[PATCH rtems-docs] User/BSPs/Beagle: Add JTAG debugger section
Christian Mauderer oss at c-mauderer.de
Mon Mar 29 18:13:26 UTC 2021
 user/bsps/arm/beagle.rst | 67 ++++++++++++++++++++++++++++++++++++++--
 1 file changed, 65 insertions(+), 2 deletions(-)
diff --git a/user/bsps/arm/beagle.rst b/user/bsps/arm/beagle.rst
index ac49b1c..dedd01b 100644
--- a/user/bsps/arm/beagle.rst
+++ b/user/bsps/arm/beagle.rst
@@ -102,8 +102,8 @@ The function prototype is given below:
        rtems_vector_number irq
-Debugging
+Debugging using libdebugger
 RTEMS's ``libdebugger`` requires the ARM debug resources be enabled for it to
 work. The TI SOC used on the ``beagleboneblack`` board provides no access for
@@ -162,3 +162,66 @@ If ``libdebugger`` fails to detect the registers open the ``bspdebug.c``
 source and change ``has_tdo`` to ``1``, save then rebuild and install the
 BSP. This will turn on an internal feeback to check the JTAG logic. Discard
 the edit once the hardware is working.
+Debugging Beagle Bone Black using a JTAG debugger and gdb
+Debugging a Beagle Bone Black (or variants) is also possible using a hardware
+JTAG debugger. The JTAG is available via P2. The connector is thought for a
+ARM 20 pin cTI connector. That connector should be used, if it is relevant to
+have access to commercially available adapters.
+For hand-made cables and adapters a standard 1.27mm pitch header and a 0.635mm
+ribbon cable can be much cheaper. But note that even if it looks compatible,
+it's not the same pin out as a ARM Cortex 20 pin connector!
+A lot of JTAG adapters that are working together with OpenOCD will work. There
+are also commercially available systems (like Segger J-Link) that work well with
+the Beagle. Note that the JTAG debugger has to be compatible with ARM Cortex A8.
+Cortex M only debuggers (like the Segger J-Link Edu Mini) won't work.
+If the debugger offers a gdb server (like OpenOCD or Segger J-Link) the
+following gdb start script can be used:
+.. code-block::
+    define reset
+            echo -- Reset target and wait for U-Boot to start kernel.\n
+            monitor reset
+            # RTEMS U-Boot starts at this address.
+            tbreak *0x80000000
+            # Linux starts here.
+            tbreak *0x82000000
+            continue
+            echo -- Disable watchdog.\n
+            set *(uint32_t*)0x44e35048=0xAAAA
+            while (*(uint32_t*)0x44e35034 != 0)
+            end
+            set *(uint32_t*)0x44e35048=0x5555
+            end
+            echo -- Overwrite kernel with application to debug.\n
+            load
+    end
+    target remote :2331
+Note that you might have to replace the ``monitor reset`` by some other command
+that resets the target using your specific debugger. You also have to replace
+the ``target remote :2331`` to match the port of your gdb server.
+The script expects that the Beagle Bone Black starts some application from an SD
+card or from eMMC. It defines a ``reset`` command that does the following:
+ * reset the target
+ * let U-Boot run, initialize the base system, load an FDT and an application
+ * break at the application entry point
+ * disable the watchdog
+ * overwrite the application that has been loaded by U-Boot with the application
+   provided as an command line argument to gdb
+This method has the advantage that the application is executed in nearly exact
+the same environment like it would be executed if loaded by U-Boot directly
+(except for the watchdog).
2.30.2
