[PATCH rtems 07/18] mv643xx_eth_bsdnet.c: removed leftover macros
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:39 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4344
.../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 352 +-----------------
1 file changed, 8 insertions(+), 344 deletions(-)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index b3ec1542ff..e233f96dde 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -132,11 +132,6 @@
/* CONFIGURABLE PARAMETERS */
-/* Enable Hardware Snooping; if this is disabled (undefined),
- * cache coherency is maintained by software.
-#undef ENABLE_HW_SNOOPING
/* Compile-time debugging features */
/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing */
@@ -189,8 +184,6 @@
#define MV643XXETH_NUM_DRIVER_SLOTS 2
#endif
-#define TX_NUM_TAG_SLOTS 1 /* leave room for tag; must not be 0 */
#define DRVNAME "mve"
#define MAX_NUM_SLOTS 3
@@ -204,32 +197,8 @@
#define STATIC static
#endif
-struct mveth_private *
-BSP_mve_setup(
- int unit,
- rtems_id tid,
- void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
- void *cleanup_txbuf_arg,
- void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
- void (*consume_rxbuf)(void *user_buf, void *closure, int len),
- void *consume_rxbuf_arg,
- int rx_ring_size,
- int tx_ring_size,
- int irq_mask
-#define TX_AVAILABLE_RING_SIZE(mp) ((mp)->xbuf_count - (TX_NUM_TAG_SLOTS))
/* macros for ring alignment; proper alignment is a hardware req; . */
-#ifdef ENABLE_HW_SNOOPING
-#define RING_ALIGNMENT 16
-/* rx buffers must be 64-bit aligned (chip requirement) */
-#define RX_BUF_ALIGNMENT 8
-#else /* ENABLE_HW_SNOOPING */
/* Software cache management */
#ifndef __PPC__
@@ -247,292 +216,17 @@ BSP_mve_setup(
#define RX_BUF_ALIGNMENT PPC_CACHE_ALIGNMENT
#endif
-#endif /* ENABLE_HW_SNOOPING */
/* HELPER MACROS */
/* Align base to alignment 'a' */
#define MV643XX_ALIGN(b, a) ((((uint32_t)(b)) + (a)-1) & (~((a)-1)))
-#define NOOP() do {} while(0)
-/* Function like macros */
-#define MV_READ(off) \
- ld_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)))
-#define MV_WRITE(off, data) \
- st_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)), ((unsigned)data))
-/* ENET window mapped 1:1 to CPU addresses by our BSP/MotLoad
- * -- if this is changed, we should think about caching the 'next' and 'buf' pointers.
-#define CPUADDR2ENET(a) ((Dma_addr_t)(a))
-#define ENET2CPUADDR(a) (a)
-#if 1 /* Whether to automatically try to reclaim descriptors when enqueueing new packets */
-#define MVETH_CLEAN_ON_SEND(mp) (BSP_mve_swipe_tx(mp))
-#else
-#define MVETH_CLEAN_ON_SEND(mp) (-1)
-#endif
-#define NEXT_TXD(d) (d)->next
-#define NEXT_RXD(d) (d)->next
-/* REGISTER AND DESCRIPTOR OFFSET AND BIT DEFINITIONS */
-/* Descriptor Definitions */
-/* Rx descriptor */
-#define RDESC_ERROR (1<< 0) /* Error summary */
-/* Error code (bit 1&2) is only valid if summary bit is set */
-#define RDESC_CRC_ERROR ( 1)
-#define RDESC_OVERRUN_ERROR ( 3)
-#define RDESC_MAX_FRAMELENGTH_ERROR ( 5)
-#define RDESC_RESOURCE_ERROR ( 7)
-#define RDESC_LAST (1<<26) /* Last Descriptor */
-#define RDESC_FRST (1<<27) /* First Descriptor */
-#define RDESC_INT_ENA (1<<29) /* Enable Interrupts */
