[PATCH] Open firmware: restore FDT in ofw01 to avoid test timeout
Christian MAUDERER
christian.mauderer at embedded-brains.de
Tue Mar 30 14:37:34 UTC 2021
Hello Jiri and Joel,
I tested the patch on the i.MXRT BSP and it runs fine. Therefore I
pushed it.
@Jiri: Thanks for the patch.
Best regards
Christian
Am 28.03.21 um 17:43 schrieb Joel Sherrill:
> On Sun, Mar 28, 2021, 7:56 AM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>> wrote:
> The ofw01 test will hang on RISC-V unless the real FDT is restored
> at the end of the test. This will allow the Sifive test module be
> found by _CPU_Fatal_halt() and avoid an infinite loop.
> I'm ok with this but would like someone with another bsp with a FDT to
> report that this is ok.
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
> <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
