[PATCH rtems-examples] lvgl/wscript: Add libpath to search for required libraries
Vijay Kumar Banerjee vijay at rtems.org
Mon Mar 29 15:20:04 UTC 2021
Hi,
Is this OK to push? This only affects lvgl.
Best regards,
Vijay
On Fri, Mar 26, 2021 at 2:47 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>  lvgl/wscript | 12 ++++++++++--
>  1 file changed, 10 insertions(+), 2 deletions(-)
> diff --git a/lvgl/wscript b/lvgl/wscript
> index 064ebed..281af25 100644
> --- a/lvgl/wscript
> +++ b/lvgl/wscript
> @@ -5,11 +5,19 @@
>  import rtems_waf.rtems as rtems
>  import rtems_waf.rtems_bsd as rtems_bsd
> +import os
>  def configure(conf):
> +    arch_lib_path = rtems.arch_bsp_lib_path(str(conf.env.RTEMS_VERSION),
> +                                                str(conf.env.RTEMS_ARCH_BSP))
> +    arch_lib_path = os.path.join(conf.env.PREFIX, arch_lib_path)
>      rtems.check_lib_path(conf, lib = 'm')
> -    rtems.check_lib_path(conf, lib = 'lvgl', mandatory = False)
> -    rtems.check_lib_path(conf, lib = 'bsd', mandatory = False)
> +    rtems.check_lib_path(conf, lib = 'lvgl',
> +                         libpath = [arch_lib_path],
> +                         mandatory = False)
> +    rtems.check_lib_path(conf, lib = 'bsd',
>  def build(bld):
>      bld.recurse('hello')
> 2.26.2
