[PATCH v6 1/2] covoar: Fix NOP execution marking
Fri Mar 26 02:24:57 UTC 2021
On 26/3/21 10:28 am, Alex White wrote:
> On Thu, Mar 25, 2021 at 6:10 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 26/3/21 8:49 am, Alex White wrote:
>>> Some NOP instructions were not being marked as executed because they
>>> are located at the end of uncovered ranges. This has been fixed.
>>>  tester/covoar/CoverageMapBase.cc  |  10 +++
>>>  tester/covoar/CoverageMapBase.h   |   4 ++
>>>  tester/covoar/DesiredSymbols.cc   |  38 +++++++++--
>>>  tester/covoar/DesiredSymbols.h    |  11 +++-
>>>  tester/covoar/ExecutableInfo.cc   |   2 +-
>>>  tester/covoar/ExecutableInfo.h    |   4 ++
>>>  tester/covoar/ObjdumpProcessor.cc | 105 ++++++++++++++++++++++--------
>>>  7 files changed, 138 insertions(+), 36 deletions(-)
>>> diff --git a/tester/covoar/CoverageMapBase.cc b/tester/covoar/CoverageMapBase.cc
>>> index ad0080d..6ca5cf7 100644
>>> --- a/tester/covoar/CoverageMapBase.cc
>>> +++ b/tester/covoar/CoverageMapBase.cc
>>> @@ -142,6 +142,11 @@ namespace Coverage {
>>>      return size;
>>> +  uint32_t CoverageMapBase::getSizeOfRange( size_t index ) const
>>> +    return Ranges.at(index).size();
>>>    bool CoverageMapBase::getBeginningOfInstruction(
>>>      uint32_t  address,
>>>      uint32_t* beginning
>>> @@ -178,6 +183,11 @@ namespace Coverage {
>>>      return Ranges.front().lowAddress;
>>> +  uint32_t CoverageMapBase::getLowAddressOfRange( size_t index ) const
>>> +    return Ranges.at(index).lowAddress;
>>>    bool CoverageMapBase::getRange( uint32_t address, AddressRange& range ) const
>>>      for ( auto r : Ranges ) {
>>> diff --git a/tester/covoar/CoverageMapBase.h b/tester/covoar/CoverageMapBase.h
>>> index 6ad76d3..a58c696 100644
>>> --- a/tester/covoar/CoverageMapBase.h
>>> +++ b/tester/covoar/CoverageMapBase.h
>>> @@ -156,6 +156,8 @@ namespace Coverage {
>>>      int32_t getFirstLowAddress() const;
>>> +    uint32_t getLowAddressOfRange( size_t index ) const;
>>>       *  This method returns true and sets the address range if
>>>       *  the address falls with the bounds of an address range
>>> @@ -177,6 +179,8 @@ namespace Coverage {
>>>      uint32_t getSize() const;
>>> +    uint32_t getSizeOfRange( size_t index ) const;
>>>       *  This method returns the address of the beginning of the
>>>       *  instruction that contains the specified address.
>>> diff --git a/tester/covoar/DesiredSymbols.cc b/tester/covoar/DesiredSymbols.cc
>>> index b9a5bb7..c97b25c 100644
>>> --- a/tester/covoar/DesiredSymbols.cc
>>> +++ b/tester/covoar/DesiredSymbols.cc
>>> @@ -142,7 +142,7 @@ namespace Coverage {
>>>        CoverageMapBase* theCoverageMap = s.second.unifiedCoverageMap;
>>>        if (theCoverageMap)
>>> -        // Increment the total sizeInBytes byt the bytes in the symbol
>>> +        // Increment the total sizeInBytes by the bytes in the symbol
>>>          stats.sizeInBytes += s.second.stats.sizeInBytes;
>>>          // Now scan through the coverage map of this symbol.
