[PATCH] STM32H743ZI Nucleo and basic lwIP support
Gedare Bloom
gedare at rtems.org
Mon Mar 29 15:52:02 UTC 2021
On Mon, Mar 29, 2021 at 6:17 AM Robin Mueller <robin.mueller.m at gmail.com> wrote:
> This patch adds support for the STM32H743ZI-Nucleo board
> variation. This currently works by setting the STM32H743ZI_NUCLEO
> flag in the config.ini flag
> It also adds basic lwIP support which can be enabled
> with the flag STM32H7_ADD_LWIP. This enables certain functionalities
> required for lwIP to work properly
> This patch also changes the default implementation
> of HAL_GetTick to return the system tick by forwarding the call
> to the respective RTEMS function.
> bsps/arm/stm32h7/console/console-usart3-cfg.c | 21 ++++++++++++++++
> bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c | 16 ++++++++-----
> .../stm32h7/include/Legacy/stm32_hal_legacy.h | 4 +++-
> bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 11 ++++++++-
> bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h | 1 +
> bsps/arm/stm32h7/start/bspstart.c | 2 +-
> bsps/arm/stm32h7/start/stm32h7-hal-eth.c | 3 +--
> spec/build/bsps/arm/stm32h7/bspstm32h7.yml | 4 ++++
> spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 ++++++++++
> spec/build/bsps/arm/stm32h7/optlwip.yml | 24 +++++++++++++++++++
> 10 files changed, 88 insertions(+), 11 deletions(-)
> create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> create mode 100644 spec/build/bsps/arm/stm32h7/optlwip.yml
> diff --git a/bsps/arm/stm32h7/console/console-usart3-cfg.c b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> index b40f6da5aa..dc552610e1 100644
> --- a/bsps/arm/stm32h7/console/console-usart3-cfg.c
> +++ b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> @@ -25,12 +25,32 @@
> * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef __rtems__
> +#include <bspopts.h>
> +#endif
> #ifdef HAVE_CONFIG_H
> #include "config.h"
> #endif
> #include <stm32h7/hal.h>
> +#if STM32H743ZI_NUCLEO == 1
> +const stm32h7_uart_config stm32h7_usart3_config = {
> + .gpio = {
> + .regs = GPIOD,
> + .config = {
> + .Pin = GPIO_PIN_8 | GPIO_PIN_9,
> + .Mode = GPIO_MODE_AF_PP,
> + .Pull = GPIO_NOPULL,
> + .Speed = GPIO_SPEED_FREQ_LOW,
> + .Alternate = GPIO_AF7_USART3
> + .irq = USART3_IRQn,
> + .device_index = 2
> +#else
> .gpio = {
> .regs = GPIOB,
> @@ -45,3 +65,4 @@ const stm32h7_uart_config stm32h7_usart3_config = {
> .irq = USART3_IRQn,
> .device_index = 2
> +#endif /* STM32H743ZI_NUCLEO == 1 */
> diff --git a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> index 4f2634df5b..6c3590bce8 100644
> --- a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> +++ b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> @@ -146,6 +146,10 @@
> /* Includes ------------------------------------------------------------------*/
> #include "stm32h7xx_hal.h"
> +#ifdef __rtems__
> +#endif
> /** @addtogroup STM32H7xx_HAL_Driver
> @@ -361,10 +365,10 @@ HAL_StatusTypeDef HAL_ETH_Init(ETH_HandleTypeDef *heth)
> /*------------------ MAC, MTL and DMA default Configuration ----------------*/
> ETH_MACDMAConfig(heth);
> -#ifndef __rtems__
> +#if STM32H7_ADD_LWIP == 1
Someone else may be able to address whether we need to disable this
stuff for 'non-lwip' builds of stm32. There is an ongoing effort to
collect lwip drivers and lwip build as a library after building rtems,
so maybe this will move eventually to the lwip driver repo when that
gets into production.