-#define RDESC_DMA_OWNED (1<<31)
-/* Tx descriptor */
-#define TDESC_ERROR (1<< 0) /* Error summary */
-#define TDESC_ZERO_PAD (1<<19)
-#define TDESC_LAST (1<<20) /* Last Descriptor */
-#define TDESC_FRST (1<<21) /* First Descriptor */
-#define TDESC_GEN_CRC (1<<22)
-#define TDESC_INT_ENA (1<<23) /* Enable Interrupts */
-#define TDESC_DMA_OWNED (1<<31)
-/* Register Definitions */
-#define MV643XX_ETH_PHY_ADDR_R (0x2000)
-#define MV643XX_ETH_SMI_R (0x2004)
-#define MV643XX_ETH_SMI_BUSY (1<<28)
-#define MV643XX_ETH_SMI_VALID (1<<27)
-#define MV643XX_ETH_SMI_OP_WR (0<<26)
-#define MV643XX_ETH_SMI_OP_RD (1<<26)
-#define MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port) (0x2448 + ((port)<<10))
-#define MV643XX_ETH_TX_START(queue) (0x0001<<(queue))
-#define MV643XX_ETH_TX_STOP(queue) (0x0100<<(queue))
-#define MV643XX_ETH_TX_START_M(queues) ((queues)&0xff)
-#define MV643XX_ETH_TX_STOP_M(queues) (((queues)&0xff)<<8)
-#define MV643XX_ETH_TX_STOP_ALL (0xff00)
-#define MV643XX_ETH_TX_ANY_RUNNING (0x00ff)
-#define MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(port) (0x2680 + ((port)<<10))
-#define MV643XX_ETH_RX_START(queue) (0x0001<<(queue))
-#define MV643XX_ETH_RX_STOP(queue) (0x0100<<(queue))
-#define MV643XX_ETH_RX_STOP_ALL (0xff00)
-#define MV643XX_ETH_RX_ANY_RUNNING (0x00ff)
-#define MV643XX_ETH_CURRENT_SERVED_TX_DESC(port) (0x2684 + ((port)<<10))
/* The chip puts the ethernet header at offset 2 into the buffer so
* that the payload is aligned
#define ETH_RX_OFFSET 2
#define ETH_CRC_LEN 4 /* strip FCS at end of packet */
-#define MV643XX_ETH_INTERRUPT_CAUSE_R(port) (0x2460 + ((port)<<10))
-/* not fully understood; RX seems to raise 0x0005 or 0x0c05 if last buffer is filled and 0x0c00
- * if there are no buffers
-#define MV643XX_ETH_ALL_IRQS (0x0007ffff)
-#define MV643XX_ETH_KNOWN_IRQS (0x00000c05)
-#define MV643XX_ETH_IRQ_EXT_ENA (1<<1)
-#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
-#define MV643XX_ETH_IRQ_RX_NO_DESC (1<<10)
-#define MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(port) (0x2464 + ((port)<<10))
-/* not fully understood; TX seems to raise 0x0001 and link change is 0x00010000
-#define MV643XX_ETH_ALL_EXT_IRQS (0x0011ffff)
-#define MV643XX_ETH_KNOWN_EXT_IRQS (0x00010101)
-#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
-#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
-#define MV643XX_ETH_INTERRUPT_ENBL_R(port) (0x2468 + ((port)<<10))
-#define MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(port) (0x246c + ((port)<<10))
-/* port configuration */
-#define MV643XX_ETH_PORT_CONFIG_R(port) (0x2400 + ((port)<<10))
-#define MV643XX_ETH_UNICAST_PROMISC_MODE (1<<0)
-#define MV643XX_ETH_DFLT_RX_Q(q) ((q)<<1)
-#define MV643XX_ETH_DFLT_RX_ARP_Q(q) ((q)<<4)
-#define MV643XX_ETH_REJ_BCAST_IF_NOT_IP_OR_ARP (1<<7)
-#define MV643XX_ETH_REJ_BCAST_IF_IP (1<<8)
-#define MV643XX_ETH_REJ_BCAST_IF_ARP (1<<9)
-#define MV643XX_ETH_TX_AM_NO_UPDATE_ERR_SUMMARY (1<<12)
-#define MV643XX_ETH_CAPTURE_TCP_FRAMES_ENBL (1<<14)
-#define MV643XX_ETH_CAPTURE_UDP_FRAMES_ENBL (1<<15)
-#define MV643XX_ETH_DFLT_RX_TCP_Q(q) ((q)<<16)
-#define MV643XX_ETH_DFLT_RX_UDP_Q(q) ((q)<<19)
