[PATCH rtems-examples] lvgl/wscript: Add libpath to search for required libraries
Vijay Kumar Banerjee
vijay at rtems.org
Fri Mar 26 20:47:27 UTC 2021
lvgl/wscript | 12 ++++++++++--
1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/lvgl/wscript b/lvgl/wscript
index 064ebed..281af25 100644
--- a/lvgl/wscript
+++ b/lvgl/wscript
@@ -5,11 +5,19 @@
import rtems_waf.rtems as rtems
import rtems_waf.rtems_bsd as rtems_bsd
+import os
def configure(conf):
+ arch_lib_path = rtems.arch_bsp_lib_path(str(conf.env.RTEMS_VERSION),
+ str(conf.env.RTEMS_ARCH_BSP))
+ arch_lib_path = os.path.join(conf.env.PREFIX, arch_lib_path)
rtems.check_lib_path(conf, lib = 'm')
- rtems.check_lib_path(conf, lib = 'lvgl', mandatory = False)
- rtems.check_lib_path(conf, lib = 'bsd', mandatory = False)
+ rtems.check_lib_path(conf, lib = 'lvgl',
+ libpath = [arch_lib_path],
+ mandatory = False)
+ rtems.check_lib_path(conf, lib = 'bsd',
def build(bld):
bld.recurse('hello')
2.26.2
