GSoC Project - Beagle BSP Projects
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Mar 26 14:46:57 UTC 2021
Hello Ahamed,
Am 26.03.21 um 15:31 schrieb Ahamed Husni:
>     USB OTG would be a nice area. But that will be less writing a driver
>     for
>     Beagle but more finding out how that works with libbsd and finding a
>     good way to configure it. I once put a few hours into it didn't take
>     too
>     much time till a PC detected an USB device (see
>     https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce
>     <https://gitlab.com/c-mauderer/rtems-libbsd/-/tree/20170707-cdce>).
>     Basically it's about importing the "usb_template" stuff and finding a
>     way to configure it in libbsd.
>     I think that topic would have to be a bit of an open one: You might
>     work
>     only a day on it and have a working CDC Ethernet afterwards or you can
>     need weeks for that. So you should add an open list of possible
>     advanced
>     targets. An OTG device can be:
>     - Ethernet
>     - Serial port
>     - Mass storage
>     - Keyboard / Mouse
>     - Modem
>     - Audio
>     The simplest one will most likely be Ethernet followed by serial
>     port. I
>     would add some of the others (like mass storage) as an extended targets.
>     Best regards
>     Christian
> USB OTG would allow more extended capabilities for the beagle board.
> To work on the USB OTG devices, what would be the best way?
> What I understood from what Christian says is,
>  1. Finding out how USB OTG works with libbsd and finding a
>       way to configure it for the beagle.
>  2. Work on CDC Ethernet
>  3. CDC Ethernet - Example application & Documentation
>  4. Work on Serial over USB
>  5. Serial over USB - Example application & Documentation
> Am I right?
Most likely we would have to put some further open points at the end of
that because like I said: Depending on how well it works you might need
anything between a day and three weeks to get CDC Ethernet running. From
my first guess, it's maybe a week.
Note that I would expect that you will need a debugger and the RTEMS
event recording for this kind of project.
CDC Serial should be only a small step as soon as CDC Ethernet is running.
Mass storage depends on the current implementation for that in FreeBSD.
It might could be an interesting part.
> Would implementing Ethernet and Serial solve the problem of using TTL
> converters
> when working on RTEMS in Beagle for the developers?
Depends on the application. For those who want to write an application,
a CDC Serial device would be a nice alternative. For those who want to
develop drivers or RTEMS itself: Very unlikely that CDC Serial is enough
for that.
>     Yes, this seems like an area that can be chipped away at, with a
>     strong plan of activities. My concern would be whether it is about
>     writing code or not?
> After completing the above milestones, if we have more time I can start
> to work on
> the Mass storage support.
I would suggest to put _more_ into the proposal and make it clear that
the later points depend on whether there is enough time or not.
@Gedare: The time and effort for that project is really hard to estimate
in my point of view. Do you have an idea how we could handle that?
>     Hi,
>     Regarding the PRU.
>     I was able to load code to the PRU.
>     However I wasn't able to map IRQ interrupts to the PRU, thus unable
>     to communicate with it in a meaningful way.
>     Also I don't think that this project should be continued without a
>     full DEBUGGING Setup.
>     Best,
>     Nils
>     +1, without a proper debugging setup I found it hard to precisely
>     pin point the problem when I initially took up this task.
> What is the full DEBUGGING setup needed to work on the PRU?
I expect a JTAG-Debugger. I had good experience with the Segger J-Link
EDU for GSoC projects with BBB. Alternatively there are OpenOCD based
ones out there too that are said do work well. Note that you have to
solder a debug connector to the Beagle for that.
Best regards
Christian
> Regards,
> Husni.
> On Tue, Mar 23, 2021 at 10:25 PM Utkarsh Rai <utkarsh.rai60 at gmail.com
> <mailto:utkarsh.rai60 at gmail.com>> wrote:
>     On Tue, Mar 23, 2021 at 9:36 PM Nils Hölscher <nilhoel1 at gmail.com
>     <mailto:nilhoel1 at gmail.com>> wrote:
>         Hi,
>         Regarding the PRU.
>         unable to communicate with it in a meaningful way
>     Just a small addition, AFAIK the issue with this was the fact that
>     mmap() would always fail.
>         a full DEBUGGING Setup.
>         Best,
>         Nils
>         On Tue, 23 Mar 2021 at 17:00, Christian MAUDERER
>         <christian.mauderer at embedded-brains.de
>         <mailto:christian.mauderer at embedded-brains.de>> wrote:
>             Hello Gedare,
>             Am 23.03.21 um 16:48 schrieb Gedare Bloom:
>              > CC: Nils, Utkarsh
>              > On Tue, Mar 23, 2021 at 9:17 AM Christian MAUDERER
>              >> Hello Ahamed,
>              >> Am 23.03.21 um 11:24 schrieb Ahamed Husni:
>              >>> Hi everyone,
>              >>> I'm really interested to work on the *Beagle BSP
>             Projects* [#2891
>              >>> <https://devel.rtems.org/ticket/2891
>             <https://devel.rtems.org/ticket/2891>>]. *
>              >>> *Adding PRU Support* [#3730
>             <https://devel.rtems.org/ticket/3730
>             <https://devel.rtems.org/ticket/3730>>]
>              >>> project seems really interesting to me.
