[PATCH] STM32H743ZI Nucleo and basic lwIP support
Vijay Kumar Banerjee vijay at rtems.org
Mon Mar 29 20:25:34 UTC 2021
On Mon, Mar 29, 2021 at 9:52 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Mar 29, 2021 at 6:17 AM Robin Mueller <robin.mueller.m at gmail.com> wrote:
> > This patch adds support for the STM32H743ZI-Nucleo board
> > variation. This currently works by setting the STM32H743ZI_NUCLEO
> > flag in the config.ini flag
> > It also adds basic lwIP support which can be enabled
> > with the flag STM32H7_ADD_LWIP. This enables certain functionalities
> > required for lwIP to work properly
> > This patch also changes the default implementation
> > of HAL_GetTick to return the system tick by forwarding the call
> > to the respective RTEMS function.
> >  bsps/arm/stm32h7/console/console-usart3-cfg.c | 21 ++++++++++++++++
> >  bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c      | 16 ++++++++-----
> >  .../stm32h7/include/Legacy/stm32_hal_legacy.h |  4 +++-
> >  bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h | 11 ++++++++-
> >  bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h |  1 +
> >  bsps/arm/stm32h7/start/bspstart.c             |  2 +-
> >  bsps/arm/stm32h7/start/stm32h7-hal-eth.c      |  3 +--
> >  spec/build/bsps/arm/stm32h7/bspstm32h7.yml    |  4 ++++
> >  spec/build/bsps/arm/stm32h7/opth743nucleo.yml | 13 ++++++++++
> >  spec/build/bsps/arm/stm32h7/optlwip.yml       | 24 +++++++++++++++++++
> >  10 files changed, 88 insertions(+), 11 deletions(-)
> >  create mode 100644 spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> >  create mode 100644 spec/build/bsps/arm/stm32h7/optlwip.yml
> > diff --git a/bsps/arm/stm32h7/console/console-usart3-cfg.c b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> > index b40f6da5aa..dc552610e1 100644
> > --- a/bsps/arm/stm32h7/console/console-usart3-cfg.c
> > +++ b/bsps/arm/stm32h7/console/console-usart3-cfg.c
> > @@ -25,12 +25,32 @@
> >   * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef __rtems__
> > +#include <bspopts.h>
> > +#endif
> >  #ifdef HAVE_CONFIG_H
> >  #include "config.h"
> >  #endif
> >  #include <stm32h7/hal.h>
> > +#if STM32H743ZI_NUCLEO == 1
> > +const stm32h7_uart_config stm32h7_usart3_config = {
> > +  .gpio = {
> > +    .regs = GPIOD,
> > +    .config = {
> > +      .Pin = GPIO_PIN_8 | GPIO_PIN_9,
> > +      .Mode = GPIO_MODE_AF_PP,
> > +      .Pull = GPIO_NOPULL,
> > +      .Speed = GPIO_SPEED_FREQ_LOW,
> > +      .Alternate = GPIO_AF7_USART3
> > +  .irq = USART3_IRQn,
> > +  .device_index = 2
> > +#else
> >    .gpio = {
> >      .regs = GPIOB,
> > @@ -45,3 +65,4 @@ const stm32h7_uart_config stm32h7_usart3_config = {
> >    .irq = USART3_IRQn,
> >    .device_index = 2
> > +#endif /*  STM32H743ZI_NUCLEO == 1 */
> > diff --git a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> > index 4f2634df5b..6c3590bce8 100644
> > --- a/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> > +++ b/bsps/arm/stm32h7/hal/stm32h7xx_hal_eth.c
> > @@ -146,6 +146,10 @@
> >  /* Includes ------------------------------------------------------------------*/
> >  #include "stm32h7xx_hal.h"
> > +#ifdef __rtems__
> > +#endif
> >  /** @addtogroup STM32H7xx_HAL_Driver
> > @@ -361,10 +365,10 @@ HAL_StatusTypeDef HAL_ETH_Init(ETH_HandleTypeDef *heth)
> >    /*------------------ MAC, MTL and DMA default Configuration ----------------*/
> >    ETH_MACDMAConfig(heth);
> > -#ifndef __rtems__
> > +#if STM32H7_ADD_LWIP == 1
> Someone else may be able to address whether we need to disable this
> stuff for 'non-lwip' builds of stm32. There is an ongoing effort to
> collect lwip drivers and lwip build as a library after building rtems,
> so maybe this will move eventually to the lwip driver repo when that
> gets into production.
