[PATCH rtems 01/18] Broke low-level parts of mv643xx_eth driver into separate files
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:33 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4344
bsps/powerpc/beatnik/headers.am | 1 +
.../powerpc/beatnik/include/bsp/mv643xx_eth.h | 111 +
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 1162 +-----
.../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 3519 +++++++++++++++++
c/src/lib/libbsp/powerpc/beatnik/Makefile.am | 4 +-
5 files changed, 3659 insertions(+), 1138 deletions(-)
create mode 100644 bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
create mode 100644 bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
diff --git a/bsps/powerpc/beatnik/headers.am b/bsps/powerpc/beatnik/headers.am
index 36df3cd759..8416bbd626 100644
--- a/bsps/powerpc/beatnik/headers.am
+++ b/bsps/powerpc/beatnik/headers.am
@@ -20,3 +20,4 @@ include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_em_
include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/irq.h
+include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
diff --git a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
new file mode 100644
index 0000000000..eefca62603
--- /dev/null
+++ b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
@@ -0,0 +1,111 @@
+#ifndef MV643XX_LOWLEVEL_DRIVER_H
+#define MV643XX_LOWLEVEL_DRIVER_H
+struct mveth_private;
+/* Clear multicast filters */
+void
+BSP_mve_mcast_filter_clear(struct mveth_private *mp);
+void
+BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
+void
+BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
+void
+BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
+/* Stop hardware and clean out the rings */
+void
+BSP_mve_stop_hw(struct mveth_private *mp);
+struct mveth_private *
+BSP_mve_setup_1(
+ struct mveth_private*,
+ int unit,
+ void (*isr)(void *isr_arg),
+ void *isr_arg,
+ void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
+ void *cleanup_txbuf_arg,
+ void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
+ void (*consume_rxbuf)(void *user_buf, void *closure, int len),
+ void *consume_rxbuf_arg,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+/* MAIN RX-TX ROUTINES
+ * BSP_mve_swipe_tx(): descriptor scavenger; releases mbufs
+ * BSP_mve_send_buf(): xfer mbufs from IF to chip
+ * BSP_mve_swipe_rx(): enqueue received mbufs to interface
+ * allocate new ones and yield them to the
+ * chip.
+/* clean up the TX ring freeing up buffers */
+int
+BSP_mve_swipe_tx(struct mveth_private *mp);
+int
+BSP_mve_send_buf_raw(
+ struct mveth_private *mp,
+ void *head_p,
+ int h_len,
+ void *data_p,
+ int d_len);
+/* send received buffers upwards and replace them
+ * with freshly allocated ones;
+ * ASSUMPTION: buffer length NEVER changes and is set
+ * when the ring is initialized.
+ * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
+int
+BSP_mve_swipe_rx(struct mveth_private *mp);
+rtems_id
+BSP_mve_get_tid(struct mveth_private *mp);
+int
+BSP_mve_detach(struct mveth_private *mp);
+/* Fire up the low-level driver
+ * - make sure hardware is halted
+ * - enable cache snooping
+ * - clear address filters
+ * - clear mib counters
+ * - reset phy
+ * - initialize (or reinitialize) descriptor rings
+ * - check that the firmware has set up a reasonable mac address.
+ * - generate unicast filter entry for our mac address
+ * - write register config values to the chip
+ * - start hardware (serial port and SDMA)
+void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
+/* read ethernet address from hw to buffer */
+void
+BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr);
+void
+BSP_mve_enable_irqs(struct mveth_private *mp);
+void
+BSP_mve_disable_irqs(struct mveth_private *mp);
+uint32_t
+BSP_mve_ack_irqs(struct mveth_private *mp);
+void
+BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask);
+uint32_t
+BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask);
+uint32_t
+BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
+void
+BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
+unsigned
+BSP_mve_mii_read(struct mveth_private *mp, unsigned addr);
+unsigned
+BSP_mve_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
+#endif
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index 85ab038bf5..d002fd52ce 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -74,12 +74,14 @@
* further down...
#ifndef KERNEL
#define KERNEL
#endif
#ifndef _KERNEL
#define _KERNEL
#endif
#include <rtems/bspIo.h>
@@ -88,44 +90,12 @@
#include <bsp/irq.h>
#include <bsp/gtreg.h>
#include <libcpu/byteorder.h>
-#include <sys/param.h>
-#include <sys/proc.h>
-#include <sys/socket.h>
-#include <sys/sockio.h>
-#include <dev/mii/mii.h>
-#include <net/if_var.h>
-#include <net/if_media.h>
-/* Not so nice; would be more elegant not to depend on C library but the
- * RTEMS-specific ioctl for dumping statistics needs stdio anyways.
-/*#define NDEBUG effectively removes all assertions
- * If defining NDEBUG, MAKE SURE assert() EXPRESSION HAVE NO SIDE_EFFECTS!!
- * This driver DOES have side-effects, so DONT DEFINE NDEBUG
- * Performance-critical assertions are removed by undefining MVETH_TESTING.
-#undef NDEBUG
#include <assert.h>
#include <inttypes.h>
-#include <rtems/rtems_bsdnet.h>
-#include <sys/mbuf.h>
-#include <net/ethernet.h>
-#include <net/if.h>
-#include <netinet/in.h>
-#include <netinet/if_ether.h>
-#include <rtems/rtems_mii_ioctl.h>
-#include <bsp/early_enet_link_status.h>
-#include <bsp/if_mve_pub.h>
+#include <bsp/mv643xx_eth.h>
/* CONFIGURABLE PARAMETERS */
@@ -777,41 +747,11 @@ struct mveth_private {
} mc_refcnt;
-/* stuff needed for bsdnet support */
-struct mveth_bsdsupp {
- int oif_flags; /* old / cached if_flags */
-struct mveth_softc {
- struct arpcom arpcom;
- struct mveth_bsdsupp bsd;
- struct mveth_private pvt;
/* GLOBAL VARIABLES */
#ifdef MVETH_DEBUG_TX_DUMP
int mveth_tx_dump = 0;
#endif
-/* THE array of driver/bsdnet structs */
-/* If detaching/module unloading is enabled, the main driver data
- * structure must remain in memory; hence it must reside in its own
- * 'dummy' module...
-#ifdef MVETH_DETACH_HACK
-extern
-#else
-STATIC
-#endif
-struct mveth_softc theMvEths[MV643XXETH_NUM_DRIVER_SLOTS]
-#ifndef MVETH_DETACH_HACK
-= {{{{0}},}}
-#endif
-/* daemon task id */
-STATIC rtems_id mveth_tid = 0;
/* register access protection mutex */
STATIC rtems_id mveth_mtx = 0;
#define REGLOCK() do { \
@@ -861,7 +801,6 @@ static const char *mibfmt[] = {
/* forward decls + implementation for IRQ API funcs */
static void mveth_isr(rtems_irq_hdl_param unit);
-static void mveth_isr_1(rtems_irq_hdl_param unit);
static void noop(const rtems_irq_connect_data *unused) {}
static int noop1(const rtems_irq_connect_data *unused) { return 0; }
@@ -892,40 +831,6 @@ static rtems_irq_connect_data irq_data[MAX_NUM_SLOTS] = {
-/* MII Ioctl Interface */
-STATIC unsigned
-mveth_mii_read(struct mveth_private *mp, unsigned addr);
-STATIC unsigned
-mveth_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
-/* mdio / mii interface wrappers for rtems_mii_ioctl API */
-static int mveth_mdio_r(int phy, void *uarg, unsigned reg, uint32_t *pval)
- if ( phy > 1 )
- return -1;
- *pval = mveth_mii_read(uarg, reg);
- return 0;
-static int mveth_mdio_w(int phy, void *uarg, unsigned reg, uint32_t val)
- if ( phy > 1 )
- return -1;
- mveth_mii_write(uarg, reg, val);
- return 0;
-static struct rtems_mdio_info mveth_mdio = {
- mdio_r: mveth_mdio_r,
- mdio_w: mveth_mdio_w,
- has_gmii: 1,
/* LOW LEVEL SUPPORT ROUTINES */
/* Software Cache Coherency */
@@ -1094,16 +999,7 @@ register uint32_t x,xe,p;
static void mveth_isr(rtems_irq_hdl_param arg)
-unsigned unit = (unsigned)arg;
- mveth_disable_irqs(&theMvEths[unit].pvt, -1);
- theMvEths[unit].pvt.stats.irqs++;
- rtems_bsdnet_event_send( theMvEths[unit].pvt.tid, 1<<unit );
-static void mveth_isr_1(rtems_irq_hdl_param arg)
-struct mveth_private *mp = &theMvEths[unit].pvt;
+struct mveth_private *mp = (struct mveth_private*) arg;
mp->stats.irqs++;
mp->isr(mp->isr_arg);
@@ -1172,8 +1068,8 @@ uint32_t x;
* If non-bsd drivers are running on a subset of IFs proper
* locking of all shared registers must be implemented!
-STATIC unsigned
+unsigned
unsigned v;
unsigned wc = 0;
@@ -1198,8 +1094,8 @@ unsigned wc = 0;
return (wc<<16) | (v & 0xffff);
-STATIC unsigned
+unsigned
unsigned wc = 0;
@@ -1256,56 +1152,7 @@ uint32_t active_q;
/* update serial port settings from current link status */
-static void
-mveth_update_serial_port(struct mveth_private *mp, int media)
-int port = mp->port_num;
-uint32_t old, new;
- new = old = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(port));
- /* mask speed and duplex settings */
- new &= ~( MV643XX_ETH_SET_GMII_SPEED_1000
- | MV643XX_ETH_SET_MII_SPEED_100
- | MV643XX_ETH_SET_FULL_DUPLEX );
- if ( IFM_FDX & media )
- new |= MV643XX_ETH_SET_FULL_DUPLEX;
- switch ( IFM_SUBTYPE(media) ) {
- default: /* treat as 10 */
- break;
- case IFM_100_TX:
- new |= MV643XX_ETH_SET_MII_SPEED_100;
- break;
- case IFM_1000_T:
- new |= MV643XX_ETH_SET_GMII_SPEED_1000;
- break;
- if ( new != old ) {
- if ( ! (MV643XX_ETH_SERIAL_PORT_ENBL & new) ) {
- /* just write */
- MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), new);
- } else {
- uint32_t were_running;
- were_running = mveth_stop_tx(port);
- old &= ~MV643XX_ETH_SERIAL_PORT_ENBL;
- MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), old);
- /* linux driver writes twice... */
- if ( were_running ) {
- MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_TX_START(0));
-/* Clear multicast filters */
void
@@ -1519,34 +1366,6 @@ register uint8_t *d = to, *s = fro;
#endif
-/* Assign values (buffer + user data) to a tx descriptor slot */
-static int
-mveth_assign_desc(MvEthTxDesc d, struct mbuf *m, unsigned long extra)
-int rval = (d->byte_cnt = m->m_len);
-#ifdef MVETH_TESTING
- assert( !d->mb );
- assert( m->m_len );
-#endif
- /* set CRC on all descriptors; seems to be necessary */
- d->cmd_sts = extra | (TDESC_GEN_CRC | TDESC_ZERO_PAD);
-#ifdef ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
- /* The buffer must be 64bit aligned if the payload is <8 (??) */
- if ( rval < 8 && ((mtod(m, uintptr_t)) & 7) ) {
- d->buf_ptr = CPUADDR2ENET( d->workaround );
- memcpy((void*)d->workaround, mtod(m, void*), rval);
- } else
-#endif
- d->buf_ptr = CPUADDR2ENET( mtod(m, unsigned long) );
- d->l4i_chk = 0;
- return rval;
static int
mveth_assign_desc_raw(MvEthTxDesc d, void *buf, int len, unsigned long extra)
@@ -1660,6 +1479,7 @@ MvEthTxDesc d;
static struct mveth_private *
mve_setup_internal(
int unit,
rtems_id tid,
void (*isr)(void*isr_arg),
@@ -1675,21 +1495,12 @@ mve_setup_internal(
-struct mveth_private *mp;
-struct ifnet *ifp;
int InstallISRSuccessful;
if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
return 0;
- ifp = &theMvEths[unit-1].arpcom.ac_if;
- if ( ifp->if_init ) {
- printk(DRVNAME": instance %i already attached.\n", unit);
- return 0;
if ( rx_ring_size < 0 && tx_ring_size < 0 )
return 0;
@@ -1714,8 +1525,6 @@ int InstallISRSuccessful;
- mp = &theMvEths[unit-1].pvt;
memset(mp, 0, sizeof(*mp));
mp->port_num = unit-1;
@@ -1742,6 +1551,7 @@ int InstallISRSuccessful;
if ( mp->xbuf_count < 0 )
mp->xbuf_count = 0;
+#ifdef BSDBSD
/* allocate ring area; add 1 entry -- room for alignment */
assert( !mp->ring_area );
mp->ring_area = malloc(
@@ -1750,18 +1560,17 @@ int InstallISRSuccessful;
M_DEVBUF,
M_WAIT );
assert( mp->ring_area );
+#endif
BSP_mve_stop_hw(mp);
if ( irq_mask ) {
- irq_data[mp->port_num].hdl = tid ? mveth_isr : mveth_isr_1;
+ irq_data[mp->port_num].hdl = mveth_isr;
+ irq_data[mp->port_num].handle = (rtems_irq_hdl_param)mp;
InstallISRSuccessful = BSP_install_rtems_irq_handler( &irq_data[mp->port_num] );
assert( InstallISRSuccessful );
- /* mark as used */
- ifp->if_init = (void*)(-1);
if ( rx_ring_size < 0 )
irq_mask &= ~ MV643XX_ETH_IRQ_RX_DONE;
if ( tx_ring_size < 0 )
@@ -1778,38 +1587,9 @@ int InstallISRSuccessful;
return mp;
-BSP_mve_setup(
- int unit,
- rtems_id tid,
- void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
- void *cleanup_txbuf_arg,
- void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
- void (*consume_rxbuf)(void *user_buf, void *closure, int len),
- void *consume_rxbuf_arg,
- int rx_ring_size,
- int tx_ring_size,
- int irq_mask
- if ( irq_mask && 0 == tid ) {
- printk(DRVNAME": must supply a TID if irq_msk not zero\n");
- return 0;
- return mve_setup_internal(
- unit,
- tid,
- 0, 0,
- cleanup_txbuf, cleanup_txbuf_arg,
- alloc_rxbuf,
- consume_rxbuf, consume_rxbuf_arg,
- rx_ring_size, tx_ring_size,
- irq_mask);
BSP_mve_setup_1(
int unit,
void *isr_arg,
@@ -1829,6 +1609,7 @@ BSP_mve_setup_1(
+ mp,
unit,
0,
isr, isr_arg,
@@ -1848,17 +1629,24 @@ BSP_mve_get_tid(struct mveth_private *mp)
int
+#ifdef BSDBSD
int unit = mp->port_num;
+#endif
if ( mp->irq_mask || mp->xirq_mask ) {
if ( !BSP_remove_rtems_irq_handler( &irq_data[mp->port_num] ) )
return -1;
+#ifdef BSDBSD
+#warning FIXME
free( (void*)mp->ring_area, M_DEVBUF );
+#endif
__asm__ __volatile__("":::"memory");
/* mark as unused */
+#ifdef BSDBSD
theMvEths[unit].arpcom.ac_if.if_init = 0;
+#endif
return 0;
@@ -1904,236 +1692,6 @@ register MvEthTxDesc d;
return rval;
-/* allocate a new cluster and copy an existing chain there;
- * old chain is released...
-static struct mbuf *
-repackage_chain(struct mbuf *m_head)
-struct mbuf *m;
- MGETHDR(m, M_DONTWAIT, MT_DATA);
- if ( !m ) {
- goto bail;
- MCLGET(m, M_DONTWAIT);
- if ( !(M_EXT & m->m_flags) ) {
- m_freem(m);
- m = 0;
- goto bail;
- m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
- m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
-bail:
- m_freem(m_head);
- return m;
-/* Enqueue a mbuf chain or a raw data buffer for transmission;
- * RETURN: #bytes sent or -1 if there are not enough descriptors
- * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
- * OTOH, a raw data packet may be send (non-BSD driver) by pointing
- * m_head to the start of the data and passing 'len' > 0.
- * Comments: software cache-flushing incurs a penalty if the
- * packet cannot be queued since it is flushed anyways.
- * The algorithm is slightly more efficient in the normal
- * case, though.
-int
-BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len)
-int rval;
-register MvEthTxDesc l,d,h;
-register struct mbuf *m1;
-int nmbs;
-int ismbuf = (len <= 0);
-/* Only way to get here is when we discover that the mbuf chain
- * is too long for the tx ring
-startover:
- rval = 0;
- assert(m_head);
-#endif
- /* if no descriptor is available; try to wipe the queue */
- if ( (mp->avail < 1) && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
- /* Maybe TX is stalled and needs to be restarted */
- mveth_start_tx(mp);
- return -1;
- h = mp->d_tx_h;
- assert( !h->buf_ptr );
- assert( !h->mb );
-#endif
- if ( ! (m1 = m_head) )
- return 0;
- if ( ismbuf ) {
- /* find first mbuf with actual data */
- while ( 0 == m1->m_len ) {
- if ( ! (m1 = m1->m_next) ) {
- /* end reached and still no data to send ?? */
- m_freem(m_head);
- return 0;
- /* Don't use the first descriptor yet because BSP_mve_swipe_tx()
- * needs mp->d_tx_h->buf_ptr == NULL as a marker. Hence, we
- * start with the second mbuf and fill the first descriptor
- * last.
- l = h;
- d = NEXT_TXD(h);
- mp->avail--;
- nmbs = 1;
- if ( ismbuf ) {
- register struct mbuf *m;
- for ( m=m1->m_next; m; m=m->m_next ) {
- if ( 0 == m->m_len )
- continue; /* skip empty mbufs */
- nmbs++;
- if ( mp->avail < 1 && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
- /* Maybe TX was stalled - try to restart */
- /* not enough descriptors; cleanup...
