[PATCH] STM32H743ZI Nucleo and basic lwIP support
Robin Mueller robin.mueller.m at gmail.com
Mon Mar 29 12:16:53 UTC 2021
This patch adds support for the STM32H743ZI-Nucleo board
variation. This currently works by setting the STM32H743ZI_NUCLEO
flag in the config.ini flag
It also adds basic lwIP support which can be enabled
with the flag STM32H7_ADD_LWIP. This enables certain functionalities
required for lwIP to work properly
This patch also changes the default implementation
of HAL_GetTick to return the system tick by forwarding the call
to the respective RTEMS function.
 bsps/arm/stm32h7/console/console-usart3-cfg.c | 21 ++++++++++++++++
 bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c      | 16 ++++++++-----
 .../stm32h7/include/Legacy/stm32_hal_legacy.h |  4 +++-
 bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 11 ++++++++-
 bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h |  1 +
 bsps/arm/stm32h7/start/bspstart.c             |  2 +-
 bsps/arm/stm32h7/start/stm32h7-hal-eth.c      |  3 +--
 spec/build/bsps/arm/stm32h7/bspstm32h7.yml    |  4 ++++
 spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 ++++++++++
 spec/build/bsps/arm/stm32h7/optlwip.yml       | 24 +++++++++++++++++++
 10 files changed, 88 insertions(+), 11 deletions(-)
 create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
 create mode 100644 spec/build/bsps/arm/stm32h7/optlwip.yml
diff --git a/bsps/arm/stm32h7/console/console-usart3-cfg.c b/bsps/arm/stm32h7/console/console-usart3-cfg.c
index b40f6da5aa..dc552610e1 100644
--- a/bsps/arm/stm32h7/console/console-usart3-cfg.c
+++ b/bsps/arm/stm32h7/console/console-usart3-cfg.c
@@ -25,12 +25,32 @@
  * POSSIBILITY OF SUCH DAMAGE.
+#ifdef __rtems__
+#include <bspopts.h>
+#endif
 #ifdef HAVE_CONFIG_H
 #include "config.h"
 #endif
 #include <stm32h7/hal.h>
+#if STM32H743ZI_NUCLEO == 1
+const stm32h7_uart_config stm32h7_usart3_config = {
+  .gpio = {
+    .regs = GPIOD,
+    .config = {
+      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
+      .Mode = GPIO_MODE_AF_PP,
+      .Pull = GPIO_NOPULL,
+      .Speed = GPIO_SPEED_FREQ_LOW,
+      .Alternate = GPIO_AF7_USART3
+  .irq = USART3_IRQn,
+  .device_index = 2
+#else
   .gpio = {
     .regs = GPIOB,
@@ -45,3 +65,4 @@ const stm32h7_uart_config stm32h7_usart3_config = {
   .irq = USART3_IRQn,
   .device_index = 2
+#endif /*  STM32H743ZI_NUCLEO == 1 */
diff --git a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
index 4f2634df5b..6c3590bce8 100644
--- a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
+++ b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
@@ -146,6 +146,10 @@
 /* Includes ------------------------------------------------------------------*/
 #include "stm32h7xx_hal.h"
+#ifdef __rtems__
+#endif
 /** @addtogroup STM32H7xx_HAL_Driver
@@ -361,10 +365,10 @@ HAL_StatusTypeDef HAL_ETH_Init(ETH_HandleTypeDef *heth)
   /*------------------ MAC, MTL and DMA default Configuration ----------------*/
   ETH_MACDMAConfig(heth);
-#ifndef __rtems__
+#if STM32H7_ADD_LWIP == 1
   /* SET DSL to 64 bit */
   MODIFY_REG(heth->Instance->DMACCR, ETH_DMACCR_DSL, ETH_DMACCR_DSL_64BIT);
-#endif /* __rtems__ */
+#endif
   /* Set Receive Buffers Length (must be a multiple of 4) */
   if ((heth->Init.RxBuffLen % 0x4U) != 0x0U)
@@ -2647,7 +2651,7 @@ static void ETH_MAC_MDIO_ClkConfig(ETH_HandleTypeDef *heth)
 static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
-#ifndef __rtems__
   ETH_DMADescTypeDef *dmatxdesc;
   uint32_t i;
@@ -2674,7 +2678,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
   /* Set Transmit Descriptor Tail pointer */
   WRITE_REG(heth->Instance->DMACTDTPR, (uint32_t) heth->Init.TxDesc);
+#endif /* STM32H7_ADD_LWIP == 1 */
@@ -2686,7 +2690,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
 static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
-#ifndef __rtems__
   ETH_DMADescTypeDef *dmarxdesc;
   uint32_t i;
@@ -2719,7 +2723,7 @@ static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
   /* Set Receive Descriptor Tail pointer Address */
   WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc + (((uint32_t)(ETH_RX_DESC_CNT - 1))*sizeof(ETH_DMADescTypeDef)))));
diff --git a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
index c311c1618e..c4fa5d7151 100644
--- a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
+++ b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
