[PATCH rtems 09/18] if_mve_pub.h, mv643xx_eth.h: header reorg and cleanup.
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:41 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
All low-level interfaces were moved to mv643xx_eth.h
and the latter is included by if_mve_pub.h.
Update #4344
bsps/powerpc/beatnik/include/bsp/if_mve_pub.h | 199 +-----------
.../powerpc/beatnik/include/bsp/mv643xx_eth.h | 298 ++++++++++++++----
2 files changed, 250 insertions(+), 247 deletions(-)
diff --git a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
index 46cc4ccd23..b9f0c7101b 100644
--- a/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
+++ b/bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
@@ -1,19 +1,19 @@
#ifndef RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
#define RTEMS_BSDNET_IF_MVE_PUBLIC_SYMBOLS_H
* Authorship
* This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
* created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
* Stanford Linear Accelerator Center, Stanford University.
* Acknowledgement of sponsorship
* The 'beatnik' BSP was produced by
* the Stanford Linear Accelerator Center, Stanford University,
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
* Government disclaimer of liability
* Neither the United States nor the United States Department of Energy,
@@ -22,18 +22,18 @@
* completeness, or usefulness of any data, apparatus, product, or process
* disclosed, or represents that its use would not infringe privately owned
* rights.
* Stanford disclaimer of liability
* Stanford University makes no representations or warranties, express or
* implied, nor assumes any liability for the use of this software.
* Stanford disclaimer of copyright
* Stanford University, owner of the copyright, hereby disclaims its
* copyright and all other rights in this software. Hence, anyone may
- * freely use it for any purpose without restriction.
+ * freely use it for any purpose without restriction.
* Maintenance of notices
* In the interest of clarity regarding the origin and status of this
@@ -42,13 +42,14 @@
* or distributed by the recipient and are to be affixed to any copy of
* software made or distributed by the recipient that contains a copy or
* derivative of this software.
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
#include <bsp/early_enet_link_status.h>
#include <stdint.h>
+#include <bsp/mv643xx_eth.h>
#ifdef __cplusplus
extern "C" {
@@ -86,8 +87,8 @@ struct mveth_private;
* by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
* and a flag indicating whether the send had been successful.
* The driver no longer accesses 'user_buf' after invoking this callback.
- * CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
- * BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
+ * CONTEXT: This callback is executed either by BSP_mve_swipe_tx() or
+ * BSP_mve_send_buf(), BSP_mve_init_hw(), BSP_mve_stop_hw() (the latter
* ones calling BSP_mve_swipe_tx()).
* void *cleanup_txbuf_arg:
* Closure argument that is passed on to 'cleanup_txbuf()' callback;
@@ -105,7 +106,7 @@ struct mveth_private;
* instead of handing it out to 'consume_rxbuf()'.
* CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
* swiping it (BSP_mve_swipe_rx()).
* void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
* Pointer to user-supplied callback to pass a received buffer back to
@@ -140,7 +141,7 @@ struct mveth_private *
BSP_mve_setup(
int unit,
rtems_id driver_tid,
- void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
+ void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred),
void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len),
@@ -161,7 +162,7 @@ BSP_mve_setup_1(
int unit,
void (*isr)(void *isr_arg),
void *isr_arg,
@@ -172,81 +173,6 @@ BSP_mve_setup_1(
- * Initialize interface hardware
- * 'mp' handle obtained by from BSP_mve_setup().
- * 'promisc' whether to set promiscuous flag.
- * 'enaddr' pointer to six bytes with MAC address. Read
- * from the device if NULL.
- * Note: Multicast filters are cleared by this routine.
- * However, in promiscuous mode the mcast filters
- * are programmed to accept all multicast frames.
-void
-BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
- * Clear multicast hash filter. No multicast frames are accepted
- * after executing this routine (unless the hardware was initialized
- * in 'promiscuous' mode).
-void
-BSP_mve_mcast_filter_clear(struct mveth_private *mp);
- * Program multicast filter to accept all multicast frames
-void
-BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
- * Add a MAC address to the multicast filter.
