[PATCH rtems-examples] lvgl/wscript: Add libpath to search for required libraries
Mon Mar 29 16:09:43 UTC 2021
On Mon, Mar 29, 2021 at 9:20 AM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi,
> Is this OK to push? This only affects lvgl.
You're a  maintainer of lvgl repo, so you can make that decision yourself ;)
> Best regards,
> Vijay
> On Fri, Mar 26, 2021 at 2:47 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> >  lvgl/wscript | 12 ++++++++++--
> >  1 file changed, 10 insertions(+), 2 deletions(-)
> > diff --git a/lvgl/wscript b/lvgl/wscript
> > index 064ebed..281af25 100644
> > --- a/lvgl/wscript
> > +++ b/lvgl/wscript
> > @@ -5,11 +5,19 @@
> >  import rtems_waf.rtems as rtems
> >  import rtems_waf.rtems_bsd as rtems_bsd
> > +import os
> >  def configure(conf):
> > +    arch_lib_path = rtems.arch_bsp_lib_path(str(conf.env.RTEMS_VERSION),
> > +                                                str(conf.env.RTEMS_ARCH_BSP))
> > +    arch_lib_path = os.path.join(conf.env.PREFIX, arch_lib_path)
> >      rtems.check_lib_path(conf, lib = 'm')
> > -    rtems.check_lib_path(conf, lib = 'lvgl', mandatory = False)
> > -    rtems.check_lib_path(conf, lib = 'bsd', mandatory = False)
> > +    rtems.check_lib_path(conf, lib = 'lvgl',
> > +                         libpath = [arch_lib_path],
> > +                         mandatory = False)
> > +    rtems.check_lib_path(conf, lib = 'bsd',
> >  def build(bld):
> >      bld.recurse('hello')
> > 2.26.2
> devel mailing list
> devel at rtems.org
