[PATCH v6 1/2] covoar: Fix NOP execution marking
Alex White
alex.white at oarcorp.com
Thu Mar 25 23:28:39 UTC 2021
On Thu, Mar 25, 2021 at 6:10 PM Chris Johns <chrisj at rtems.org> wrote:
> On 26/3/21 8:49 am, Alex White wrote:
> > Some NOP instructions were not being marked as executed because they
> > are located at the end of uncovered ranges. This has been fixed.
> > tester/covoar/CoverageMapBase.cc | 10 +++
> > tester/covoar/CoverageMapBase.h | 4 ++
> > tester/covoar/DesiredSymbols.cc | 38 +++++++++--
> > tester/covoar/DesiredSymbols.h | 11 +++-
> > tester/covoar/ExecutableInfo.cc | 2 +-
> > tester/covoar/ExecutableInfo.h | 4 ++
> > tester/covoar/ObjdumpProcessor.cc | 105 ++++++++++++++++++++++--------
> > 7 files changed, 138 insertions(+), 36 deletions(-)
> > diff --git a/tester/covoar/CoverageMapBase.cc b/tester/covoar/CoverageMapBase.cc
> > index ad0080d..6ca5cf7 100644
> > --- a/tester/covoar/CoverageMapBase.cc
> > +++ b/tester/covoar/CoverageMapBase.cc
> > @@ -142,6 +142,11 @@ namespace Coverage {
> > return size;
> > + uint32_t CoverageMapBase::getSizeOfRange( size_t index ) const
> > + return Ranges.at(index).size();
> > bool CoverageMapBase::getBeginningOfInstruction(
> > uint32_t address,
> > uint32_t* beginning
> > @@ -178,6 +183,11 @@ namespace Coverage {
> > return Ranges.front().lowAddress;
> > + uint32_t CoverageMapBase::getLowAddressOfRange( size_t index ) const
> > + return Ranges.at(index).lowAddress;
> > bool CoverageMapBase::getRange( uint32_t address, AddressRange& range ) const
> > for ( auto r : Ranges ) {
> > diff --git a/tester/covoar/CoverageMapBase.h b/tester/covoar/CoverageMapBase.h
> > index 6ad76d3..a58c696 100644
> > --- a/tester/covoar/CoverageMapBase.h
> > +++ b/tester/covoar/CoverageMapBase.h
> > @@ -156,6 +156,8 @@ namespace Coverage {
> > int32_t getFirstLowAddress() const;
> > + uint32_t getLowAddressOfRange( size_t index ) const;
> > * This method returns true and sets the address range if
> > * the address falls with the bounds of an address range
> > @@ -177,6 +179,8 @@ namespace Coverage {
> > uint32_t getSize() const;
> > + uint32_t getSizeOfRange( size_t index ) const;
> > * This method returns the address of the beginning of the
> > * instruction that contains the specified address.
> > diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
> > index b9a5bb7..c97b25c 100644
> > --- a/tester/covoar/DesiredSymbols.cc
> > +++ b/tester/covoar/DesiredSymbols.cc
> > @@ -142,7 +142,7 @@ namespace Coverage {
> > CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
> > if (theCoverageMap)
> > - // Increment the total sizeInBytes byt the bytes in the symbol
> > + // Increment the total sizeInBytes by the bytes in the symbol
> > stats.sizeInBytes += s.second.stats.sizeInBytes;
> > // Now scan through the coverage map of this symbol.