- * the first slot was never used, so we start
- * at mp->d_tx_h->next;
- for ( l = NEXT_TXD(h); l!=d; l=NEXT_TXD(l) ) {
- assert( l->mb == 0 );
-#endif
- l->buf_ptr = 0;
- l->cmd_sts = 0;
- mp->avail++;
- mp->avail++;
- if ( nmbs > TX_AVAILABLE_RING_SIZE(mp) ) {
- /* this chain will never fit into the ring */
- if ( nmbs > mp->stats.maxchain )
- mp->stats.maxchain = nmbs;
- mp->stats.repack++;
- if ( ! (m_head = repackage_chain(m_head)) ) {
- /* no cluster available */
- mp->stats.odrops++;
- return 0;
- goto startover;
- return -1;
- mp->avail--;
- assert( d != h );
- assert( !d->buf_ptr );
-#endif
- /* fill this slot */
- rval += mveth_assign_desc(d, m, TDESC_DMA_OWNED);
- FLUSH_BUF(mtod(m, uint32_t), m->m_len);
- l = d;
- d = NEXT_TXD(d);
- FLUSH_DESC(l);
- /* fill first slot - don't release to DMA yet */
- rval += mveth_assign_desc(h, m1, TDESC_FRST);
- FLUSH_BUF(mtod(m1, uint32_t), m1->m_len);
- } else {
- /* fill first slot with raw buffer - don't release to DMA yet */
- rval += mveth_assign_desc_raw(h, data_p, len, TDESC_FRST);
- FLUSH_BUF( (uint32_t)data_p, len);
- /* tag last slot; this covers the case where 1st==last */
- l->cmd_sts |= TDESC_LAST | TDESC_INT_ENA;
- /* mbuf goes into last desc */
- l->u_buf = m_head;
- FLUSH_DESC(l);
- /* Tag end; make sure chip doesn't try to read ahead of here! */
- l->next->cmd_sts = 0;
- FLUSH_DESC(l->next);
-#ifdef MVETH_DEBUG_TX_DUMP
- if ( (mveth_tx_dump & (1<<mp->port_num)) ) {
- int ll,kk;
- if ( ismbuf ) {
- struct mbuf *m;
- for ( kk=0, m=m_head; m; m=m->m_next) {
- for ( ll=0; ll<m->m_len; ll++ ) {
- printf("%02X ",*(mtod(m,char*) + ll));
- if ( ((++kk)&0xf) == 0 )
- printf("\n");
- } else {
- for ( ll=0; ll<len; ) {
- printf("%02X ",*((char*)data_p + ll));
- if ( ((++ll)&0xf) == 0 )
- printf("\n");
- printf("\n");
-#endif
- membarrier();
- /* turn over the whole chain by flipping ownership of the first desc */
- h->cmd_sts |= TDESC_DMA_OWNED;
- FLUSH_DESC(h);
- membarrier();
- /* notify the device */
- /* Update softc */
- mp->stats.packet++;
- /* remember new head */
- mp->d_tx_h = d;
- return rval; /* #bytes sent */
int
@@ -2490,12 +2048,15 @@ static int inited = 0;
v |= mveth_serial_ctrl_config_val;
MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
+#ifdef BSDMII
+#warning FIXME
i = IFM_MAKEWORD(0, 0, 0, 0);
if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
if ( (IFM_LINK_OK & i) ) {
mveth_update_serial_port(mp, i);
+#endif
/* enable serial port */
v = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
@@ -2560,26 +2121,6 @@ unsigned char buf[6], *eaddr;
-int
-BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg)
-int rval;
- /* alias cmd == 0,1 */
- switch ( cmd ) {
- case 0: cmd = SIOCGIFMEDIA;
- break;
- case 1: cmd = SIOCSIFMEDIA;
- case SIOCGIFMEDIA:
- case SIOCSIFMEDIA:
- break;
- default: return -1;
- REGLOCK();
- rval = rtems_mii_ioctl(&mveth_mdio, mp, cmd, parg);
- REGUNLOCK();
- return rval;
void
@@ -2617,132 +2158,6 @@ BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask)
return mveth_ack_irqs(mp, mask);
-int
-BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
-int media = IFM_MAKEWORD(0,0,0,0);
- if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
- if ( IFM_LINK_OK & media ) {
- mveth_update_serial_port(mp, media);
- /* If TX stalled because there was no buffer then whack it */
- if ( pmedia )
- *pmedia = media;
- return 0;
- return -1;
-/* BSDNET SUPPORT/GLUE ROUTINES */
-static void
-mveth_set_filters(struct ifnet *ifp);
-STATIC void
-mveth_stop(struct mveth_softc *sc)
- BSP_mve_stop_hw(&sc->pvt);
- sc->arpcom.ac_if.if_timer = 0;
-/* allocate a mbuf for RX with a properly aligned data buffer
- * RETURNS 0 if allocation fails
-static void *
-alloc_mbuf_rx(int *psz, uintptr_t *paddr)
-struct mbuf *m;
-unsigned long l,o;
- if ( !m )
- return 0;
- if ( ! (m->m_flags & M_EXT) ) {
- m_freem(m);
- return 0;
- o = mtod(m, unsigned long);
- l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
- /* align start of buffer */
- m->m_data += l;
- /* reduced length */
- l = MCLBYTES - l;
- m->m_len = m->m_pkthdr.len = l;
- *psz = m->m_len;
- *paddr = mtod(m, uintptr_t);
- return (void*) m;
-static void consume_rx_mbuf(void *buf, void *arg, int len)
-struct ifnet *ifp = arg;
-struct mbuf *m = buf;
- if ( len <= 0 ) {
- ifp->if_iqdrops++;
- if ( len < 0 ) {
- ifp->if_ierrors++;
- if ( m )
- m_freem(m);
- } else {
- struct ether_header *eh;
- eh = (struct ether_header *)(mtod(m, unsigned long) + ETH_RX_OFFSET);
- m->m_len = m->m_pkthdr.len = len - sizeof(struct ether_header) - ETH_RX_OFFSET - ETH_CRC_LEN;
- m->m_data += sizeof(struct ether_header) + ETH_RX_OFFSET;
- m->m_pkthdr.rcvif = ifp;
- ifp->if_ipackets++;
- ifp->if_ibytes += m->m_pkthdr.len;
- if (0) {
- /* Low-level debugging */
- int i;
- for (i=0; i<13; i++) {
- printf("%02X:",((char*)eh)[i]);
- printf("%02X\n",((char*)eh)[i]);
- for (i=0; i<m->m_len; i++) {
- if ( !(i&15) )
- printf("\n");
- printf("0x%02x ",mtod(m,char*)[i]);
- printf("\n");
- if (0) {
- /* Low-level debugging/testing without bsd stack */
- m_freem(m);
- } else {
- /* send buffer upwards */
- ether_input(ifp, eh, m);
-static void release_tx_mbuf(void *buf, void *arg, int err)
-struct mbuf *mb = buf;
- if ( err ) {
- ifp->if_oerrors++;
- } else {
- ifp->if_opackets++;
- ifp->if_obytes += mb->m_pkthdr.len;
- m_freem(mb);
static void
dump_update_stats(struct mveth_private *mp, FILE *f)
@@ -2789,530 +2204,3 @@ BSP_mve_dump_stats(struct mveth_private *mp, FILE *f)
dump_update_stats(mp, f);
-/* BSDNET DRIVER CALLBACKS */
-static void
-mveth_init(void *arg)
-struct mveth_softc *sc = arg;
-struct ifnet *ifp = &sc->arpcom.ac_if;
-int media;
- BSP_mve_init_hw(&sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
- media = IFM_MAKEWORD(0, 0, 0, 0);
- if ( 0 == BSP_mve_media_ioctl(&sc->pvt, SIOCGIFMEDIA, &media) ) {
- if ( (IFM_LINK_OK & media) ) {
- ifp->if_flags &= ~IFF_OACTIVE;
- } else {
- ifp->if_flags |= IFF_OACTIVE;
- /* if promiscuous then there is no need to change */
- if ( ! (ifp->if_flags & IFF_PROMISC) )
- mveth_set_filters(ifp);
- ifp->if_flags |= IFF_RUNNING;
-/* bsdnet driver entry to start transmission */
-static void
-mveth_start(struct ifnet *ifp)
-struct mveth_softc *sc = ifp->if_softc;
-struct mbuf *m = 0;
- while ( ifp->if_snd.ifq_head ) {
- IF_DEQUEUE( &ifp->if_snd, m );
- if ( BSP_mve_send_buf(&sc->pvt, m, 0, 0) < 0 ) {
- IF_PREPEND( &ifp->if_snd, m);
- break;
- /* need to do this really only once
- * but it's cheaper this way.
- ifp->if_timer = 2*IFNET_SLOWHZ;
-/* bsdnet driver entry; */
-static void
-mveth_watchdog(struct ifnet *ifp)
- printk(DRVNAME"%i: watchdog timeout; resetting\n", ifp->if_unit);
- mveth_init(sc);
- mveth_start(ifp);
-static void
-uint32_t v;
- v = MV_READ(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num));
- if ( ifp->if_flags & IFF_PROMISC )
- v |= MV643XX_ETH_UNICAST_PROMISC_MODE;
- else
- v &= ~MV643XX_ETH_UNICAST_PROMISC_MODE;
- MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num), v);
- if ( ifp->if_flags & (IFF_PROMISC | IFF_ALLMULTI) ) {
- BSP_mve_mcast_filter_accept_all(&sc->pvt);
- } else {
- struct ether_multi *enm;
- struct ether_multistep step;
- BSP_mve_mcast_filter_clear( &sc->pvt );
- ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
- while ( enm ) {
- if ( memcmp(enm->enm_addrlo, enm->enm_addrhi, ETHER_ADDR_LEN) )
- assert( !"Should never get here; IFF_ALLMULTI should be set!" );
- BSP_mve_mcast_filter_accept_add(&sc->pvt, enm->enm_addrlo);
- ETHER_NEXT_MULTI(step, enm);
-/* bsdnet driver ioctl entry */
-static int
-mveth_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
-struct ifreq *ifr = (struct ifreq *)data;
-int error = 0;
-int f;
- switch ( cmd ) {
- case SIOCSIFFLAGS:
- f = ifp->if_flags;
- if ( f & IFF_UP ) {
- if ( ! ( f & IFF_RUNNING ) ) {
- mveth_init(sc);
- } else {
- if ( (f & IFF_PROMISC) != (sc->bsd.oif_flags & IFF_PROMISC) ) {
- /* Note: in all other scenarios the 'promisc' flag
- * in the low-level driver [which affects the way
- * the multicast filter is setup: accept none vs.
- * accept all in promisc mode] is eventually
- * set when the IF is brought up...
- sc->pvt.promisc = (f & IFF_PROMISC);
- /* FIXME: other flag changes are ignored/unimplemented */
- } else {
- if ( f & IFF_RUNNING ) {
- mveth_stop(sc);
- ifp->if_flags &= ~(IFF_RUNNING | IFF_OACTIVE);
- sc->bsd.oif_flags = ifp->if_flags;
- break;
- error = BSP_mve_media_ioctl(&sc->pvt, cmd, &ifr->ifr_media);
- break;
- case SIOCADDMULTI:
- case SIOCDELMULTI:
- error = (cmd == SIOCADDMULTI)
- ? ether_addmulti(ifr, &sc->arpcom)
- : ether_delmulti(ifr, &sc->arpcom);
- if (error == ENETRESET) {
- if (ifp->if_flags & IFF_RUNNING) {
- error = 0;
- break;
- break;
- case SIO_RTEMS_SHOW_STATS:
- dump_update_stats(&sc->pvt, stdout);
- break;
- default:
- error = ether_ioctl(ifp, cmd, data);
- break;
- return error;
-/* DRIVER TASK */
-/* Daemon task does all the 'interrupt' work */
-static void mveth_daemon(void *arg)
-struct mveth_softc *sc;
-struct ifnet *ifp;
-rtems_event_set evs;
- for (;;) {
- rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
- evs &= 7;
- for ( sc = theMvEths; evs; evs>>=1, sc++ ) {
- if ( (evs & 1) ) {
- register uint32_t x;
- ifp = &sc->arpcom.ac_if;
- if ( !(ifp->if_flags & IFF_UP) ) {
- mveth_stop(sc);
- ifp->if_flags &= ~(IFF_UP|IFF_RUNNING);
- continue;
- if ( !(ifp->if_flags & IFF_RUNNING) ) {
- /* event could have been pending at the time hw was stopped;
- * just ignore...
- continue;
- x = mveth_ack_irqs(&sc->pvt, -1);
- if ( MV643XX_ETH_EXT_IRQ_LINK_CHG & x ) {
- /* phy status changed */
- int media;
- if ( 0 == BSP_mve_ack_link_chg(&sc->pvt, &media) ) {
- mveth_start(ifp);
- } else {
- /* stop sending */
- /* free tx chain */
- if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(&sc->pvt) ) {
- if ( TX_AVAILABLE_RING_SIZE(&sc->pvt) == sc->pvt.avail )
- ifp->if_timer = 0;
- mveth_start(ifp);
- if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
- BSP_mve_swipe_rx(&sc->pvt);
- mveth_enable_irqs(&sc->pvt, -1);
-static int mveth_detach(struct mveth_softc *sc);
-#endif
-/* PUBLIC RTEMS BSDNET ATTACH FUNCTION */
-int
-rtems_mve_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching)
-char *unitName;
-int unit,i,cfgUnits;
-struct ifnet *ifp;
- unit = rtems_bsdnet_parse_driver_name(ifcfg, &unitName);
- if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
- printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
- return 1;
- sc = &theMvEths[unit-1];
- sc->pvt.port_num = unit-1;
- sc->pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*sc->pvt.port_num)) & 0x1f;
- if ( attaching ) {
- return -1;
- for ( i=cfgUnits = 0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
- if ( theMvEths[i].arpcom.ac_if.if_init )
- cfgUnits++;
- cfgUnits++; /* this new one */
- /* lazy init of TID should still be thread-safe because we are protected
- * by the global networking semaphore..
- if ( !mveth_tid ) {
- /* newproc uses the 1st 4 chars of name string to build an rtems name */
- mveth_tid = rtems_bsdnet_newproc("MVEd", 4096, mveth_daemon, 0);
- if ( !BSP_mve_setup( unit,
- mveth_tid,
- release_tx_mbuf, ifp,
- alloc_mbuf_rx,
- consume_rx_mbuf, ifp,
- ifcfg->rbuf_count,
- ifcfg->xbuf_count,
- BSP_MVE_IRQ_TX | BSP_MVE_IRQ_RX | BSP_MVE_IRQ_LINK) ) {
- return -1;
- if ( nmbclusters < sc->pvt.rbuf_count * cfgUnits + 60 /* arbitrary */ ) {
- printk(DRVNAME"%i: (mv643xx ethernet) Your application has not enough mbuf clusters\n", unit);
- printk( " configured for this driver.\n");
- return -1;
- if ( ifcfg->hardware_address ) {
- memcpy(sc->arpcom.ac_enaddr, ifcfg->hardware_address, ETHER_ADDR_LEN);
- } else {
- /* read back from hardware assuming that MotLoad already had set it up */
- BSP_mve_read_eaddr(&sc->pvt, sc->arpcom.ac_enaddr);
- ifp->if_softc = sc;
- ifp->if_unit = unit;
- ifp->if_name = unitName;
- ifp->if_mtu = ifcfg->mtu ? ifcfg->mtu : ETHERMTU;
- ifp->if_init = mveth_init;
- ifp->if_ioctl = mveth_ioctl;
- ifp->if_start = mveth_start;
- ifp->if_output = ether_output;
- * While nonzero, the 'if->if_timer' is decremented
- * (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
- * is called when it expires.
- * If either of those fields is 0 the feature is disabled.
- ifp->if_watchdog = mveth_watchdog;
- sc->bsd.oif_flags = /* ... */
- ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
- * if unset, this set to 10Mbps by ether_ifattach; seems to be unused by bsdnet stack;
- * could be updated along with phy speed, though...
- ifp->if_baudrate = 10000000;
- /* NOTE: ether_output drops packets if ifq_len >= ifq_maxlen
- * but this is the packet count, not the fragment count!
- ifp->if_snd.ifq_maxlen = sc->pvt.xbuf_count;
- ifp->if_snd.ifq_maxlen = ifqmaxlen;
- if ( !ifp->if_addrlist ) /* do only the first time [reattach hack] */
-#endif
- if_attach(ifp);
- ether_ifattach(ifp);
- } else {
- if ( !ifp->if_init ) {
- printk(DRVNAME": instance %i not attached.\n", unit);
- return -1;
- return mveth_detach(sc);
-#else
- printk(DRVNAME": interface detaching not implemented\n");
- return -1;
-#endif
- return 0;
-/* EARLY PHY ACCESS */
-static int
-mveth_early_init(int idx)
- if ( idx < 0 || idx >= MV643XXETH_NUM_DRIVER_SLOTS )
- return -1;
- /* determine the phy */
- theMvEths[idx].pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*idx)) & 0x1f;
- return 0;
-static int
-mveth_early_read_phy(int idx, unsigned reg)
-int rval;
- return -1;
- rval = mveth_mii_read(&theMvEths[idx].pvt, reg);
- return rval < 0 ? rval : rval & 0xffff;
-static int
-mveth_early_write_phy(int idx, unsigned reg, unsigned val)
- return -1;
- mveth_mii_write(&theMvEths[idx].pvt, reg, val);
- return 0;
-rtems_bsdnet_early_link_check_ops
-rtems_mve_early_link_check_ops = {
- init: mveth_early_init,
- read_phy: mveth_early_read_phy,
- write_phy: mveth_early_write_phy,
- name: DRVNAME,
- num_slots: MAX_NUM_SLOTS
-/* DEBUGGING */
-#ifdef MVETH_DEBUG
-/* Display/dump descriptor rings */
-int
-mveth_dring(struct mveth_softc *sc)
-int i;
-if (1) {
-MvEthRxDesc pr;
-printf("RX:\n");
- for (i=0, pr=sc->pvt.rx_ring; i<sc->pvt.rbuf_count; i++, pr++) {
-#ifndef ENABLE_HW_SNOOPING
- /* can't just invalidate the descriptor - if it contains
- * data that hasn't been flushed yet, we create an inconsistency...