- * Existing entries are not changed but note that
- * the filter is imperfect, i.e., multiple MAC addresses
- * may alias to a single filter entry. Hence software
- * filtering must still be performed.
- * If a higher-level driver implements IP multicasting
- * then multiple IP addresses may alias to the same MAC
- * address. This driver maintains a 'reference-count'
- * which is incremented every time the same MAC-address
- * is passed to this routine; the address is only removed
- * from the filter if BSP_mve_mcast_filter_accept_del()
- * is called the same number of times (or by BSP_mve_mcast_filter_clear).
-void
-BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
- * Remove a MAC address from the multicast filter.
- * This routine decrements the reference count of the given
- * MAC-address and removes it from the filter once the
- * count reaches zero.
-void
-BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
- * Shutdown hardware and clean out the rings
-void
-BSP_mve_stop_hw(struct mveth_private *mp);
-/* calls BSP_mve_stop_hw(), releases all resources and marks the interface
- * as unused.
- * RETURNS 0 on success, nonzero on failure.
- * NOTE: the handle MUST NOT be used after successful execution of this
- * routine.
-int
-BSP_mve_detach(struct mveth_private *mp);
-int
-BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
- void *data_p, int d_len);
* Enqueue a mbuf chain or a raw data buffer for transmission;
* RETURN: #bytes sent or -1 if there are not enough free descriptors
@@ -268,29 +194,6 @@ BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len,
int
BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len);
-/* Descriptor scavenger; cleanup the TX ring, passing all buffers
- * that have been sent to the cleanup_tx() callback.
- * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
- * BSP_mve_stop_hw().
- * RETURNS: number of buffers processed.
-int
-BSP_mve_swipe_tx(struct mveth_private *mp);
-/* Retrieve all received buffers from the RX ring, replacing them
- * by fresh ones (obtained from the alloc_rxbuf() callback). The
- * received buffers are passed to consume_rxbuf().
-int
-BSP_mve_swipe_rx(struct mveth_private *mp);
-/* read ethernet address from hw to buffer */
-void
-BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
/* read/write media word.
* 'cmd': can be SIOCGIFMEDIA, SIOCSIFMEDIA, 0 or 1. The latter
* are aliased to the former for convenience.
@@ -303,62 +206,6 @@ BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *eaddr);
int
BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg);
-/* Interrupt related routines */
-/* Note: the BSP_mve_enable/disable/ack_irqs() entry points
- * are deprecated.
- * The newer API where the user passes a mask allows
- * for more selective control.
-/* Enable all supported interrupts at device */
-void
-BSP_mve_enable_irqs(struct mveth_private *mp);
-/* Disable all supported interrupts at device */
-void
-BSP_mve_disable_irqs(struct mveth_private *mp);
-/* Acknowledge (and clear) all supported interrupts.
- * RETURNS: interrupts that were raised.
-uint32_t
-BSP_mve_ack_irqs(struct mveth_private *mp);
-/* Enable interrupts included in 'mask' (leaving
- * already enabled interrupts on). If the mask
- * includes bits that were not passed to the 'setup'
- * routine then the behavior is undefined.
-void
-BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
-/* Disable interrupts included in 'mask' (leaving
- * other ones that are currently enabled on). If the
- * mask includes bits that were not passed to the 'setup'
- * RETURNS: Bitmask of interrupts that were enabled upon entry
- * into this routine. This can be used to restore the
- * previous state.
-uint32_t
-BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
-/* Acknowledge and clear selected interrupts.
- * RETURNS: All pending interrupts.
- * NOTE: Only pending interrupts contained in 'mask'
- * are cleared. Others are left pending.
- * This routine can be used to check for pending
- * interrupts (pass mask == 0) or to clear all
- * interrupts (pass mask == -1).
-uint32_t
-BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
/* If the PHY link status changes then some
* internal settings in the ethernet controller's
* serial port need to be updated to match the
@@ -378,21 +225,7 @@ BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
int
BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia);
-/* Retrieve the driver daemon TID that was passed to
- * BSP_mve_setup().