> > @@ -202,6 +202,26 @@ namespace Coverage {
> > uint32_t count;
> > // Mark NOPs as executed
> > + a = s.second.stats.sizeInBytes - 1;
> > + count = 0;
> > + while (a > 0) {
> > + if (theCoverageMap->isStartOfInstruction( a )) {
> > + break;
> > + count++;
> > + if (theCoverageMap->isNop( a )) {
> > + for (la = a; la < (a + count); la++) {
> > + theCoverageMap->setWasExecuted( la );
> > + count = 0;
> > + a--;
> > endAddress = s.second.stats.sizeInBytes - 1;
> > a = 0;
> > while (a < endAddress) {
> > @@ -223,12 +243,13 @@ namespace Coverage {
> > ha++;
> > if ( ha >= endAddress )
> > break;
> > - } while ( !theCoverageMap->isStartOfInstruction( ha ) );
> > + } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
> > + theCoverageMap->isNop( ha ) );
> > a = ha;
> > - endAddress = s.second.stats.sizeInBytes - 1;
> > + endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
> > a = 0;
> > while (a <= endAddress) {
> > // If an address was NOT executed, find consecutive unexecuted
> > @@ -316,7 +337,8 @@ namespace Coverage {
> > void DesiredSymbols::createCoverageMap(
> > const std::string& exefileName,
> > const std::string& symbolName,
> > - uint32_t size
> > + uint32_t size,
> > + uint32_t sizeWithoutNops
> > CoverageMapBase* aCoverageMap;
> > @@ -354,9 +376,10 @@ namespace Coverage {
> > << '/' << size << ')'
> > << std::endl;
> > - if ( itr->second.stats.sizeInBytes < size )
> > + if ( itr->second.stats.sizeInBytes < size ) {
> > itr->second.stats.sizeInBytes = size;
> > - else
> > + itr->second.stats.sizeInBytesWithoutNops = sizeWithoutNops;
> > + } else
> > size = itr->second.stats.sizeInBytes;
> > @@ -376,6 +399,7 @@ namespace Coverage {
> > itr->second.unifiedCoverageMap = aCoverageMap;
> > @@ -479,7 +503,7 @@ namespace Coverage {
> > // are the same size.
> > // Changed from ERROR msg to INFO, because size mismatch is not
> > // treated as error anymore. 2015-07-20
> > - uint32_t dMapSize = sinfo.stats.sizeInBytes;
> > + uint32_t dMapSize = sinfo.stats.sizeInBytesWithoutNops;
> > uint32_t sBaseAddress = sourceCoverageMap->getFirstLowAddress();
> > uint32_t sMapSize = sourceCoverageMap->getSize();
> > if (dMapSize != 0 && dMapSize != sMapSize) {
> > diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
> > index 5c45af8..367ca95 100644
> > --- a/tester/covoar/DesiredSymbols.h
> > +++ b/tester/covoar/DesiredSymbols.h
> > @@ -57,7 +57,12 @@ namespace Coverage {
> > uint32_t sizeInBytes;
> > - * This member contains the size in Bytes.
> > + * This member contains the size in Bytes not accounting for NOPs.
> > + uint32_t sizeInBytesWithoutNops;
> > + * This member contains the size in instructions.
> > uint32_t sizeInInstructions;
> > @@ -100,6 +105,7 @@ namespace Coverage {
> > branchesNeverTaken(0),
> > branchesNotExecuted(0),
> > sizeInBytes(0),
> > + sizeInBytesWithoutNops(0),
> > sizeInInstructions(0),
> > uncoveredBytes(0),
> > uncoveredInstructions(0),
> > @@ -227,7 +233,8 @@ namespace Coverage {
> > void createCoverageMap(
> > - uint32_t size
> > + uint32_t size,
> > diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
> > index c593e1d..ddd2987 100644
> > --- a/tester/covoar/ExecutableInfo.cc
> > +++ b/tester/covoar/ExecutableInfo.cc
> > @@ -127,7 +127,7 @@ namespace Coverage {
> > CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
> > if ( cmi == coverageMaps.end() )
> > - throw rld::error (symbolName, "ExecutableInfo::findCoverageMap");
> > + throw CoverageMapNotFoundError(symbolName);
> > return *(cmi->second);
> > diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
> > index dcb4dcb..ab74b7f 100644
> > --- a/tester/covoar/ExecutableInfo.h
> > +++ b/tester/covoar/ExecutableInfo.h
> > @@ -29,6 +29,10 @@ namespace Coverage {
> > public:
> > + class CoverageMapNotFoundError : public std::runtime_error {
> > + using std::runtime_error::runtime_error;
> Ok sorry for raising C++ things (again) ....
> Why is `using` being used here?
> I do not use `using` anywhere execpt come special `chrono` related codes. I do
> not know `std::runtime_error::runtime_error` enough to know where it is being
> used in the code below. If those places had the full namespace I would.
This usage of `using` was introduced in C++11. It makes the constructors in std::runtime_error::runtime_error visible to overload resolution when initializing CoverageMapNotFoundError.
It's just a shortcut so that the constructors don't have to be redefined. It refers to the constructor `std::runtime_error::runtime_error`.
Alex
> Chris
> > * This method constructs an ExecutableInfo instance.
> > diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
> > index 56ee219..05a50f1 100644
> > --- a/tester/covoar/ObjdumpProcessor.cc
> > +++ b/tester/covoar/ObjdumpProcessor.cc
> > @@ -32,35 +32,88 @@ namespace Coverage {
> > ObjdumpProcessor::objdumpLines_t instructions
> > // Find the symbol's coverage map.