@@ -420,7 +420,9 @@
 #define TYPEPROGRAMDATA_FASTBYTE      FLASH_TYPEPROGRAMDATA_FASTBYTE
 #define TYPEPROGRAMDATA_FASTHALFWORD  FLASH_TYPEPROGRAMDATA_FASTHALFWORD
 #define TYPEPROGRAMDATA_FASTWORD      FLASH_TYPEPROGRAMDATA_FASTWORD
-#define PAGESIZE                      FLASH_PAGE_SIZE
+/* Commented out for the RTEMS BSP because there can be nameclashes with another
+similar defininition in limits.h */
+//#define PAGESIZE                      FLASH_PAGE_SIZE
 #define TYPEPROGRAM_FASTBYTE          FLASH_TYPEPROGRAM_BYTE
 #define TYPEPROGRAM_FASTHALFWORD      FLASH_TYPEPROGRAM_HALFWORD
 #define TYPEPROGRAM_FASTWORD          FLASH_TYPEPROGRAM_WORD
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
index d423e4f782..b608188b4f 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
@@ -21,6 +21,9 @@
 #ifndef __STM32H7xx_HAL_CONF_H
 #define __STM32H7xx_HAL_CONF_H
+#ifdef __rtems__
+#endif /* __rtems__ */
 #ifdef __cplusplus
  extern "C" {
 #endif
@@ -103,7 +106,13 @@
   *        (when HSE is used as system clock source, directly or through the PLL).
 #if !defined  (HSE_VALUE)
-#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+  #if STM32H743ZI_NUCLEO == 1
+    /*!< External oscillator clock for the STM32H743ZI Nucleo */
+    #define HSE_VALUE    ((uint32_t)8000000)
+  #else
+    /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
+    #define HSE_VALUE    ((uint32_t)25000000)
+  #endif /* STM32H743ZI_NUCLEO == 1 */
 #endif /* HSE_VALUE */
 #if !defined  (HSE_STARTUP_TIMEOUT)
diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
index e9fecc4aa0..b171f7dac7 100644
--- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
+++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
@@ -27,6 +27,7 @@ extern "C" {
 #include "stm32h7xx_hal_def.h"
+#include "stm32h7xx_hal_dma.h"
diff --git a/bsps/arm/stm32h7/start/bspstart.c b/bsps/arm/stm32h7/start/bspstart.c
index 2fc8133cca..d942fbdcb3 100644
--- a/bsps/arm/stm32h7/start/bspstart.c
+++ b/bsps/arm/stm32h7/start/bspstart.c
@@ -34,7 +34,7 @@
 uint32_t HAL_GetTick(void)
-  return 0;
+  return rtems_clock_get_ticks_since_boot();
 uint32_t stm32h7_systick_frequency(void)
diff --git a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
index 46475f4316..36363f84a5 100644
--- a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
+++ b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
@@ -64,8 +64,7 @@ static const stm32h7_gpio_config gpioa = {
-void
-HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
+void HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
   stm32h7_clk_enable(STM32H7_MODULE_ETH1MAC);
   stm32h7_clk_enable(STM32H7_MODULE_ETH1TX);
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
index 80e13472c8..89b5a3c00d 100644
--- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
@@ -247,6 +247,10 @@ links:
   uid: ../../optconsolebaud
 - role: build-dependency
   uid: ../../optconsoleirq
+- role: build-dependency
+  uid: opth743nucleo
+  uid: optlwip
   uid: ../grp
diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
new file mode 100644
index 0000000000..2c4176bf00
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
@@ -0,0 +1,13 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+default: false
+default-by-variant: []
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H743ZI_NUCLEO
+description: |
+  Nucleo board. Use 8 MHz HSE external clock and different pins for the UART console.
+type: build
diff --git a/spec/build/bsps/arm/stm32h7/optlwip.yml b/spec/build/bsps/arm/stm32h7/optlwip.yml
index 0000000000..04613a3bb6
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/optlwip.yml
@@ -0,0 +1,24 @@
+actions:
+- env-assign: null
+build-type: option
+default: false
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H7_ADD_LWIP
+description: |
+  This changes the code to allow lwIP to work properly based on the STM32 lwIP example.
+  The user must take care of the following steps in the application:
+   1. The lwIP DMA descriptors have to be placed into the .bsp_no_cache section instead
+      of custom sections
+   2. The sections need to be aligned to 32 bytes (0x20) boundaries
+  This can be achieved by appending
+    __attribute__((section(.bsp_no_cache),__aligned__(0x20)));
+  to the descriptor definitions.
+type: build
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+copyrights:
+- Copyright (C) 2020 Robin Mueller
2.23.0.windows.1
