[PATCH rtems 18/18] mv643xx_eth.c, mv643xx_eth_bsdnet.c: removed trailing whitespace
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:27:50 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4344
bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 66 +++++++++++--------
.../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 44 ++++++-------
2 files changed, 61 insertions(+), 49 deletions(-)
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
index e952cbbb8a..7fc0bed86a 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
@@ -18,19 +18,19 @@
* new implementation and is the original work by the author.
* Authorship
* This software (mv643xx ethernet driver for RTEMS) was
* created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
* Stanford Linear Accelerator Center, Stanford University.
* Acknowledgement of sponsorship
* The 'mv643xx ethernet driver for RTEMS' was produced by
* the Stanford Linear Accelerator Center, Stanford University,
* under Contract DE-AC03-76SFO0515 with the Department of Energy.
* Government disclaimer of liability
* Neither the United States nor the United States Department of Energy,
@@ -39,18 +39,18 @@
* completeness, or usefulness of any data, apparatus, product, or process
* disclosed, or represents that its use would not infringe privately owned
* rights.
* Stanford disclaimer of liability
* Stanford University makes no representations or warranties, express or
* implied, nor assumes any liability for the use of this software.
* Stanford disclaimer of copyright
* Stanford University, owner of the copyright, hereby disclaims its
* copyright and all other rights in this software. Hence, anyone may
- * freely use it for any purpose without restriction.
+ * freely use it for any purpose without restriction.
* Maintenance of notices
* In the interest of clarity regarding the origin and status of this
@@ -59,9 +59,9 @@
* or distributed by the recipient and are to be affixed to any copy of
* software made or distributed by the recipient that contains a copy or
* derivative of this software.
* ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
* NOTE: Some register (e.g., the SMI register) are SHARED among the
@@ -110,7 +110,7 @@
/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing */
#define MVETH_TESTING
-/* Enable debugging messages and some support routines (dump rings etc.) */
+/* Enable debugging messages and some support routines (dump rings etc.) */
#undef MVETH_DEBUG
#define TX_NUM_TAG_SLOTS 1 /* leave room for tag; must not be 0 */
@@ -199,7 +199,7 @@
* broadcast packet RX: 0x00000005
* last buf: 0x00000c05
- * overrun: 0x00000c00
+ * overrun: 0x00000c00
* unicast packet RX: 0x00000005
* bad CRC received: 0x00000005
@@ -232,11 +232,11 @@
* --> sometimes, cmd_sts is STILL != 0 here
- * b) Sometimes, the OWNership flag is *not cleared*.
+ * b) Sometimes, the OWNership flag is *not cleared*.
* c) Weird things happen if the chip finds a descriptor with 'OWN'
* still set (i.e., not properly loaded), i.e., corrupted packets
- * are sent [with OK checksum since the chip calculates it].
+ * are sent [with OK checksum since the chip calculates it].
* Combine a+b+c and we end up with a real mess.
@@ -398,11 +398,16 @@
/* not fully understood; RX seems to raise 0x0005 or 0x0c05 if last buffer is filled and 0x0c00
* if there are no buffers
-#define MV643XX_ETH_ALL_IRQS (0x0007ffff)
-#define MV643XX_ETH_KNOWN_IRQS (0x00000c05)
+#define MV643XX_ETH_ALL_IRQS (0x07ffffff)
+#define MV643XX_ETH_KNOWN_IRQS (0x00080c07)
#define MV643XX_ETH_IRQ_EXT_ENA (1<<1)
+/* defined in public header
#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
#define MV643XX_ETH_IRQ_RX_NO_DESC (1<<10)
+#define MV643XX_ETH_TX_Q_N_END(n) (1<<((n)+19))
+/* We just use queue 0 */
+#define MV643XX_ETH_TX_Q_END MV643XX_ETH_TX_Q_N_END(0)
#define MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(port) (0x2464 + ((port)<<10))
/* not fully understood; TX seems to raise 0x0001 and link change is 0x00010000
@@ -411,8 +416,13 @@
#define MV643XX_ETH_ALL_EXT_IRQS (0x0011ffff)
/* Recent (2013) linux driver mentions both bits 0x00110000 as 'link change' causes */
#define MV643XX_ETH_KNOWN_EXT_IRQS (0x00110101)
-#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
+/* TX queues 0..7 */
+#define MV643XX_ETH_EXT_IRQ_TXN_DONE(n) (1<<(n))
+#define MV643XX_ETH_EXT_IRQ_TX_DONE MV643XX_ETH_EXT_IRQ_TXN_DONE(0)
#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
#define MV643XX_ETH_INTERRUPT_ENBL_R(port) (0x2468 + ((port)<<10))
#define MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(port) (0x246c + ((port)<<10))
@@ -640,7 +650,7 @@ struct mveth_private {
int port_num;
int phy;
MvEthRxDesc d_rx_t; /* tail of the RX ring; next received packet */
- MvEthTxDesc d_tx_t, d_tx_h;
+ MvEthTxDesc d_tx_t, d_tx_h;
uint32_t rx_desc_dma, tx_desc_dma; /* ring address as seen by DMA; (1:1 on this BSP) */
int avail;
void (*isr)(void*);
@@ -830,7 +840,7 @@ static inline void FLUSH_BUF(register uintptr_t addr, register int len)
asm volatile("":::"memory");
len = MV643XX_ALIGN(len, RX_BUF_ALIGNMENT);
- do {
+ do {
asm volatile("dcbf %0, %1"::"b"(addr),"r"(len));
len -= RX_BUF_ALIGNMENT;
} while ( len >= 0 );
@@ -938,8 +948,10 @@ register uint32_t rval;
|| ((xe & MV643XX_ETH_ALL_EXT_IRQS) & ~MV643XX_ETH_KNOWN_EXT_IRQS) ) {
fprintf(stderr, "Unknown IRQs detected; leaving all disabled for debugging:\n");
fprintf(stderr, "Cause reg was 0x%08x, ext cause 0x%08x\n", x, xe);
mp->irq_mask = 0;
mp->xirq_mask = 0;
#endif
/* luckily, the extended and 'normal' interrupts we use don't overlap so
@@ -1029,7 +1041,7 @@ port2phy(int port)
/* PHY/MII Interface
* Read/write a PHY register;
* NOTE: The SMI register is shared among the three devices.
