods"
+ * before CMD is written again. The sdmmc_hclk is the clock that is used
+ * to access the Registers. Some more registers are accessed before the
+ * next CMD write. So that should be no problem.
+ * Make sure the semaphore is cleared at this point. There can be an
+ * error case where a previous command run into a timeout and still
+ * produced an interrupt before it has been disabled.
+ if (rtems_binary_semaphore_try_wait(&sc->wait_done) == 0) {
+ device_printf(sc->dev, "Semaphore set from last command\n");
+ int_mask = SDMMC_INT_ERROR_MASK;
+ arg = cmd->arg;
+ cmdval = (cmd->opcode & SDMMC_CMD_CMDINDEX_Msk) | SDMMC_CMD_CPSMEN;
+ if ((cmd->flags & MMC_RSP_PRESENT) != 0) {
+ if ((cmd->flags & MMC_RSP_136) != 0) {
+ cmdval |= SDMMC_CMD_WAITRESP_0 | SDMMC_CMD_WAITRESP_1;
+ } else if ((cmd->flags & MMC_RSP_CRC) != 0) {
+ cmdval |= SDMMC_CMD_WAITRESP_0;
+ } else {
+ cmdval |= SDMMC_CMD_WAITRESP_1;
+ int_mask |= SDMMC_INT_CMD_RESPONSE_DONE_MASK;
+ } else {
+ int_mask |= SDMMC_INT_CMD_DONE_MASK;
+ if (cmd->opcode == MMC_STOP_TRANSMISSION) {
+ cmdval |= SDMMC_CMD_CMDSTOP;
+ if ((cmd->flags & MMC_CMD_MASK) == MMC_CMD_ADTC) {
+ cmdval |= SDMMC_CMD_CMDTRANS;
+ if ((cmd->flags & MMC_RSP_BUSY) != 0) {
+ int_mask |= SDMMC_MASK_BUSYD0ENDIE;
+ if (cmd->data != NULL) {
+ uint32_t blksize;
+ uint32_t dctrl = 0;
+ xferlen = cmd->data->len;
+ if (xferlen > MMC_SECTOR_SIZE) {
+ blksize = ffs(MMC_SECTOR_SIZE) - 1;
+ } else {
+ blksize = ffs(xferlen) - 1;
+ "data: len: %d, xferlen: %d, blksize: %d, dataflags: 0x%x\n",
+ cmd->data->len, xferlen, blksize, cmd->data->flags);
+ BSD_ASSERT(xferlen % (1 << blksize) == 0);
+ if (xferlen < CPU_CACHE_LINE_BYTES) {
+ if ((cmd->data->flags & MMC_DATA_READ) == 0) {
+ memcpy(sc->dmabuf, cmd->data->data, xferlen);
+ data = sc->dmabuf;
+ short_xfer = true;
+ } else {
+ data = cmd->data->data;
+ dctrl |= blksize << SDMMC_DCTRL_DBLOCKSIZE_Pos;
+ if ((cmd->data->flags & MMC_DATA_READ) != 0) {
+ dctrl |= SDMMC_DCTRL_DTDIR;
+ rtems_cache_invalidate_multiple_data_lines(data,
+ roundup2(xferlen, CPU_CACHE_LINE_BYTES));
+ } else {
+ rtems_cache_flush_multiple_data_lines(data,
+ st_sdmmc_idma_txrx(sc, data);
+ sc->sdmmc->DTIMER = 0xFFFFFFFF;
+ sc->sdmmc->DLEN = xferlen;
+ sc->sdmmc->DCTRL = dctrl;
+ int_mask &= ~(SDMMC_INT_CMD_DONE_MASK |
+ SDMMC_INT_CMD_RESPONSE_DONE_MASK);
+ int_mask |= SDMMC_INT_DATA_DONE_MASK;
+ sc->sdmmc->MASK = int_mask;
+ sc->sdmmc->ARG = arg;
+ sc->sdmmc->CMD = cmdval | cmd->opcode;
+ cmd->error = st_sdmmc_wait_irq(sc);
+ if (cmd->error) {
+ sleep(10);
+ "error (%d) waiting for xfer: status %08x, cmd: %d, flags: %08x\n",
+ cmd->error, sc->intr_status, cmd->opcode, cmd->flags);
+ } else {
+ cmd->resp[0] = sc->sdmmc->RESP1;
+ cmd->resp[1] = sc->sdmmc->RESP2;
+ cmd->resp[2] = sc->sdmmc->RESP3;
+ cmd->resp[3] = sc->sdmmc->RESP4;
+ debug_print(sc, 2, "rsp: %08x %08x %08x %08x\n",
+ cmd->resp[0],
+ cmd->resp[1],
+ cmd->resp[2],
+ cmd->resp[3]);
+ } else {
+ debug_print(sc, 2, "rsp: %08x\n", cmd->resp[0]);
+ if (short_xfer && cmd->data != NULL &&
+ (cmd->data->flags & MMC_DATA_READ) != 0) {
+ memcpy(cmd->data->data, sc->dmabuf, xferlen);
+ st_sdmmc_idma_stop(sc);
+static int
+st_sdmmc_request(device_t brdev, device_t reqdev, struct mmc_request *req)
+ st_sdmmc_cmd_do(sc, req->cmd);
+ if (req->stop != NULL) {
+ st_sdmmc_cmd_do(sc, req->stop);
+ (*req->done)(req);
+ return (0);
+static int
+st_sdmmc_get_ro(device_t brdev, device_t reqdev)
+ * FIXME: Currently just ignore write protection. Micro-SD doesn't have
+ * it anyway and most boards are now using Micro-SD slots.