- rtems_bsdnet_semaphore_obtain();
- INVAL_DESC(pr);
-#endif
- printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
- pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
- rtems_bsdnet_semaphore_release();
-#endif
-if (1) {
-MvEthTxDesc pt;
-printf("TX:\n");
- for (i=0, pt=sc->pvt.tx_ring; i<sc->pvt.xbuf_count; i++, pt++) {
- INVAL_DESC(pt);
-#endif
- printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
- pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
- (uint32_t)pt->mb);
-#endif
- return 0;
-#endif
-/* DETACH HACK DETAILS */
-int
-_cexpModuleFinalize(void *mh)
-int i;
- for ( i=0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
- if ( theMvEths[i].arpcom.ac_if.if_init ) {
- printf("Interface %i still attached; refuse to unload\n", i+1);
- return -1;
- /* delete task; since there are no attached interfaces, it should block
- * for events and hence not hold the semaphore or other resources...
- rtems_task_delete(mveth_tid);
- return 0;
-/* ugly hack to allow unloading/reloading the driver core.
- * needed because rtems' bsdnet release doesn't implement
- * if_detach(). Therefore, we bring the interface down but
- * keep the device record alive...
-static void
-ether_ifdetach_pvt(struct ifnet *ifp)
- ifp->if_flags = 0;
- ifp->if_ioctl = 0;
- ifp->if_start = 0;
- ifp->if_watchdog = 0;
- ifp->if_init = 0;
-static int
-mveth_detach(struct mveth_softc *sc)
- if ( ifp->if_flags & (IFF_UP | IFF_RUNNING) ) {
- printf(DRVNAME"%i: refuse to detach; interface still up\n",sc->pvt.port_num+1);
- return -1;
- mveth_stop(sc);
-/* not implemented in BSDnet/RTEMS (yet) but declared in header */
-#define ether_ifdetach ether_ifdetach_pvt
- ether_ifdetach(ifp);
- free( (void*)sc->pvt.ring_area, M_DEVBUF );
- sc->pvt.ring_area = 0;
- sc->pvt.tx_ring = 0;
- sc->pvt.rx_ring = 0;
- sc->pvt.d_tx_t = sc->pvt.d_tx_h = 0;
- sc->pvt.d_rx_t = 0;
- sc->pvt.avail = 0;
- /* may fail if ISR was not installed yet */
- BSP_remove_rtems_irq_handler( &irq_data[sc->pvt.port_num] );
- return 0;
-#ifdef MVETH_DEBUG
-struct rtems_bsdnet_ifconfig mveth_dbg_config = {
- name: DRVNAME"1",
- attach: rtems_mve_attach,
- ip_address: "192.168.2.10", /* not used by rtems_bsdnet_attach */
- ip_netmask: "255.255.255.0", /* not used by rtems_bsdnet_attach */
- hardware_address: 0, /* (void *) */
- ignore_broadcast: 0, /* TODO driver should honour this */
- mtu: 0,
- rbuf_count: 0, /* TODO driver should honour this */
- xbuf_count: 0, /* TODO driver should honour this */
-#endif
-#endif
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index 0000000000..a2efdce8e1
--- /dev/null
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -0,0 +1,3519 @@
+/* RTEMS driver for the mv643xx gigabit ethernet chip */
+/* Acknowledgement:
+ * Valuable information for developing this driver was obtained
+ * from the linux open-source driver mv643xx_eth.c which was written
+ * by the following people and organizations:
+ * Matthew Dharm <mdharm at momenco.com>
+ * rabeeh at galileo.co.il
+ * PMC-Sierra, Inc., Manish Lachwani
+ * Ralf Baechle <ralf at linux-mips.org>
+ * MontaVista Software, Inc., Dale Farnsworth <dale at farnsworth.org>
+ * Steven J. Hill <sjhill1 at rockwellcollins.com>/<sjhill at realitydiluted.com>
+ * Note however, that in spite of the identical name of this file
+ * (and some of the symbols used herein) this file provides a
+ * new implementation and is the original work by the author.
+ * Authorship
+ * This software (mv643xx ethernet driver for RTEMS) was
+ * created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
+ * Stanford Linear Accelerator Center, Stanford University.
+ * Acknowledgement of sponsorship
+ * The 'mv643xx ethernet driver for RTEMS' was produced by
+ * the Stanford Linear Accelerator Center, Stanford University,
+ * under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software. Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+ * NOTE: Some register (e.g., the SMI register) are SHARED among the
+ * three devices. Concurrent access protection is provided by
+ * the global networking semaphore.
+ * If other drivers are running on a subset of IFs then proper
+ * locking of all shared registers must be implemented!
+ * Some things I learned about this hardware can be found
+ * further down...
+#ifndef KERNEL
+#define KERNEL
+#endif
+#ifndef _KERNEL
+#define _KERNEL
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/error.h>
+#include <bsp.h>
+#include <bsp/irq.h>
+#include <bsp/gtreg.h>
+#include <libcpu/byteorder.h>
+#include <assert.h>
+#include <stdio.h>
+#include <errno.h>
+#include <inttypes.h>
+#ifdef BSDBSD
+#include <sys/param.h>
+#include <sys/proc.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <dev/mii/mii.h>
+#include <net/if_var.h>
+#include <net/if_media.h>
+/* Not so nice; would be more elegant not to depend on C library but the
+ * RTEMS-specific ioctl for dumping statistics needs stdio anyways.
+/*#define NDEBUG effectively removes all assertions
+ * If defining NDEBUG, MAKE SURE assert() EXPRESSION HAVE NO SIDE_EFFECTS!!
+ * This driver DOES have side-effects, so DONT DEFINE NDEBUG
+ * Performance-critical assertions are removed by undefining MVETH_TESTING.
+#undef NDEBUG
+#include <rtems/rtems_bsdnet.h>
+#include <sys/mbuf.h>
+#include <net/ethernet.h>
+#include <net/if.h>
+#include <netinet/in.h>
+#include <netinet/if_ether.h>
+#endif /* BSDBSD */
+#ifdef BSDBSD
+#include <rtems/rtems_mii_ioctl.h>
+#include <bsp/early_enet_link_status.h>
+#include <bsp/if_mve_pub.h>
+/* CONFIGURABLE PARAMETERS */
+/* Enable Hardware Snooping; if this is disabled (undefined),
+ * cache coherency is maintained by software.
+#undef ENABLE_HW_SNOOPING
+/* Compile-time debugging features */
+/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing */
+#undef MVETH_TESTING
+/* Enable debugging messages and some support routines (dump rings etc.) */
+#undef MVETH_DEBUG
+/* Hack for driver development; rtems bsdnet doesn't implement detaching an interface :-(
+ * but this hack allows us to unload/reload the driver module which makes development
+ * a lot less painful.
+#undef MVETH_DETACH_HACK
+/* Ring sizes */
+#ifdef MVETH_TESTING
+/* hard and small defaults */
+#undef MV643XX_RX_RING_SIZE
+#define MV643XX_RX_RING_SIZE 2
+#undef MV643XX_TX_RING_SIZE
+#define MV643XX_TX_RING_SIZE 4
+#else /* MVETH_TESTING */
+/* Define default ring sizes, allow override from bsp.h, Makefile,... and from ifcfg->rbuf_count/xbuf_count */
+#ifndef MV643XX_RX_RING_SIZE
+#define MV643XX_RX_RING_SIZE 40 /* attached buffers are always 2k clusters, i.e., this
+ * driver - with a configured ring size of 40 - constantly
+ * locks 80k of cluster memory - your app config better
+ * provides enough space!
+#endif
+#ifndef MV643XX_TX_RING_SIZE
+/* NOTE: tx ring size MUST be > max. # of fragments / mbufs in a chain;
+ * in 'TESTING' mode, special code is compiled in to repackage
+ * chains that are longer than the ring size. Normally, this is
+ * disabled for sake of speed.
+ * I observed chains of >17 entries regularly!
+ * Also, TX_NUM_TAG_SLOTS (1) must be left empty as a marker, hence
+ * the ring size must be > max. #frags + 1.
+#define MV643XX_TX_RING_SIZE 200 /* these are smaller fragments and not occupied when
+ * the driver is idle.
+#endif
+#endif /* MVETH_TESTING */
+/* How many instances to we support (bsp.h could override) */
+#ifndef MV643XXETH_NUM_DRIVER_SLOTS
+#define MV643XXETH_NUM_DRIVER_SLOTS 2
+#endif
+#define TX_NUM_TAG_SLOTS 1 /* leave room for tag; must not be 0 */
+/* This is REAL; chip reads from 64-bit down-aligned buffer
+ * if the buffer size is < 8 !!! for buffer sizes 8 and upwards
+ * alignment is not an issue. This was verified using the
+ * 'mve_smallbuf_test.c'
+#define ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
+/* Chip register configuration values */
+#define MVETH_PORT_CONFIG_VAL (0 \
+ | MV643XX_ETH_DFLT_RX_Q(0) \
+ | MV643XX_ETH_DFLT_RX_ARP_Q(0) \
+ | MV643XX_ETH_DFLT_RX_TCP_Q(0) \
+ | MV643XX_ETH_DFLT_RX_UDP_Q(0) \
+ | MV643XX_ETH_DFLT_RX_BPDU_Q(0) \
+#define MVETH_PORT_XTEND_CONFIG_VAL 0
+#ifdef OLDCONFIGVAL
+#define MVETH_SERIAL_CTRL_CONFIG_VAL (0 \
+ | MV643XX_ETH_FORCE_LINK_PASS \
+ | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL \
+ | MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL \
+ | MV643XX_ETH_BIT9_UNKNOWN \
+ | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE \
+ | MV643XX_ETH_SC_MAX_RX_1552 \
+ | MV643XX_ETH_SET_FULL_DUPLEX \
+ | MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD \
+#endif
+/* If we enable autoneg (duplex, speed, ...) then it seems
+ * that the chip automatically updates link settings
+ * (correct link settings are reflected in PORT_STATUS_R).
+ * However, when we disable aneg in the PHY then things
+ * can get messed up and the port doesn't work anymore.
+ * => we follow the linux driver in disabling all aneg
+ * in the serial config reg. and manually updating the
+ * speed & duplex bits when the phy link status changes.
+ * FIXME: don't know what to do about pause/flow-ctrl.
+ * It is best to just use ANEG anyways!!!
+ | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX \
+ | MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII \
+#define MVETH_SERIAL_CTRL_CONFIG_MSK (0 \
+ | MV643XX_ETH_SERIAL_PORT_ENBL \
+ | MV643XX_ETH_SC_MAX_RX_MASK \
+#ifdef __PPC__
+#define MVETH_SDMA_CONFIG_VAL (0 \
+ | MV643XX_ETH_RX_BURST_SZ_4_64BIT \
+ | MV643XX_ETH_TX_BURST_SZ_4_64BIT \
+#else
+ | MV643XX_ETH_RX_BURST_SZ_16_64BIT \
+ | MV643XX_ETH_TX_BURST_SZ_16_64BIT \
+#endif
+/* minimal frame size we accept */
+#define MVETH_MIN_FRAMSZ_CONFIG_VAL 40
+/* END OF CONFIGURABLE SECTION */
+ * Here's stuff I learned about this chip:
+ * RX interrupt flags:
+ * broadcast packet RX: 0x00000005
+ * last buf: 0x00000c05
+ * overrun: 0x00000c00
+ * unicast packet RX: 0x00000005
+ * bad CRC received: 0x00000005
+ * clearing 0x00000004 -> clears 0x00000001
+ * clearing 0x00000400 -> clears 0x00000800
+ * --> 0x0801 are probably some sort of summary bits.
+ * TX interrupt flags:
+ * broadcast packet in 1 buf: xcause: 0x00000001 (cause 0x00080000)
+ * into disconn. link: " "
+ * in some cases, I observed xcause: 0x00000101 (reason for 0x100 unknown
+ * but the linux driver accepts it also).
+ * Here a few more ugly things about this piece of hardware I learned
+ * (painfully, painfully; spending many many hours & nights :-()
+ * a) Especially in the case of 'chained' descriptors, the DMA keeps
+ * clobbering 'cmd_sts' long after it cleared the OWNership flag!!!
+ * Only after the whole chain is processed (OWN cleared on the
+ * last descriptor) it is safe to change cmd_sts.
+ * However, in the case of hardware snooping I found that the
+ * last descriptor in chain has its cmd_sts still clobbered *after*
+ * checking ownership!, I.e.,
+ * if ( ! OWN & cmd_sts ) {
+ * cmd_sts = 0;
+ * --> sometimes, cmd_sts is STILL != 0 here
+ * b) Sometimes, the OWNership flag is *not cleared*.
+ * c) Weird things happen if the chip finds a descriptor with 'OWN'
+ * still set (i.e., not properly loaded), i.e., corrupted packets
+ * are sent [with OK checksum since the chip calculates it].
+ * Combine a+b+c and we end up with a real mess.
+ * The fact that the chip doesn't reliably reset OWN and that OTOH,
+ * it can't be reliably reset by the driver and still, the chip needs
+ * it for proper communication doesn't make things easy...
+ * Here the basic workarounds:
+ * - In addition to check OWN, the scavenger compares the "currently
+ * served desc" register to the descriptor it tries to recover and
+ * ignores OWN if they do not match. Hope this is OK.
+ * Otherwise, we could scan the list of used descriptors and proceed
+ * recycling descriptors if we find a !OWNed one behind the target...
+ * - Always keep an empty slot around to mark the end of the list of
+ * jobs. The driver clears the descriptor ahead when enqueueing a new
+ * packet.
+#define DRVNAME "mve"
+#define MAX_NUM_SLOTS 3
+#if MV643XXETH_NUM_DRIVER_SLOTS > MAX_NUM_SLOTS
+#error "mv643xxeth: only MAX_NUM_SLOTS supported"
+#endif
+#ifdef NDEBUG
+#error "Driver uses assert() statements with side-effects; MUST NOT define NDEBUG"
+#endif
+#ifdef MVETH_DEBUG
+#define STATIC
+#else
+#define STATIC static
+#endif
+void
+void
+void
+void
+void
+BSP_mve_setup(
+ int unit,
+ rtems_id tid,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+BSP_mve_setup_1(
+ int unit,
+ void *isr_arg,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+ * chip.
+int
+int
+ void *head_p,
+ int h_len,
+ void *data_p,
+ int d_len);
+int
+rtems_id
+int
+ * - reset phy
+void
+void
+void
+void
+uint32_t
+void
+uint32_t
+uint32_t
+void
+unsigned
+mveth_mii_read(struct mveth_private *mp, unsigned addr);
+unsigned
+mveth_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
+#define TX_AVAILABLE_RING_SIZE(mp) ((mp)->xbuf_count - (TX_NUM_TAG_SLOTS))
+/* macros for ring alignment; proper alignment is a hardware req; . */
+#ifdef ENABLE_HW_SNOOPING
+#define RING_ALIGNMENT 16
+/* rx buffers must be 64-bit aligned (chip requirement) */
+#define RX_BUF_ALIGNMENT 8
+#else /* ENABLE_HW_SNOOPING */
+/* Software cache management */
+#ifndef __PPC__
+#error "Dont' know how to deal with cache on this CPU architecture"
+#endif
+/* Ring entries are 32 bytes; coherency-critical chunks are 16 -> software coherency
+ * management works for cache line sizes of 16 and 32 bytes only. If the line size
+ * is bigger, the descriptors could be padded...
+#if PPC_CACHE_ALIGMENT != 16 && PPC_CACHE_ALIGNMENT != 32
+#error "Cache line size must be 16 or 32"
+#else
+#define RING_ALIGNMENT PPC_CACHE_ALIGNMENT
+#define RX_BUF_ALIGNMENT PPC_CACHE_ALIGNMENT
+#endif
+#endif /* ENABLE_HW_SNOOPING */
+/* HELPER MACROS */
+/* Align base to alignment 'a' */
+#define MV643XX_ALIGN(b, a) ((((uint32_t)(b)) + (a)-1) & (~((a)-1)))
+#define NOOP() do {} while(0)
+/* Function like macros */
+#define MV_READ(off) \
+ ld_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)))
+#define MV_WRITE(off, data) \
+ st_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)), ((unsigned)data))
+/* ENET window mapped 1:1 to CPU addresses by our BSP/MotLoad
+ * -- if this is changed, we should think about caching the 'next' and 'buf' pointers.
