[PATCH rtems-docs v3] networking: Rename to legacy networking
Vijay Kumar Banerjee
vijay at rtems.org
Fri Mar 26 22:52:54 UTC 2021
Hi Joel,
On Fri, Mar 26, 2021, 16:46 Joel Sherrill <joel.sherrill at gmail.com> wrote:
> I thought I said this looked good on the first round.
In this version of the patch I send networking to bottom of the index in
coverpage.
> My only question was whether you want to update it the minimum to point to
> the legacy stack as a separate package. But that should be a follow up
> patch.
Yes, I'll add a note in the docs about the separate package and how to
build it manually and with RSB. I'll send that as a separate patch as you
mentioned.
Best regards,
Vijay
> --joel
> On Fri, Mar 26, 2021 at 3:48 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
>> Ping :)
>> On Tue, Mar 23, 2021 at 2:04 PM Vijay Kumar Banerjee <vijay at rtems.org>
>> wrote:
>> > book/index_book.rst | 2 +-
>> > {networking => legacy-networking}/command.rst | 0
>> > {networking => legacy-networking}/conf.py | 6 +++---
>> > {networking => legacy-networking}/dec_21140.rst | 0
>> > {networking => legacy-networking}/index.rst | 2 +-
>> > {networking => legacy-networking}/network_servers.rst | 0
>> > .../network_task_structure.rst | 0
>> > {networking => legacy-networking}/networking_driver.rst | 0
>> > {networking => legacy-networking}/preface.rst | 0
>> > {networking => legacy-networking}/testing_the_driver.rst | 0
>> > .../using_networking_rtems_app.rst | 0
>> > {networking => legacy-networking}/wscript | 0
>> > wscript | 4 ++--
>> > 13 files changed, 7 insertions(+), 7 deletions(-)
>> > rename {networking => legacy-networking}/command.rst (100%)
>> > rename {networking => legacy-networking}/conf.py (58%)
>> > rename {networking => legacy-networking}/dec_21140.rst (100%)
>> > rename {networking => legacy-networking}/index.rst (92%)
>> > rename {networking => legacy-networking}/network_servers.rst (100%)
>> > rename {networking => legacy-networking}/network_task_structure.rst
>> (100%)
>> > rename {networking => legacy-networking}/networking_driver.rst (100%)
>> > rename {networking => legacy-networking}/preface.rst (100%)
>> > rename {networking => legacy-networking}/testing_the_driver.rst (100%)
>> legacy-networking}/using_networking_rtems_app.rst (100%)
>> > rename {networking => legacy-networking}/wscript (100%)
>> > diff --git a/book/index_book.rst b/book/index_book.rst
>> > index 8282006..afe15a1 100644
>> > --- a/book/index_book.rst
>> > +++ b/book/index_book.rst
>> > @@ -23,7 +23,7 @@ Table of Contents
>> > cpu_supplement/index.rst
>> > develenv/index.rst
>> > filesystem/index.rst
>> > - networking/index.rst
>> > porting/index.rst
>> > posix1003_1/index.rst
>> > posix_users/index.rst
>> > + legacy_networking/index.rst
>> > diff --git a/networking/command.rst b/legacy-networking/command.rst
>> > similarity index 100%
>> > rename from networking/command.rst
>> > rename to legacy-networking/command.rst
>> > diff --git a/networking/conf.py b/legacy-networking/conf.py
>> > similarity index 58%
>> > rename from networking/conf.py
>> > rename to legacy-networking/conf.py
>> > index 1c129bc..98a06b6 100644
>> > --- a/networking/conf.py
>> > +++ b/legacy-networking/conf.py
>> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
>> > from conf import *
>> > -project = "RTEMS Networking User Manual"
>> > +project = "RTEMS Legacy Networking User Manual"
>> > latex_documents = [
>> > ('index',
>> > - 'networking.tex',
>> > - u'RTEMS Networking User Manual',
>> > + 'legacy-networking.tex',
>> > + u'RTEMS Legacy Networking User Manual',
>> > u'RTEMS Documentation Project',
>> > 'manual'),
>> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
>> > rename from networking/dec_21140.rst
>> > rename to legacy-networking/dec_21140.rst
>> > diff --git a/networking/index.rst b/legacy-networking/index.rst
>> > similarity index 92%
>> > rename from networking/index.rst
>> > rename to legacy-networking/index.rst
>> > index f56a60d..b85119d 100644
>> > --- a/networking/index.rst
>> > +++ b/legacy-networking/index.rst
>> > @@ -5,7 +5,7 @@
>> > .. highlight:: c
>> > -RTEMS Network User Manual (|version|).
>> > +RTEMS Legacy Network User Manual (|version|).
>> > .. topic:: Copyrights and License
>> > diff --git a/networking/network_servers.rst
>> b/legacy-networking/network_servers.rst
>> > rename from networking/network_servers.rst
>> > rename to legacy-networking/network_servers.rst
>> > diff --git a/networking/network_task_structure.rst
>> b/legacy-networking/network_task_structure.rst
>> > rename from networking/network_task_structure.rst
>> > rename to legacy-networking/network_task_structure.rst
>> > diff --git a/networking/networking_driver.rst
>> b/legacy-networking/networking_driver.rst
>> > rename from networking/networking_driver.rst
>> > rename to legacy-networking/networking_driver.rst
>> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
>> > rename from networking/preface.rst
>> > rename to legacy-networking/preface.rst
>> > diff --git a/networking/testing_the_driver.rst
>> b/legacy-networking/testing_the_driver.rst
>> > rename from networking/testing_the_driver.rst
>> > rename to legacy-networking/testing_the_driver.rst
>> > diff --git a/networking/using_networking_rtems_app.rst
>> b/legacy-networking/using_networking_rtems_app.rst
>> > rename from networking/using_networking_rtems_app.rst
>> > rename to legacy-networking/using_networking_rtems_app.rst
>> > diff --git a/networking/wscript b/legacy-networking/wscript
>> > rename from networking/wscript
>> > rename to legacy-networking/wscript
>> > diff --git a/wscript b/wscript
>> > index ce644f8..0b1c368 100644
>> > --- a/wscript
>> > +++ b/wscript
>> > @@ -32,11 +32,11 @@ build_all = ['user',
>> > 'posix-compliance',
>> > 'eng',
>> > 'filesystem',
>> > - 'networking',
>> > 'shell',
>> > 'cpu-supplement',
>> > 'develenv',
>> > - 'eclipse']
>> > + 'eclipse',
>> > + 'legacy-networking']
>> > building = build_all
>> > 2.26.2
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210326/2a8692c2/attachment.html>