-rtems_id
-BSP_mve_get_tid(struct mveth_private *mp);
-/* Dump statistics to file (stdout if NULL)
- * NOTE: this routine is not thread safe
-void
-BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
* Example driver task loop (note: no synchronization of
* buffer access shown!).
diff --git a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
index 6a7dbacf69..160cadbc82 100644
--- a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
+++ b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
@@ -1,15 +1,96 @@
#ifndef MV643XX_LOWLEVEL_DRIVER_H
#define MV643XX_LOWLEVEL_DRIVER_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define MV643XXETH_NUM_DRIVER_SLOTS 2
+/* Create interface.
+ * Allocates resources for descriptor rings and sets up the driver software structure.
+ * Arguments:
+ * unit:
+ * interface # (1..2). The interface must not be attached to BSD.
+ * driver_tid:
+ * optional driver task-id (can be retrieved with BSP_mve_get_tid()).
+ * Not used by the low-level driver.
+ * isr(isr_arg):
+ * user ISR.
+ * void (*cleanup_txbuf)(void *user_buf, void *cleanup_txbuf_arg, int error_on_tx_occurred):
+ * Pointer to user-supplied callback to release a buffer that had been sent
+ * by BSP_mve_send_buf() earlier. The callback is passed 'cleanup_txbuf_arg'
+ * and a flag indicating whether the send had been successful.
+ * The driver no longer accesses 'user_buf' after invoking this callback.
+ * ones calling BSP_mve_swipe_tx()).
+ * void *cleanup_txbuf_arg:
+ * Closure argument that is passed on to 'cleanup_txbuf()' callback;
+ * void *(*alloc_rxbuf)(int *p_size, unsigned long *p_data_addr),
+ * Pointer to user-supplied callback to allocate a buffer for subsequent
+ * insertion into the RX ring by the driver.
+ * RETURNS: opaque handle to the buffer (which may be a more complex object
+ * such as an 'mbuf'). The handle is not used by the driver directly
+ * but passed back to the 'consume_rxbuf()' callback.
+ * Size of the available data area and pointer to buffer's data area
+ * in '*psize' and '*p_data_area', respectively.
+ * If no buffer is available, this routine should return NULL in which
+ * case the driver drops the last packet and re-uses the last buffer
+ * instead of handing it out to 'consume_rxbuf()'.
+ * CONTEXT: Called when initializing the RX ring (BSP_mve_init_hw()) or when
+ * swiping it (BSP_mve_swipe_rx()).
+ * void (*consume_rxbuf)(void *user_buf, void *consume_rxbuf_arg, int len);
+ * Pointer to user-supplied callback to pass a received buffer back to
+ * the user. The driver no longer accesses the buffer after invoking this
+ * callback (with 'len'>0, see below). 'user_buf' is the buffer handle
+ * previously generated by 'alloc_rxbuf()'.
+ * The callback is passed 'cleanup_rxbuf_arg' and a 'len'
+ * argument giving the number of bytes that were received.
+ * 'len' may be <=0 in which case the 'user_buf' argument is NULL.
+ * 'len' == 0 means that the last 'alloc_rxbuf()' had failed,
+ * 'len' < 0 indicates a receiver error. In both cases, the last packet
+ * was dropped/missed and the last buffer will be re-used by the driver.
+ * NOTE: the data are 'prefixed' with two bytes, i.e., the ethernet packet header
+ * is stored at offset 2 in the buffer's data area. Also, the FCS (4 bytes)
+ * is appended. 'len' accounts for both.
+ * CONTEXT: Called from BSP_mve_swipe_rx().
+ * void *cleanup_rxbuf_arg:
+ * Closure argument that is passed on to 'consume_rxbuf()' callback;
+ * rx_ring_size, tx_ring_size:
+ * How many big to make the RX and TX descriptor rings. Note that the sizes
+ * may be 0 in which case a reasonable default will be used.
+ * If either ring size is < 0 then the RX or TX will be disabled.
+ * Note that it is illegal in this case to use BSP_mve_swipe_rx() or
+ * BSP_mve_swipe_tx(), respectively.
+ * irq_mask:
+ * Interrupts to enable. OR of flags from above.