+#define CPUADDR2ENET(a) ((Dma_addr_t)(a))
+#define ENET2CPUADDR(a) (a)
+#if 1 /* Whether to automatically try to reclaim descriptors when enqueueing new packets */
+#define MVETH_CLEAN_ON_SEND(mp) (BSP_mve_swipe_tx(mp))
+#else
+#define MVETH_CLEAN_ON_SEND(mp) (-1)
+#endif
+#define NEXT_TXD(d) (d)->next
+#define NEXT_RXD(d) (d)->next
+/* REGISTER AND DESCRIPTOR OFFSET AND BIT DEFINITIONS */
+/* Descriptor Definitions */
+/* Rx descriptor */
+#define RDESC_ERROR (1<< 0) /* Error summary */
+/* Error code (bit 1&2) is only valid if summary bit is set */
+#define RDESC_CRC_ERROR ( 1)
+#define RDESC_OVERRUN_ERROR ( 3)
+#define RDESC_MAX_FRAMELENGTH_ERROR ( 5)
+#define RDESC_RESOURCE_ERROR ( 7)
+#define RDESC_LAST (1<<26) /* Last Descriptor */
+#define RDESC_FRST (1<<27) /* First Descriptor */
+#define RDESC_INT_ENA (1<<29) /* Enable Interrupts */
+#define RDESC_DMA_OWNED (1<<31)
+/* Tx descriptor */
+#define TDESC_ERROR (1<< 0) /* Error summary */
+#define TDESC_ZERO_PAD (1<<19)
+#define TDESC_LAST (1<<20) /* Last Descriptor */
+#define TDESC_FRST (1<<21) /* First Descriptor */
+#define TDESC_GEN_CRC (1<<22)
+#define TDESC_INT_ENA (1<<23) /* Enable Interrupts */
+#define TDESC_DMA_OWNED (1<<31)
+/* Register Definitions */
+#define MV643XX_ETH_PHY_ADDR_R (0x2000)
+#define MV643XX_ETH_SMI_R (0x2004)
+#define MV643XX_ETH_SMI_BUSY (1<<28)
+#define MV643XX_ETH_SMI_VALID (1<<27)
+#define MV643XX_ETH_SMI_OP_WR (0<<26)
+#define MV643XX_ETH_SMI_OP_RD (1<<26)
+#define MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port) (0x2448 + ((port)<<10))
+#define MV643XX_ETH_TX_START(queue) (0x0001<<(queue))
+#define MV643XX_ETH_TX_STOP(queue) (0x0100<<(queue))
+#define MV643XX_ETH_TX_START_M(queues) ((queues)&0xff)
+#define MV643XX_ETH_TX_STOP_M(queues) (((queues)&0xff)<<8)
+#define MV643XX_ETH_TX_STOP_ALL (0xff00)
+#define MV643XX_ETH_TX_ANY_RUNNING (0x00ff)
+#define MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(port) (0x2680 + ((port)<<10))
+#define MV643XX_ETH_RX_START(queue) (0x0001<<(queue))
+#define MV643XX_ETH_RX_STOP(queue) (0x0100<<(queue))
+#define MV643XX_ETH_RX_STOP_ALL (0xff00)
+#define MV643XX_ETH_RX_ANY_RUNNING (0x00ff)
+#define MV643XX_ETH_CURRENT_SERVED_TX_DESC(port) (0x2684 + ((port)<<10))
+/* The chip puts the ethernet header at offset 2 into the buffer so
+ * that the payload is aligned
+#define ETH_RX_OFFSET 2
+#define ETH_CRC_LEN 4 /* strip FCS at end of packet */
+#define MV643XX_ETH_INTERRUPT_CAUSE_R(port) (0x2460 + ((port)<<10))
+/* not fully understood; RX seems to raise 0x0005 or 0x0c05 if last buffer is filled and 0x0c00
+ * if there are no buffers
+#define MV643XX_ETH_ALL_IRQS (0x0007ffff)
+#define MV643XX_ETH_KNOWN_IRQS (0x00000c05)
+#define MV643XX_ETH_IRQ_EXT_ENA (1<<1)
+#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
+#define MV643XX_ETH_IRQ_RX_NO_DESC (1<<10)
+#define MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(port) (0x2464 + ((port)<<10))
+/* not fully understood; TX seems to raise 0x0001 and link change is 0x00010000
+#define MV643XX_ETH_ALL_EXT_IRQS (0x0011ffff)
+#define MV643XX_ETH_KNOWN_EXT_IRQS (0x00010101)
+#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
+#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
+#define MV643XX_ETH_INTERRUPT_ENBL_R(port) (0x2468 + ((port)<<10))
+#define MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(port) (0x246c + ((port)<<10))
+/* port configuration */
+#define MV643XX_ETH_PORT_CONFIG_R(port) (0x2400 + ((port)<<10))
+#define MV643XX_ETH_UNICAST_PROMISC_MODE (1<<0)
+#define MV643XX_ETH_DFLT_RX_Q(q) ((q)<<1)
+#define MV643XX_ETH_DFLT_RX_ARP_Q(q) ((q)<<4)
+#define MV643XX_ETH_REJ_BCAST_IF_NOT_IP_OR_ARP (1<<7)
+#define MV643XX_ETH_REJ_BCAST_IF_IP (1<<8)
+#define MV643XX_ETH_REJ_BCAST_IF_ARP (1<<9)
+#define MV643XX_ETH_TX_AM_NO_UPDATE_ERR_SUMMARY (1<<12)
+#define MV643XX_ETH_CAPTURE_TCP_FRAMES_ENBL (1<<14)
+#define MV643XX_ETH_CAPTURE_UDP_FRAMES_ENBL (1<<15)
+#define MV643XX_ETH_DFLT_RX_TCP_Q(q) ((q)<<16)
+#define MV643XX_ETH_DFLT_RX_UDP_Q(q) ((q)<<19)
+#define MV643XX_ETH_DFLT_RX_BPDU_Q(q) ((q)<<22)
+#define MV643XX_ETH_PORT_CONFIG_XTEND_R(port) (0x2404 + ((port)<<10))
+#define MV643XX_ETH_CLASSIFY_ENBL (1<<0)
+#define MV643XX_ETH_SPAN_BPDU_PACKETS_AS_NORMAL (0<<1)
+#define MV643XX_ETH_SPAN_BPDU_PACKETS_2_Q7 (1<<1)
+#define MV643XX_ETH_PARTITION_DISBL (0<<2)
+#define MV643XX_ETH_PARTITION_ENBL (1<<2)
+#define MV643XX_ETH_SDMA_CONFIG_R(port) (0x241c + ((port)<<10))
+#define MV643XX_ETH_SDMA_RIFB (1<<0)
+#define MV643XX_ETH_RX_BURST_SZ_1_64BIT (0<<1)
+#define MV643XX_ETH_RX_BURST_SZ_2_64BIT (1<<1)
+#define MV643XX_ETH_RX_BURST_SZ_4_64BIT (2<<1)
+#define MV643XX_ETH_RX_BURST_SZ_8_64BIT (3<<1)
+#define MV643XX_ETH_RX_BURST_SZ_16_64BIT (4<<1)
+#define MV643XX_ETH_SMDA_BLM_RX_NO_SWAP (1<<4)
+#define MV643XX_ETH_SMDA_BLM_TX_NO_SWAP (1<<5)
+#define MV643XX_ETH_SMDA_DESC_BYTE_SWAP (1<<6)
+#define MV643XX_ETH_TX_BURST_SZ_1_64BIT (0<<22)
+#define MV643XX_ETH_TX_BURST_SZ_2_64BIT (1<<22)
+#define MV643XX_ETH_TX_BURST_SZ_4_64BIT (2<<22)
+#define MV643XX_ETH_TX_BURST_SZ_8_64BIT (3<<22)
+#define MV643XX_ETH_TX_BURST_SZ_16_64BIT (4<<22)
+#define MV643XX_ETH_RX_MIN_FRAME_SIZE_R(port) (0x247c + ((port)<<10))
+#define MV643XX_ETH_SERIAL_CONTROL_R(port) (0x243c + ((port)<<10))
+#define MV643XX_ETH_SERIAL_PORT_ENBL (1<<0) /* Enable serial port */
+#define MV643XX_ETH_FORCE_LINK_PASS (1<<1)
+#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX (1<<2)
+#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL (1<<3)
+#define MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL (1<<4)
+#define MV643XX_ETH_FORCE_FC_MODE_TX_PAUSE_DIS (1<<5)
+#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX (1<<7)
+#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX_ON_RX_ERR (1<<8)
+#define MV643XX_ETH_BIT9_UNKNOWN (1<<9) /* unknown purpose; linux sets this */
+#define MV643XX_ETH_FORCE_LINK_FAIL_DISABLE (1<<10)
+#define MV643XX_ETH_RETRANSMIT_FOREVER (1<<11) /* limit to 16 attempts if clear */
+#define MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII (1<<13)
+#define MV643XX_ETH_DTE_ADV_1 (1<<14)
+#define MV643XX_ETH_AUTO_NEG_BYPASS_ENBL (1<<15)
+#define MV643XX_ETH_RESTART_AUTO_NEG (1<<16)
+#define MV643XX_ETH_SC_MAX_RX_1518 (0<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_1522 (1<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_1552 (2<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9022 (3<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9192 (4<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_9700 (5<<17) /* Limit RX packet size */
+#define MV643XX_ETH_SC_MAX_RX_MASK (7<<17) /* bitmask */
+#define MV643XX_ETH_SET_EXT_LOOPBACK (1<<20)
+#define MV643XX_ETH_SET_FULL_DUPLEX (1<<21)
+#define MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD (1<<22) /* enable flow ctrl on rx and tx in full-duplex */
+#define MV643XX_ETH_SET_GMII_SPEED_1000 (1<<23) /* 10/100 if clear */
+#define MV643XX_ETH_SET_MII_SPEED_100 (1<<24) /* 10 if clear */
+#define MV643XX_ETH_PORT_STATUS_R(port) (0x2444 + ((port)<<10))
+#define MV643XX_ETH_PORT_STATUS_MODE_10_BIT (1<<0)
+#define MV643XX_ETH_PORT_STATUS_LINK_UP (1<<1)
+#define MV643XX_ETH_PORT_STATUS_FDX (1<<2)
+#define MV643XX_ETH_PORT_STATUS_FC (1<<3)
+#define MV643XX_ETH_PORT_STATUS_1000 (1<<4)
+#define MV643XX_ETH_PORT_STATUS_100 (1<<5)
+/* PSR bit 6 unknown */
+#define MV643XX_ETH_PORT_STATUS_TX_IN_PROGRESS (1<<7)
+#define MV643XX_ETH_PORT_STATUS_ANEG_BYPASSED (1<<8)
+#define MV643XX_ETH_PORT_STATUS_PARTITION (1<<9)
+#define MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY (1<<10)
+#define MV643XX_ETH_MIB_COUNTERS(port) (0x3000 + ((port)<<7))
+#define MV643XX_ETH_NUM_MIB_COUNTERS 32
+#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO (0)
+#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_HI (1<<2)
+#define MV643XX_ETH_MIB_BAD_OCTS_RCVD (2<<2)
+#define MV643XX_ETH_MIB_INTERNAL_MAC_TX_ERR (3<<2)
+#define MV643XX_ETH_MIB_GOOD_FRAMES_RCVD (4<<2)
+#define MV643XX_ETH_MIB_BAD_FRAMES_RCVD (5<<2)
+#define MV643XX_ETH_MIB_BCAST_FRAMES_RCVD (6<<2)
+#define MV643XX_ETH_MIB_MCAST_FRAMES_RCVD (7<<2)
+#define MV643XX_ETH_MIB_FRAMES_64_OCTS (8<<2)
+#define MV643XX_ETH_MIB_FRAMES_65_127_OCTS (9<<2)
+#define MV643XX_ETH_MIB_FRAMES_128_255_OCTS (10<<2)
+#define MV643XX_ETH_MIB_FRAMES_256_511_OCTS (11<<2)
+#define MV643XX_ETH_MIB_FRAMES_512_1023_OCTS (12<<2)
+#define MV643XX_ETH_MIB_FRAMES_1024_MAX_OCTS (13<<2)
+#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO (14<<2)
+#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_HI (15<<2)
+#define MV643XX_ETH_MIB_GOOD_FRAMES_SENT (16<<2)
+#define MV643XX_ETH_MIB_EXCESSIVE_COLL (17<<2)
+#define MV643XX_ETH_MIB_MCAST_FRAMES_SENT (18<<2)
+#define MV643XX_ETH_MIB_BCAST_FRAMES_SENT (19<<2)
+#define MV643XX_ETH_MIB_UNREC_MAC_CTRL_RCVD (20<<2)
+#define MV643XX_ETH_MIB_FC_SENT (21<<2)
+#define MV643XX_ETH_MIB_GOOD_FC_RCVD (22<<2)
+#define MV643XX_ETH_MIB_BAD_FC_RCVD (23<<2)
+#define MV643XX_ETH_MIB_UNDERSIZE_RCVD (24<<2)
+#define MV643XX_ETH_MIB_FRAGMENTS_RCVD (25<<2)
+#define MV643XX_ETH_MIB_OVERSIZE_RCVD (26<<2)
+#define MV643XX_ETH_MIB_JABBER_RCVD (27<<2)
+#define MV643XX_ETH_MIB_MAC_RX_ERR (28<<2)
+#define MV643XX_ETH_MIB_BAD_CRC_EVENT (29<<2)
+#define MV643XX_ETH_MIB_COLL (30<<2)
+#define MV643XX_ETH_MIB_LATE_COLL (31<<2)
+#define MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(port) (0x3400+((port)<<10))
+#define MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(port) (0x3500+((port)<<10))
+#define MV643XX_ETH_DA_FILTER_UNICAST_TBL(port) (0x3600+((port)<<10))
+#define MV643XX_ETH_NUM_MCAST_ENTRIES 64
+#define MV643XX_ETH_NUM_UNICAST_ENTRIES 4
+#define MV643XX_ETH_BAR_0 (0x2200)
+#define MV643XX_ETH_SIZE_R_0 (0x2204)
+#define MV643XX_ETH_BAR_1 (0x2208)
+#define MV643XX_ETH_SIZE_R_1 (0x220c)
+#define MV643XX_ETH_BAR_2 (0x2210)
+#define MV643XX_ETH_SIZE_R_2 (0x2214)
+#define MV643XX_ETH_BAR_3 (0x2218)
+#define MV643XX_ETH_SIZE_R_3 (0x221c)
+#define MV643XX_ETH_BAR_4 (0x2220)
+#define MV643XX_ETH_SIZE_R_4 (0x2224)
+#define MV643XX_ETH_BAR_5 (0x2228)
+#define MV643XX_ETH_SIZE_R_5 (0x222c)
+#define MV643XX_ETH_NUM_BARS 6
+/* Bits in the BAR reg to program cache snooping */
+#define MV64360_ENET2MEM_SNOOP_NONE 0x0000
+#define MV64360_ENET2MEM_SNOOP_WT 0x1000
+#define MV64360_ENET2MEM_SNOOP_WB 0x2000
+#define MV64360_ENET2MEM_SNOOP_MSK 0x3000
+#define MV643XX_ETH_BAR_ENBL_R (0x2290)
+#define MV643XX_ETH_BAR_DISABLE(bar) (1<<(bar))
+#define MV643XX_ETH_BAR_DISBL_ALL 0x3f
+#define MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(port) (0x260c+((port)<<10))
+#define MV643XX_ETH_RX_Q1_CURRENT_DESC_PTR(port) (0x261c+((port)<<10))
+#define MV643XX_ETH_RX_Q2_CURRENT_DESC_PTR(port) (0x262c+((port)<<10))
+#define MV643XX_ETH_RX_Q3_CURRENT_DESC_PTR(port) (0x263c+((port)<<10))
+#define MV643XX_ETH_RX_Q4_CURRENT_DESC_PTR(port) (0x264c+((port)<<10))
+#define MV643XX_ETH_RX_Q5_CURRENT_DESC_PTR(port) (0x265c+((port)<<10))
+#define MV643XX_ETH_RX_Q6_CURRENT_DESC_PTR(port) (0x266c+((port)<<10))
+#define MV643XX_ETH_RX_Q7_CURRENT_DESC_PTR(port) (0x267c+((port)<<10))
+#define MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(port) (0x26c0+((port)<<10))
+#define MV643XX_ETH_TX_Q1_CURRENT_DESC_PTR(port) (0x26c4+((port)<<10))
+#define MV643XX_ETH_TX_Q2_CURRENT_DESC_PTR(port) (0x26c8+((port)<<10))
+#define MV643XX_ETH_TX_Q3_CURRENT_DESC_PTR(port) (0x26cc+((port)<<10))
+#define MV643XX_ETH_TX_Q4_CURRENT_DESC_PTR(port) (0x26d0+((port)<<10))
+#define MV643XX_ETH_TX_Q5_CURRENT_DESC_PTR(port) (0x26d4+((port)<<10))
+#define MV643XX_ETH_TX_Q6_CURRENT_DESC_PTR(port) (0x26d8+((port)<<10))
+#define MV643XX_ETH_TX_Q7_CURRENT_DESC_PTR(port) (0x26dc+((port)<<10))
+#define MV643XX_ETH_MAC_ADDR_LO(port) (0x2414+((port)<<10))
+#define MV643XX_ETH_MAC_ADDR_HI(port) (0x2418+((port)<<10))
+/* TYPE DEFINITIONS */
+/* just to make the purpose explicit; vars of this
+ * type may need CPU-dependent address translation,
+ * endian conversion etc.
