[PATCH rtems-docs v3] networking: Rename to legacy networking
Joel Sherrill joel.sherrill at gmail.com
Fri Mar 26 22:46:24 UTC 2021
I thought I said this looked good on the first round.
My only question was whether you want to update it the minimum to point to
the legacy stack as a separate package. But that should be a follow up
patch.
--joel
On Fri, Mar 26, 2021 at 3:48 PM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> Ping :)
> On Tue, Mar 23, 2021 at 2:04 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >  book/index_book.rst                                         | 2 +-
> >  {networking => legacy-networking}/command.rst               | 0
> >  {networking => legacy-networking}/conf.py                   | 6 +++---
> >  {networking => legacy-networking}/dec_21140.rst             | 0
> >  {networking => legacy-networking}/index.rst                 | 2 +-
> >  {networking => legacy-networking}/network_servers.rst       | 0
> >  .../network_task_structure.rst                              | 0
> >  {networking => legacy-networking}/networking_driver.rst     | 0
> >  {networking => legacy-networking}/preface.rst               | 0
> >  {networking => legacy-networking}/testing_the_driver.rst    | 0
> >  .../using_networking_rtems_app.rst                          | 0
> >  {networking => legacy-networking}/wscript                   | 0
> >  wscript                                                     | 4 ++--
> >  13 files changed, 7 insertions(+), 7 deletions(-)
> >  rename {networking => legacy-networking}/command.rst (100%)
> >  rename {networking => legacy-networking}/conf.py (58%)
> >  rename {networking => legacy-networking}/dec_21140.rst (100%)
> >  rename {networking => legacy-networking}/index.rst (92%)
> >  rename {networking => legacy-networking}/network_servers.rst (100%)
> >  rename {networking => legacy-networking}/network_task_structure.rst
> (100%)
> >  rename {networking => legacy-networking}/networking_driver.rst (100%)
> >  rename {networking => legacy-networking}/preface.rst (100%)
> >  rename {networking => legacy-networking}/testing_the_driver.rst (100%)
> >  rename {networking => legacy-networking}/using_networking_rtems_app.rst
> (100%)
> >  rename {networking => legacy-networking}/wscript (100%)
> > diff --git a/book/index_book.rst b/book/index_book.rst
> > index 8282006..afe15a1 100644
> > --- a/book/index_book.rst
> > +++ b/book/index_book.rst
> > @@ -23,7 +23,7 @@ Table of Contents
> >         cpu_supplement/index.rst
> >         develenv/index.rst
> >         filesystem/index.rst
> > -       networking/index.rst
> >         porting/index.rst
> >         posix1003_1/index.rst
> >         posix_users/index.rst
> > +       legacy_networking/index.rst
> > diff --git a/networking/command.rst b/legacy-networking/command.rst
> > similarity index 100%
> > rename from networking/command.rst
> > rename to legacy-networking/command.rst
> > diff --git a/networking/conf.py b/legacy-networking/conf.py
> > similarity index 58%
> > rename from networking/conf.py
> > rename to legacy-networking/conf.py
> > index 1c129bc..98a06b6 100644
> > --- a/networking/conf.py
> > +++ b/legacy-networking/conf.py
> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
> >  from conf import *
> > -project = "RTEMS Networking User Manual"
> > +project = "RTEMS Legacy Networking User Manual"
> >  latex_documents = [
> >      ('index',
> > -     'networking.tex',
> > -     u'RTEMS Networking User Manual',
> > +     'legacy-networking.tex',
> > +     u'RTEMS Legacy Networking User Manual',
> >       u'RTEMS Documentation Project',
> >       'manual'),
> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
> > rename from networking/dec_21140.rst
> > rename to legacy-networking/dec_21140.rst
> > diff --git a/networking/index.rst b/legacy-networking/index.rst
> > similarity index 92%
> > rename from networking/index.rst
> > rename to legacy-networking/index.rst
> > index f56a60d..b85119d 100644
> > --- a/networking/index.rst
> > +++ b/legacy-networking/index.rst
> > @@ -5,7 +5,7 @@
> >  .. highlight:: c
> > -RTEMS Network User Manual (|version|).
> > +RTEMS Legacy Network User Manual (|version|).
> >  .. topic:: Copyrights and License
> > diff --git a/networking/network_servers.rst
> b/legacy-networking/network_servers.rst
> > rename from networking/network_servers.rst
> > rename to legacy-networking/network_servers.rst
> > diff --git a/networking/network_task_structure.rst
> b/legacy-networking/network_task_structure.rst
> > rename from networking/network_task_structure.rst
> > rename to legacy-networking/network_task_structure.rst
> > diff --git a/networking/networking_driver.rst
> b/legacy-networking/networking_driver.rst
> > rename from networking/networking_driver.rst
> > rename to legacy-networking/networking_driver.rst
> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
> > rename from networking/preface.rst
> > rename to legacy-networking/preface.rst
> > diff --git a/networking/testing_the_driver.rst
> b/legacy-networking/testing_the_driver.rst
> > rename from networking/testing_the_driver.rst
> > rename to legacy-networking/testing_the_driver.rst
> > diff --git a/networking/using_networking_rtems_app.rst
> b/legacy-networking/using_networking_rtems_app.rst
> > rename from networking/using_networking_rtems_app.rst
> > rename to legacy-networking/using_networking_rtems_app.rst
> > diff --git a/networking/wscript b/legacy-networking/wscript
> > rename from networking/wscript
> > rename to legacy-networking/wscript
> > diff --git a/wscript b/wscript
> > index ce644f8..0b1c368 100644
> > --- a/wscript
> > +++ b/wscript
> > @@ -32,11 +32,11 @@ build_all = ['user',
> >               'posix-compliance',
> >               'eng',
> >               'filesystem',
> > -             'networking',
> >               'shell',
> >               'cpu-supplement',
> >               'develenv',
> > -             'eclipse']
> > +             'eclipse',
> > +             'legacy-networking']
> >  building = build_all
> > 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210326/171a7dd7/attachment-0001.html>
