#4328: New APIs added to POSIX Standard (2021)
Matthew Joyce
mfjoyce2004 at gmail.com
Sun Mar 28 08:09:48 UTC 2021
Hi Eshan,
Got it, thanks very much for the explanation! I went ahead and updated
the spreadsheet. It looks like you did an awesome job last year, by
the way :-)
Matt
On Sun, Mar 28, 2021 at 9:57 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> > On 28-Mar-2021, at 12:17 PM, Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> > Hi Eshan,
> > Ok, great! Thank you for letting me know. By the way, where will it be
> > implemented when it's patched in? Thanks again and have a great rest
> > of your Sunday.
> Function file : rtems/cpukit/posix
> Tests : testsuite/psxtests
> Since confstr tells about the programming environments supported so it is RTEMS specific.
> > Sincerely,
> > Matt
> >> On Sun, Mar 28, 2021 at 6:54 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> >>>> On 27-Mar-2021, at 1:49 AM, Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>> Hi Dr. Joel,
> >>> I finally built rtems-libbsd and see that pselect and sockatmark are
> >>> both defined there. I went ahead and added a "In rtems-libbsd" column
> >>> in the spreadsheet to reflect that.
> >>> With those two defined, it looks like the only methods from the FACE
> >>> 3.0 General Purpose Profile that aren't currently supported are
> >>> confstr() and the <spawn.h> set. Could I ask, what is the thinking on
> >>> those? The man page suggests that spawn was created with embedded
> >>> systems in mind, but I'd guess a conscious decision was made to leave
> >>> them out? How about confstr?
> >>> Thank you!
> >>> Matt
> >> Hi Matt
> >> Confstr code is ready just under styling issues.
> >> So maybe you could count it as Present.
> >> Thanks
> >> - Eshan
> >>>> On Thu, Mar 25, 2021 at 2:18 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>> On Thu, Mar 25, 2021 at 7:14 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>> Hi Dr. Joel,
> >>>>> Thanks very much, that's a big help! Correct, I've been updating the
> >>>>> spreadsheet as I go along. Ok, now I see that strlcat/strlcpy are used
> >>>>> in rtems/cpukit and implemented in Newlib.
> >>>>> One additional question, please: I haven't yet looked into the source
> >>>>> of NetBSD or FreeBSD, but I do see that Newlib already implements
> >>>>> ppoll (poll.cc), dladdr (dlfcn.cc), pselect (select.cc), and
> >>>>> sockatmark (net.cc). None of them are defined in the rtems environment
> >>>>> yet. Is there any reason why the NetBSD/FreeBSD version would be
> >>>>> preferable to Newlib for these? Or is it just a matter of testing
> >>>>> what's out there to find what works well in the rtems environment?
> >>>> Without looking at the newlib git repo, I can tell you that the files
> >>>> you cite are the implementation of those methods for Cygwin. Just
> >>>> because they are in C++. :)
> >>>> The parts of the newlib repo RTEMS uses are under the newlib/
> >>>> subdirectory not the cygwin one. Within that, there is a libc/sys and
> >>>> only libc/sys/rtems is used for RTEMS. The others are for different
> >>>> operating systems. There are a few places with "machine" directory
> >>>> structures. Only the ones for the architecture you are building for
> >>>> is used.
> >>>> As to why NetBSD for libdl, that is because portions of the code
> >>>> originated there.
> >>>> And rtems-libbsd is based on FreeBSD. It is as close to the FreeBSD
> >>>> source as we can keep it.
> >>>>> In my proposal I'll take your advice and work on some of the easier
> >>>>> ones first in order to get the experience and process down.
> >>>> There are tickets for a lot of methods. The rtems-docs repo has the
> >>>> csv file (e.g. spreadsheet) which tracks RTEMS support against
> >>>> various standards. The RTEMS POSIX Compliance Guide is generated
> >>>> from that csv file. Between those, you can find other methods to ask
> >>>> about. In general, if it is required by the Software Communications
> >>>> Architecture (SCA) or FACE Technical Standard, then it is a method
> >>>> someone expected to possibly be used in an embedded system.