>              >>> This project is partially done during GSoC 2019
>              >>> <https://devel.rtems.org/wiki/GSoC/2019
>             <https://devel.rtems.org/wiki/GSoC/2019>>by Nils Hölscher .
>              >>> Is this a good project for the GSoC?
>              >>> Up to now I have,
>              >>>   1. Completed the GSoC prerequisite task
>              >>>   2. Got the required hardware and tested it.
>             (Beagleboard Black, USB to
>              >>>      TTL Converter)
>              >>>   3. Installed RTEMS on the Beagleboard and tested.
>             (Screenshot attached
>              >>>      below)
>              >>> I need guidance to define the scope of the project.
>              >>> I'm currently thinking of ,
>              >>>   1. First finish the remaining work from GSoC 2019 on
>             the PRU.
>              >>>      (What is the status of current implementation of
>             the PRU?)
>              >> I'm really not sure what the state of the PRU is. I
>             didn't follow that
>              >> project closely. Maybe one of the mentors of that
>             project can say
>              >> anything regarding that.
>              > Some more background:
>             https://lists.rtems.org/pipermail/devel/2019-December/056478.html
>             <https://lists.rtems.org/pipermail/devel/2019-December/056478.html>
>             https://lists.rtems.org/pipermail/devel/2020-January/056958.html
>             <https://lists.rtems.org/pipermail/devel/2020-January/056958.html>
>              > Maybe Utkarsh or Nils have more to say.
>              >>>   2. Implement additional peripheral support.
>              >>>      What would be most useful?
>              >>>      (USB OTG, CAN, ...).
>              >> I think CAN is a bit hard without some CAN analyzer
>             hardware as a peer.
>             writing a driver for
>             and finding a
>             didn't take too
>             and finding a
>             one: You might work
>             possible advanced
>              >> - Ethernet
>              >> - Serial port
>              >> - Mass storage
>              >> - Keyboard / Mouse
>              >> - Modem
>              >> - Audio
>             by serial port. I
>             extended targets.
>             with a
>             is about
>             It won't produce a lot of code. But it will produce relevant
>             one:
>             1. Interface for configuration (if necessary)
>             2. Example application
>             3. Documentation
>             For Ethernet and serial port that's most likely it. For Mass
>             storage
>             there might be some more code. Without a too detailed look:
>             I would
>             expect that the mass storage either implements some access
>             to a raw
>             block device - in which case it would be necessary to add
>             the access to
>             block devices. Or it implements something like the PTP stuff
>             used on
>             smartphones in which case there will be most likely some
>             code that
>             accesses the file system using POSIX functions instead of
>             FreeBSD kernel
>             functions.
>             Best regards
>             Christian
>              >> Best regards
>              >> Christian
>              >>>      The builtin USB is NOT functional other than for
>             power under RTEMS.
>              >>>      (USB OTG would have to be implemented in RTEMS to
>             get rid of USB to
>              >>>      TTL Converter.)
>              >>>      - Ben Gras
>             <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>             <http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html>>
>              >>>      (Blog post)
>              >>> Thanks,
>              >>> Husni Faiz.
>              >>> _______________________________________________
>              >>> devel mailing list
>              >>> devel at rtems.org <mailto:devel at rtems.org>
>              >>> http://lists.rtems.org/mailman/listinfo/devel
>             <http://lists.rtems.org/mailman/listinfo/devel>
>              >> embedded brains GmbH
>              >> Herr Christian MAUDERER
>              >> Dornierstr. 4
>              >> 82178 Puchheim
>              >> Germany
>              >> email: christian.mauderer at embedded-brains.de
>              >> phone: +49-89-18 94 741 - 18
>              >> fax:   +49-89-18 94 741 - 08
>              >> Registergericht: Amtsgericht München
>              >> Registernummer: HRB 157899
>              >> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen,
>             Thomas Dörfler
>              >> Unsere Datenschutzerklärung finden Sie hier:
>              >> https://embedded-brains.de/datenschutzerklaerung/
>             <https://embedded-brains.de/datenschutzerklaerung/>
>              >> devel mailing list
>             Dornierstr. 4
>             82178 Puchheim
>             Germany
>             Thomas Dörfler
Dornierstr. 4
82178 Puchheim
Germany
