Two Resource Leaks
    Sebastian Huber
    Sat Mar 27 18:38:28 UTC 2021
On 27/03/2021 17:20, Joel Sherrill wrote:
> On Sat, Mar 27, 2021, 11:07 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 27/03/2021 16:08, Joel Sherrill wrote:
>     >     The issue I found is different and won't happen on every
>     target or
>     >     bsp.
>     >     Psim has 6-9 failures even after freeing the right stack
>     address.
>     > The stack address and now (I think) size saved for later use are
>     wrong
>     > and this leads to multiple failures.
>     I work on a fix. psim seems to be a good platform for these tests.
> I put a patch for the address issue but I think the fundamental issue
> is you changed the semantics of what was stored in the stack
> structure. You probably want a different approach but this is at least
> a good temporary fix.
I checked in a fix. However, I still get two unexpected failures:
Failures:
  fsimfsgeneric01.exe
  psxkey08.exe
A rtems_resource_snapshot_check() is not happy.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