> >>>> SCA is a set of POSIX profiles focused on software defined radios and
> >>>> the FACE Technical Standard was developed with avionics in mind.
> >>>> But any are fair game if they are actually implementable. I don;t think
> >>>> the Compliance Guide says it yet, but we decided last year that
> >>>> wordexp() is likely not supportable on RTEMS. The newlib
> >>>> implementation assumes the presence of a shell with wildcard expansion
> >>>> and ability to fork a process.
> >>>> --joel
> >>>>> Thank you again for your time!
> >>>>> Matt
> >>>>> On Wed, Mar 24, 2021 at 5:03 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>> Wow! Good work. There is a lot to digest here. Comments interspersed.
> >>>>>> I assume the spreadsheet is updated.
> >>>>>> On Wed, Mar 24, 2021 at 7:38 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>>>> Hi Dr. Joel,
> >>>>>>> I've gone over the list a few times now and see a few categories shaping up:
> >>>>>>> 1) Already done (In Newlib source, defined in libc.a):
> >>>>>>> a) reallocarray
> >>>>>>> b) qsort_r
> >>>>>>> c) memmem
> >>>>>>> d) strlcat / strlcpy
> >>>>>>> d) wcslcat / wcslcpy
> >>>>>>> *Out of this group, strlcat and strlcpy also show up in
> >>>>>>> src/rtems/cpukit. Why is that?
> >>>>>> The good news is that we support these. :)
> >>>>>> It looks to me that strlcat and strlcpy are used in cpukit but not implemented
> >>>>>> there. Where do you think they are implemented.
> >>>>>> This is a good example where a source code browser is helpful. grep can
> >>>>>> often answer the question but a source code browser can be easier. Personally,
> >>>>>> I use cscope but that is exceedingly old school. Any modern IDE should be
> >>>>>> helpful.
> >>>>>>> 2) Not done yet (Do not show up in Newlib source or RTEMS):
> >>>>>>> a) getlocalename_l
> >>>>>>> b) posix_getdents
> >>>>>>> c) sem_clockwait
> >>>>>>> d) sig2str / str2sig
> >>>>>>> 3) Not in Newlib; Referenced in RTEMS but hidden behind #ifdef:
> >>>>>>> a) pthread_cond_clockwait
> >>>>>>> (rtems/6/lib/gcc/sparc-rtems6/10.2.1/include/c++/condition_variable)
> >>>>>>> b) pthread_mutex_clocklock
> >>>>>>> (rtems/6/lib/gcc/sparc-rtems6/10.2.1/include/c++/mutex)
> >>>>>>> c) pthread_rwlock_clockrdlock
> >>>>>>> (rtems/6/lib/gcc/sparc-rtems6/10.2.1/include/c++/shared_mutex)
> >>>>>>> c) pthread_rwlock_clockwrlock
> >>>>>>> *It looks like some groundwork was done, but the methods are not yet supported.
> >>>>>> The paths you point to are C++ files that would implement C++ features
> >>>>>> using the available POSIX services. So they are users, not providers.
> >>>>>> All of the pthread services related to these are implemented in
> >>>>>> cpukit/posix/src. I think you can configure a clock for all these now
> >>>>>> to be used by detailed on wait and timedwait calls. My understanding
> >>>>>> is that these would let you use a specific clock on a per blocking call
> >>>>>> basis.
> >>>>>> First question is which clocks are intended to be supported.
> >>>>>> Second is the pattern of picking which timeout queue to go on when
> >>>>>> now it is coded to let you pick one which is used for the life of the object.
> >>>>>>> 4) Misc (In Newlib source, not defined in libc.a, appear in RTEMS in
> >>>>>>> various ways)
> >>>>>>> a) getentropy (an alternate version is defined in RTEMS librtemsbsd.a,
> >>>>>>> in src/rtems/bsps/shared/dev/getentropy/getentropy-cpucounter.c. The
> >>>>>>> comments note that it is not cryptographically secure, so it may not
> >>>>>>> fit the bill for the getentropy() mentioned in the Open Group
> >>>>>>> document)
> >>>>>> I am far from a cryptography expert but this looks like a case where
> >>>>>> this method would be considered supported with the disclaimer that
> >>>>>> the quality of the entropy value depends on the BSP. If the user has
> >>>>>> specific requirements, they will need to verify the implementation
> >>>>>> used by the BSP by default is appropriate.
