[PATCH rtems 17/18] mv643xx_eth.c: added 0x00100000 bit to 'known' ext. interrupt causes
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 30 01:27:49 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
In 'testing' mode the paranoia checks found this bit asserted. The
recent linux driver (2013) mentions lists this bit as a 'phy link
status change' bit (together with (1<<16)). Thus, we accept this
as a 'known' bit now.
Update #4344
 bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index 9e21614367..e952cbbb8a 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -108,7 +108,7 @@
 /* Compile-time debugging features */
 /* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing   */
-#undef  MVETH_TESTING
+#define MVETH_TESTING
 /* Enable debugging messages and some support routines  (dump rings etc.)                    */
 #undef  MVETH_DEBUG
@@ -409,7 +409,8 @@
  * if there are no buffers
 #define MV643XX_ETH_ALL_EXT_IRQS					(0x0011ffff)
-#define MV643XX_ETH_KNOWN_EXT_IRQS					(0x00010101)
+/* Recent (2013) linux driver mentions both bits 0x00110000 as 'link change' causes */
+#define MV643XX_ETH_KNOWN_EXT_IRQS					(0x00110101)
 #define MV643XX_ETH_EXT_IRQ_TX_DONE					(1<<0)
 #define MV643XX_ETH_EXT_IRQ_LINK_CHG				(1<<16)
 #define MV643XX_ETH_INTERRUPT_ENBL_R(port)			(0x2468 + ((port)<<10))
2.26.2
