[PATCH rtems-libbsd 1/5] rtemsbsd: Add mv643xx nexus ethernet driver
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:30:11 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Update #4345
libbsd.py | 19 +
rtemsbsd/include/bsp/nexus-devices.h | 7 +-
rtemsbsd/sys/dev/mve/mv643xx_nexus.c | 965 +++++++++++++++++++++++++++
3 files changed, 990 insertions(+), 1 deletion(-)
create mode 100644 rtemsbsd/sys/dev/mve/mv643xx_nexus.c
diff --git a/libbsd.py b/libbsd.py
index a2056f36..b25d7e03 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -292,6 +292,25 @@ class rtems(builder.Module):
'pppd/sys-rtems.c',
'pppd/upap.c',
'pppd/utils.c',
+ 'sys/arm/lpc/if_lpe.c',
+ 'sys/arm/lpc/lpc_pwr.c',
+ 'sys/dev/atsam/if_atsam.c',
+ 'sys/dev/atsam/if_atsam_media.c',
+ 'sys/dev/dw_mmc/dw_mmc.c',
+ 'sys/dev/ffec/if_ffec_mcf548x.c',
+ 'sys/dev/ffec/if_ffec_mpc8xx.c',
+ 'sys/dev/mve/mv643xx_nexus.c',
+ 'sys/dev/input/touchscreen/tsc_lpc32xx.c',
+ 'sys/dev/smc/if_smc_nexus.c',
+ 'sys/dev/tsec/if_tsec_nexus.c',
+ 'sys/dev/usb/controller/ehci_mpc83xx.c',
+ 'sys/dev/usb/controller/ohci_lpc32xx.c',
+ 'sys/dev/usb/controller/ohci_lpc.c',
+ 'sys/dev/usb/controller/usb_otg_transceiver.c',
+ 'sys/dev/usb/controller/usb_otg_transceiver_dump.c',
+ 'sys/fs/devfs/devfs_devs.c',
+ 'sys/net/if_ppp.c',
+ 'sys/net/ppp_tty.c',
'telnetd/telnetd-service.c',
mm.generator['source']()
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 53a22798..82a6f332 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -246,6 +246,11 @@ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
RTEMS_BSD_DRIVER_PC_LEGACY;
-#endif /* LIBBSP_POWERPC_MOTOROLA_POWERPC_BSP_H */
+#elif defined(LIBBSP_BEATNIK_BSP_H)
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(mve, 0, 0, NULL);
+SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
+#endif
#endif
diff --git a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
new file mode 100644
index 00000000..804c3e7f
--- /dev/null
+++ b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
@@ -0,0 +1,965 @@
+/* RTEMS driver for the mv643xx gigabit ethernet chip */
+/* Acknowledgement:
+ * Valuable information for developing this driver was obtained
+ * from the linux open-source driver mv643xx_eth.c which was written
+ * by the following people and organizations:
+ * Matthew Dharm <mdharm at momenco.com>
+ * rabeeh at galileo.co.il
+ * PMC-Sierra, Inc., Manish Lachwani
+ * Ralf Baechle <ralf at linux-mips.org>
+ * MontaVista Software, Inc., Dale Farnsworth <dale at farnsworth.org>
+ * Steven J. Hill <sjhill1 at rockwellcollins.com>/<sjhill at realitydiluted.com>
+ * Note however, that in spite of the identical name of this file
+ * (and some of the symbols used herein) this file provides a
+ * new implementation and is the original work by the author.
+ * Authorship
+ * This software (mv643xx ethernet driver for RTEMS) was
+ * created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
+ * Stanford Linear Accelerator Center, Stanford University.
+ * Acknowledgement of sponsorship
+ * The 'mv643xx ethernet driver for RTEMS' was produced by
+ * the Stanford Linear Accelerator Center, Stanford University,
+ * under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * Government disclaimer of liability
+ * Neither the United States nor the United States Department of Energy,
+ * nor any of their employees, makes any warranty, express or implied, or
+ * assumes any legal liability or responsibility for the accuracy,
+ * completeness, or usefulness of any data, apparatus, product, or process
+ * disclosed, or represents that its use would not infringe privately owned
+ * rights.
+ * Stanford disclaimer of liability
+ * Stanford University makes no representations or warranties, express or
+ * implied, nor assumes any liability for the use of this software.
+ * Stanford disclaimer of copyright
+ * Stanford University, owner of the copyright, hereby disclaims its
+ * copyright and all other rights in this software. Hence, anyone may
+ * freely use it for any purpose without restriction.