> >>>>>>> b) ppoll (appears in rtems/6/share/gdb/syscalls)
> >>>>>> You need to be more careful with the grep. These again are in the
> >>>>>> installed tools and in this case, they appear in an XML file. Referenced
> >>>>>> but not implemented.
> >>>>>> ppoll() will need to come from rtems-libbsd. The required system call
> >>>>>> is included but disabled currently. AFAIK this means it is possible to
> >>>>>> provide this but that would require a more detailed discussion in case
> >>>>>> some underlying capability is missing. Chris Johns and Sebastian
> >>>>>> Huber would be the ones to guide here.
> >>>>>> Ruling: Likely possible.
> >>>>>>> c) dladdr (appears in rtems/cpukit but not defined)
> >>>>>> I think this can be implemented in libdl but I am not sure if the
> >>>>>> code from NetBSD from this would directly work or just be a guide.
> >>>>>>> 5) Others?
> >>>>>>> It looks like there was work done on methods like sockatmark and
> >>>>>>> pselect, but I don't see them supported as yet. Should those be added
> >>>>>>> to the list or are they still being worked on?
> >>>>>> These would come from rtems-libbsd.
> >>>>>> I think sockatmark.c is implemented in freebsd/lib/libc/net/sockatmark.c
> >>>>>> but I don't know if the ioctl() is implemented. I expect it is but this would
> >>>>>> at least require a test. It may just work.
> >>>>>> pselect() looks to be missing and would have to be ported from FreeBSD.
> >>>>>>> As you suggested, I'll look into NetBSD for dladdr and do some digging
> >>>>>>> on the implementation of the other outstanding methods. You mentioned
> >>>>>>> that the "clock" ones have to be strictly added to rtems/cpukit, but
> >>>>>>> the references I found above are all in lib/gcc/sparc-rtems6/10.2.1.
> >>>>>>> Why is that the case and what is 10.2.1? Also, I'm not sure what to
> >>>>>>> make of getentropy and ppoll based on what I found above...at your
> >>>>>>> convenience could you please advise?
> >>>>>> Hopefully the above helped.
> >>>>>> You don't have to restrict your possible set to these new additions.
> >>>>>> There are others. I think Eshan has done the research for where to
> >>>>>> get implementations of the missing long double methods for newlib.
> >>>>>> And there are tickets for other missing methods or specific capabilities
> >>>>>> in methods that are supported. Those are quite possible to have
> >>>>>> some alternatives that are easier to approach.
> >>>>>> --joel
> >>>>>>> Thank you very much!
> >>>>>>> Matt
> >>>>>>> On Sun, Mar 21, 2021 at 6:38 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>>>> On Sun, Mar 21, 2021 at 2:28 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>>>>>> Gentlemen,
> >>>>>>>>> Awesome, thanks! I see how that works now...I'll give it a thorough
> >>>>>>>>> look tomorrow and will update the spreadsheet accordingly. I'll pipe
> >>>>>>>>> back up when I have a more accurate look of what's currently there.
> >>>>>>>> Knowing what doesn't have to be done is the first step. (rtems, newlib, and libbsd)
> >>>>>>>> I'd be prone to look for things that are easy to add first.
> >>>>>>>> Some may not be implementable on RTEMS due to only supporting a
> >>>>>>>> single process and no virtual memory. If you have doubts on whether it
> >>>>>>>> is possible to support a specific method, speak up and let's try to decide.
> >>>>>>>> Then find upstream places for an implementation where possible. I suspect
> >>>>>>>> all the new "clock" methods will require discussion on an implementation
> >>>>>>>> pattern but those must strictly be added to rtems/cpukit with tests and
> >>>>>>>> documentation. At least I can throw you that much. :)
> >>>>>>>>> Thanks again and have a great Sunday!
