[PATCH rtems-docs v3] networking: Rename to legacy networking
Joel Sherrill
joel at rtems.org
Fri Mar 26 23:26:04 UTC 2021
On Fri, Mar 26, 2021, 5:53 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi Joel,
> On Fri, Mar 26, 2021, 16:46 Joel Sherrill <joel.sherrill at gmail.com> wrote:
>> I thought I said this looked good on the first round.
> In this version of the patch I send networking to bottom of the index in
> coverpage.
Sorry. That was a subtle change. Thanks for making it.
>> My only question was whether you want to update it the minimum to point
>> to the legacy stack as a separate package. But that should be a follow up
>> patch.
> Yes, I'll add a note in the docs about the separate package and how to
> build it manually and with RSB. I'll send that as a separate patch as you
> mentioned.
Good enough. Thanks to you the legacy network stack is not as dead as it
could be. Since you did this fantastic piece of work to put it in a
separate repository, we just want the documentation to reflect that.
> Best regards,
> Vijay
>> --joel
>> On Fri, Mar 26, 2021 at 3:48 PM Vijay Kumar Banerjee <vijay at rtems.org>
>> wrote:
>>> Ping :)
>>> On Tue, Mar 23, 2021 at 2:04 PM Vijay Kumar Banerjee <vijay at rtems.org>
>>> wrote:
>>> > book/index_book.rst | 2 +-
>>> > {networking => legacy-networking}/command.rst | 0
>>> > {networking => legacy-networking}/conf.py | 6 +++---
>>> > {networking => legacy-networking}/dec_21140.rst | 0
>>> > {networking => legacy-networking}/index.rst | 2 +-
>>> > {networking => legacy-networking}/network_servers.rst | 0
>>> > .../network_task_structure.rst | 0
>>> > {networking => legacy-networking}/networking_driver.rst | 0
>>> > {networking => legacy-networking}/preface.rst | 0
>>> > {networking => legacy-networking}/testing_the_driver.rst | 0
>>> > .../using_networking_rtems_app.rst | 0
>>> > {networking => legacy-networking}/wscript | 0
>>> > wscript | 4 ++--
>>> > 13 files changed, 7 insertions(+), 7 deletions(-)
>>> > rename {networking => legacy-networking}/command.rst (100%)
>>> > rename {networking => legacy-networking}/conf.py (58%)
>>> > rename {networking => legacy-networking}/dec_21140.rst (100%)
>>> > rename {networking => legacy-networking}/index.rst (92%)
>>> > rename {networking => legacy-networking}/network_servers.rst (100%)
>>> > rename {networking => legacy-networking}/network_task_structure.rst
>>> (100%)
>>> > rename {networking => legacy-networking}/networking_driver.rst (100%)
>>> > rename {networking => legacy-networking}/preface.rst (100%)
>>> > rename {networking => legacy-networking}/testing_the_driver.rst (100%)
>>> legacy-networking}/using_networking_rtems_app.rst (100%)
>>> > rename {networking => legacy-networking}/wscript (100%)
>>> > diff --git a/book/index_book.rst b/book/index_book.rst
>>> > index 8282006..afe15a1 100644
>>> > --- a/book/index_book.rst
>>> > +++ b/book/index_book.rst
>>> > @@ -23,7 +23,7 @@ Table of Contents
>>> > cpu_supplement/index.rst
>>> > develenv/index.rst
>>> > filesystem/index.rst
>>> > - networking/index.rst
>>> > porting/index.rst
>>> > posix1003_1/index.rst
>>> > posix_users/index.rst
>>> > + legacy_networking/index.rst
>>> > diff --git a/networking/command.rst b/legacy-networking/command.rst
>>> > similarity index 100%
>>> > rename from networking/command.rst
>>> > rename to legacy-networking/command.rst
>>> > diff --git a/networking/conf.py b/legacy-networking/conf.py
>>> > similarity index 58%
>>> > rename from networking/conf.py
>>> > rename to legacy-networking/conf.py
>>> > index 1c129bc..98a06b6 100644
>>> > --- a/networking/conf.py
>>> > +++ b/legacy-networking/conf.py
>>> > @@ -3,12 +3,12 @@ sys.path.insert(0, os.path.abspath('../common/'))
>>> > from conf import *
>>> > -project = "RTEMS Networking User Manual"
>>> > +project = "RTEMS Legacy Networking User Manual"
>>> > latex_documents = [
>>> > ('index',
>>> > - 'networking.tex',
>>> > - u'RTEMS Networking User Manual',
>>> > + 'legacy-networking.tex',
>>> > + u'RTEMS Legacy Networking User Manual',
>>> > u'RTEMS Documentation Project',
>>> > 'manual'),
>>> > diff --git a/networking/dec_21140.rst b/legacy-networking/dec_21140.rst
>>> > rename from networking/dec_21140.rst
>>> > rename to legacy-networking/dec_21140.rst
>>> > diff --git a/networking/index.rst b/legacy-networking/index.rst
>>> > similarity index 92%
>>> > rename from networking/index.rst
>>> > rename to legacy-networking/index.rst
>>> > index f56a60d..b85119d 100644
>>> > --- a/networking/index.rst
>>> > +++ b/legacy-networking/index.rst
>>> > @@ -5,7 +5,7 @@
>>> > .. highlight:: c
>>> > -RTEMS Network User Manual (|version|).
>>> > +RTEMS Legacy Network User Manual (|version|).
>>> > .. topic:: Copyrights and License
>>> > diff --git a/networking/network_servers.rst
>>> b/legacy-networking/network_servers.rst
>>> > rename from networking/network_servers.rst
>>> > rename to legacy-networking/network_servers.rst
>>> > diff --git a/networking/network_task_structure.rst
>>> b/legacy-networking/network_task_structure.rst
>>> > rename from networking/network_task_structure.rst
>>> > rename to legacy-networking/network_task_structure.rst
>>> > diff --git a/networking/networking_driver.rst
>>> b/legacy-networking/networking_driver.rst
>>> > rename from networking/networking_driver.rst
>>> > rename to legacy-networking/networking_driver.rst
>>> > diff --git a/networking/preface.rst b/legacy-networking/preface.rst
>>> > rename from networking/preface.rst
>>> > rename to legacy-networking/preface.rst
>>> > diff --git a/networking/testing_the_driver.rst
>>> b/legacy-networking/testing_the_driver.rst
>>> > rename from networking/testing_the_driver.rst
>>> > rename to legacy-networking/testing_the_driver.rst
>>> > diff --git a/networking/using_networking_rtems_app.rst
>>> b/legacy-networking/using_networking_rtems_app.rst
>>> > rename from networking/using_networking_rtems_app.rst
>>> > rename to legacy-networking/using_networking_rtems_app.rst
>>> > diff --git a/networking/wscript b/legacy-networking/wscript
>>> > rename from networking/wscript
>>> > rename to legacy-networking/wscript
>>> > diff --git a/wscript b/wscript
>>> > index ce644f8..0b1c368 100644
>>> > --- a/wscript
>>> > +++ b/wscript
>>> > @@ -32,11 +32,11 @@ build_all = ['user',
>>> > 'posix-compliance',
>>> > 'eng',
>>> > 'filesystem',
>>> > - 'networking',
>>> > 'shell',
>>> > 'cpu-supplement',
>>> > 'develenv',
>>> > - 'eclipse']
>>> > + 'eclipse',
>>> > + 'legacy-networking']
>>> > building = build_all
>>> > 2.26.2
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210326/cd6d3284/attachment-0001.html>
