Issue in Recent Beagle Patch was Fwd: New Defects reported by Coverity Scan for RTEMS
Joel Sherrill
joel at rtems.org
Tue Mar 23 12:44:58 UTC 2021
---------- Forwarded message ---------
Date: Tue, Mar 23, 2021 at 12:22 AM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <build at rtems.org>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
3 new defect(s) introduced to RTEMS found with Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 3 of 3 defect(s)
** CID 1474437: Memory - corruptions (ARRAY_VS_SINGLETON)
________________________________________________________________________________________________________
*** CID 1474437: Memory - corruptions (ARRAY_VS_SINGLETON)
/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c: 480 in
beagle_pinctrl_configure_children()
474 int len;
475 uint32_t phandle;
476
477 for (node = OF_child(parent); node != 0; node =
OF_peer(node)) {
478 if (rtems_ofw_node_status(node)) {
479 beagle_pinctrl_configure_children(sc, node);
>>> Passing "&phandle" to function "rtems_ofw_get_enc_prop" which uses
it as an array. This might corrupt or misinterpret adjacent memory
locations.
480 len = OF_getencprop(node, "pinctrl-0",
&phandle, sizeof(phandle));
481 if (len == sizeof(phandle)) {
482 ti_pinmux_configure_pins(sc,
phandle);
483 }
484 }
485 }
** CID 1474436: Memory - corruptions (ARRAY_VS_SINGLETON)
*** CID 1474436: Memory - corruptions (ARRAY_VS_SINGLETON)
/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c: 545 in beagle_pinmux_init()
539 break;
540 default:
541 printk("Unknown CPU in pinmux\n");
542 return ;
543 }
544
>>> Passing "®" to function "rtems_ofw_get_reg" which uses it as an
array. This might corrupt or misinterpret adjacent memory locations.
545 rv = rtems_ofw_get_reg(node, ®, sizeof(reg));
546 if (rv == -1) {
547 printk("pinmux_init: rtems_ofw_get_reg failed
%d\n", rv);
548 return ;
549 }
550 pinmux_softc.sc_bsh = reg.start;
** CID 1474435: (RESOURCE_LEAK)
/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c: 408 in
ti_pinmux_configure_pins()
/bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c: 405 in
*** CID 1474435: (RESOURCE_LEAK)
402 sizeof(*cfgtuples), (void **)&cfgtuples);
403
404 if (ntuples < 0)
405 return (ENOENT);
406
407 if (ntuples == 0)
>>> Variable "cfgtuples" going out of scope leaks the storage it points
to.
408 return (0); /* Empty property is not an error. */
409
410 for (i = 0, cfg = cfgtuples; i < ntuples; i++, cfg++) {
411 #ifndef __rtems__
412 if (bootverbose) {
413 char name[32];
399 #endif /* __rtems__ */
400 cfgnode = OF_node_from_xref(cfgxref);
401 ntuples = OF_getencprop_alloc_multi(cfgnode,
"pinctrl-single,pins",
403
to.
406
409
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DZ9JC_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMrRpCRwRnwhWe3mGbZhfe5TEhVIZWqvzu-2BkK7GzWu18aemlzIGVqBnjE1VG1WYYnqAUylIIGsDE-2BbTTVBzIJdmJneUsK-2BEaTP8-2FdYkzR0L3nGksetaEs-2BWFiyM7otFz-2B3Jlvd7kkQjkZQhm78Hs6VA2e-2BgdMc6t9S3bFnOSaz2HAgqXpiOSsmtmoifKj8QLZB0-3D
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210323/1ff82486/attachment.html>