> >>>>>>>>> Matt
> >>>>>>>>> On Fri, Mar 19, 2021 at 8:27 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>>>>>> On Fri, Mar 19, 2021 at 1:08 PM Gedare Bloom <gedare at rtems.org> wrote:
> >>>>>>>>>>> On Fri, Mar 19, 2021 at 11:16 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>>>>>>>>> Dr. Joel,
> >>>>>>>>>>>> Thanks very much...I'll keep working to get a sense of what goes
> >>>>>>>>>>>> where! In the meantime, where can I look to get the ground truth of
> >>>>>>>>>>>> which methods are "in RTEMS" as opposed to those in newlib?
> >>>>>>>>>>> There is only one ground truth:
> >>>>>>>>>>> git://git.rtems.org/rtems.git
> >>>>>>>>>>> And for newlib
> >>>>>>>>>>> git://sourceware.org/git/newlib-cygwin.git
> >>>>>>>>>>> That said, searching for the function name symbols in compiled
> >>>>>>>>>>> libraries is a good first step to rule out newlib. Then, you can
> >>>>>>>>>>> 'grep' the RTEMS source code for the function names to see if they
> >>>>>>>>>>> exist there.
> >>>>>>>>>> rtems/cpukit to be specitic. It won't be implemented anywhere else.
> >>>>>>>>>> And clearly we both have forgotten that networking APIs are in the
> >>>>>>>>>> rtems-libbsd repository.
> >>>>>>>>>> https://git.rtems.org/rtems-libbsd/
> >>>>>>>>>> I suspect ppoll() might already be in there. Or at least supported by
> >>>>>>>>>> FreeBSD.
> >>>>>>>>>> You should clone everything and grep the sources. newlib already has
> >>>>>>>>>> qsort_r. This is the nm I used:
> >>>>>>>>>> $ ~/rtems-work/tools/6/bin/sparc-rtems6-nm ~/rtems-work/tools/6/sparc-rtems6/lib/libc.a | grep qsort_r
> >>>>>>>>>> lib_a-bsd_qsort_r.o:
> >>>>>>>>>> 00000000 T __bsd_qsort_r
> >>>>>>>>>> lib_a-qsort_r.o:
> >>>>>>>>>> 00000000 T qsort_r
> >>>>>>>>>> Notice the last line has "T qsort_r" which says it is defined.
> >>>>>>>>>> grep -r in the newlib source shows it is in ./libc/search/qsort_r.c
> >>>>>>>>>> dladdr() looks to be prototyped in RTEMS but hidden behind an ifdef like it
> >>>>>>>>>> wasn't ported from NetBSD so that looks possible. It is in rtems.
> >>>>>>>>>> Those two examples should help you figure out why you missed
> >>>>>>>>>> finding some things that were implemented.
> >>>>>>>>>> I need to figure out what this next POSIX version is to be called
> >>>>>>>>>> so I can update the tracking spreadsheet that generates the RTEMS
> >>>>>>>>>> POSIX Compliance Guide, :)
> >>>>>>>>>> --joel
> >>>>>>>>>>>> Thanks again!
> >>>>>>>>>>>> Matt
> >>>>>>>>>>>> On Fri, Mar 19, 2021 at 1:58 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>>>>>>>>> Keep devel@ on the list. :)
> >>>>>>>>>>>>> On Fri, Mar 19, 2021 at 7:51 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>>>>>>>>>>> Sir,
> >>>>>>>>>>>>>> Thank you for the link! I see that you're right, those last four are
> >>>>>>>>>>>>>> in newlib, plus memmem(). I updated those in the Google Sheet.
> >>>>>>>>>>>>>> Now I see the newlib part, but where are you referring to specifically
> >>>>>>>>>>>>>> when you say RTEMS, as in "POSIX support comes from a mix of RTEMS and
> >>>>>>>>>>>>>> newlib"?
> >>>>>>>>>>>>> POSIX is a HUGE HUGE standard and references other standards. One
> >>>>>>>>>>>>> it references and pulls in is the C99 Standard C Library which is libc and
> >>>>>>>>>>>>> libm. RTEMS mostly does not implement this functionality and relies on
> >>>>>>>>>>>>> another open source project for those APIs. Newlib is an open source
> >>>>>>>>>>>>> C Library used by RTEMS, Cygwin, and most embedded systems GNU tools
> >>>>>>>>>>>>> chains.