+ * Maintenance of notices
+ * In the interest of clarity regarding the origin and status of this
+ * SLAC software, this and all the preceding Stanford University notices
+ * are to remain affixed to any copy or derivative of this software made
+ * or distributed by the recipient and are to be affixed to any copy of
+ * software made or distributed by the recipient that contains a copy or
+ * derivative of this software.
+ * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
+/* Nexus port by Till Straumann, <till.straumann at psi.ch>, 3/2021 */
+#include <machine/rtems-bsd-kernel-space.h>
+#include <bsp.h>
+#ifdef LIBBSP_BEATNIK_BSP_H
+#include <sys/types.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/module.h>
+#include <sys/socket.h>
+#include <sys/sockio.h>
+#include <net/if.h>
+#include <net/if_types.h>
+#include <net/if_var.h>
+#include <net/if_dl.h>
+#include <net/if_media.h>
+#include <net/ethernet.h>
+#include <dev/mii/mii.h>
+#include <dev/mii/miivar.h>
+#include <rtems/bsd/local/miibus_if.h>
+#include <stdio.h>
+#include <bsp/mv643xx_eth.h>
+#define DRVNAME "mv63xx_nexus"
+#undef MVETH_DEBUG
+/* Define default ring sizes */
+#ifdef MVETH_TESTING
+/* hard and small defaults */
+#define MV643XX_RX_RING_SIZE 2
+#define MV643XX_TX_QUEUE_SIZE 4
+#define MV643XX_BD_PER_PACKET 1
+#define TX_LOWWATER 1
+#else /* MVETH_TESTING */
+#define MV643XX_RX_RING_SIZE 40 /* attached buffers are always 2k clusters, i.e., this
+ * driver - with a configured ring size of 40 - constantly
+ * locks 80k of cluster memory - your app config better
+ * provides enough space!
+#define MV643XX_TX_QUEUE_SIZE 40
+#define MV643XX_BD_PER_PACKET 10
+#define TX_LOWWATER (4*(MV643XX_BD_PER_PACKET))
+#endif /* MVETH_TESTING */
+/* NOTE: tx ring size MUST be > max. # of fragments / mbufs in a chain;
+ * in 'TESTING' mode, special code is compiled in to repackage
+ * chains that are longer than the ring size. Normally, this is
+ * disabled for sake of speed.
+ * I observed chains of >17 entries regularly!
+#define MV643XX_TX_RING_SIZE ((MV643XX_TX_QUEUE_SIZE) * (MV643XX_BD_PER_PACKET))
+/* The chip puts the ethernet header at offset 2 into the buffer so
+ * that the payload is aligned
+#define ETH_RX_OFFSET 2
+#define ETH_CRC_LEN 4 /* strip FCS at end of packet */
+#ifndef __PPC__
+#error "Dont' know how to deal with cache on this CPU architecture"
+#endif
+/* Ring entries are 32 bytes; coherency-critical chunks are 16 -> software coherency
+ * management works for cache line sizes of 16 and 32 bytes only. If the line size
+ * is bigger, the descriptors could be padded...