-#define MV643XX_ETH_DFLT_RX_BPDU_Q(q) ((q)<<22)
-#define MV643XX_ETH_PORT_CONFIG_XTEND_R(port) (0x2404 + ((port)<<10))
-#define MV643XX_ETH_CLASSIFY_ENBL (1<<0)
-#define MV643XX_ETH_SPAN_BPDU_PACKETS_AS_NORMAL (0<<1)
-#define MV643XX_ETH_SPAN_BPDU_PACKETS_2_Q7 (1<<1)
-#define MV643XX_ETH_PARTITION_DISBL (0<<2)
-#define MV643XX_ETH_PARTITION_ENBL (1<<2)
-#define MV643XX_ETH_SDMA_CONFIG_R(port) (0x241c + ((port)<<10))
-#define MV643XX_ETH_SDMA_RIFB (1<<0)
-#define MV643XX_ETH_RX_BURST_SZ_1_64BIT (0<<1)
-#define MV643XX_ETH_RX_BURST_SZ_2_64BIT (1<<1)
-#define MV643XX_ETH_RX_BURST_SZ_4_64BIT (2<<1)
-#define MV643XX_ETH_RX_BURST_SZ_8_64BIT (3<<1)
-#define MV643XX_ETH_RX_BURST_SZ_16_64BIT (4<<1)
-#define MV643XX_ETH_SMDA_BLM_RX_NO_SWAP (1<<4)
-#define MV643XX_ETH_SMDA_BLM_TX_NO_SWAP (1<<5)
-#define MV643XX_ETH_SMDA_DESC_BYTE_SWAP (1<<6)
-#define MV643XX_ETH_TX_BURST_SZ_1_64BIT (0<<22)
-#define MV643XX_ETH_TX_BURST_SZ_2_64BIT (1<<22)
-#define MV643XX_ETH_TX_BURST_SZ_4_64BIT (2<<22)
-#define MV643XX_ETH_TX_BURST_SZ_8_64BIT (3<<22)
-#define MV643XX_ETH_TX_BURST_SZ_16_64BIT (4<<22)
-#define MV643XX_ETH_RX_MIN_FRAME_SIZE_R(port) (0x247c + ((port)<<10))
-#define MV643XX_ETH_SERIAL_CONTROL_R(port) (0x243c + ((port)<<10))
-#define MV643XX_ETH_SERIAL_PORT_ENBL (1<<0) /* Enable serial port */
-#define MV643XX_ETH_FORCE_LINK_PASS (1<<1)
-#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX (1<<2)
-#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL (1<<3)
-#define MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL (1<<4)
-#define MV643XX_ETH_FORCE_FC_MODE_TX_PAUSE_DIS (1<<5)
-#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX (1<<7)
-#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX_ON_RX_ERR (1<<8)
-#define MV643XX_ETH_BIT9_UNKNOWN (1<<9) /* unknown purpose; linux sets this */
-#define MV643XX_ETH_FORCE_LINK_FAIL_DISABLE (1<<10)
-#define MV643XX_ETH_RETRANSMIT_FOREVER (1<<11) /* limit to 16 attempts if clear */
-#define MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII (1<<13)
-#define MV643XX_ETH_DTE_ADV_1 (1<<14)
-#define MV643XX_ETH_AUTO_NEG_BYPASS_ENBL (1<<15)
-#define MV643XX_ETH_RESTART_AUTO_NEG (1<<16)
-#define MV643XX_ETH_SC_MAX_RX_1518 (0<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_1522 (1<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_1552 (2<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_9022 (3<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_9192 (4<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_9700 (5<<17) /* Limit RX packet size */
-#define MV643XX_ETH_SC_MAX_RX_MASK (7<<17) /* bitmask */
-#define MV643XX_ETH_SET_EXT_LOOPBACK (1<<20)
-#define MV643XX_ETH_SET_FULL_DUPLEX (1<<21)
-#define MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD (1<<22) /* enable flow ctrl on rx and tx in full-duplex */
-#define MV643XX_ETH_SET_GMII_SPEED_1000 (1<<23) /* 10/100 if clear */
-#define MV643XX_ETH_SET_MII_SPEED_100 (1<<24) /* 10 if clear */
-#define MV643XX_ETH_PORT_STATUS_R(port) (0x2444 + ((port)<<10))
-#define MV643XX_ETH_PORT_STATUS_MODE_10_BIT (1<<0)
-#define MV643XX_ETH_PORT_STATUS_LINK_UP (1<<1)
-#define MV643XX_ETH_PORT_STATUS_FDX (1<<2)