+typedef uint32_t Dma_addr_t;
+typedef volatile struct mveth_rx_desc {
+#ifndef __BIG_ENDIAN__
+#error "descriptor declaration not implemented for little endian machines"
+#endif
+ uint16_t byte_cnt;
+ uint16_t buf_size;
+ uint32_t cmd_sts; /* control and status */
+ Dma_addr_t next_desc_ptr; /* next descriptor (as seen from DMA) */
+ Dma_addr_t buf_ptr;
+ /* fields below here are not used by the chip */
+ void *u_buf; /* user buffer */
+ volatile struct mveth_rx_desc *next; /* next descriptor (CPU address; next_desc_ptr is a DMA address) */
+ uint32_t pad[2];
+} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthRxDescRec, *MvEthRxDesc;
+typedef volatile struct mveth_tx_desc {
+#endif
+ uint16_t l4i_chk;
+ uint32_t workaround[2]; /* use this space to work around the 8byte problem (is this real?) */
+ volatile struct mveth_tx_desc *next; /* next descriptor (CPU address; next_desc_ptr is a DMA address) */
+} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthTxDescRec, *MvEthTxDesc;
+/* Assume there are never more then 64k aliasing entries */
+typedef uint16_t Mc_Refcnt[MV643XX_ETH_NUM_MCAST_ENTRIES*4];
+/* driver private data and bsdnet interface structure */
+struct mveth_private {
+ MvEthRxDesc rx_ring; /* pointers to aligned ring area */
+ MvEthTxDesc tx_ring; /* pointers to aligned ring area */
+ MvEthRxDesc ring_area; /* allocated ring area */
+ int rbuf_count, xbuf_count; /* saved ring sizes from ifconfig */
+ int port_num;
+ int phy;
+ MvEthRxDesc d_rx_t; /* tail of the RX ring; next received packet */
+ MvEthTxDesc d_tx_t, d_tx_h;
+ uint32_t rx_desc_dma, tx_desc_dma; /* ring address as seen by DMA; (1:1 on this BSP) */
+ int avail;
+ void (*isr)(void*);
+ void *isr_arg;
+ /* Callbacks to handle buffers */
+ void (*cleanup_txbuf)(void*, void*, int); /* callback to cleanup TX buffer */
+ void *cleanup_txbuf_arg;
+ void *(*alloc_rxbuf)(int *psize, uintptr_t *paddr); /* allocate RX buffer */
+ void (*consume_rxbuf)(void*, void*, int); /* callback to consume RX buffer */
+ void *consume_rxbuf_arg;
+ rtems_id tid;
+ uint32_t irq_mask; /* IRQs we use */
+ uint32_t xirq_mask;
+ int promisc;
+ struct {
+ unsigned irqs;
+ unsigned maxchain;
+ unsigned repack;
+ unsigned packet;
+ unsigned odrops; /* no counter in core code */
+ struct {
+ uint64_t good_octs_rcvd; /* 64-bit */
+ uint32_t bad_octs_rcvd;
+ uint32_t internal_mac_tx_err;
+ uint32_t good_frames_rcvd;
+ uint32_t bad_frames_rcvd;
+ uint32_t bcast_frames_rcvd;
+ uint32_t mcast_frames_rcvd;
+ uint32_t frames_64_octs;
+ uint32_t frames_65_127_octs;
+ uint32_t frames_128_255_octs;
+ uint32_t frames_256_511_octs;
+ uint32_t frames_512_1023_octs;
+ uint32_t frames_1024_max_octs;
+ uint64_t good_octs_sent; /* 64-bit */
+ uint32_t good_frames_sent;
+ uint32_t excessive_coll;
+ uint32_t mcast_frames_sent;
+ uint32_t bcast_frames_sent;
+ uint32_t unrec_mac_ctrl_rcvd;
+ uint32_t fc_sent;
+ uint32_t good_fc_rcvd;
+ uint32_t bad_fc_rcvd;
+ uint32_t undersize_rcvd;
+ uint32_t fragments_rcvd;
+ uint32_t oversize_rcvd;
+ uint32_t jabber_rcvd;
+ uint32_t mac_rx_err;
+ uint32_t bad_crc_event;
+ uint32_t coll;
+ uint32_t late_coll;
+ } mib;
+ } stats;
+ struct {
+ Mc_Refcnt specl, other;
+ } mc_refcnt;
+/* stuff needed for bsdnet support */
+#ifdef BSDBSD
+struct mveth_bsdsupp {
+ int oif_flags; /* old / cached if_flags */
+#endif /*BSDBSD*/
+struct mveth_softc {
+#ifdef BSDBSD
+ struct arpcom arpcom;
+ struct mveth_bsdsupp bsd;
+#endif /*BSDBSD*/
+ struct mveth_private pvt;
+/* GLOBAL VARIABLES */
+#ifdef MVETH_DEBUG_TX_DUMP
+int mveth_tx_dump = 0;
+#endif
+/* THE array of driver/bsdnet structs */
+/* If detaching/module unloading is enabled, the main driver data
+ * structure must remain in memory; hence it must reside in its own
+ * 'dummy' module...
+#ifdef MVETH_DETACH_HACK
+extern
+#else
+STATIC
+#endif
+struct mveth_softc theMvEths[MV643XXETH_NUM_DRIVER_SLOTS]
+#ifndef MVETH_DETACH_HACK
+= {{{{0}},}}
+#endif
+#ifdef BSDBSD
+/* daemon task id */
+STATIC rtems_id mveth_tid = 0;
+#endif /*BSDBSD*/
+/* register access protection mutex */
+STATIC rtems_id mveth_mtx = 0;
+#define REGLOCK() do { \
+ if ( RTEMS_SUCCESSFUL != rtems_semaphore_obtain(mveth_mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT) ) \
+ rtems_panic(DRVNAME": unable to lock register protection mutex"); \
+ } while (0)
+#define REGUNLOCK() rtems_semaphore_release(mveth_mtx)
+/* Format strings for statistics messages */
+static const char *mibfmt[] = {
+ " GOOD_OCTS_RCVD: %"PRIu64"\n",
+ 0,
+ " BAD_OCTS_RCVD: %"PRIu32"\n",
+ " INTERNAL_MAC_TX_ERR: %"PRIu32"\n",
+ " GOOD_FRAMES_RCVD: %"PRIu32"\n",
+ " BAD_FRAMES_RCVD: %"PRIu32"\n",
+ " BCAST_FRAMES_RCVD: %"PRIu32"\n",
+ " MCAST_FRAMES_RCVD: %"PRIu32"\n",
+ " FRAMES_64_OCTS: %"PRIu32"\n",
+ " FRAMES_65_127_OCTS: %"PRIu32"\n",
+ " FRAMES_128_255_OCTS: %"PRIu32"\n",
+ " FRAMES_256_511_OCTS: %"PRIu32"\n",
+ " FRAMES_512_1023_OCTS:%"PRIu32"\n",
+ " FRAMES_1024_MAX_OCTS:%"PRIu32"\n",
+ " GOOD_OCTS_SENT: %"PRIu64"\n",
+ 0,
+ " GOOD_FRAMES_SENT: %"PRIu32"\n",
+ " EXCESSIVE_COLL: %"PRIu32"\n",
+ " MCAST_FRAMES_SENT: %"PRIu32"\n",
+ " BCAST_FRAMES_SENT: %"PRIu32"\n",
+ " UNREC_MAC_CTRL_RCVD: %"PRIu32"\n",
+ " FC_SENT: %"PRIu32"\n",
+ " GOOD_FC_RCVD: %"PRIu32"\n",
+ " BAD_FC_RCVD: %"PRIu32"\n",
+ " UNDERSIZE_RCVD: %"PRIu32"\n",
+ " FRAGMENTS_RCVD: %"PRIu32"\n",
+ " OVERSIZE_RCVD: %"PRIu32"\n",
+ " JABBER_RCVD: %"PRIu32"\n",
+ " MAC_RX_ERR: %"PRIu32"\n",
+ " BAD_CRC_EVENT: %"PRIu32"\n",
+ " COLL: %"PRIu32"\n",
+ " LATE_COLL: %"PRIu32"\n",
+/* Interrupt Handler Connection */
+/* forward decls + implementation for IRQ API funcs */
+static void mveth_isr(rtems_irq_hdl_param unit);
+static void mveth_isr_1(rtems_irq_hdl_param unit);
+static void noop(const rtems_irq_connect_data *unused) {}
+static int noop1(const rtems_irq_connect_data *unused) { return 0; }
+static rtems_irq_connect_data irq_data[MAX_NUM_SLOTS] = {
+ BSP_IRQ_ETH0,
+ 0,
+ (rtems_irq_hdl_param)0,
+ noop,
+ noop,
+ noop1
+ BSP_IRQ_ETH1,
+ 0,
+ (rtems_irq_hdl_param)1,
+ noop,
+ noop,
+ noop1
+ BSP_IRQ_ETH2,
+ 0,
+ (rtems_irq_hdl_param)2,
+ noop,
+ noop,
+ noop1
+/* MII Ioctl Interface */
+#ifdef BSDMII
+/* mdio / mii interface wrappers for rtems_mii_ioctl API */
+static int mveth_mdio_r(int phy, void *uarg, unsigned reg, uint32_t *pval)
+ if ( phy > 1 )
+ return -1;
+ *pval = mveth_mii_read(uarg, reg);
+ return 0;
+static int mveth_mdio_w(int phy, void *uarg, unsigned reg, uint32_t val)
+ if ( phy > 1 )
+ return -1;
+ mveth_mii_write(uarg, reg, val);
+ return 0;
+static struct rtems_mdio_info mveth_mdio = {
+ mdio_r: mveth_mdio_r,
+ mdio_w: mveth_mdio_w,
+ has_gmii: 1,
+/* LOW LEVEL SUPPORT ROUTINES */
+/* Software Cache Coherency */
+#ifndef ENABLE_HW_SNOOPING
+#ifndef __PPC__
+#error "Software cache coherency maintenance is not implemented for your CPU architecture"
+#endif
+static inline unsigned INVAL_DESC(volatile void *d)
+typedef const char cache_line[PPC_CACHE_ALIGNMENT];
+ asm volatile("dcbi 0, %1":"=m"(*(cache_line*)d):"r"(d));
+ return (unsigned)d; /* so this can be used in comma expression */
+static inline void FLUSH_DESC(volatile void *d)
+ asm volatile("dcbf 0, %0"::"r"(d),"m"(*(cache_line*)d));
+static inline void FLUSH_BARRIER(void)
+ asm volatile("eieio");
+/* RX buffers are always cache-line aligned
+ * ASSUMPTIONS:
+ * - 'addr' is cache aligned
+ * - len is a multiple >0 of cache lines
+static inline void INVAL_BUF(register uintptr_t addr, register int len)
+typedef char maxbuf[2048]; /* more than an ethernet packet */
+ do {
+ len -= RX_BUF_ALIGNMENT;
+ asm volatile("dcbi %0, %1"::"b"(addr),"r"(len));
+ } while (len > 0);
+ asm volatile("":"=m"(*(maxbuf*)addr));
+/* Flushing TX buffers is a little bit trickier; we don't really know their
+ * alignment but *assume* adjacent addresses are covering 'ordinary' memory
+ * so that flushing them does no harm!
+static inline void FLUSH_BUF(register uintptr_t addr, register int len)
+ asm volatile("":::"memory");
+ len = MV643XX_ALIGN(len, RX_BUF_ALIGNMENT);
+ do {
+ asm volatile("dcbf %0, %1"::"b"(addr),"r"(len));
+ } while ( len >= 0 );
+#else /* hardware snooping enabled */
+/* inline this to silence compiler warnings */
+static inline int INVAL_DESC(volatile void *d)
+{ return 0; }
+#define FLUSH_DESC(d) NOOP()
+#define INVAL_BUF(b,l) NOOP()
+#define FLUSH_BUF(b,l) NOOP()
+#define FLUSH_BARRIER() NOOP()
+#endif /* cache coherency support */
+/* Synchronize memory access */
+#ifdef __PPC__
+static inline void membarrier(void)
+ asm volatile("sync":::"memory");
+#else
+#error "memory barrier instruction not defined (yet) for this CPU"
+#endif
+/* Enable and disable interrupts at the device */
+static inline void
+mveth_enable_irqs(struct mveth_private *mp, uint32_t mask)
+rtems_interrupt_level l;
+uint32_t val;
+ rtems_interrupt_disable(l);
+ val = MV_READ(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num));
+ val = (val | mask | MV643XX_ETH_IRQ_EXT_ENA) & mp->irq_mask;
+ MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), val);
+ val = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
+ val = (val | mask) & mp->xirq_mask;
+ MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), val);
+ rtems_interrupt_enable(l);
+static inline uint32_t
+mveth_disable_irqs(struct mveth_private *mp, uint32_t mask)
+uint32_t val,xval,tmp;
+ tmp = ( (val & ~mask) | MV643XX_ETH_IRQ_EXT_ENA ) & mp->irq_mask;
+ MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), tmp);
+ xval = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
+ tmp = (xval & ~mask) & mp->xirq_mask;
+ MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), tmp);
+ return (val | xval);
+/* This should be safe even w/o turning off interrupts if multiple
+ * threads ack different bits in the cause register (and ignore
+ * other ones) since writing 'ones' into the cause register doesn't
+ * 'stick'.
+mveth_ack_irqs(struct mveth_private *mp, uint32_t mask)
+register uint32_t x,xe,p;
+ p = mp->port_num;
+ /* Get cause */
+ x = MV_READ(MV643XX_ETH_INTERRUPT_CAUSE_R(p));
+ /* Ack interrupts filtering the ones we're interested in */
+ /* Note: EXT_IRQ bit clears by itself if EXT interrupts are cleared */
+ MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(p), ~ (x & mp->irq_mask & mask));
+ /* linux driver tests 1<<1 as a summary bit for extended interrupts;
+ * the mv64360 seems to use 1<<19 for that purpose; for the moment,
+ * I just check both.
+ * Update: link status irq (1<<16 in xe) doesn't set (1<<19) in x!
+ if ( 1 /* x & 2 */ )
+ xe = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p));
+ MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p), ~ (xe & mp->xirq_mask & mask));
+ } else {
+ xe = 0;
+ if ( ((x & MV643XX_ETH_ALL_IRQS) & ~MV643XX_ETH_KNOWN_IRQS)
+ || ((xe & MV643XX_ETH_ALL_EXT_IRQS) & ~MV643XX_ETH_KNOWN_EXT_IRQS) ) {
+ fprintf(stderr, "Unknown IRQs detected; leaving all disabled for debugging:\n");
+ fprintf(stderr, "Cause reg was 0x%08x, ext cause 0x%08x\n", x, xe);
+ mp->irq_mask = 0;
+ mp->xirq_mask = 0;
+#endif
+ /* luckily, the extended and 'normal' interrupts we use don't overlap so
+ * we can just OR them into a single word
+ return (xe & mp->xirq_mask) | (x & mp->irq_mask);
+static void mveth_isr(rtems_irq_hdl_param arg)
+unsigned unit = (unsigned)arg;
+ mveth_disable_irqs(&theMvEths[unit].pvt, -1);
+ theMvEths[unit].pvt.stats.irqs++;
+#ifdef BSDBSD
+#warning FIXME
+ rtems_bsdnet_event_send( theMvEths[unit].pvt.tid, 1<<unit );
+#endif
+static void mveth_isr_1(rtems_irq_hdl_param arg)
+struct mveth_private *mp = &theMvEths[unit].pvt;
+ mp->stats.irqs++;
+ mp->isr(mp->isr_arg);
+static void
+mveth_clear_mib_counters(struct mveth_private *mp)
+register int i;
+register uint32_t b;
+ /* reading the counters resets them */
+ b = MV643XX_ETH_MIB_COUNTERS(mp->port_num);
+ for (i=0; i< MV643XX_ETH_NUM_MIB_COUNTERS; i++, b+=4)
+ (void)MV_READ(b);
+/* Reading a MIB register also clears it. Hence we read the lo
+ * register first, then the hi one. Correct reading is guaranteed since
+ * the 'lo' register cannot overflow after it is read since it had
+ * been reset to 0.
+static unsigned long long
+read_long_mib_counter(int port_num, int idx)
+unsigned long lo;
+unsigned long long hi;
+ lo = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+ idx++;
+ hi = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+ return (hi<<32) | lo;
+static inline unsigned long
+read_mib_counter(int port_num, int idx)
+ return MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
+/* write ethernet address from buffer to hardware (need to change unicast filter after this) */
+static void
+mveth_write_eaddr(struct mveth_private *mp, unsigned char *eaddr)
+int i;
+uint32_t x;
+ /* build hi word */
+ for (i=4,x=0; i; i--, eaddr++) {
+ x = (x<<8) | *eaddr;
+ MV_WRITE(MV643XX_ETH_MAC_ADDR_HI(mp->port_num), x);
+ /* build lo word */
+ for (i=2,x=0; i; i--, eaddr++) {
+ MV_WRITE(MV643XX_ETH_MAC_ADDR_LO(mp->port_num), x);
+/* PHY/MII Interface
+ * Read/write a PHY register;
+ * NOTE: The SMI register is shared among the three devices.
+ * Protection is provided by the global networking semaphore.
+ * If non-bsd drivers are running on a subset of IFs proper
+unsigned
+unsigned v;
+unsigned wc = 0;
+ addr &= 0x1f;
+ /* wait until not busy */
+ do {
+ v = MV_READ(MV643XX_ETH_SMI_R);
+ wc++;
+ } while ( MV643XX_ETH_SMI_BUSY & v );
+ MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_RD );
+ do {
+ wc++;
+ if (wc>0xffff)
+ wc = 0xffff;
+ return (wc<<16) | (v & 0xffff);
+unsigned
+unsigned wc = 0;
+ addr &= 0x1f;
+ v &= 0xffff;
+ /* busywait is ugly but not preventing ISRs or high priority tasks from
+ * preempting us
+ while ( MV643XX_ETH_SMI_BUSY & MV_READ(MV643XX_ETH_SMI_R) )
+ wc++ /* wait */;
+ MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_WR | v );
+ return wc;
+/* MID-LAYER SUPPORT ROUTINES */
+/* Start TX if descriptors are exhausted */
+static __inline__ void
+mveth_start_tx(struct mveth_private *mp)
+uint32_t running;
+ if ( mp->avail <= 0 ) {
+ running = MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num));
+ if ( ! (running & MV643XX_ETH_TX_START(0)) ) {
+ MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_TX_START(0));
+/* Stop TX and wait for the command queues to stop and the fifo to drain */
+static uint32_t
+mveth_stop_tx(int port)
+uint32_t active_q;
+ active_q = (MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) & MV643XX_ETH_TX_ANY_RUNNING);
+ if ( active_q ) {
+ /* Halt TX and wait for activity to stop */
+ MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port), MV643XX_ETH_TX_STOP_ALL);
+ while ( MV643XX_ETH_TX_ANY_RUNNING & MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) )
+ /* poll-wait */;
+ /* Wait for Tx FIFO to drain */
+ while ( ! (MV643XX_ETH_PORT_STATUS_R(port) & MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY) )
+ /* poll-wait */;
+ return active_q;
+/* update serial port settings from current link status */
+#ifdef BSDMII
+static void
+mveth_update_serial_port(struct mveth_private *mp, int media)
+int port = mp->port_num;
+uint32_t old, new;
+ new = old = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(port));
+ /* mask speed and duplex settings */
+ new &= ~( MV643XX_ETH_SET_GMII_SPEED_1000
+ | MV643XX_ETH_SET_MII_SPEED_100
+ | MV643XX_ETH_SET_FULL_DUPLEX );
+ if ( IFM_FDX & media )
+ new |= MV643XX_ETH_SET_FULL_DUPLEX;
+ switch ( IFM_SUBTYPE(media) ) {
+ default: /* treat as 10 */
+ break;
+ case IFM_100_TX:
+ new |= MV643XX_ETH_SET_MII_SPEED_100;
+ break;
+ case IFM_1000_T:
+ new |= MV643XX_ETH_SET_GMII_SPEED_1000;
+ break;
+ if ( new != old ) {
+ if ( ! (MV643XX_ETH_SERIAL_PORT_ENBL & new) ) {
+ /* just write */
+ MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), new);
+ } else {
+ uint32_t were_running;
+ were_running = mveth_stop_tx(port);
+ old &= ~MV643XX_ETH_SERIAL_PORT_ENBL;
+ MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), old);
+ /* linux driver writes twice... */
+ if ( were_running ) {
+#endif /*BSDMII*/
+void
+BSP_mve_mcast_filter_clear(struct mveth_private *mp)
+int i;
+register uint32_t s,o;
+uint32_t v = mp->promisc ? 0x01010101 : 0x00000000;
+ s = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
+ o = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
+ for (i=0; i<MV643XX_ETH_NUM_MCAST_ENTRIES; i++) {
+ MV_WRITE(s,v);
+ MV_WRITE(o,v);
+ s+=4;
+ o+=4;
+ for (i=0; i<sizeof(mp->mc_refcnt.specl)/sizeof(mp->mc_refcnt.specl[0]); i++) {
+ mp->mc_refcnt.specl[i] = 0;
+ mp->mc_refcnt.other[i] = 0;
+void
+BSP_mve_mcast_filter_accept_all(struct mveth_private *mp)
+int i;
+ MV_WRITE(s,0x01010101);
+ MV_WRITE(o,0x01010101);
+ s+=4;
+ o+=4;
+ /* Not clear what we should do with the reference count.