+#if !defined(PPC_CACHE_ALIGNMENT)
+#error "PPC_CACHE_ALIGNMENT not defined"
+#elif PPC_CACHE_ALIGMENT != 16 && PPC_CACHE_ALIGNMENT != 32
+#error "Cache line size must be 16 or 32"
+#else
+#define RX_BUF_ALIGNMENT PPC_CACHE_ALIGNMENT
+#endif
+/* HELPER MACROS */
+/* Align base to alignment 'a' */
+#define MV643XX_ALIGN(b, a) ((((uint32_t)(b)) + (a)-1) & (~((a)-1)))
+#define IRQ_EVENT RTEMS_EVENT_0
+#define TX_EVENT RTEMS_EVENT_1
+/* Hacks -- FIXME */
+rtems_id
+rtems_bsdnet_newproc (char *name, int stacksize, void(*entry)(void *), void *arg);
+#define SIO_RTEMS_SHOW_STATS _IO('i', 250)
+#define MVE643XX_DUMMY_PHY 0 /* phy is defined by low-level driver */
+struct mve_enet_softc {
+ device_t dev;
+ struct ifnet *ifp;
+ device_t miibus;
+ struct mii_data *mii_softc;
+ struct mveth_private *mp;
+ struct mtx mtx;
+ struct callout wdCallout;
+ rtems_id daemonTid;
+ int oif_flags;
+typedef struct MveMbufIter {
+ MveEthBufIter it;
+ struct mbuf *next;
+ struct mbuf *head;
+} MveMbufIter;
+/* Forward Declarations */
+struct mve_enet_softc;
+static void
+mve_media_status(struct ifnet *ifp, struct ifmediareq *ifmr);
+static int
+mve_media_change(struct ifnet *ifp);
+static void
+mve_set_filters(struct ifnet *ifp);
+static int
+xlateMediaFlags(const struct mii_data *mid);
+static void
+mve_ack_link_change(struct mve_enet_softc *sc);
+static __inline__ void
+mve_send_event(struct mve_enet_softc *sc, rtems_event_set ev)
+rtems_status_code st;
+ if ( RTEMS_SUCCESSFUL != (st = rtems_event_send(sc->daemonTid, ev)) ) {
+ printk(DRVNAME": rtems_event_send returned 0x%08x (TID: 0x%08x, sc: 0x%08x)\n", st, sc->daemonTid, sc);
+ rtems_panic(DRVNAME": rtems_event_send() failed!\n");
+mve_lock(struct mve_enet_softc *sc, const char *from)
+ mtx_lock( & sc->mtx );
+/*printk("L V %s\n", from);*/
+mve_unlock(struct mve_enet_softc *sc, const char *from)
+/*printk("L ^ %s\n", from);*/
+ mtx_unlock( & sc->mtx );
+static int
+mve_probe(device_t dev)
+ int unit = device_get_unit(dev);
+ int err;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_probe (entering)\n");
+#endif
+ if ( unit >= 0 && unit < MV643XXETH_NUM_DRIVER_SLOTS ) {
+ err = BUS_PROBE_DEFAULT;
+ } else {
+ err = ENXIO;
+ return err;
+/* allocate a new cluster and copy an existing chain there;
+ * old chain is released...
+static struct mbuf *
+repackage_chain(struct mbuf *m_head)
+struct mbuf *m;
+ m = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
+ if ( m ) {
+ m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
+ m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
+ m_freem(m_head);
+ return m;
+ * starting at 'm' scan the buffer chain until we
+ * find a non-empty buffer (which we return)
+static __inline__ struct mbuf *
+skipEmpty(struct mbuf *m)
+ while ( m && ( 0 == m->m_len ) ) {
+ m = m->m_next;
+ return m;
+ * Record a buffer's info in the low-leve driver 'iterator' struct.
+ * Also scan ahead to find the next non-empty buffer (store it in
+ * the iterator's 'next' field). This info is needed because we
+ * want to know if 'this' buffer is the last (non-empty!) one
+ * in a chain.
+ * On entry 'it->next' identifies 'this' buffer and on return
+ * 'it->next' points to the next non-empty buffer.
+static MveEthBufIter *
+nextBuf(MveEthBufIter *arg)
+MveMbufIter *it = (MveMbufIter*)arg;
+struct mbuf *m;
+ /* If 'this' buffer is non-null */
+ if ( (m = it->next) ) {
+ /* find next non-empty buffer */
+ it->next = skipEmpty( m->m_next );
+ /* record 'this' buffer's info */
+ it->it.data = mtod(m, void*);
+ it->it.len = m->m_len;
+ /* if there is a non-empty buffer after 'this' uptr is NULL
+ * if this is tha last buffer in a chain then record the
+ * head of the chain in the uptr (for eventual cleanup
+ * by release_tx_mbuf()).
+ it->it.uptr = it->next ? 0 : it->head;
+ return (MveEthBufIter*)it;
+ return 0;
+ * Initialize the iterator struct
+initIter(MveMbufIter *it, struct mbuf *m)
+ /* record the head of the chain */
+ it->head = m;
+ /* initialize 'next' field to the first non-empty buffer.
+ * This may be NULL if the chain is entirely empty but
+ * that is handled correctly.
