[PATCH rtems 10/18] mv643xx_eth_bsdnet.c, mv643xx_eth.c, mv643xx_eth.h: init_hw has new 'speed' argument
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:42 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Remove any calls to mii_ioctl from the low-level driver. Instead, the caller
must determine the current speed and communicate to init_hw().
Update #4344
.../powerpc/beatnik/include/bsp/mv643xx_eth.h | 2 +-
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 12 ++---
.../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 54 ++++++++++++-------
3 files changed, 39 insertions(+), 29 deletions(-)
diff --git a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
index 160cadbc82..5bfcd9b26a 100644
--- a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
+++ b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
@@ -301,7 +301,7 @@ BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
* are programmed to accept all multicast frames.
void
-BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr, int speed);
* Update the serial port to a new speed (e.g., result of a PHY IRQ)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index f786b66c5c..35ef6622d9 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -2063,7 +2063,7 @@ uint32_t mveth_serial_ctrl_config_val = MVETH_SERIAL_CTRL_CONFIG_VAL;
void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr, int media)
int i;
uint32_t v;
@@ -2173,15 +2173,9 @@ static int inited = 0;
v |= mveth_serial_ctrl_config_val;
MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
-#ifdef BSDMII
-#warning FIXME
- i = IFM_MAKEWORD(0, 0, 0, 0);
- if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
- if ( (IFM_LINK_OK & i) ) {
- mveth_update_serial_port(mp, i);
+ if ( (MV643XX_MEDIA_LINK & media) ) {
+ BSP_mve_update_serial_port(mp, media);
-#endif
/* enable serial port */
v = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index 0a42dc4190..cdec5c6e14 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -563,6 +563,34 @@ int rval;
return rval;
+/* Translate IFFLAGS to low-level driver representation */
+static int
+xlateMediaFlags(int media)
+int lowLevelFlags = 0;
+ if ( IFM_LINK_OK & media ) {
+ lowLevelFlags |= MV643XX_MEDIA_LINK;
+ if ( IFM_FDX & media ) {
+ lowLevelFlags |= MV643XX_MEDIA_FD;
+ switch ( IFM_SUBTYPE(media) ) {
+ default: /* treat as 10 */
+ lowLevelFlags |= MV643XX_MEDIA_10;
+ break;
+ case IFM_100_TX:
+ lowLevelFlags |= MV643XX_MEDIA_100;
+ break;
+ case IFM_1000_T:
+ lowLevelFlags |= MV643XX_MEDIA_1000;
+ break;
+ return lowLevelFlags;
int
BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
@@ -570,23 +598,7 @@ int media = IFM_MAKEWORD(0,0,0,0);
if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
- int serport_cfg = 0;
- if ( IFM_FDX & media ) {
- serport_cfg |= MV643XX_MEDIA_FD;
- switch ( IFM_SUBTYPE(media) ) {
- default: /* treat as 10 */
- serport_cfg |= MV643XX_MEDIA_10;
- break;
- case IFM_100_TX:
- serport_cfg |= MV643XX_MEDIA_100;
- break;
- case IFM_1000_T:
- serport_cfg |= MV643XX_MEDIA_1000;
- break;
+ int serport_cfg = xlateMediaFlags( media );
BSP_mve_update_serial_port(mp, serport_cfg);
@@ -713,8 +725,7 @@ mveth_init(void *arg)
struct mveth_softc *sc = arg;
struct ifnet *ifp = &sc->arpcom.ac_if;
int media;
- BSP_mve_init_hw(sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
+int lowLevelMediaStatus;
media = IFM_MAKEWORD(0, 0, 0, 0);
if ( 0 == BSP_mve_media_ioctl(sc->pvt, SIOCGIFMEDIA, &media) ) {
@@ -725,6 +736,11 @@ int media;
+ lowLevelMediaStatus = xlateMediaFlags( media );
+ BSP_mve_init_hw(sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr, lowLevelMediaStatus);
/* if promiscuous then there is no need to change */
if ( ! (ifp->if_flags & IFF_PROMISC) )
mveth_set_filters(ifp);
2.26.2