+ * For now just increment it.
+ mp->mc_refcnt.specl[i]++;
+ mp->mc_refcnt.other[i]++;
+static void add_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
+uint32_t val;
+uint32_t slot = hash & 0xfc;
+ if ( 0 == (*refcnt)[hash]++ ) {
+ val = MV_READ(off+slot) | ( 1 << ((hash&3)<<3) );
+ MV_WRITE(off+slot, val);
+static void del_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
+uint32_t val;
+ if ( (*refcnt)[hash] > 0 && 0 == --(*refcnt)[hash] ) {
+ val = MV_READ(off+slot) & ~( 1 << ((hash&3)<<3) );
+void
+BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr)
+uint32_t hash;
+static const char spec[]={0x01,0x00,0x5e,0x00,0x00};
+static const char bcst[]={0xff,0xff,0xff,0xff,0xff,0xff};
+uint32_t tabl;
+Mc_Refcnt *refcnt;
+ if ( ! (0x01 & enaddr[0]) ) {
+ /* not a multicast address; ignore */
+ return;
+ if ( 0 == memcmp(enaddr, bcst, sizeof(bcst)) ) {
+ /* broadcast address; ignore */
+ return;
+ if ( 0 == memcmp(enaddr, spec, sizeof(spec)) ) {
+ hash = enaddr[5];
+ tabl = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
+ refcnt = &mp->mc_refcnt.specl;
+ } else {
+ uint32_t test, mask;
+ int i;
+ /* algorithm used by linux driver */
+ for ( hash=0, i=0; i<6; i++ ) {
+ hash = (hash ^ enaddr[i]) << 8;
+ for ( test=0x8000, mask=0x8380; test>0x0080; test>>=1, mask>>=1 ) {
+ if ( hash & test )
+ hash ^= mask;
+ tabl = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
+ refcnt = &mp->mc_refcnt.other;
+ add_entry(tabl, hash, refcnt);
+void
+BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr)
+uint32_t hash;
+uint32_t tabl;
+Mc_Refcnt *refcnt;
+ return;
+ return;
+ hash = enaddr[5];
+ } else {
+ int i;
+ hash ^= mask;
+ del_entry(tabl, hash, refcnt);
+/* Clear all address filters (multi- and unicast) */
+static void
+mveth_clear_addr_filters(struct mveth_private *mp)
+register int i;
+register uint32_t u;
+ u = MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num);
+ for (i=0; i<MV643XX_ETH_NUM_UNICAST_ENTRIES; i++) {
+ MV_WRITE(u,0);
+ u+=4;
+ BSP_mve_mcast_filter_clear(mp);
+/* Setup unicast filter for a given MAC address (least significant nibble) */
+static void
+mveth_ucfilter(struct mveth_private *mp, unsigned char mac_lsbyte, int accept)
+unsigned nib, slot, bit;
+uint32_t val;
+ /* compute slot in table */
+ nib = mac_lsbyte & 0xf; /* strip nibble */
+ slot = nib & ~3; /* (nibble/4)*4 */
+ bit = (nib & 3)<<3; /* 8*(nibble % 4) */
+ val = MV_READ(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot);
+ if ( accept ) {
+ val |= 0x01 << bit;
+ } else {
+ val &= 0x0e << bit;
+ MV_WRITE(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot, val);
+#if defined( ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM ) && 0
+/* Currently unused; small unaligned buffers seem to be rare
+ * so we just use memcpy()...
+/* memcpy for 0..7 bytes; arranged so that gcc
+ * optimizes for powerpc...
+static inline void memcpy8(void *to, void *fr, unsigned x)
+register uint8_t *d = to, *s = fro;
+ d+=l; s+=l;
+ if ( l & 1 ) {
+ *--d=*--s;
+ if ( l & 2 ) {
+ /* pre-decrementing causes gcc to use auto-decrementing
+ * PPC instructions (lhzu rx, -2(ry))
+ d-=2; s-=2;
+ /* use memcpy; don't cast to short -- accessing
+ * misaligned data as short is not portable
+ * (but it works on PPC).
+ __builtin_memcpy(d,s,2);
+ if ( l & 4 ) {
+ d-=4; s-=4;
+ /* see above */
+ __builtin_memcpy(d,s,4);
+#endif
+#ifdef BSDBSD
+/* Assign values (buffer + user data) to a tx descriptor slot */
+static int
+mveth_assign_desc(MvEthTxDesc d, struct mbuf *m, unsigned long extra)
+int rval = (d->byte_cnt = m->m_len);
+ assert( !d->mb );
+ assert( m->m_len );
+#endif
+ /* set CRC on all descriptors; seems to be necessary */
+ d->cmd_sts = extra | (TDESC_GEN_CRC | TDESC_ZERO_PAD);
+#ifdef ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
+ /* The buffer must be 64bit aligned if the payload is <8 (??) */
+ if ( rval < 8 && ((mtod(m, uintptr_t)) & 7) ) {
+ d->buf_ptr = CPUADDR2ENET( d->workaround );
+ memcpy((void*)d->workaround, mtod(m, void*), rval);
+ } else
+#endif
+ d->buf_ptr = CPUADDR2ENET( mtod(m, unsigned long) );
+ d->l4i_chk = 0;
+ return rval;
+#endif /*BSDBSD*/
+static int
+mveth_assign_desc_raw(MvEthTxDesc d, void *buf, int len, unsigned long extra)
+int rval = (d->byte_cnt = len);
+ assert( !d->u_buf );
+ assert( len );
+#endif
+ if ( rval < 8 && ( ((uintptr_t)buf) & 7) ) {
+ memcpy((void*)d->workaround, buf, rval);
+ } else
+#endif
+ d->buf_ptr = CPUADDR2ENET( (unsigned long)buf );
+ d->l4i_chk = 0;
+ return rval;
+ * Ring Initialization
+ * ENDIAN ASSUMPTION: DMA engine matches CPU endianness (???)
+ * Linux driver discriminates __LITTLE and __BIG endian for re-arranging
+ * the u16 fields in the descriptor structs. However, no endian conversion
+ * is done on the individual fields (SDMA byte swapping is disabled on LE).
+STATIC int
+mveth_init_rx_desc_ring(struct mveth_private *mp)
+int i,sz;
+MvEthRxDesc d;
+uintptr_t baddr;
+ memset((void*)mp->rx_ring, 0, sizeof(*mp->rx_ring)*mp->rbuf_count);
+ mp->rx_desc_dma = CPUADDR2ENET(mp->rx_ring);
+ for ( i=0, d = mp->rx_ring; i<mp->rbuf_count; i++, d++ ) {
+ d->u_buf = mp->alloc_rxbuf(&sz, &baddr);
+ assert( d->u_buf );
+ /* could reduce the area to max. ethernet packet size */
+ INVAL_BUF(baddr, sz);
+#endif
+ d->buf_size = sz;
+ d->byte_cnt = 0;
+ d->cmd_sts = RDESC_DMA_OWNED | RDESC_INT_ENA;
+ d->next = mp->rx_ring + (i+1) % mp->rbuf_count;
+ d->buf_ptr = CPUADDR2ENET( baddr );
+ d->next_desc_ptr = CPUADDR2ENET(d->next);
+ FLUSH_DESC(d);
+ FLUSH_BARRIER();
+ mp->d_rx_t = mp->rx_ring;
+ /* point the chip to the start of the ring */
+ MV_WRITE(MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->rx_desc_dma);
+ return i;
+STATIC int
+mveth_init_tx_desc_ring(struct mveth_private *mp)
+int i;
+MvEthTxDesc d;
+ memset((void*)mp->tx_ring, 0, sizeof(*mp->tx_ring)*mp->xbuf_count);
+ /* DMA and CPU live in the same address space (rtems) */
+ mp->tx_desc_dma = CPUADDR2ENET(mp->tx_ring);
+ mp->avail = TX_AVAILABLE_RING_SIZE(mp);
+ for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++,d++ ) {
+ d->l4i_chk = 0;
+ d->byte_cnt = 0;
+ d->cmd_sts = 0;
+ d->buf_ptr = 0;
+ d->next = mp->tx_ring + (i+1) % mp->xbuf_count;
+ FLUSH_DESC(d);
+ FLUSH_BARRIER();
+ mp->d_tx_h = mp->d_tx_t = mp->tx_ring;
+ MV_WRITE(MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->tx_desc_dma);
+ return i;
+/* PUBLIC LOW-LEVEL DRIVER ACCESS */
+static struct mveth_private *
+mve_setup_internal(
+ int unit,
+ rtems_id tid,
+ void (*isr)(void*isr_arg),
+ void *isr_arg,
+ void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
+ void *cleanup_txbuf_arg,
+ void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
+ void (*consume_rxbuf)(void *user_buf, void *closure, int len),
+ void *consume_rxbuf_arg,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+struct mveth_private *mp;
+#ifdef BSDBSD
+struct ifnet *ifp;
+#endif
+int InstallISRSuccessful;
+ if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
+ printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
+ return 0;
+#ifdef BSDBSD
+#warning FIXME
+ ifp = &theMvEths[unit-1].arpcom.ac_if;
+ if ( ifp->if_init ) {
+ printk(DRVNAME": instance %i already attached.\n", unit);
+ return 0;
+#endif
+ if ( rx_ring_size < 0 && tx_ring_size < 0 )
+ return 0;
+ if ( MV_64360 != BSP_getDiscoveryVersion(0) ) {
+ printk(DRVNAME": not mv64360 chip\n");
+ return 0;
+ /* lazy init of mutex (non thread-safe! - we assume 1st initialization is single-threaded) */
+ if ( ! mveth_mtx ) {
+ rtems_status_code sc;
+ sc = rtems_semaphore_create(
+ rtems_build_name('m','v','e','X'),
+ 1,
+ RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY | RTEMS_DEFAULT_ATTRIBUTES,
+ 0,
+ &mveth_mtx);
+ if ( RTEMS_SUCCESSFUL != sc ) {
+ rtems_error(sc,DRVNAME": creating mutex\n");
+ rtems_panic("unable to proceed\n");
+ mp = &theMvEths[unit-1].pvt;
+ memset(mp, 0, sizeof(*mp));
+ mp->port_num = unit-1;
+ mp->phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*mp->port_num)) & 0x1f;
+ mp->tid = tid;
+ mp->isr = isr;
+ mp->isr_arg = isr_arg;
+ mp->cleanup_txbuf = cleanup_txbuf;
+ mp->cleanup_txbuf_arg = cleanup_txbuf_arg;
+ mp->alloc_rxbuf = alloc_rxbuf;
+ mp->consume_rxbuf = consume_rxbuf;
+ mp->consume_rxbuf_arg = consume_rxbuf_arg;
+ mp->rbuf_count = rx_ring_size ? rx_ring_size : MV643XX_RX_RING_SIZE;
+ mp->xbuf_count = tx_ring_size ? tx_ring_size : MV643XX_TX_RING_SIZE;
+ if ( mp->xbuf_count > 0 )
+ mp->xbuf_count += TX_NUM_TAG_SLOTS;
+ if ( mp->rbuf_count < 0 )
+ mp->rbuf_count = 0;
+ if ( mp->xbuf_count < 0 )
+ mp->xbuf_count = 0;
+#ifdef BSDBSD
+ /* allocate ring area; add 1 entry -- room for alignment */
+ assert( !mp->ring_area );
+ mp->ring_area = malloc(
+ sizeof(*mp->ring_area) *
+ (mp->rbuf_count + mp->xbuf_count + 1),
+ M_DEVBUF,
+ M_WAIT );
+ assert( mp->ring_area );
+#endif
+ BSP_mve_stop_hw(mp);
+ if ( irq_mask ) {
+ irq_data[mp->port_num].hdl = tid ? mveth_isr : mveth_isr_1;
+ InstallISRSuccessful = BSP_install_rtems_irq_handler( &irq_data[mp->port_num] );
+ assert( InstallISRSuccessful );
+#ifdef BSDBSD
+#warning fixme
+ /* mark as used */
+ ifp->if_init = (void*)(-1);
+#endif
+ if ( rx_ring_size < 0 )
+ irq_mask &= ~ MV643XX_ETH_IRQ_RX_DONE;
+ if ( tx_ring_size < 0 )
+ irq_mask &= ~ MV643XX_ETH_EXT_IRQ_TX_DONE;
+ mp->irq_mask = (irq_mask & MV643XX_ETH_IRQ_RX_DONE);
+ if ( (irq_mask &= (MV643XX_ETH_EXT_IRQ_TX_DONE | MV643XX_ETH_EXT_IRQ_LINK_CHG)) ) {
+ mp->irq_mask |= MV643XX_ETH_IRQ_EXT_ENA;
+ mp->xirq_mask = irq_mask;
+ } else {
+ return mp;
+BSP_mve_setup(
+ int unit,
+ rtems_id tid,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+struct ifnet *ifp;
+struct mveth_private *mp,
+ return 0;
+ if ( irq_mask && 0 == tid ) {
+ printk(DRVNAME": must supply a TID if irq_msk not zero\n");
+ return 0;
+ return 0;
+ if ( 0 == mve_setup_internal(
+ mp,
+ unit,
+ tid,
+ 0, 0,
+ cleanup_txbuf, cleanup_txbuf_arg,
+ alloc_rxbuf,
+ consume_rxbuf, consume_rxbuf_arg,
+ rx_ring_size, tx_ring_size,
+ irq_mask) ) {
+ return 0;
+ return mp;
+BSP_mve_setup_1(
+ int unit,
+ void (*isr)(void *isr_arg),
+ void *isr_arg,
+ int rx_ring_size,
+ int tx_ring_size,
+ int irq_mask
+ if ( irq_mask && 0 == isr ) {
+ printk(DRVNAME": must supply an ISR if irq_msk not zero\n");
+ return 0;
+ return mve_setup_internal(
+ unit,
+ 0,
+ isr, isr_arg,
+ alloc_rxbuf,
+ irq_mask);
+rtems_id
+BSP_mve_get_tid(struct mveth_private *mp)
+ return mp->tid;
+int
+BSP_mve_detach(struct mveth_private *mp)
+#ifdef BSDBSD
+int unit = mp->port_num;
+#endif
+ if ( mp->irq_mask || mp->xirq_mask ) {
+ if ( !BSP_remove_rtems_irq_handler( &irq_data[mp->port_num] ) )
+ return -1;
+#ifdef BSDBSD
+#warning FIXME
+ free( (void*)mp->ring_area, M_DEVBUF );
+#endif
+ __asm__ __volatile__("":::"memory");
+ /* mark as unused */
+#ifdef BSDBSD
+ theMvEths[unit].arpcom.ac_if.if_init = 0;
+#endif
+ return 0;
+/* MAIN RX-TX ROUTINES
+ * BSP_mve_swipe_tx(): descriptor scavenger; releases mbufs
+ * BSP_mve_send_buf(): xfer mbufs from IF to chip
+ * BSP_mve_swipe_rx(): enqueue received mbufs to interface
+ * allocate new ones and yield them to the
+ * chip.
+/* clean up the TX ring freeing up buffers */
+int
+BSP_mve_swipe_tx(struct mveth_private *mp)
+int rval = 0;
+register MvEthTxDesc d;
+ for ( d = mp->d_tx_t; d->buf_ptr; d = NEXT_TXD(d) ) {
+ INVAL_DESC(d);
+ if ( (TDESC_DMA_OWNED & d->cmd_sts)
+ && (uint32_t)d == MV_READ(MV643XX_ETH_CURRENT_SERVED_TX_DESC(mp->port_num)) )
+ break;
+ /* d->u_buf is only set on the last descriptor in a chain;
+ * we only count errors in the last descriptor;
+ if ( d->u_buf ) {
+ mp->cleanup_txbuf(d->u_buf, mp->cleanup_txbuf_arg, (d->cmd_sts & TDESC_ERROR) ? 1 : 0);
+ d->u_buf = 0;
+ d->buf_ptr = 0;
+ rval++;
+ mp->d_tx_t = d;
+ mp->avail += rval;
+ return rval;
+#ifdef BSDBSD
+/* allocate a new cluster and copy an existing chain there;
+ * old chain is released...
+static struct mbuf *
+repackage_chain(struct mbuf *m_head)
+struct mbuf *m;
+ MGETHDR(m, M_DONTWAIT, MT_DATA);
+ if ( !m ) {
+ goto bail;
+ MCLGET(m, M_DONTWAIT);
+ if ( !(M_EXT & m->m_flags) ) {
+ m_freem(m);
+ m = 0;
+ goto bail;
+ m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
+ m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
+bail:
+ m_freem(m_head);
+ return m;
+/* Enqueue a mbuf chain or a raw data buffer for transmission;
+ * RETURN: #bytes sent or -1 if there are not enough descriptors
+ * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
+ * OTOH, a raw data packet may be send (non-BSD driver) by pointing
+ * m_head to the start of the data and passing 'len' > 0.
+ * Comments: software cache-flushing incurs a penalty if the
+ * packet cannot be queued since it is flushed anyways.
+ * The algorithm is slightly more efficient in the normal
+ * case, though.
