[PATCH] Open firmware: restore FDT in ofw01 to avoid test timeout
Sun Mar 28 15:43:48 UTC 2021
On Sun, Mar 28, 2021, 7:56 AM Jiri Gaisler <jiri at gaisler.se> wrote:
> The ofw01 test will hang on RISC-V unless the real FDT is restored at the
> end of the test. This will allow the Sifive test module be found by
> _CPU_Fatal_halt() and avoid an infinite loop.
I'm ok with this but would like someone with another bsp with a FDT to
report that this is ok.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210328/643beae5/attachment.html>
