[PATCH rtems-docs v3 1/6] prefixes: Update installation prefix
Gedare Bloom
gedare at rtems.org
Thu Mar 25 14:43:12 UTC 2021
I'm pushing this patch set. Eventually we'll want to figure out how to
deal with this.
On Tue, Mar 23, 2021 at 9:39 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Mar 23, 2021 at 9:28 AM Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Mar 23, 2021 at 10:16 AM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Mon, Mar 22, 2021 at 3:12 PM Chris Johns <chrisj at rtems.org> wrote:
> >> > On 23/3/21 4:41 am, Gedare Bloom wrote:> I wonder what is your opinion, should
> >> > we bump these tutorials with
> >> > > every version? And, is the find/replace of the commands the best way
> >> > > to do this?
> >> > > I feel like this topic comes up now and again. Maintaining these
> >> > > examples is a little fragile.
> >> > It is fragile and I have in the past invested some time looking for a way to
> >> > automatically manage these version based blocks of documentation however subtle
> >> > change happen so making it automatic is difficult. Arguments to commands change
> >> > and if there is captured output it needs to change.
> >> > > @Ida: Thanks for the patches,
> >> > Yes, thank you. The patches are great.
> >> > > now we'll need to determine if we want
> >> > > to bump these examples like this, and whether we should consider a
> >> > > better way to maintain this stuff in the future.
> >> > I am open to solutions. A few ideas are:
> >> > 1. Group commands we consider as stable interfaces and see if the RTEMS version
> >> > can be supplied via a conf variable passed in by waf. This would lower the
> >> > number of changes.
> >> > 2. Tag version specific blocks with something in a comment. Making a change is
> >> > part of the solution however I find knowing there is a change to make is harder.
> >> > If we can grep the sources we could see. For example:
> >> I like tagging.
> >> > .. rtems-version-block: 5
> > Texinfo had variables. Looking at Sphinx docs, I see this:
> > https://www.sphinx-doc.org/en/master/usage/restructuredtext/basics.html#substitutions
> > Does that work? Could we have
> > .. |rtems-version| replace:: 6
> > This should work in text without doing any magic. It looks like example
> > and code blocks may need a special block for this to work. I think this
> > page has a solution to that
> > https://stackoverflow.com/questions/42158111/variable-substitution-not-working-properly-in-sphinx
> > This won't help when command line arguments change and things like the
> > transition from the sis to erc32 BSP will still need work.
> It also doesn't address that example output changes with each version.
> That's the bigger problem here.
> >> > The version number is updated when changed so we can see what needs to be done.
> >> > This would be helpful when making releases.
> >> > 3. Other ideas ...
> >> A script/tutorial to regenerate these parts could work also. Kind of a
> >> guide how to update for a new version, and what needs to be
> >> run/captured as output examples.
> >> > Chris
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