+/* Direct assignment of MVE flags to user API relies on irqs and x-irqs not overlapping */
+#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
+#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
+#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
BSP_mve_create(
int unit,
rtems_id tid,
void (*isr)(void*isr_arg),
void *isr_arg,
- void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
+ void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
void (*consume_rxbuf)(void *user_buf, void *closure, int len),
@@ -19,37 +100,63 @@ BSP_mve_create(
int irq_mask
-/* Enable/disable promiscuous mode */
-void
-BSP_mve_promisc_set(struct mveth_private *mp, int promisc);
-/* Clear multicast filters */
+ * Clear multicast hash filter. No multicast frames are accepted
+ * after executing this routine (unless the hardware was initialized
+ * in 'promiscuous' mode).
void
+ * Program multicast filter to accept all multicast frames
void
+ * Add a MAC address to the multicast filter.
+ * Existing entries are not changed but note that
+ * the filter is imperfect, i.e., multiple MAC addresses
+ * may alias to a single filter entry. Hence software
+ * filtering must still be performed.
+ * If a higher-level driver implements IP multicasting
+ * then multiple IP addresses may alias to the same MAC
+ * address. This driver maintains a 'reference-count'
+ * which is incremented every time the same MAC-address
+ * is passed to this routine; the address is only removed
+ * from the filter if BSP_mve_mcast_filter_accept_del()
+ * is called the same number of times (or by BSP_mve_mcast_filter_clear).
void
+ * Remove a MAC address from the multicast filter.
+ * This routine decrements the reference count of the given
+ * MAC-address and removes it from the filter once the
+ * count reaches zero.
void
-/* Stop hardware and clean out the rings */
+/* Enable/disable promiscuous mode */
void
+BSP_mve_promisc_set(struct mveth_private *mp, int promisc);
-/* MAIN RX-TX ROUTINES
- * BSP_mve_swipe_tx(): descriptor scavenger; releases mbufs
- * BSP_mve_send_buf(): xfer mbufs from IF to chip
- * BSP_mve_swipe_rx(): enqueue received mbufs to interface
- * allocate new ones and yield them to the
- * chip.
+/* calls BSP_mve_stop_hw(), releases all resources and marks the interface
+ * as unused.
+ * RETURNS 0 on success, nonzero on failure.
+ * NOTE: the handle MUST NOT be used after successful execution of this
+ * routine.
-/* clean up the TX ring freeing up buffers */
int
+BSP_mve_detach(struct mveth_private *mp);
-/* Enqueue a mbuf chain or a raw data buffer for transmission;
+/* Enqueue a buffer chain for transmission.
* RETURN: #bytes sent or -1 if there are not enough descriptors
* -2 is returned if the caller should attempt to
* repackage the chain into a smaller one.
@@ -75,80 +182,139 @@ typedef MveEthBufIter *(*MveEthBufIterNext)(MveEthBufIter*);
int
BSP_mve_send_buf_chain(struct mveth_private *mp, MveEthBufIterNext next, MveEthBufIter *it);
-int
- struct mveth_private *mp,
- void *head_p,
- int h_len,
- void *data_p,
- int d_len);
-/* send received buffers upwards and replace them
- * with freshly allocated ones;
- * ASSUMPTION: buffer length NEVER changes and is set
- * when the ring is initialized.
- * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
-int
-rtems_id
+/* Legacy entry point to send a header + a buffer */
int
+BSP_mve_send_buf_raw(struct mveth_private *mp, void *head_p, int h_len, void *data_p, int d_len);
-/* Fire up the low-level driver
+/* Descriptor scavenger; cleanup the TX ring, passing all buffers
+ * that have been sent to the cleanup_tx() callback.
+ * This routine is called from BSP_mve_send_buf(), BSP_mve_init_hw(),
+ * BSP_mve_stop_hw().
- * - make sure hardware is halted
- * - enable cache snooping
- * - clear address filters
- * - clear mib counters
- * - reset phy
- * - initialize (or reinitialize) descriptor rings
- * - check that the firmware has set up a reasonable mac address.
