Two Resource Leaks
Joel Sherrill
joel at rtems.org
Sat Mar 27 16:20:12 UTC 2021
On Sat, Mar 27, 2021, 11:07 AM Sebastian Huber <
> On 27/03/2021 16:08, Joel Sherrill wrote:
> > The issue I found is different and won't happen on every target or
> > bsp.
> > Psim has 6-9 failures even after freeing the right stack address.
> > The stack address and now (I think) size saved for later use are wrong
> > and this leads to multiple failures.
> I work on a fix. psim seems to be a good platform for these tests.
I put a patch for the address issue but I think the fundamental issue is
you changed the semantics of what was stored in the stack structure. You
probably want a different approach but this is at least a good
temporary fix.
And something different on Libbsd. But not sure.
I think Richi has raised the issue that there are some recently introduced
failures. Not sure how many are this.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210327/7f0ac4c6/attachment.html>