+int
+BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len)
+int rval;
+register MvEthTxDesc l,d,h;
+register struct mbuf *m1;
+int nmbs;
+int ismbuf = (len <= 0);
+/* Only way to get here is when we discover that the mbuf chain
+ * is too long for the tx ring
+startover:
+ rval = 0;
+ assert(m_head);
+#endif
+ /* if no descriptor is available; try to wipe the queue */
+ if ( (mp->avail < 1) && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
+ /* Maybe TX is stalled and needs to be restarted */
+ mveth_start_tx(mp);
+ return -1;
+ h = mp->d_tx_h;
+ assert( !h->buf_ptr );
+ assert( !h->mb );
+#endif
+ if ( ! (m1 = m_head) )
+ return 0;
+ if ( ismbuf ) {
+ /* find first mbuf with actual data */
+ while ( 0 == m1->m_len ) {
+ if ( ! (m1 = m1->m_next) ) {
+ /* end reached and still no data to send ?? */
+ m_freem(m_head);
+ return 0;
+ /* Don't use the first descriptor yet because BSP_mve_swipe_tx()
+ * needs mp->d_tx_h->buf_ptr == NULL as a marker. Hence, we
+ * start with the second mbuf and fill the first descriptor
+ * last.
+ l = h;
+ d = NEXT_TXD(h);
+ mp->avail--;
+ nmbs = 1;
+ if ( ismbuf ) {
+ register struct mbuf *m;
+ for ( m=m1->m_next; m; m=m->m_next ) {
+ if ( 0 == m->m_len )
+ continue; /* skip empty mbufs */
+ nmbs++;
+ if ( mp->avail < 1 && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
+ /* Maybe TX was stalled - try to restart */
+ /* not enough descriptors; cleanup...
+ * the first slot was never used, so we start
+ * at mp->d_tx_h->next;
+ for ( l = NEXT_TXD(h); l!=d; l=NEXT_TXD(l) ) {
+ assert( l->mb == 0 );
+#endif
+ l->buf_ptr = 0;
+ l->cmd_sts = 0;
+ mp->avail++;
+ mp->avail++;
+ if ( nmbs > TX_AVAILABLE_RING_SIZE(mp) ) {
+ /* this chain will never fit into the ring */
+ if ( nmbs > mp->stats.maxchain )
+ mp->stats.maxchain = nmbs;
+ mp->stats.repack++;
+ if ( ! (m_head = repackage_chain(m_head)) ) {
+ /* no cluster available */
+ mp->stats.odrops++;
+ return 0;
+ goto startover;
+ return -1;
+ mp->avail--;
+ assert( d != h );
+ assert( !d->buf_ptr );
+#endif
+ /* fill this slot */
+ rval += mveth_assign_desc(d, m, TDESC_DMA_OWNED);
+ FLUSH_BUF(mtod(m, uint32_t), m->m_len);
+ l = d;
+ d = NEXT_TXD(d);
+ FLUSH_DESC(l);
+ /* fill first slot - don't release to DMA yet */
+ rval += mveth_assign_desc(h, m1, TDESC_FRST);
+ FLUSH_BUF(mtod(m1, uint32_t), m1->m_len);
+ } else {
+ /* fill first slot with raw buffer - don't release to DMA yet */
+ rval += mveth_assign_desc_raw(h, data_p, len, TDESC_FRST);
+ FLUSH_BUF( (uint32_t)data_p, len);
+ /* tag last slot; this covers the case where 1st==last */
+ l->cmd_sts |= TDESC_LAST | TDESC_INT_ENA;
+ /* mbuf goes into last desc */
+ l->u_buf = m_head;
+ FLUSH_DESC(l);
+ /* Tag end; make sure chip doesn't try to read ahead of here! */
+ l->next->cmd_sts = 0;
+ FLUSH_DESC(l->next);
+ if ( (mveth_tx_dump & (1<<mp->port_num)) ) {
+ int ll,kk;
+ if ( ismbuf ) {
+ struct mbuf *m;
+ for ( kk=0, m=m_head; m; m=m->m_next) {
+ for ( ll=0; ll<m->m_len; ll++ ) {
+ printf("%02X ",*(mtod(m,char*) + ll));
+ if ( ((++kk)&0xf) == 0 )
+ printf("\n");
+ } else {
+ for ( ll=0; ll<len; ) {
+ printf("%02X ",*((char*)data_p + ll));
+ if ( ((++ll)&0xf) == 0 )
+ printf("\n");
+ printf("\n");
+#endif
+ membarrier();
+ /* turn over the whole chain by flipping ownership of the first desc */
+ h->cmd_sts |= TDESC_DMA_OWNED;
+ FLUSH_DESC(h);
+ membarrier();
+ /* notify the device */
+ /* Update softc */
+ mp->stats.packet++;
+ /* remember new head */
+ mp->d_tx_h = d;
+ return rval; /* #bytes sent */
+int
+BSP_mve_send_buf_raw(
+ struct mveth_private *mp,
+ void *head_p,
+ int h_len,
+ void *data_p,
+ int d_len)
+int rval;
+int needed;
+void *frst_buf;
+int frst_len;
+ rval = 0;
+ assert(header || data);
+#endif
+ needed = head_p && data_p ? 2 : 1;
+ if ( ( mp->avail < needed )
+ && ( MVETH_CLEAN_ON_SEND(mp) <= 0 || mp->avail < needed ) ) {
+ /* Maybe TX was stalled and needs a restart */
+ return -1;
+ h = mp->d_tx_h;
+ assert( !h->mb );
+#endif
+ /* find the 'first' user buffer */
+ if ( (frst_buf = head_p) ) {
+ frst_len = h_len;
+ } else {
+ frst_buf = data_p;
+ frst_len = d_len;
+ * start with the second (optional) slot and fill the first
+ * descriptor last.
+ l = h;
+ d = NEXT_TXD(h);
+ mp->avail--;
+ if ( needed > 1 ) {
+ mp->avail--;
+ assert( d != h );
+#endif
+ rval += mveth_assign_desc_raw(d, data_p, d_len, TDESC_DMA_OWNED);
+ FLUSH_BUF( (uint32_t)data_p, d_len );
+ d->u_buf = data_p;
+ l = d;
+ d = NEXT_TXD(d);
+ FLUSH_DESC(l);
+ rval += mveth_assign_desc_raw(h, frst_buf, frst_len, TDESC_FRST);
+ FLUSH_BUF( (uint32_t)frst_buf, frst_len);
+ /* first buffer of 'chain' goes into last desc */
+ l->u_buf = frst_buf;
+ FLUSH_DESC(l);
+ membarrier();
+ FLUSH_DESC(h);
+ membarrier();
+ if ( needed > mp->stats.maxchain )
+ mp->stats.maxchain = needed;
+ mp->d_tx_h = d;
+/* send received buffers upwards and replace them
+ * with freshly allocated ones;
+ * ASSUMPTION: buffer length NEVER changes and is set
+ * when the ring is initialized.
+ * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
+int
+BSP_mve_swipe_rx(struct mveth_private *mp)
+int rval = 0, err;
+register MvEthRxDesc d;
+void *newbuf;
+int sz;
+uintptr_t baddr;
+ for ( d = mp->d_rx_t; ! (INVAL_DESC(d), (RDESC_DMA_OWNED & d->cmd_sts)); d=NEXT_RXD(d) ) {
+ assert(d->u_buf);
+#endif
+ err = (RDESC_ERROR & d->cmd_sts);
+ if ( err || !(newbuf = mp->alloc_rxbuf(&sz, &baddr)) ) {
+ /* drop packet and recycle buffer */
+ newbuf = d->u_buf;
+ mp->consume_rxbuf(0, mp->consume_rxbuf_arg, err ? -1 : 0);
+ } else {
+ assert( d->byte_cnt > 0 );
+#endif
+ mp->consume_rxbuf(d->u_buf, mp->consume_rxbuf_arg, d->byte_cnt);
+#endif
+ d->u_buf = newbuf;
+ d->buf_ptr = CPUADDR2ENET(baddr);
+ d->buf_size = sz;
+ FLUSH_DESC(d);
+ membarrier();
+ FLUSH_DESC(d);
+ rval++;
+ MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_START(0));
+ mp->d_rx_t = d;
+ return rval;
+/* Stop hardware and clean out the rings */
+void
+BSP_mve_stop_hw(struct mveth_private *mp)
+MvEthTxDesc d;
+MvEthRxDesc r;
+int i;
+ mveth_disable_irqs(mp, -1);
+ mveth_stop_tx(mp->port_num);
+ /* cleanup TX rings */
+ if (mp->d_tx_t) { /* maybe ring isn't initialized yet */
+ for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++, d++ ) {
+ /* should be safe to clear ownership */
+ d->cmd_sts &= ~TDESC_DMA_OWNED;
+ FLUSH_DESC(d);
+ FLUSH_BARRIER();
+ BSP_mve_swipe_tx(mp);
+ assert( mp->d_tx_h == mp->d_tx_t );
+#endif
+ MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_STOP_ALL);
+ while ( MV643XX_ETH_RX_ANY_RUNNING & MV_READ(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num)) )
+ /* poll-wait */;
+ /* stop serial port */
+ MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num),
+ MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num))
+ & ~( MV643XX_ETH_SERIAL_PORT_ENBL | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE | MV643XX_ETH_FORCE_LINK_PASS)
+ /* clear pending interrupts */
+ MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(mp->port_num), 0);
+ MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(mp->port_num), 0);
+ /* cleanup RX rings */
+ if ( mp->rx_ring ) {
+ for ( i=0, r=mp->rx_ring; i<mp->rbuf_count; i++, r++ ) {
+ /* should be OK to clear ownership flag */
+ r->cmd_sts = 0;
+ FLUSH_DESC(r);
+ mp->consume_rxbuf(r->u_buf, mp->consume_rxbuf_arg, 0);
+ r->u_buf = 0;
+ FLUSH_BARRIER();
+uint32_t mveth_serial_ctrl_config_val = MVETH_SERIAL_CTRL_CONFIG_VAL;
+/* Fire up the low-level driver
+ * - make sure hardware is halted
+ * - enable cache snooping
+ * - clear address filters
+ * - clear mib counters
+ * - reset phy
+ * - initialize (or reinitialize) descriptor rings
+ * - check that the firmware has set up a reasonable mac address.
+ * - generate unicast filter entry for our mac address
+ * - write register config values to the chip
+ * - start hardware (serial port and SDMA)
+void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr)
+int i;
+uint32_t v;
+static int inited = 0;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"%i: Entering BSP_mve_init_hw()\n", mp->port_num+1);
+#endif
+ /* since enable/disable IRQ routine only operate on select bitsets
+ * we must make sure everything is masked initially.
+ MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), 0);
+ MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), 0);
+ memset(&mp->stats, 0, sizeof(mp->stats));
+ mp->promisc = promisc;
+ /* MotLoad has cache snooping disabled on the ENET2MEM windows.
+ * Some comments in (linux) indicate that there are errata
+ * which cause problems which would be a real bummer.
+ * We try it anyways...
+ if ( !inited ) {
+ unsigned long disbl, bar;
+ inited = 1; /* FIXME: non-thread safe lazy init */
+ disbl = MV_READ(MV643XX_ETH_BAR_ENBL_R);
+ /* disable all 6 windows */
+ MV_WRITE(MV643XX_ETH_BAR_ENBL_R, MV643XX_ETH_BAR_DISBL_ALL);
+ /* set WB snooping on enabled bars */
+ for ( i=0; i<MV643XX_ETH_NUM_BARS*8; i+=8 ) {
+ if ( (bar = MV_READ(MV643XX_ETH_BAR_0 + i)) && MV_READ(MV643XX_ETH_SIZE_R_0 + i) ) {
+ MV_WRITE(MV643XX_ETH_BAR_0 + i, bar | MV64360_ENET2MEM_SNOOP_WB);
+#else
+ MV_WRITE(MV643XX_ETH_BAR_0 + i, bar & ~MV64360_ENET2MEM_SNOOP_MSK);
+#endif
+ /* read back to flush fifo [linux comment] */
+ (void)MV_READ(MV643XX_ETH_BAR_0 + i);
+ /* restore/re-enable */
+ MV_WRITE(MV643XX_ETH_BAR_ENBL_R, disbl);
+ mveth_clear_mib_counters(mp);
+ mveth_clear_addr_filters(mp);
+/* Just leave it alone...
+ reset_phy();
+ if ( mp->rbuf_count > 0 ) {
+ mp->rx_ring = (MvEthRxDesc)MV643XX_ALIGN(mp->ring_area, RING_ALIGNMENT);
+ mveth_init_rx_desc_ring(mp);
+ if ( mp->xbuf_count > 0 ) {
+ mp->tx_ring = (MvEthTxDesc)mp->rx_ring + mp->rbuf_count;
+ mveth_init_tx_desc_ring(mp);
+ if ( enaddr ) {
+ /* set ethernet address from arpcom struct */
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"%i: Writing MAC addr ", mp->port_num+1);
+ for (i=5; i>=0; i--) {
+ printk("%02X%c", enaddr[i], i?':':'\n');
+#endif
+ mveth_write_eaddr(mp, enaddr);
+ /* set mac address and unicast filter */
+ uint32_t machi, maclo;
+ maclo = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
+ machi = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
+ /* ASSUME: firmware has set the mac address for us
+ * - if assertion fails, we have to do more work...
+ assert( maclo && machi && maclo != 0xffffffff && machi != 0xffffffff );
+ mveth_ucfilter(mp, maclo&0xff, 1/* accept */);
+ /* port, serial and sdma configuration */
+ v = MVETH_PORT_CONFIG_VAL;
+ if ( promisc ) {
+ /* multicast filters were already set up to
+ * accept everything (mveth_clear_addr_filters())
+ v |= MV643XX_ETH_UNICAST_PROMISC_MODE;
+ } else {
+ v &= ~MV643XX_ETH_UNICAST_PROMISC_MODE;
+ MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(mp->port_num),
+ v);
+ MV_WRITE(MV643XX_ETH_PORT_CONFIG_XTEND_R(mp->port_num),
+ MVETH_PORT_XTEND_CONFIG_VAL);
+ v = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
+ v &= ~(MVETH_SERIAL_CTRL_CONFIG_MSK);
+ v |= mveth_serial_ctrl_config_val;
+ MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
+#ifdef BSDMII
+#warning FIXME
+ i = IFM_MAKEWORD(0, 0, 0, 0);
+ if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
+ if ( (IFM_LINK_OK & i) ) {
+ mveth_update_serial_port(mp, i);
+#endif
+ /* enable serial port */
+ v | MV643XX_ETH_SERIAL_PORT_ENBL);
+#error "byte swapping needs to be disabled for little endian machines"
+#endif
+ MV_WRITE(MV643XX_ETH_SDMA_CONFIG_R(mp->port_num), MVETH_SDMA_CONFIG_VAL);
+ /* allow short frames */
+ MV_WRITE(MV643XX_ETH_RX_MIN_FRAME_SIZE_R(mp->port_num), MVETH_MIN_FRAMSZ_CONFIG_VAL);
+ /* TODO: set irq coalescing */
+ /* enable Rx */
+ mveth_enable_irqs(mp, -1);
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"%i: Leaving BSP_mve_init_hw()\n", mp->port_num+1);
+#endif
+/* read ethernet address from hw to buffer */
+void
+BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr)
+int i;
+uint32_t x;
+unsigned char buf[6], *eaddr;
+ eaddr = oeaddr ? oeaddr : buf;
+ eaddr += 5;
+ x = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
+ /* lo word */
+ for (i=2; i; i--, eaddr--) {
+ *eaddr = (unsigned char)(x & 0xff);
+ x>>=8;
+ x = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
+ /* hi word */
+ for (i=4; i; i--, eaddr--) {
+ x>>=8;
+ if ( !oeaddr ) {
+ printf("%02X",buf[0]);
+ for (i=1; i<sizeof(buf); i++)
+ printf(":%02X",buf[i]);
+ printf("\n");
+#ifdef BSDMII
+int
+BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg)
+int rval;
+ /* alias cmd == 0,1 */
+ switch ( cmd ) {
+ case 0: cmd = SIOCGIFMEDIA;
+ break;
+ case 1: cmd = SIOCSIFMEDIA;
+ case SIOCGIFMEDIA:
+ case SIOCSIFMEDIA:
+ break;
+ default: return -1;
+ REGLOCK();
+ rval = rtems_mii_ioctl(&mveth_mdio, mp, cmd, parg);
+ REGUNLOCK();
+ return rval;
+#endif
+void
+BSP_mve_enable_irqs(struct mveth_private *mp)
+void
+BSP_mve_disable_irqs(struct mveth_private *mp)
+uint32_t
+BSP_mve_ack_irqs(struct mveth_private *mp)
+ return mveth_ack_irqs(mp, -1);
+void
+BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask)
+ mveth_enable_irqs(mp, mask);
+uint32_t
+BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask)
+ return mveth_disable_irqs(mp, mask);
+uint32_t
+BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask)
+ return mveth_ack_irqs(mp, mask);
+#ifdef BSDMII
+int
+BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
+int media = IFM_MAKEWORD(0,0,0,0);
+ if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
+ if ( IFM_LINK_OK & media ) {
+ mveth_update_serial_port(mp, media);
+ /* If TX stalled because there was no buffer then whack it */
+ if ( pmedia )
+ *pmedia = media;
+ return 0;
+ return -1;
+#endif
+#ifdef BSDBSD
+/* BSDNET SUPPORT/GLUE ROUTINES */
+static void
+mveth_set_filters(struct ifnet *ifp);
+STATIC void
+mveth_stop(struct mveth_softc *sc)
+ BSP_mve_stop_hw(&sc->pvt);
+ sc->arpcom.ac_if.if_timer = 0;
+/* allocate a mbuf for RX with a properly aligned data buffer
+ * RETURNS 0 if allocation fails
+static void *
+alloc_mbuf_rx(int *psz, uintptr_t *paddr)
+struct mbuf *m;
+unsigned long l,o;
+ if ( !m )
+ return 0;
+ if ( ! (m->m_flags & M_EXT) ) {
+ m_freem(m);
+ return 0;
+ o = mtod(m, unsigned long);
+ l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
+ /* align start of buffer */
+ m->m_data += l;
+ /* reduced length */
+ l = MCLBYTES - l;
+ m->m_len = m->m_pkthdr.len = l;
+ *psz = m->m_len;
+ *paddr = mtod(m, uintptr_t);
+ return (void*) m;
+static void consume_rx_mbuf(void *buf, void *arg, int len)
+struct ifnet *ifp = arg;
+struct mbuf *m = buf;
+ if ( len <= 0 ) {
+ ifp->if_iqdrops++;
+ if ( len < 0 ) {
+ ifp->if_ierrors++;
+ if ( m )
+ m_freem(m);
+ } else {
+ struct ether_header *eh;
+ eh = (struct ether_header *)(mtod(m, unsigned long) + ETH_RX_OFFSET);
+ m->m_len = m->m_pkthdr.len = len - sizeof(struct ether_header) - ETH_RX_OFFSET - ETH_CRC_LEN;
+ m->m_data += sizeof(struct ether_header) + ETH_RX_OFFSET;
+ m->m_pkthdr.rcvif = ifp;
+ ifp->if_ipackets++;
+ ifp->if_ibytes += m->m_pkthdr.len;
+ if (0) {
+ /* Low-level debugging */
+ int i;
+ for (i=0; i<13; i++) {
+ printf("%02X:",((char*)eh)[i]);
+ printf("%02X\n",((char*)eh)[i]);
+ for (i=0; i<m->m_len; i++) {
+ if ( !(i&15) )
+ printf("\n");
+ printf("0x%02x ",mtod(m,char*)[i]);
+ printf("\n");
+ if (0) {
+ /* Low-level debugging/testing without bsd stack */
+ m_freem(m);
+ } else {
+ /* send buffer upwards */
+ ether_input(ifp, eh, m);
+static void release_tx_mbuf(void *buf, void *arg, int err)
+struct mbuf *mb = buf;
+ if ( err ) {
+ ifp->if_oerrors++;
+ } else {
+ ifp->if_opackets++;
+ ifp->if_obytes += mb->m_pkthdr.len;
+ m_freem(mb);
+#endif /*BSDBSD*/
+static void
+dump_update_stats(struct mveth_private *mp, FILE *f)
+int p = mp->port_num;
+int idx;
+uint32_t v;
+ if ( !f )
+ f = stdout;
+ fprintf(f, DRVNAME"%i Statistics:\n", mp->port_num + 1);
+ fprintf(f, " # IRQS: %i\n", mp->stats.irqs);
+ fprintf(f, " Max. mbuf chain length: %i\n", mp->stats.maxchain);
+ fprintf(f, " # repacketed: %i\n", mp->stats.repack);
+ fprintf(f, " # packets: %i\n", mp->stats.packet);
+ fprintf(f, "MIB Counters:\n");
+ for ( idx = MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2;
+ idx < MV643XX_ETH_NUM_MIB_COUNTERS;
+ idx++ ) {
+ switch ( idx ) {
+ case MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2:
+ mp->stats.mib.good_octs_rcvd += read_long_mib_counter(p, idx);
+ fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_rcvd);
+ idx++;
+ break;
+ case MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO>>2:
+ mp->stats.mib.good_octs_sent += read_long_mib_counter(p, idx);
+ fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_sent);
+ idx++;
+ break;
+ default:
+ v = ((uint32_t*)&mp->stats.mib)[idx] += read_mib_counter(p, idx);
+ fprintf(f, mibfmt[idx], v);
+ break;
+ fprintf(f, "\n");
+void
+BSP_mve_dump_stats(struct mveth_private *mp, FILE *f)
+ dump_update_stats(mp, f);
+#ifdef BSDBSD
+/* BSDNET DRIVER CALLBACKS */
+static void
+mveth_init(void *arg)
+struct mveth_softc *sc = arg;
+struct ifnet *ifp = &sc->arpcom.ac_if;
+int media;
+ BSP_mve_init_hw(&sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
+ media = IFM_MAKEWORD(0, 0, 0, 0);
+ if ( 0 == BSP_mve_media_ioctl(&sc->pvt, SIOCGIFMEDIA, &media) ) {
+ if ( (IFM_LINK_OK & media) ) {
+ ifp->if_flags &= ~IFF_OACTIVE;
+ } else {
+ ifp->if_flags |= IFF_OACTIVE;
+ /* if promiscuous then there is no need to change */
+ if ( ! (ifp->if_flags & IFF_PROMISC) )
+ mveth_set_filters(ifp);
+ ifp->if_flags |= IFF_RUNNING;
+/* bsdnet driver entry to start transmission */
+static void
+mveth_start(struct ifnet *ifp)
+struct mveth_softc *sc = ifp->if_softc;
+struct mbuf *m = 0;
+ while ( ifp->if_snd.ifq_head ) {
+ IF_DEQUEUE( &ifp->if_snd, m );
+ if ( BSP_mve_send_buf(&sc->pvt, m, 0, 0) < 0 ) {
+ IF_PREPEND( &ifp->if_snd, m);
+ break;
+ /* need to do this really only once
+ * but it's cheaper this way.