- * - generate unicast filter entry for our mac address
- * - write register config values to the chip
- * - start hardware (serial port and SDMA)
+ * RETURNS: number of buffers processed.
+int
+BSP_mve_swipe_tx(struct mveth_private *mp);
-void
-#define MV643XX_MEDIA_FD (1<<0)
-#define MV643XX_MEDIA_10 (1<<8)
-#define MV643XX_MEDIA_100 (2<<8)
-#define MV643XX_MEDIA_1000 (3<<8)
-#define MV643XX_MEDIA_SPEED_MSK (0xff00)
-void
-BSP_mve_update_serial_port(struct mveth_private *mp, int media);
+/* Retrieve all received buffers from the RX ring, replacing them
+ * by fresh ones (obtained from the alloc_rxbuf() callback). The
+ * received buffers are passed to consume_rxbuf().
+int
+BSP_mve_swipe_rx(struct mveth_private *mp);
void
BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr);
+/* Interrupt related routines */
+/* Note: the BSP_mve_enable/disable/ack_irqs() entry points
+ * are deprecated.
+ * The newer API where the user passes a mask allows
+ * for more selective control.
+/* Enable all supported interrupts at device */
void
+/* Disable all supported interrupts at device */
void
-#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
-#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
-#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
+/* Acknowledge (and clear) all supported interrupts.
+ * RETURNS: interrupts that were raised.
uint32_t
+/* Enable interrupts included in 'mask' (leaving
+ * already enabled interrupts on). If the mask
+ * includes bits that were not passed to the 'setup'
+ * routine then the behavior is undefined.
void
-BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask);
+BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
+/* Disable interrupts included in 'mask' (leaving
+ * other ones that are currently enabled on). If the
+ * mask includes bits that were not passed to the 'setup'
+ * RETURNS: Bitmask of interrupts that were enabled upon entry
+ * into this routine. This can be used to restore the
+ * previous state.
uint32_t
-BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask);
+BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t irq_mask);
+/* Acknowledge and clear selected interrupts.
+ * RETURNS: All pending interrupts.
+ * NOTE: Only pending interrupts contained in 'mask'
+ * are cleared. Others are left pending.
+ * This routine can be used to check for pending
+ * interrupts (pass mask == 0) or to clear all
+ * interrupts (pass mask == -1).
uint32_t
+/* Retrieve the driver daemon TID that was passed to
+ * BSP_mve_setup().
+rtems_id
+BSP_mve_get_tid(struct mveth_private *mp);
+/* Dump statistics to file (stdout if NULL)
+ * NOTE: this routine is not thread safe
void
+#define MV643XX_MEDIA_LINK (1<<0)
+#define MV643XX_MEDIA_FD (1<<1)
+#define MV643XX_MEDIA_10 (1<<8)
+#define MV643XX_MEDIA_100 (2<<8)
+#define MV643XX_MEDIA_1000 (3<<8)
+#define MV643XX_MEDIA_SPEED_MSK (0xff00)
+ * Initialize interface hardware
+ * 'mp' handle obtained by from BSP_mve_setup().
+ * 'promisc' whether to set promiscuous flag.
+ * 'enaddr' pointer to six bytes with MAC address. Read
+ * from the device if NULL.
+ * 'speed' current speed and link status as read from the PHY.
+ * Note: Multicast filters are cleared by this routine.
+ * However, in promiscuous mode the mcast filters
+ * are programmed to accept all multicast frames.
+void
+BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
+ * Update the serial port to a new speed (e.g., result of a PHY IRQ)
+void
+BSP_mve_update_serial_port(struct mveth_private *mp, int speed);
+ * Shutdown hardware and clean out the rings
+void
+BSP_mve_stop_hw(struct mveth_private *mp);
unsigned
BSP_mve_mii_read(struct mveth_private *mp, unsigned addr);
@@ -161,4 +327,8 @@ BSP_mve_mii_read_early(int port, unsigned addr);
unsigned
BSP_mve_mii_write_early(int port, unsigned addr, unsigned v);
+#ifdef __cplusplus
+#endif
#endif
2.26.2