>>> @@ -202,6 +202,26 @@ namespace Coverage {
>>>          uint32_t count;
>>>          // Mark NOPs as executed
>>> +        a = s.second.stats.sizeInBytes - 1;
>>> +        count = 0;
>>> +        while (a > 0) {
>>> +          if (theCoverageMap->isStartOfInstruction( a )) {
>>> +            break;
>>> +          count++;
>>> +          if (theCoverageMap->isNop( a )) {
>>> +            for (la = a; la < (a + count); la++) {
>>> +              theCoverageMap->setWasExecuted( la );
>>> +            count = 0;
>>> +          a--;
>>>          endAddress = s.second.stats.sizeInBytes - 1;
>>>          a = 0;
>>>          while (a < endAddress) {
>>> @@ -223,12 +243,13 @@ namespace Coverage {
>>>                ha++;
>>>                if ( ha >= endAddress )
>>>                  break;
>>> -            } while ( !theCoverageMap->isStartOfInstruction( ha ) );
>>> +            } while ( !theCoverageMap->isStartOfInstruction( ha ) ||
>>> +                      theCoverageMap->isNop( ha ) );
>>>            a = ha;
>>> -        endAddress = s.second.stats.sizeInBytes - 1;
>>> +        endAddress = s.second.stats.sizeInBytesWithoutNops - 1;
>>>          a = 0;
>>>          while (a <= endAddress) {
>>>            // If an address was NOT executed, find consecutive unexecuted
>>> @@ -316,7 +337,8 @@ namespace Coverage {
>>>    void DesiredSymbols::createCoverageMap(
>>>      const std::string& exefileName,
>>>      const std::string& symbolName,
>>> -    uint32_t           size
>>> +    uint32_t           size,
>>> +    uint32_t           sizeWithoutNops
>>>      CoverageMapBase* aCoverageMap;
>>> @@ -354,9 +376,10 @@ namespace Coverage {
>>>                    << '/' << size << ')'
>>>                    << std::endl;
>>> -        if ( itr->second.stats.sizeInBytes < size )
>>> +        if ( itr->second.stats.sizeInBytes < size ) {
>>>            itr->second.stats.sizeInBytes = size;
>>> -        else
>>> +          itr->second.stats.sizeInBytesWithoutNops = sizeWithoutNops;
>>> +        } else
>>>            size = itr->second.stats.sizeInBytes;
>>> @@ -376,6 +399,7 @@ namespace Coverage {
>>>        itr->second.unifiedCoverageMap = aCoverageMap;
>>> @@ -479,7 +503,7 @@ namespace Coverage {
>>>      // are the same size.
>>>      // Changed from ERROR msg to INFO, because size mismatch is not
>>>      // treated as error anymore. 2015-07-20
>>> -    uint32_t dMapSize = sinfo.stats.sizeInBytes;
>>> +    uint32_t dMapSize = sinfo.stats.sizeInBytesWithoutNops;
>>>      uint32_t sBaseAddress = sourceCoverageMap->getFirstLowAddress();
>>>      uint32_t sMapSize = sourceCoverageMap->getSize();
>>>      if (dMapSize != 0 && dMapSize != sMapSize) {
>>> diff --git a/tester/covoar/DesiredSymbols.h b/tester/covoar/DesiredSymbols.h
>>> index 5c45af8..367ca95 100644
>>> --- a/tester/covoar/DesiredSymbols.h
>>> +++ b/tester/covoar/DesiredSymbols.h
>>> @@ -57,7 +57,12 @@ namespace Coverage {
>>>      uint32_t sizeInBytes;
>>> -     *  This member contains the size in Bytes.
>>> +     *  This member contains the size in Bytes not accounting for NOPs.
>>> +    uint32_t sizeInBytesWithoutNops;
>>> +     *  This member contains the size in instructions.
>>>      uint32_t sizeInInstructions;
>>> @@ -100,6 +105,7 @@ namespace Coverage {
>>>         branchesNeverTaken(0),
>>>         branchesNotExecuted(0),
>>>         sizeInBytes(0),
>>> +       sizeInBytesWithoutNops(0),
>>>         sizeInInstructions(0),
>>>         uncoveredBytes(0),
>>>         uncoveredInstructions(0),
>>> @@ -227,7 +233,8 @@ namespace Coverage {
>>>      void createCoverageMap(
>>> -      uint32_t           size
>>> +      uint32_t           size,
>>> diff --git a/tester/covoar/ExecutableInfo.cc b/tester/covoar/ExecutableInfo.cc
>>> index c593e1d..ddd2987 100644
>>> --- a/tester/covoar/ExecutableInfo.cc
>>> +++ b/tester/covoar/ExecutableInfo.cc
>>> @@ -127,7 +127,7 @@ namespace Coverage {
>>>      CoverageMaps::iterator cmi = coverageMaps.find( symbolName );
>>>      if ( cmi == coverageMaps.end() )
>>> -      throw rld::error (symbolName, "ExecutableInfo::findCoverageMap");
>>> +      throw CoverageMapNotFoundError(symbolName);
>>>      return *(cmi->second);
>>> diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
>>> index dcb4dcb..ab74b7f 100644
>>> --- a/tester/covoar/ExecutableInfo.h
>>> +++ b/tester/covoar/ExecutableInfo.h
>>> @@ -29,6 +29,10 @@ namespace Coverage {
>>>    public:
>>> +    class CoverageMapNotFoundError : public std::runtime_error {
>>> +      using std::runtime_error::runtime_error;
>> Ok sorry for raising C++ things (again) ....
>> Why is `using` being used here?
>> I do not use `using` anywhere execpt come special `chrono` related codes. I do
>> not know `std::runtime_error::runtime_error` enough to know where it is being
>> used in the code below. If those places had the full namespace I would.
> This usage of `using` was introduced in C++11. It makes the constructors in std::runtime_error::runtime_error visible to overload resolution when initializing CoverageMapNotFoundError.
> It's just a shortcut so that the constructors don't have to be redefined. It refers to the constructor `std::runtime_error::runtime_error`.
Thanks for the explaination. Can I suggest a comment to this effect. ie Use the
defined constructors?