> >>>>>>>>>>>>> Most of the POSIX header files with RTEMS are actually in Newlib even
> >>>>>>>>>>>>> if they originated with RTEMS. Many are shared with Cygwin.
> >>>>>>>>>>>>> So methods like the string, memory, and *printf come from Newlib since they
> >>>>>>>>>>>>> are in C99. We provide POSIX like threading, signals, core file access, and
> >>>>>>>>>>>>> much more.
> >>>>>>>>>>>>> It's a complementary relationship but it takes a bit to figure out when
> >>>>>>>>>>>>> something should be in one or the other. The line gets blurred at times.
> >>>>>>>>>>>>> Say you added a new CPU architecture implementation of a math
> >>>>>>>>>>>>> method (like Eshan did last year), then it goes in newlib. But he also
> >>>>>>>>>>>>> added some POSIX methods which go in RTEMS. In either case,
> >>>>>>>>>>>>> we like tests for them in RTEMS to show they work in our environment.
> >>>>>>>>>>>>> --joel
> >>>>>>>>>>>>>> Thanks again!
> >>>>>>>>>>>>>> Matt
> >>>>>>>>>>>>>> On Fri, Mar 19, 2021 at 1:13 PM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>>>>>>>>>>> On Fri, Mar 19, 2021, 6:40 AM Joel Sherrill <joel at rtems.org> wrote:
> >>>>>>>>>>>>>>>> On Fri, Mar 19, 2021, 5:48 AM Matthew Joyce <mfjoyce2004 at gmail.com> wrote:
> >>>>>>>>>>>>>>>>> https://docs.google.com/spreadsheets/d/1reCNOIZC5JTwQENgl-hvG8THfQqNtlUDVy_07PYodic/edit?usp=sharing
> >>>>>>>>>>>>>>>>> Hello,
> >>>>>>>>>>>>>>>>> As suggested by Dr. Sherril, I've taken an initial look through this
> >>>>>>>>>>>>>>>>> document https://www.opengroup.org/austin/docs/austin_1110.pdf and
> >>>>>>>>>>>>>>>>> added the new methods to a Googe Sheet, linked above.
> >>>>>>>>>>>>>>>>> None of them appear to be in the RTEMS POSIX API Users Guide, but
> >>>>>>>>>>>>>>>>> maybe that's not the right place to look. I'll stand by for your
> >>>>>>>>>>>>>>>>> feedback regarding what's possible / desirable to add to RTEMS.
> >>>>>>>>>>>>>>>> It is possible they are in our C Library or Math Library. Or just not in the manual. The POSIX manual tends to be sparse since you can always use man pages or the POSIX standard.
> >>>>>>>>>>>>>>>> Since you have RTEMS and tools built. Find one of the libc.a and libm.a files in the tools install and librtemscpu.a in the RTEMS build or install. Then try a command something like this:
> >>>>>>>>>>>>>>>> CPU-rtems6-nm LIBRARY | grep SYMBOL
> >>>>>>>>>>>>>>>> If you see it list with T then it is in the text section and there.
> >>>>>>>>>>>>>>> Following up, I initially answered from my phone and didn't look at source. I am still on my phone but looked through the list and think the last four methods are probably the only ones currently supported.
> >>>>>>>>>>>>>>> https://sourceware.org/git/?p=newlib-cygwin.git;a=tree;f=newlib/libc/string;h=ceeec602cdd0e6b5c6b002b741bda9b41da4e441;hb=HEAD
> >>>>>>>>>>>>>>> POSIX support comes from a mix of RTEMS and newlib. That's key to this type of project.
> >>>>>>>>>>>>>>> --joel
> >>>>>>>>>>>>>>>>> Thanks very much for your time!
> >>>>>>>>>>>>>>>>> Sincerely,
> >>>>>>>>>>>>>>>>> Matt
> >>>>>>>>>>>> _______________________________________________
> >>>>>>>>>>>> devel mailing list
> >>>>>>>>>>>> devel at rtems.org
> >>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