> > - CoverageMapBase& coverageMap = executableInfo->findCoverageMap( symbolName );
> > - uint32_t lowAddress = coverageMap.getFirstLowAddress();
> > - uint32_t size = coverageMap.getSize();
> > - uint32_t highAddress = lowAddress + size - 1;
> > - // If there are NOT already saved instructions, save them.
> > - SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
> > - if (symbolInfo->instructions.empty()) {
> > - symbolInfo->sourceFile = executableInfo;
> > - symbolInfo->baseAddress = lowAddress;
> > - symbolInfo->instructions = instructions;
> > + try {
> > + CoverageMapBase& coverageMap = executableInfo->findCoverageMap(symbolName);
> > - // Add the symbol to this executable's symbol table.
> > - SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
> > - theSymbolTable->addSymbol(
> > - symbolName, lowAddress, highAddress - lowAddress + 1
> > + uint32_t firstInstructionAddress = UINT32_MAX;
> > - // Mark the start of each instruction in the coverage map.
> > - for (auto& instruction : instructions) {
> > - coverageMap.setIsStartOfInstruction( instruction.address );
> > + // Find the address of the first instruction.
> > + for (auto& line : instructions) {
> > + if (line.isInstruction) {
> > + firstInstructionAddress = line.address;
> > + break;
> > + if (firstInstructionAddress == UINT32_MAX) {
> > + std::ostringstream what;
> > + what << "Could not find first instruction address for symbol "
> > + << symbolName << " in " << executableInfo->getFileName();
> > + throw rld::error( what, "Coverage::finalizeSymbol" );
> > + int rangeIndex;
> > + uint32_t lowAddress = UINT32_MAX;
> > + for (rangeIndex = 0;
> > + firstInstructionAddress != lowAddress;
> > + rangeIndex++) {
> > + lowAddress = coverageMap.getLowAddressOfRange(rangeIndex);
> > + uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex);
> > + uint32_t size = sizeWithoutNops;
> > + uint32_t highAddress = lowAddress + size - 1;
> > + uint32_t computedHighAddress = highAddress;
> > + // Find the high address as reported by the address of the last NOP
> > + // instruction. This ensures that NOPs get marked as executed later.
> > + for (auto instruction = instructions.rbegin();
> > + instruction != instructions.rend();
> > + instruction++) {
> > + if (instruction->isInstruction) {
> > + if (instruction->isNop) {
> > + computedHighAddress = instruction->address + instruction->nopSize;
> > + break;
> > + if (highAddress != computedHighAddress) {
> > + std::cerr << "Function's high address differs between DWARF and objdump: "
> > + << symbolName << " (0x" << std::hex << highAddress << " and 0x"
> > + << computedHighAddress - 1 << ")" << std::dec << std::endl;
> > + size = computedHighAddress - lowAddress;
> > - // Create a unified coverage map for the symbol.
> > - SymbolsToAnalyze->createCoverageMap(
> > - executableInfo->getFileName().c_str(), symbolName, size
> > + // If there are NOT already saved instructions, save them.
> > + SymbolInformation* symbolInfo = SymbolsToAnalyze->find( symbolName );
> > + if (symbolInfo->instructions.empty()) {
> > + symbolInfo->sourceFile = executableInfo;
> > + symbolInfo->baseAddress = lowAddress;
> > + symbolInfo->instructions = instructions;
> > + // Add the symbol to this executable's symbol table.
> > + SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
> > + theSymbolTable->addSymbol(
> > + symbolName, lowAddress, highAddress - lowAddress + 1
> > + // Mark the start of each instruction in the coverage map.
> > + for (auto& instruction : instructions) {
> > + coverageMap.setIsStartOfInstruction( instruction.address );
> > + // Create a unified coverage map for the symbol.
> > + SymbolsToAnalyze->createCoverageMap(
> > + executableInfo->getFileName().c_str(), symbolName, size, sizeWithoutNops
> > + } catch (const ExecutableInfo::CoverageMapNotFoundError& e) {
> > + // Allow execution to continue even if a coverage map could not be
> > + // found.
> > + std::cerr << "Coverage map not found for symbol " << e.what()
> > + << std::endl;
> > ObjdumpProcessor::ObjdumpProcessor()
> devel mailing list
> devel at rtems.org