Hi,
Yes, we're moving all the network stacks out of RTEMS so that a user
can choose their preferred network stack to work with RTEMS. The LWIP
repository is in initial state and it is gradually starting to include
the drivers. This lwip patch would be a great start of adding the
drivers and I'm happy to work with you to get it integrated into that
repository. Would you be interested in taking a look at it and adding
it to the rtems-lwip repository?
https://git.rtems.org/vijay/rtems-lwip.git/
Once this is in a working state, this repository will be added to
rtems top directory as official rtems-lwip.
Best regards,
Vijay
> >    /* SET DSL to 64 bit */
> >    MODIFY_REG(heth->Instance->DMACCR, ETH_DMACCR_DSL, ETH_DMACCR_DSL_64BIT);
> > -#endif /* __rtems__ */
> > +#endif
> >    /* Set Receive Buffers Length (must be a multiple of 4) */
> >    if ((heth->Init.RxBuffLen % 0x4U) != 0x0U)
> > @@ -2647,7 +2651,7 @@ static void ETH_MAC_MDIO_ClkConfig(ETH_HandleTypeDef *heth)
> >  static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> > -#ifndef __rtems__
> >    ETH_DMADescTypeDef *dmatxdesc;
> >    uint32_t i;
> > @@ -2674,7 +2678,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> >    /* Set Transmit Descriptor Tail pointer */
> >    WRITE_REG(heth->Instance->DMACTDTPR, (uint32_t) heth->Init.TxDesc);
> > +#endif /* STM32H7_ADD_LWIP == 1 */
> > @@ -2686,7 +2690,7 @@ static void ETH_DMATxDescListInit(ETH_HandleTypeDef *heth)
> >  static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
> > -#ifndef __rtems__
> >    ETH_DMADescTypeDef *dmarxdesc;
> >    uint32_t i;
> > @@ -2719,7 +2723,7 @@ static void ETH_DMARxDescListInit(ETH_HandleTypeDef *heth)
> >    /* Set Receive Descriptor Tail pointer Address */
> >    WRITE_REG(heth->Instance->DMACRDTPR, ((uint32_t)(heth->Init.RxDesc + (((uint32_t)(ETH_RX_DESC_CNT - 1))*sizeof(ETH_DMADescTypeDef)))));
> > diff --git a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> > index c311c1618e..c4fa5d7151 100644
> > --- a/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> > +++ b/bsps/arm/stm32h7/include/Legacy/stm32_hal_legacy.h
> > @@ -420,7 +420,9 @@
> >  #define TYPEPROGRAMDATA_FASTBYTE      FLASH_TYPEPROGRAMDATA_FASTBYTE
> >  #define TYPEPROGRAMDATA_FASTHALFWORD  FLASH_TYPEPROGRAMDATA_FASTHALFWORD
> >  #define TYPEPROGRAMDATA_FASTWORD      FLASH_TYPEPROGRAMDATA_FASTWORD
> Can you instead use:
> #ifndef __rtems___
> > -#define PAGESIZE                      FLASH_PAGE_SIZE
> > +/* Commented out for the RTEMS BSP because there can be nameclashes with another
> > +similar defininition in limits.h */
> > +//#define PAGESIZE                      FLASH_PAGE_SIZE
> #endif
> >  #define TYPEPROGRAM_FASTBYTE          FLASH_TYPEPROGRAM_BYTE
> >  #define TYPEPROGRAM_FASTHALFWORD      FLASH_TYPEPROGRAM_HALFWORD
> >  #define TYPEPROGRAM_FASTWORD          FLASH_TYPEPROGRAM_WORD
> > diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> > index d423e4f782..b608188b4f 100644
> > --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> > +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h
> > @@ -21,6 +21,9 @@
> >  #ifndef __STM32H7xx_HAL_CONF_H
> >  #define __STM32H7xx_HAL_CONF_H
> > +#ifdef __rtems__
> > +#endif /* __rtems__ */
> >  #ifdef __cplusplus
> >   extern "C" {
> >  #endif
> > @@ -103,7 +106,13 @@
> >    *        (when HSE is used as system clock source, directly or through the PLL).
