Two Resource Leaks
Richi Dubey
richidubey at gmail.com
Mon Mar 29 12:55:54 UTC 2021
https://docs.google.com/spreadsheets/d/12FkAE6Wvo0dDw9D75p-w8UISc8_aOKQqntvruGGdeN4/edit#gid=0
This sheet has rtems-test result comparisons between different SMP
schedulers set as default schedulers and has results from last the 2
months. This might be of help to you.
On Sat, Mar 27, 2021 at 9:50 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 27, 2021, 11:07 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 27/03/2021 16:08, Joel Sherrill wrote:
>> > The issue I found is different and won't happen on every target or
>> > bsp.
>> > Psim has 6-9 failures even after freeing the right stack address.
>> > The stack address and now (I think) size saved for later use are wrong
>> > and this leads to multiple failures.
>> I work on a fix. psim seems to be a good platform for these tests.
> I put a patch for the address issue but I think the fundamental issue is
> you changed the semantics of what was stored in the stack structure. You
> probably want a different approach but this is at least a good
> temporary fix.
> And something different on Libbsd. But not sure.
> I think Richi has raised the issue that there are some recently introduced
> failures. Not sure how many are this.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210329/f4f35515/attachment.html>
