[PATCH v4] covoar: Handle periods in symbols from objdump
Gedare Bloom
gedare at rtems.org
Sat Mar 27 14:39:34 UTC 2021
this one looks fine to me.
On Fri, Mar 26, 2021 at 3:21 PM Alex White <alex.white at oarcorp.com> wrote:
> ping
> > -----Original Message-----
> > From: Alex White <alex.white at oarcorp.com>
> > Sent: Friday, March 19, 2021 2:10 PM
> > To: devel at rtems.org
> > Cc: Alex White <alex.white at oarcorp.com>
> > Subject: [PATCH v4] covoar: Handle periods in symbols from objdump
> > Occasionally the compiler will generate symbols that look similar to symbols
> > defined in RTEMS code except that they contain some suffix.
> > These symbol suffixes are only found in the ELF symbol table; the symbols
> > appear to be normal in the DWARF info. This appears to be happening on all
> > architectures.
> > For example, the function _Message_queue_Create from rtems appears as
> > "_Message_queue_Create.part.0". Other suffixes include ".isra.0",
> > ".constprop.0", and ".0".
> > This looks to be related to compiler optimizations. Symbols with suffixes
> > were being treated as unique. For our purposes, they should be mapped to
> > the equivalent symbols in the DWARF info. This has been fixed.
> > tester/covoar/ExecutableInfo.cc | 3 +--
> > tester/covoar/ObjdumpProcessor.cc | 15 +++++++++++++++
> > tester/covoar/SymbolTable.cc | 12 +++++++++---
> > 3 files changed, 25 insertions(+), 5 deletions(-)
> > diff --git a/tester/covoar/ExecutableInfo.cc
> > b/tester/covoar/ExecutableInfo.cc index c996d75..1e14721 100644
> > --- a/tester/covoar/ExecutableInfo.cc
> > +++ b/tester/covoar/ExecutableInfo.cc
> > @@ -118,8 +118,7 @@ namespace Coverage {
> > // Obtain the coverage map containing the specified address.
> > itsSymbol = theSymbolTable.getSymbol( address );
> > if (itsSymbol != "") {
> > - it = coverageMaps.find( itsSymbol );
> > - aCoverageMap = (*it).second;
> > + aCoverageMap = &findCoverageMap(itsSymbol);
> > return aCoverageMap;
> > diff --git a/tester/covoar/ObjdumpProcessor.cc
> > b/tester/covoar/ObjdumpProcessor.cc
> > index 0647ff9..e19fa92 100644
> > --- a/tester/covoar/ObjdumpProcessor.cc
> > +++ b/tester/covoar/ObjdumpProcessor.cc
> > @@ -417,6 +417,21 @@ namespace Coverage {
> > processSymbol = false;
> > theInstructions.clear();
> > + // Look for a '.' character and strip everything after it.
> > + // There is a chance that the compiler splits function bodies to improve
> > + // inlining. If there exists some inlinable function that contains a
> > + // branch where one path is more expensive and less likely to be taken
> > + // than the other, inlining only the branch instruction and the less
> > + // expensive path results in smaller code size while preserving most of
> > + // the performance improvement.
> > + // When this happens, the compiler will generate a function with a
> > + // ".part.n" suffix. For our purposes, this generated function part is
> > + // equivalent to the original function and should be treated as such.
> > + char *periodIndex = strstr(symbol, ".");
> > + if (periodIndex != NULL) {
> > + *periodIndex = 0;
> > // See if the new symbol is one that we care about.
> > if (SymbolsToAnalyze->isDesired( symbol )) {
> > currentSymbol = symbol;
> > diff --git a/tester/covoar/SymbolTable.cc b/tester/covoar/SymbolTable.cc
> > index 53bc8af..00062cc 100644
> > --- a/tester/covoar/SymbolTable.cc
> > +++ b/tester/covoar/SymbolTable.cc
> > @@ -46,12 +46,18 @@ namespace Coverage {
> > symbolData.startingAddress = start;
> > symbolData.length = length;
> > - if ( info[ symbol ].empty() == false ) {
> > - if ( info[ symbol ].front().length != length ) {
> > + for (auto& symData : info[ symbol ]) {
> > + // The starting address could differ since we strip any suffixes beginning
> > + // with a '.'
> > + if (symData.startingAddress != start) {
> > + continue;
> > + if (symData.length != length) {
> > std::ostringstream what;
> > what << "Different lengths for the symbol "
> > << symbol
> > - << " (" << info[ symbol ].front().length
> > + << " (" << symData.length
> > << " and " << length
> > throw rld::error( what, "SymbolTable::addSymbol" );
> > 2.27.0
> devel mailing list
> devel at rtems.org
