#3860 - GSoC enquiries
Ida Delphine
idadelm at gmail.com
Mon Mar 29 13:35:31 UTC 2021
Hello,
Please do you mind telling me how to run uncrustify with the given
configuration with any sample file?
I'm a bit stuck.
Thanks,
Ida.
On Wed, Mar 17, 2021 at 10:34 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 17, 2021 at 2:28 PM Ida Delphine <idadelm at gmail.com> wrote:
> > Hello,
> > So I have gone through this configuration file and I think I'm getting
> it. However I'm a bit lost in the reading the messages in the thread. Do
> you mind explaining? Or we can start talking about a way forward.
> > Also can you help me with some steps on how to test this by myself if
> possible?
> It may be easier if you go "up" a level to see the full thread
> context:
> https://lists.rtems.org/pipermail/devel/2020-October/thread.html#62769
> Then you can go through the messages non-linearly. Right now, the
> basic idea is to follow the steps outlined in the open project ticket.
> I think Christian has summarized it nicely in his recent email [1]: "I
> think the contributions from this project that would add value would
> be:
> 1. Finding a tool and a configuration that can do an RTEMS style or an
> acceptable close one.
> 2. Adding a "check-style" target to our build system.
> 3. Maybe add some kind of script similar to Linux "checkpatch.pl" that
> could check whether patches would need changes _before_ they are
> applied.
> The proposal preparation phase should work through identifying the
> options and pros/cons for different tools while preparing a plan for
> how to integrate style checks in 2, 3 and thinking through the coding
> tasks for the summer.
> Getting the style checking tool's configuration to match with the
> RTEMS style will be some effort, and testing it out and submitting
> some patches based on it could be a good proposal activity also to
> build some confidence about the tools that will be used.
> We also have some Python style guidelines that might be worth
> addressing. Those are harder maybe, since the style refactoring might
> be challenging to review for correctness.
> For getting started, I would recommend that you try running uncrustify
> with the given configuration on some files in RTEMS, see what it
> results in. Play around.
> [1] https://lists.rtems.org/pipermail/devel/2021-March/065547.html
> -Gedare
> > Thanks,
> > Ida
> > On Mon, Mar 15, 2021 at 9:39 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> See the related thread, and we'll have to discuss how to move forward.
> >> The existing approach provides an uncrustify script:
> >> https://lists.rtems.org/pipermail/devel/2020-October/062769.html
> >> On Sun, Mar 14, 2021 at 9:47 PM Ida Delphine <idadelm at gmail.com> wrote:
> >> > Hello everyone,
> >> > This ticket(https://devel.rtems.org/ticket/3860) was proposed to me
> and I'm interested in it for GSoC.
> >> > The first task there is to find a code checker or formater that can
> produce results that match the RTEMS coding conventions. It also made
> mention some tools have been discussed in the past. Please I will love
> suggestions on possible tools I could use to achieve this.
> >> > Cheers,
> >> > Ida.
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210329/50ec75a5/attachment-0001.html>