-#define MV643XX_ETH_PORT_STATUS_FC (1<<3)
-#define MV643XX_ETH_PORT_STATUS_1000 (1<<4)
-#define MV643XX_ETH_PORT_STATUS_100 (1<<5)
-/* PSR bit 6 unknown */
-#define MV643XX_ETH_PORT_STATUS_TX_IN_PROGRESS (1<<7)
-#define MV643XX_ETH_PORT_STATUS_ANEG_BYPASSED (1<<8)
-#define MV643XX_ETH_PORT_STATUS_PARTITION (1<<9)
-#define MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY (1<<10)
-#define MV643XX_ETH_MIB_COUNTERS(port) (0x3000 + ((port)<<7))
-#define MV643XX_ETH_NUM_MIB_COUNTERS 32
-#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO (0)
-#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_HI (1<<2)
-#define MV643XX_ETH_MIB_BAD_OCTS_RCVD (2<<2)
-#define MV643XX_ETH_MIB_INTERNAL_MAC_TX_ERR (3<<2)
-#define MV643XX_ETH_MIB_GOOD_FRAMES_RCVD (4<<2)
-#define MV643XX_ETH_MIB_BAD_FRAMES_RCVD (5<<2)
-#define MV643XX_ETH_MIB_BCAST_FRAMES_RCVD (6<<2)
-#define MV643XX_ETH_MIB_MCAST_FRAMES_RCVD (7<<2)
-#define MV643XX_ETH_MIB_FRAMES_64_OCTS (8<<2)
-#define MV643XX_ETH_MIB_FRAMES_65_127_OCTS (9<<2)
-#define MV643XX_ETH_MIB_FRAMES_128_255_OCTS (10<<2)
-#define MV643XX_ETH_MIB_FRAMES_256_511_OCTS (11<<2)
-#define MV643XX_ETH_MIB_FRAMES_512_1023_OCTS (12<<2)
-#define MV643XX_ETH_MIB_FRAMES_1024_MAX_OCTS (13<<2)
-#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO (14<<2)
-#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_HI (15<<2)
-#define MV643XX_ETH_MIB_GOOD_FRAMES_SENT (16<<2)
-#define MV643XX_ETH_MIB_EXCESSIVE_COLL (17<<2)
-#define MV643XX_ETH_MIB_MCAST_FRAMES_SENT (18<<2)
-#define MV643XX_ETH_MIB_BCAST_FRAMES_SENT (19<<2)
-#define MV643XX_ETH_MIB_UNREC_MAC_CTRL_RCVD (20<<2)
-#define MV643XX_ETH_MIB_FC_SENT (21<<2)
-#define MV643XX_ETH_MIB_GOOD_FC_RCVD (22<<2)
-#define MV643XX_ETH_MIB_BAD_FC_RCVD (23<<2)
-#define MV643XX_ETH_MIB_UNDERSIZE_RCVD (24<<2)
-#define MV643XX_ETH_MIB_FRAGMENTS_RCVD (25<<2)
-#define MV643XX_ETH_MIB_OVERSIZE_RCVD (26<<2)
-#define MV643XX_ETH_MIB_JABBER_RCVD (27<<2)
-#define MV643XX_ETH_MIB_MAC_RX_ERR (28<<2)
-#define MV643XX_ETH_MIB_BAD_CRC_EVENT (29<<2)
-#define MV643XX_ETH_MIB_COLL (30<<2)
-#define MV643XX_ETH_MIB_LATE_COLL (31<<2)
-#define MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(port) (0x3400+((port)<<10))
-#define MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(port) (0x3500+((port)<<10))
-#define MV643XX_ETH_DA_FILTER_UNICAST_TBL(port) (0x3600+((port)<<10))
-#define MV643XX_ETH_NUM_MCAST_ENTRIES 64
-#define MV643XX_ETH_NUM_UNICAST_ENTRIES 4
-#define MV643XX_ETH_BAR_0 (0x2200)
-#define MV643XX_ETH_SIZE_R_0 (0x2204)
-#define MV643XX_ETH_BAR_1 (0x2208)
-#define MV643XX_ETH_SIZE_R_1 (0x220c)
-#define MV643XX_ETH_BAR_2 (0x2210)
-#define MV643XX_ETH_SIZE_R_2 (0x2214)
-#define MV643XX_ETH_BAR_3 (0x2218)
-#define MV643XX_ETH_SIZE_R_3 (0x221c)
-#define MV643XX_ETH_BAR_4 (0x2220)
-#define MV643XX_ETH_SIZE_R_4 (0x2224)
-#define MV643XX_ETH_BAR_5 (0x2228)
-#define MV643XX_ETH_SIZE_R_5 (0x222c)
-#define MV643XX_ETH_NUM_BARS 6
-/* Bits in the BAR reg to program cache snooping */
-#define MV64360_ENET2MEM_SNOOP_NONE 0x0000
-#define MV64360_ENET2MEM_SNOOP_WT 0x1000
-#define MV64360_ENET2MEM_SNOOP_WB 0x2000
-#define MV64360_ENET2MEM_SNOOP_MSK 0x3000
-#define MV643XX_ETH_BAR_ENBL_R (0x2290)
