psim failure - psx12
Sat Mar 27 20:21:15 UTC 2021
Hi
While the "multiple resource leaks" thread continues, I thought I would
start threads for other failures that are not resource leaks. psx12 fails
as follows. This could be as simple as the decrementer counts instructions
and it needs to allow more between clock ticks. But that would require
experimentation. And it assumes this test doesn't fail on another BSP.
*** BEGIN OF TEST PSX 12 ***
*** TEST VERSION: 6.0.0.1e62e15f46283a3affb1e6dcceead0c382482287
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API
*** TEST TOOLS: 10.2.1 20210308 (RTEMS 6, RSB
56cba3c6a34dae16271efb7b349cfce0e5e5b4c5, Newlib abc8acb)
Init's ID is 0x0b010001
Init: pthread_attr_init - SUCCESSFUL
Init: pthread_create - EINVAL (invalid scheduling policy)
Init: set scheduling parameter attributes for sporadic server
Init: pthread_create - EINVAL (replenish < budget)
Init: pthread_create - EINVAL (invalid sched_ss_low_priority)
Init: pthread_create - SUCCESSFUL
Sporadic Server: exitting
[0] H  96ms
[0] L 196ms
../../../testsuites/psxtests/psx12/init.c: 224 ctx->samples[ i ].low /
SS_REPL_PERIOD_MS == i + 1
*** FATAL ***
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210327/bcc823b3/attachment.html>