> >  #if !defined  (HSE_VALUE)
> > -#define HSE_VALUE    ((uint32_t)25000000) /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
> > +  #if STM32H743ZI_NUCLEO == 1
> > +    /*!< External oscillator clock for the STM32H743ZI Nucleo */
> > +    #define HSE_VALUE    ((uint32_t)8000000)
> > +  #else
> > +    /*!< Value of the External oscillator in Hz : FPGA case fixed to 60MHZ */
> > +    #define HSE_VALUE    ((uint32_t)25000000)
> > +  #endif /* STM32H743ZI_NUCLEO == 1 */
> >  #endif /* HSE_VALUE */
> >  #if !defined  (HSE_STARTUP_TIMEOUT)
> > diff --git a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> > index e9fecc4aa0..b171f7dac7 100644
> > --- a/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> > +++ b/bsps/arm/stm32h7/include/stm32h7xx_hal_uart.h
> > @@ -27,6 +27,7 @@ extern "C" {
> >  #include "stm32h7xx_hal_def.h"
> > +#include "stm32h7xx_hal_dma.h"
> > diff --git a/bsps/arm/stm32h7/start/bspstart.c b/bsps/arm/stm32h7/start/bspstart.c
> > index 2fc8133cca..d942fbdcb3 100644
> > --- a/bsps/arm/stm32h7/start/bspstart.c
> > +++ b/bsps/arm/stm32h7/start/bspstart.c
> > @@ -34,7 +34,7 @@
> >  uint32_t HAL_GetTick(void)
> > -  return 0;
> > +  return rtems_clock_get_ticks_since_boot();
> >  uint32_t stm32h7_systick_frequency(void)
> > diff --git a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> > index 46475f4316..36363f84a5 100644
> > --- a/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> > +++ b/bsps/arm/stm32h7/start/stm32h7-hal-eth.c
> > @@ -64,8 +64,7 @@ static const stm32h7_gpio_config gpioa = {
> > -void
> > -HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
> > +void HAL_ETH_MspInit(ETH_HandleTypeDef *heth)
> why this change?
> >    stm32h7_clk_enable(STM32H7_MODULE_ETH1MAC);
> >    stm32h7_clk_enable(STM32H7_MODULE_ETH1TX);
> > diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> > index 80e13472c8..89b5a3c00d 100644
> > --- a/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> > +++ b/spec/build/bsps/arm/stm32h7/bspstm32h7.yml
> > @@ -247,6 +247,10 @@ links:
> >    uid: ../../optconsolebaud
> >  - role: build-dependency
> >    uid: ../../optconsoleirq
> > +- role: build-dependency
> > +  uid: opth743nucleo
> > +  uid: optlwip
> >    uid: ../grp
> > diff --git a/spec/build/bsps/arm/stm32h7/opth743nucleo.yml b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> > new file mode 100644
> > index 0000000000..2c4176bf00
> > --- /dev/null
> > +++ b/spec/build/bsps/arm/stm32h7/opth743nucleo.yml
> > @@ -0,0 +1,13 @@
> > +actions:
> > +- get-boolean: null
> > +- define-condition: null
> > +build-type: option
> > +default: false
> > +default-by-variant: []
> > +enabled-by: true
> > +format: '{}'
> > +links: []
> > +name: STM32H743ZI_NUCLEO
> > +description: |
> > +  Nucleo board. Use 8 MHz HSE external clock and different pins for the UART console.
> > +type: build
> > diff --git a/spec/build/bsps/arm/stm32h7/optlwip.yml b/spec/build/bsps/arm/stm32h7/optlwip.yml
> > index 0000000000..04613a3bb6
> > --- /dev/null
> > +++ b/spec/build/bsps/arm/stm32h7/optlwip.yml
> > @@ -0,0 +1,24 @@
> > +actions:
> > +- env-assign: null
> > +build-type: option
> > +default: false
> > +enabled-by: true
> > +format: '{}'
> > +links: []
> > +name: STM32H7_ADD_LWIP
> > +description: |
> > +  This changes the code to allow lwIP to work properly based on the STM32 lwIP example.
> > +  The user must take care of the following steps in the application:
> > +   1. The lwIP DMA descriptors have to be placed into the .bsp_no_cache section instead
> > +      of custom sections
> > +   2. The sections need to be aligned to 32 bytes (0x20) boundaries
> > +  This can be achieved by appending
> > +    __attribute__((section(.bsp_no_cache),__aligned__(0x20)));
> > +  to the descriptor definitions.
> > +type: build
> > +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > +copyrights:
> > +- Copyright (C) 2020 Robin Mueller
> > 2.23.0.windows.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