> /* SET DSL to 64 bit */
> MODIFY_REG(heth->Instance->DMACCR, ETH_DMACCR_DSL, ETH_DMACCR_DSL_64BIT);
> -#endif /* __rtems__ */
> +#endif
> /* Set Receive Buffers Length (must be a multiple of 4) */
> if ((heth->Init.RxBuffLen % 0x4U) != 0x0U)
> @@ -2647,7 +2651,7 @@ static void ETH_MAC_MDIO_ClkConfig(ETH_HandleTypeDef *heth)
> static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> -#ifndef __rtems__
> ETH_DMADescTypeDef *dmatxdesc;
> uint32_t i;
> @@ -2674,7 +2678,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> /* Set Transmit Descriptor Tail pointer */
> WRITE_REG(heth->Instance->DMACTDTPR, (uint32_t) heth->Init.TxDesc);
> +#endif /* STM32H7_ADD_LWIP == 1 */
> @@ -2686,7 +2690,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
> -#ifndef __rtems__
> ETH_DMADescTypeDef *dmarxdesc;
> uint32_t i;
> @@ -2719,7 +2723,7 @@ static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
> /* Set Receive Descriptor Tail pointer Address */
> WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc + (((uint32_t)(ETH_RX_DESC_CNT - 1))*sizeof(ETH_DMADescTypeDef)))));
> diff --git a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> index c311c1618e..c4fa5d7151 100644
> --- a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> +++ b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> @@ -420,7 +420,9 @@
> #define TYPEPROGRAMDATA_FASTBYTE FLASH_TYPEPROGRAMDATA_FASTBYTE
> #define TYPEPROGRAMDATA_FASTHALFWORD FLASH_TYPEPROGRAMDATA_FASTHALFWORD
> #define TYPEPROGRAMDATA_FASTWORD FLASH_TYPEPROGRAMDATA_FASTWORD
Can you instead use:
#ifndef __rtems___
> -#define PAGESIZE FLASH_PAGE_SIZE
> +/* Commented out for the RTEMS BSP because there can be nameclashes with another
> +similar defininition in limits.h */
> +//#define PAGESIZE FLASH_PAGE_SIZE
#endif
> #define TYPEPROGRAM_FASTBYTE FLASH_TYPEPROGRAM_BYTE
> #define TYPEPROGRAM_FASTHALFWORD FLASH_TYPEPROGRAM_HALFWORD
> #define TYPEPROGRAM_FASTWORD FLASH_TYPEPROGRAM_WORD
> diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> index d423e4f782..b608188b4f 100644
> --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> @@ -21,6 +21,9 @@
> #ifndef __STM32H7xx_HAL_CONF_H
> #define __STM32H7xx_HAL_CONF_H
> +#ifdef __rtems__
> +#endif /* __rtems__ */
> #ifdef __cplusplus
> extern "C" {
> #endif
> @@ -103,7 +106,13 @@
> * (when HSE is used as system clock source, directly or through the PLL).
> #if !defined (HSE_VALUE)
> -#define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
> + #if STM32H743ZI_NUCLEO == 1
> + /*!< External oscillator clock for the STM32H743ZI Nucleo */
> + #define HSE_VALUE ((uint32_t)8000000)
> + #else
> + /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
> + #define HSE_VALUE ((uint32_t)25000000)
> + #endif /* STM32H743ZI_NUCLEO == 1 */
> #endif /* HSE_VALUE */
> #if !defined (HSE_STARTUP_TIMEOUT)
> diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> index e9fecc4aa0..b171f7dac7 100644
> --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> @@ -27,6 +27,7 @@ extern "C" {
> #include "stm32h7xx_hal_def.h"
> +#include "stm32h7xx_hal_dma.h"
> diff --git a/bsps/arm/stm32h7/start/bspstart.c b/bsps/arm/stm32h7/start/bspstart.c
> index 2fc8133cca..d942fbdcb3 100644
> --- a/bsps/arm/stm32h7/start/bspstart.c
> +++ b/bsps/arm/stm32h7/start/bspstart.c
> @@ -34,7 +34,7 @@
> uint32_t HAL_GetTick(void)
> - return 0;
> + return rtems_clock_get_ticks_since_boot();
> uint32_t stm32h7_systick_frequency(void)
> diff --git a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> index 46475f4316..36363f84a5 100644
> --- a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> +++ b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> @@ -64,8 +64,7 @@ static const stm32h7_gpio_config gpioa = {
> -void
> -HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
> +void HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
why this change?
> stm32h7_clk_enable(STM32H7_MODULE_ETH1MAC);
> stm32h7_clk_enable(STM32H7_MODULE_ETH1TX);
> diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> index 80e13472c8..89b5a3c00d 100644
> --- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> +++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> @@ -247,6 +247,10 @@ links:
> uid: ../../optconsolebaud
> - role: build-dependency
> uid: ../../optconsoleirq
> +- role: build-dependency
> + uid: opth743nucleo
> + uid: optlwip
> uid: ../grp
> diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> new file mode 100644
> index 0000000000..2c4176bf00
> --- /dev/null
> +++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> @@ -0,0 +1,13 @@
> +actions:
> +- get-boolean: null
> +- define-condition: null
> +build-type: option
> +default: false
> +default-by-variant: []
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: STM32H743ZI_NUCLEO
> +description: |
> + Nucleo board. Use 8 MHz HSE external clock and different pins for the UART console.
> +type: build
> diff --git a/spec/build/bsps/arm/stm32h7/optlwip.yml b/spec/build/bsps/arm/stm32h7/optlwip.yml
> index 0000000000..04613a3bb6
> --- /dev/null
> +++ b/spec/build/bsps/arm/stm32h7/optlwip.yml
> @@ -0,0 +1,24 @@
> +actions:
> +- env-assign: null
> +build-type: option
> +default: false
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: STM32H7_ADD_LWIP
> +description: |
> + This changes the code to allow lwIP to work properly based on the STM32 lwIP example.
> + The user must take care of the following steps in the application:
> + 1. The lwIP DMA descriptors have to be placed into the .bsp_no_cache section instead
> + of custom sections
> + 2. The sections need to be aligned to 32 bytes (0x20) boundaries
> + This can be achieved by appending
> + __attribute__((section(.bsp_no_cache),__aligned__(0x20)));
> + to the descriptor definitions.
> +type: build
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +copyrights:
> +- Copyright (C) 2020 Robin Mueller
> 2.23.0.windows.1
> devel mailing list
> devel at rtems.org
