[PATCH rtems 08/18] mv643xx_eth.c, mv643xx_eth_bsdnet.c: moved some definitions to public header
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:40 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4344
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 5 -----
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 5 -----
2 files changed, 10 deletions(-)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index b475711fef..f786b66c5c 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -113,11 +113,6 @@
/* Enable debugging messages and some support routines (dump rings etc.) */
#undef MVETH_DEBUG
-/* How many instances to we support (bsp.h could override) */
-#ifndef MV643XXETH_NUM_DRIVER_SLOTS
-#define MV643XXETH_NUM_DRIVER_SLOTS 2
-#endif
#define TX_NUM_TAG_SLOTS 1 /* leave room for tag; must not be 0 */
/* This is REAL; chip reads from 64-bit down-aligned buffer
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index e233f96dde..0a42dc4190 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -179,11 +179,6 @@
#endif /* MVETH_TESTING */
-#endif
#define DRVNAME "mve"
#define MAX_NUM_SLOTS 3
2.26.2