+ ifp->if_timer = 2*IFNET_SLOWHZ;
+/* bsdnet driver entry; */
+static void
+mveth_watchdog(struct ifnet *ifp)
+ printk(DRVNAME"%i: watchdog timeout; resetting\n", ifp->if_unit);
+ mveth_init(sc);
+ mveth_start(ifp);
+static void
+uint32_t v;
+ v = MV_READ(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num));
+ if ( ifp->if_flags & IFF_PROMISC )
+ else
+ MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num), v);
+ if ( ifp->if_flags & (IFF_PROMISC | IFF_ALLMULTI) ) {
+ BSP_mve_mcast_filter_accept_all(&sc->pvt);
+ } else {
+ struct ether_multi *enm;
+ struct ether_multistep step;
+ BSP_mve_mcast_filter_clear( &sc->pvt );
+ ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
+ while ( enm ) {
+ if ( memcmp(enm->enm_addrlo, enm->enm_addrhi, ETHER_ADDR_LEN) )
+ assert( !"Should never get here; IFF_ALLMULTI should be set!" );
+ BSP_mve_mcast_filter_accept_add(&sc->pvt, enm->enm_addrlo);
+ ETHER_NEXT_MULTI(step, enm);
+/* bsdnet driver ioctl entry */
+static int
+mveth_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
+struct ifreq *ifr = (struct ifreq *)data;
+int error = 0;
+int f;
+ switch ( cmd ) {
+ case SIOCSIFFLAGS:
+ f = ifp->if_flags;
+ if ( f & IFF_UP ) {
+ if ( ! ( f & IFF_RUNNING ) ) {
+ mveth_init(sc);
+ } else {
+ if ( (f & IFF_PROMISC) != (sc->bsd.oif_flags & IFF_PROMISC) ) {
+ /* Note: in all other scenarios the 'promisc' flag
+ * in the low-level driver [which affects the way
+ * the multicast filter is setup: accept none vs.
+ * accept all in promisc mode] is eventually
+ * set when the IF is brought up...
+ sc->pvt.promisc = (f & IFF_PROMISC);
+ /* FIXME: other flag changes are ignored/unimplemented */
+ } else {
+ if ( f & IFF_RUNNING ) {
+ mveth_stop(sc);
+ ifp->if_flags &= ~(IFF_RUNNING | IFF_OACTIVE);
+ sc->bsd.oif_flags = ifp->if_flags;
+ break;
+ error = BSP_mve_media_ioctl(&sc->pvt, cmd, &ifr->ifr_media);
+ break;
+ case SIOCADDMULTI:
+ case SIOCDELMULTI:
+ error = (cmd == SIOCADDMULTI)
+ ? ether_addmulti(ifr, &sc->arpcom)
+ : ether_delmulti(ifr, &sc->arpcom);
+ if (error == ENETRESET) {
+ if (ifp->if_flags & IFF_RUNNING) {
+ error = 0;
+ break;
+ break;
+ case SIO_RTEMS_SHOW_STATS:
+ dump_update_stats(&sc->pvt, stdout);
+ break;
+ default:
+ error = ether_ioctl(ifp, cmd, data);
+ break;
+ return error;
+/* DRIVER TASK */
+/* Daemon task does all the 'interrupt' work */
+static void mveth_daemon(void *arg)
+struct mveth_softc *sc;
+struct ifnet *ifp;
+rtems_event_set evs;
+ for (;;) {
+ rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
+ evs &= 7;
+ for ( sc = theMvEths; evs; evs>>=1, sc++ ) {
+ if ( (evs & 1) ) {
+ register uint32_t x;
+ ifp = &sc->arpcom.ac_if;
+ if ( !(ifp->if_flags & IFF_UP) ) {
+ mveth_stop(sc);
+ ifp->if_flags &= ~(IFF_UP|IFF_RUNNING);
+ continue;
+ if ( !(ifp->if_flags & IFF_RUNNING) ) {
+ /* event could have been pending at the time hw was stopped;
+ * just ignore...
+ continue;
+ x = mveth_ack_irqs(&sc->pvt, -1);
+ if ( MV643XX_ETH_EXT_IRQ_LINK_CHG & x ) {
+ /* phy status changed */
+ int media;
+ if ( 0 == BSP_mve_ack_link_chg(&sc->pvt, &media) ) {
+ mveth_start(ifp);
+ } else {
+ /* stop sending */
+ /* free tx chain */
+ if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(&sc->pvt) ) {
+ if ( TX_AVAILABLE_RING_SIZE(&sc->pvt) == sc->pvt.avail )
+ ifp->if_timer = 0;
+ mveth_start(ifp);
+ if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
+ BSP_mve_swipe_rx(&sc->pvt);
+ mveth_enable_irqs(&sc->pvt, -1);
+static int mveth_detach(struct mveth_softc *sc);
+#endif
+/* PUBLIC RTEMS BSDNET ATTACH FUNCTION */
+int
+rtems_mve_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching)
+char *unitName;
+int unit,i,cfgUnits;
+struct ifnet *ifp;
+ unit = rtems_bsdnet_parse_driver_name(ifcfg, &unitName);
+ return 1;
+ sc = &theMvEths[unit-1];
+ sc->pvt.port_num = unit-1;
+ sc->pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*sc->pvt.port_num)) & 0x1f;
+ if ( attaching ) {
+ return -1;
+ for ( i=cfgUnits = 0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
+ if ( theMvEths[i].arpcom.ac_if.if_init )
+ cfgUnits++;
+ cfgUnits++; /* this new one */
+ /* lazy init of TID should still be thread-safe because we are protected
+ * by the global networking semaphore..
+ if ( !mveth_tid ) {
+ /* newproc uses the 1st 4 chars of name string to build an rtems name */
+ mveth_tid = rtems_bsdnet_newproc("MVEd", 4096, mveth_daemon, 0);
+ if ( !BSP_mve_setup( unit,
+ mveth_tid,
+ release_tx_mbuf, ifp,
+ alloc_mbuf_rx,
+ consume_rx_mbuf, ifp,
+ ifcfg->rbuf_count,
+ ifcfg->xbuf_count,
+ BSP_MVE_IRQ_TX | BSP_MVE_IRQ_RX | BSP_MVE_IRQ_LINK) ) {
+ return -1;
+ if ( nmbclusters < sc->pvt.rbuf_count * cfgUnits + 60 /* arbitrary */ ) {
+ printk(DRVNAME"%i: (mv643xx ethernet) Your application has not enough mbuf clusters\n", unit);
+ printk( " configured for this driver.\n");
+ return -1;
+ if ( ifcfg->hardware_address ) {
+ memcpy(sc->arpcom.ac_enaddr, ifcfg->hardware_address, ETHER_ADDR_LEN);
+ } else {
+ /* read back from hardware assuming that MotLoad already had set it up */
+ BSP_mve_read_eaddr(&sc->pvt, sc->arpcom.ac_enaddr);
+ ifp->if_softc = sc;
+ ifp->if_unit = unit;
+ ifp->if_name = unitName;
+ ifp->if_mtu = ifcfg->mtu ? ifcfg->mtu : ETHERMTU;
+ ifp->if_init = mveth_init;
+ ifp->if_ioctl = mveth_ioctl;
+ ifp->if_start = mveth_start;
+ ifp->if_output = ether_output;
+ * While nonzero, the 'if->if_timer' is decremented
+ * (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
+ * is called when it expires.
+ * If either of those fields is 0 the feature is disabled.
+ ifp->if_watchdog = mveth_watchdog;
+ sc->bsd.oif_flags = /* ... */
+ ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
+ * if unset, this set to 10Mbps by ether_ifattach; seems to be unused by bsdnet stack;
+ * could be updated along with phy speed, though...
+ ifp->if_baudrate = 10000000;
+ /* NOTE: ether_output drops packets if ifq_len >= ifq_maxlen
+ * but this is the packet count, not the fragment count!
+ ifp->if_snd.ifq_maxlen = sc->pvt.xbuf_count;
+ ifp->if_snd.ifq_maxlen = ifqmaxlen;
+ if ( !ifp->if_addrlist ) /* do only the first time [reattach hack] */
+#endif
+ if_attach(ifp);
+ ether_ifattach(ifp);
+ } else {
+ if ( !ifp->if_init ) {
+ printk(DRVNAME": instance %i not attached.\n", unit);
+ return -1;
+ return mveth_detach(sc);
+#else
+ printk(DRVNAME": interface detaching not implemented\n");
+ return -1;
+#endif
+ return 0;
+/* EARLY PHY ACCESS */
+static int
+mveth_early_init(int idx)
+ if ( idx < 0 || idx >= MV643XXETH_NUM_DRIVER_SLOTS )
+ return -1;
+ /* determine the phy */
+ theMvEths[idx].pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*idx)) & 0x1f;
+ return 0;
+static int
+mveth_early_read_phy(int idx, unsigned reg)
+int rval;
+ return -1;
+ rval = mveth_mii_read(&theMvEths[idx].pvt, reg);
+ return rval < 0 ? rval : rval & 0xffff;
+static int
+mveth_early_write_phy(int idx, unsigned reg, unsigned val)
+ return -1;
+ mveth_mii_write(&theMvEths[idx].pvt, reg, val);
+ return 0;
+rtems_bsdnet_early_link_check_ops
+rtems_mve_early_link_check_ops = {
+ init: mveth_early_init,
+ read_phy: mveth_early_read_phy,
+ write_phy: mveth_early_write_phy,
+ name: DRVNAME,
+ num_slots: MAX_NUM_SLOTS
+/* DEBUGGING */
+#endif /*BSDBSD*/
+#ifdef MVETH_DEBUG
+/* Display/dump descriptor rings */
+int
+mveth_dring(struct mveth_softc *sc)
+int i;
+if (1) {
+MvEthRxDesc pr;
+printf("RX:\n");
+ for (i=0, pr=sc->pvt.rx_ring; i<sc->pvt.rbuf_count; i++, pr++) {
+ /* can't just invalidate the descriptor - if it contains
+ * data that hasn't been flushed yet, we create an inconsistency...
+ rtems_bsdnet_semaphore_obtain();
+ INVAL_DESC(pr);
+#endif
+ printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
+ pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
+ rtems_bsdnet_semaphore_release();
+#endif
+if (1) {
+MvEthTxDesc pt;
+printf("TX:\n");
+ for (i=0, pt=sc->pvt.tx_ring; i<sc->pvt.xbuf_count; i++, pt++) {
+ INVAL_DESC(pt);
+#endif
+ printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
+ pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
+ (uint32_t)pt->mb);
+#endif
+ return 0;
+#endif
+/* DETACH HACK DETAILS */
+int
+_cexpModuleFinalize(void *mh)
+int i;
+ for ( i=0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
+ if ( theMvEths[i].arpcom.ac_if.if_init ) {
+ printf("Interface %i still attached; refuse to unload\n", i+1);
+ return -1;
+ /* delete task; since there are no attached interfaces, it should block
+ * for events and hence not hold the semaphore or other resources...
+ rtems_task_delete(mveth_tid);
+ return 0;
+/* ugly hack to allow unloading/reloading the driver core.
+ * needed because rtems' bsdnet release doesn't implement
+ * if_detach(). Therefore, we bring the interface down but
+ * keep the device record alive...
+static void
+ether_ifdetach_pvt(struct ifnet *ifp)
+ ifp->if_flags = 0;
+ ifp->if_ioctl = 0;
+ ifp->if_start = 0;
+ ifp->if_watchdog = 0;
+ ifp->if_init = 0;
+static int
+mveth_detach(struct mveth_softc *sc)
+ if ( ifp->if_flags & (IFF_UP | IFF_RUNNING) ) {
+ printf(DRVNAME"%i: refuse to detach; interface still up\n",sc->pvt.port_num+1);
+ return -1;
+ mveth_stop(sc);
+/* not implemented in BSDnet/RTEMS (yet) but declared in header */
+#define ether_ifdetach ether_ifdetach_pvt
+ ether_ifdetach(ifp);
+ free( (void*)sc->pvt.ring_area, M_DEVBUF );
+ sc->pvt.ring_area = 0;
+ sc->pvt.tx_ring = 0;
+ sc->pvt.rx_ring = 0;
+ sc->pvt.d_tx_t = sc->pvt.d_tx_h = 0;
+ sc->pvt.d_rx_t = 0;
+ sc->pvt.avail = 0;
+ /* may fail if ISR was not installed yet */
+ BSP_remove_rtems_irq_handler( &irq_data[sc->pvt.port_num] );
+ return 0;
+#ifdef MVETH_DEBUG
+struct rtems_bsdnet_ifconfig mveth_dbg_config = {
+ name: DRVNAME"1",
+ attach: rtems_mve_attach,
+ ip_address: "192.168.2.10", /* not used by rtems_bsdnet_attach */
+ ip_netmask: "255.255.255.0", /* not used by rtems_bsdnet_attach */
+ hardware_address: 0, /* (void *) */
+ ignore_broadcast: 0, /* TODO driver should honour this */
+ mtu: 0,
+ rbuf_count: 0, /* TODO driver should honour this */
+ xbuf_count: 0, /* TODO driver should honour this */
+#endif
+#endif
diff --git a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
index 10c3652f97..6cc419966d 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
@@ -84,13 +84,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/pci/motload_fixu
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/pci/pcifinddevice.c
#network
+# low-level driver
+librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
if HAS_NETWORKING
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em_hw.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em_rtems.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_gfe/if_gfe.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/support/bsp_attach.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/support/early_link_status.c
endif
2.26.2
