[Beagle BSP] How to run all tests on a Beaglebone Black in an automated way
Christian Mauderer
oss at c-mauderer.de
Mon Mar 29 18:14:28 UTC 2021
On 29/03/2021 00:29, Chris Johns wrote:
> On 28/3/21 8:04 pm, Christian Mauderer wrote:
>> On 28/03/2021 03:16, Chris Johns wrote:
>>> On 28/3/21 6:16 am, Ahamed Husni wrote:
>>>> Hi,
>>>> I ran the hello program on the BBB using a bootable SD card. The SD card has two
>>>> partitions.
>>>> 1. BOOT - primary, bootable, FAT32
>>>> 2. ROOT - primary, ext4
>>>> The BOOT partition has the following files.
>>>> 1. uEnv.txt
>>>> 2. rtems-app.img
>>>> 3. Device Tree Blob (am335x-boneblack.dtb)
>>>> I want to run all the tests on the BBB. Is there any other way to do this?
>>>> You have to get the BBB to fetch exes from a ftftp server (provided inside
>>>> rtems-test) and provide some automated power control to the board.
>>>> - Dr. Joel (in Discord)
>>> Please have a look at ..
>>> https://docs.rtems.org/branches/master/user/testing/configuration.html
>>> https://docs.rtems.org/branches/master/user/testing/tftp.html
>>> Chris
>> Like Chris pointed out, the testing documentation is a good start point if you
>> want to automate running tests.
> Thanks. We are talking about an online tut session to work through running the
> tests on real hardware as a practical demonstration. I am not sure how we run
> this and what we need to handle doing this.
>> Beneath using TFTP for the Beagle you could also use a JTAG debugger to load the
>> application if you have one. As far as I know, the tester is quite flexible
>> regarding how to load an application.
>> If your JTAG debugger has an GDB interface, you could use about the following
>> commands for beagle (you have to adapt "monitor reset" to whatever causes a
>> reset with your JTAG hardware):
>> define reset
>> echo -- Reset target and wait for U-Boot to start kernel.\n
>> monitor reset
>> # RTEMS starts at this address.
>> tbreak *0x80000000
>> # Linux starts here.
>> tbreak *0x82000000
>> continue
>> echo -- Disable watchdog.\n
>> set *(uint32_t*)0x44e35048=0xAAAA
>> while (*(uint32_t*)0x44e35034 != 0)
>> end
>> set *(uint32_t*)0x44e35048=0x5555
>> end
>> echo -- Overwrite kernel with application to debug.\n
>> load
>> end
> Nice. This would be a great example for the user manual :)
I've sent a patch.
Best regards
Christian
> Chris