* Protection is provided by the global networking semaphore.
* If non-bsd drivers are running on a subset of IFs proper
@@ -1496,7 +1508,7 @@ BSP_mve_create(
rtems_id tid,
void (*isr)(void*isr_arg),
void *isr_arg,
- void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
+ void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
void *cleanup_txbuf_arg,
void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
void (*consume_rxbuf)(void *user_buf, void *closure, int len),
@@ -1725,7 +1737,7 @@ MveEthBufIter head = *it;
h = mp->d_tx_h;
-#ifdef MVETH_TESTING
+#ifdef MVETH_TESTING
assert( !h->buf_ptr );
assert( !h->u_buf );
#endif
@@ -1850,7 +1862,7 @@ void *uarg;
rval = 0;
assert(head_p || data_p);
#endif
@@ -1866,7 +1878,7 @@ void *uarg;
h = mp->d_tx_h;
#endif
@@ -1968,7 +1980,7 @@ uintptr_t baddr;
for ( d = mp->d_rx_t; ! (INVAL_DESC(d), (RDESC_DMA_OWNED & d->cmd_sts)); d=NEXT_RXD(d) ) {
assert(d->u_buf);
#endif
@@ -2030,7 +2042,7 @@ int i;
BSP_mve_swipe_tx(mp);
assert( mp->d_tx_h == mp->d_tx_t );
for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++, d++ ) {
assert( !d->buf_ptr );
@@ -2173,7 +2185,7 @@ static int inited = 0;
assert( maclo && machi && maclo != 0xffffffff && machi != 0xffffffff );
mveth_ucfilter(mp, maclo&0xff, 1/* accept */);
/* port, serial and sdma configuration */
v = MVETH_PORT_CONFIG_VAL;
if ( promisc ) {
diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
index 0f2a97d49a..41cb149331 100644
--- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
+++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
@@ -18,19 +18,19 @@
* Authorship
@@ -39,18 +39,18 @@
* rights.
@@ -59,9 +59,9 @@
@@ -137,7 +137,7 @@
#undef MVETH_TESTING
#undef MVETH_DEBUG
/* Ring sizes */
@@ -302,7 +302,7 @@ mve_setup_bsd(
rtems_id tid,
void (*isr)(void *isr_arg),
void *isr_arg,
@@ -372,7 +372,7 @@ struct mveth_private *
BSP_mve_setup(
int unit,
rtems_id tid,
@@ -384,7 +384,7 @@ BSP_mve_setup(
if ( irq_mask && 0 == tid ) {
printk(DRVNAME": must supply a TID if irq_msk not zero\n");
- return 0;
+ return 0;
return mve_setup_bsd(
@@ -403,7 +403,7 @@ BSP_mve_setup_1(
int unit,
void *isr_arg,
@@ -415,7 +415,7 @@ BSP_mve_setup_1(
if ( irq_mask && 0 == isr ) {
printk(DRVNAME": must supply an ISR if irq_msk not zero\n");
- return 0;
+ return 0;
@@ -502,7 +502,7 @@ startover:
rval = 0;
assert(m_head);
#endif
@@ -536,7 +536,7 @@ startover:
if ( -2 == rval ) {
if ( ! (m_head = repackage_chain( m_head )) ) {
/* no cluster available */
- /* No access to this counter, unfortunately
+ /* No access to this counter, unfortunately
mp->stats.odrops++;
return 0;
@@ -654,7 +654,7 @@ unsigned long l,o;
m->m_len = m->m_pkthdr.len = l;
*psz = m->m_len;
- *paddr = mtod(m, uintptr_t);
+ *paddr = mtod(m, uintptr_t);
return (void*) m;
@@ -681,7 +681,7 @@ struct mbuf *m = buf;
ifp->if_ipackets++;
ifp->if_ibytes += m->m_pkthdr.len;
if (0) {
/* Low-level debugging */
int i;
@@ -801,7 +801,7 @@ struct mveth_softc *sc = ifp->if_softc;
struct ether_multistep step;
BSP_mve_mcast_filter_clear( sc->pvt );
ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
while ( enm ) {
@@ -849,7 +849,7 @@ int f;
case SIOCSIFMEDIA:
error = BSP_mve_media_ioctl(sc->pvt, cmd, &ifr->ifr_media);
break;
case SIOCADDMULTI:
case SIOCDELMULTI:
error = (cmd == SIOCADDMULTI)
@@ -1050,7 +1050,7 @@ struct ifnet *ifp;
* While nonzero, the 'if->if_timer' is decremented
* (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
- * is called when it expires.
+ * is called when it expires.
* If either of those fields is 0 the feature is disabled.
ifp->if_watchdog = mveth_watchdog;
2.26.2