-#define MV643XX_ETH_BAR_DISABLE(bar) (1<<(bar))
-#define MV643XX_ETH_BAR_DISBL_ALL 0x3f
-#define MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(port) (0x260c+((port)<<10))
-#define MV643XX_ETH_RX_Q1_CURRENT_DESC_PTR(port) (0x261c+((port)<<10))
-#define MV643XX_ETH_RX_Q2_CURRENT_DESC_PTR(port) (0x262c+((port)<<10))
-#define MV643XX_ETH_RX_Q3_CURRENT_DESC_PTR(port) (0x263c+((port)<<10))
-#define MV643XX_ETH_RX_Q4_CURRENT_DESC_PTR(port) (0x264c+((port)<<10))
-#define MV643XX_ETH_RX_Q5_CURRENT_DESC_PTR(port) (0x265c+((port)<<10))
-#define MV643XX_ETH_RX_Q6_CURRENT_DESC_PTR(port) (0x266c+((port)<<10))
-#define MV643XX_ETH_RX_Q7_CURRENT_DESC_PTR(port) (0x267c+((port)<<10))
-#define MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(port) (0x26c0+((port)<<10))
-#define MV643XX_ETH_TX_Q1_CURRENT_DESC_PTR(port) (0x26c4+((port)<<10))
-#define MV643XX_ETH_TX_Q2_CURRENT_DESC_PTR(port) (0x26c8+((port)<<10))
-#define MV643XX_ETH_TX_Q3_CURRENT_DESC_PTR(port) (0x26cc+((port)<<10))
-#define MV643XX_ETH_TX_Q4_CURRENT_DESC_PTR(port) (0x26d0+((port)<<10))
-#define MV643XX_ETH_TX_Q5_CURRENT_DESC_PTR(port) (0x26d4+((port)<<10))
-#define MV643XX_ETH_TX_Q6_CURRENT_DESC_PTR(port) (0x26d8+((port)<<10))
-#define MV643XX_ETH_TX_Q7_CURRENT_DESC_PTR(port) (0x26dc+((port)<<10))
-#define MV643XX_ETH_MAC_ADDR_LO(port) (0x2414+((port)<<10))
-#define MV643XX_ETH_MAC_ADDR_HI(port) (0x2418+((port)<<10))
/* TYPE DEFINITIONS */
/* just to make the purpose explicit; vars of this
@@ -554,6 +248,12 @@ struct mveth_softc {
struct mveth_private *pvt;
+typedef struct BsdMveIter {
+ MveEthBufIter it;
+ struct mbuf *m;
+ struct mbuf *h;
+} BsdMveIter;
/* GLOBAL VARIABLES */
#ifdef MVETH_DEBUG_TX_DUMP
int mveth_tx_dump = 0;
@@ -767,12 +467,6 @@ bail:
return m;
-typedef struct BsdMveIter {
- MveEthBufIter it;
- struct mbuf *m;
- struct mbuf *h;
-} BsdMveIter;
static MveEthBufIter *fillIter(struct mbuf *m, BsdMveIter *it)
if ( (it->m = (void*)m) ) {
@@ -784,7 +478,7 @@ static MveEthBufIter *fillIter(struct mbuf *m, BsdMveIter *it)
return 0;
-static MveEthBufIter *nextBuf(const MveEthBufIter *arg)
+static MveEthBufIter *nextBuf(MveEthBufIter *arg)
BsdMveIter *it = (BsdMveIter*)arg;
return fillIter( it->m->m_next, it );
@@ -1399,44 +1093,14 @@ rtems_mve_early_link_check_ops = {
int
mveth_dring(struct mveth_softc *sc)
-int i;
-if (1) {
-MvEthRxDesc pr;
-printf("RX:\n");
- for (i=0, pr=sc->pvt->rx_ring; i<sc->pvt->rbuf_count; i++, pr++) {
-#ifndef ENABLE_HW_SNOOPING
/* can't just invalidate the descriptor - if it contains
* data that hasn't been flushed yet, we create an inconsistency...
rtems_bsdnet_semaphore_obtain();
- INVAL_DESC(pr);
-#endif
- printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
- pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
- rtems_bsdnet_semaphore_release();
-#endif
-if (1) {
-MvEthTxDesc pt;
-printf("TX:\n");
- for (i=0, pt=sc->pvt->tx_ring; i<sc->pvt->xbuf_count; i++, pt++) {
- rtems_bsdnet_semaphore_obtain();
- INVAL_DESC(pt);
-#endif
- printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
- pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
- (uint32_t)pt->mb);
+ BSP_mve_dring_nosync(sc->pvt);
-#endif
return 0;
2.26.2