+ return (0);
+static int
+st_sdmmc_acquire_host(device_t brdev, device_t reqdev)
+ while (sc->bus_busy)
+ msleep(sc, &sc->mtx, PZERO, "stsdmmcah", hz / 5);
+ sc->bus_busy++;
+ return (0);
+static int
+st_sdmmc_release_host(device_t brdev, device_t reqdev)
+ sc->bus_busy--;
+ wakeup(sc);
+ return (0);
+static int
+st_sdmmc_read_ivar(device_t bus, device_t child, int which, uintptr_t *result)
+ sc = device_get_softc(bus);
+ switch (which) {
+ default:
+ return (EINVAL);
+ case MMCBR_IVAR_BUS_MODE:
+ *(int *)result = sc->host.ios.bus_mode;
+ break;
+ case MMCBR_IVAR_BUS_WIDTH:
+ *(int *)result = sc->host.ios.bus_width;
+ break;
+ case MMCBR_IVAR_CHIP_SELECT:
+ *(int *)result = sc->host.ios.chip_select;
+ break;
+ case MMCBR_IVAR_CLOCK:
+ *(int *)result = sc->host.ios.clock;
+ break;
+ case MMCBR_IVAR_F_MIN:
+ *(int *)result = sc->host.f_min;
+ break;
+ case MMCBR_IVAR_F_MAX:
+ *(int *)result = sc->host.f_max;
+ break;
+ case MMCBR_IVAR_HOST_OCR:
+ *(int *)result = sc->host.host_ocr;
+ break;
+ case MMCBR_IVAR_MODE:
+ *(int *)result = sc->host.mode;
+ break;
+ case MMCBR_IVAR_OCR:
+ *(int *)result = sc->host.ocr;
+ break;
+ case MMCBR_IVAR_POWER_MODE:
+ *(int *)result = sc->host.ios.power_mode;
+ break;
+ case MMCBR_IVAR_VDD:
+ *(int *)result = sc->host.ios.vdd;
+ break;
+ case MMCBR_IVAR_VCCQ:
+ *(int *)result = sc->host.ios.vccq;
+ break;
+ case MMCBR_IVAR_CAPS:
+ *(int *)result = sc->host.caps;
+ break;
+ case MMCBR_IVAR_MAX_DATA:
+ * Note: At the moment of writing this, RTEMS ignores this
+ * value. So it's quite irrelevant what is returned here.
+ *(int *)result = (SDMMC_DLEN_DATALENGTH_Msk) / MMC_SECTOR_SIZE;
+ break;
+ case MMCBR_IVAR_TIMING:
+ *(int *)result = sc->host.ios.timing;
+ break;
+ return (0);
+static int
+st_sdmmc_write_ivar(device_t bus, device_t child, int which, uintptr_t value)
+ switch (which) {
+ default:
+ return (EINVAL);
+ sc->host.ios.bus_mode = value;
+ break;
+ sc->host.ios.bus_width = value;
+ break;
+ sc->host.ios.chip_select = value;
+ break;
+ sc->host.ios.clock = value;
+ break;
+ sc->host.mode = value;
+ break;
+ sc->host.ocr = value;
+ break;
+ sc->host.ios.power_mode = value;
+ break;
+ sc->host.ios.vdd = value;
+ break;
+ sc->host.ios.timing = value;
+ break;
+ sc->host.ios.vccq = value;
+ break;
+ /* These are read-only */
+ return (EINVAL);
+ return (0);
+static device_method_t st_sdmmc_methods[] = {
+ /* device_if */
+ DEVMETHOD(device_probe, st_sdmmc_probe),
+ DEVMETHOD(device_attach, st_sdmmc_attach),
+ DEVMETHOD(device_detach, st_sdmmc_detach),
+ /* Bus interface */
+ DEVMETHOD(bus_read_ivar, st_sdmmc_read_ivar),
+ DEVMETHOD(bus_write_ivar, st_sdmmc_write_ivar),
+ /* mmcbr_if */
+ DEVMETHOD(mmcbr_update_ios, st_sdmmc_update_ios),
+ DEVMETHOD(mmcbr_request, st_sdmmc_request),
+ DEVMETHOD(mmcbr_get_ro, st_sdmmc_get_ro),
+ DEVMETHOD(mmcbr_acquire_host, st_sdmmc_acquire_host),
+ DEVMETHOD(mmcbr_release_host, st_sdmmc_release_host),
+ DEVMETHOD_END
+static driver_t st_sdmmc_driver = {
+ "st_sdmmc",
+ st_sdmmc_methods,
+ sizeof(struct st_sdmmc_softc)
+static devclass_t st_sdmmc_devclass;
+DRIVER_MODULE(st_sdmmc, nexus, st_sdmmc_driver, st_sdmmc_devclass, NULL, NULL);
+DRIVER_MODULE(mmc, st_sdmmc, mmc_driver, mmc_devclass, NULL, NULL);
+MODULE_DEPEND(st_sdmmc, mmc, 1, 1, 1);
2.26.2