+ it->next = skipEmpty( m );
+ /* Fill with first buf info */
+ return nextBuf( &it->it );
+static int
+mve_send_mbuf( struct mve_enet_softc *sc, struct mbuf *m_head )
+MveMbufIter iter;
+int rval;
+startover:
+ if ( ! m_head ) {
+ return 0;
+ if ( ! initIter( &iter, m_head ) ) {
+ /* completely empty chain */
+ m_freem( m_head );
+ return 0;
+ rval = BSP_mve_send_buf_chain( sc->mp, nextBuf, &iter.it );
+ if ( -2 == rval ) {
+ /* would never fit (too many fragments) */
+ m_head = repackage_chain( m_head );
+ goto startover;
+ return rval;
+static void
+mve_isr(void *closure)
+struct mve_enet_softc *sc = (struct mve_enet_softc*)closure;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_isr; posting event to %x\n", sc->daemonTid);
+#endif
+ BSP_mve_disable_irqs( sc->mp );
+ mve_send_event( sc, IRQ_EVENT );
+static void
+mve_stop(struct mve_enet_softc *sc)
+ BSP_mve_stop_hw( sc->mp );
+ /* clear IF flags */
+ if_setdrvflagbits(sc->ifp, 0, (IFF_DRV_OACTIVE | IFF_DRV_RUNNING));
+static void
+struct mve_enet_softc *sc = (struct mve_enet_softc*)ifp->if_softc;
+int iff = if_getflags(ifp);
+struct ifmultiaddr *ifma;
+unsigned char *lladdr;
+ BSP_mve_promisc_set( sc->mp, !!(iff & IFF_PROMISC));
+ if ( iff & (IFF_PROMISC | IFF_ALLMULTI) ) {
+ BSP_mve_mcast_filter_accept_all(sc->mp);
+ } else {
+ BSP_mve_mcast_filter_clear( sc->mp );
+ if_maddr_rlock( ifp );
+ CK_STAILQ_FOREACH( ifma, &ifp->if_multiaddrs, ifma_link ) {
+ if ( ifma->ifma_addr->sa_family != AF_LINK ) {
+ continue;
+ lladdr = LLADDR((struct sockaddr_dl *) ifma->ifma_addr);
+ BSP_mve_mcast_filter_accept_add( sc->mp, lladdr );
+ if_maddr_runlock( ifp );
+/* Daemon task does all the 'interrupt' work */
+static void
+mve_daemon(void *arg)
+struct mve_enet_softc *sc = (struct mve_enet_softc*) arg;
+struct ifnet *ifp = sc->ifp;
+rtems_event_set evs;
+struct mbuf *m;
+int avail;
+int sndStat;
+uint32_t irqstat;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": bsdnet mveth_daemon started\n");
+#endif
+ mve_lock( sc, "daemon" );
+ for (;;) {
+ mve_unlock( sc, "daemon" );
+ if ( RTEMS_SUCCESSFUL != rtems_event_receive( (IRQ_EVENT | TX_EVENT), (RTEMS_WAIT | RTEMS_EVENT_ANY), RTEMS_NO_TIMEOUT, &evs ) ) {
+ rtems_panic(DRVNAME": rtems_event_receive() failed!\n");
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": bsdnet mveth_daemon event received 0x%x\n", evs);
+#endif
+ if ( !(if_getflags(ifp) & IFF_UP) ) {
+ mve_stop(sc);
+ /* clear flag */
+ if_setdrvflagbits(sc->ifp, 0, IFF_DRV_RUNNING);
+ continue;
+ if ( ! (if_getdrvflags(ifp) & IFF_DRV_RUNNING) ) {
+ /* event could have been pending at the time hw was stopped;
+ * just ignore...
+ continue;
+ if ( (evs & IRQ_EVENT) ) {
+ irqstat = BSP_mve_ack_irqs(sc->mp);
+ } else {
+ irqstat = 0;
+ if ( (MV643XX_ETH_EXT_IRQ_LINK_CHG & irqstat) && sc->mii_softc ) {
+ /* phy status changed */
+ mii_pollstat( sc->mii_softc );
+ /* free tx chain and send */
+ if ( (evs & TX_EVENT) || (MV643XX_ETH_EXT_IRQ_TX_DONE & irqstat) ) {
+ while ( (avail = BSP_mve_swipe_tx( sc->mp )) > TX_LOWWATER ) {
+ IF_DEQUEUE( &ifp->if_snd, m );
+ if ( ! m ) {
+ /* clear active bit */
+ if_setdrvflagbits(ifp, 0, IFF_DRV_OACTIVE);
+ break;
+ sndStat = mve_send_mbuf( sc, m );
+ if ( sndStat < 0 ) {
+ /* maybe not enough space right now; requeue and wait for next IRQ */
+ IF_PREPEND( &ifp->if_snd, m );
+ break;
+ if ( (MV643XX_ETH_IRQ_RX_DONE & irqstat) ) {
+ BSP_mve_swipe_rx(sc->mp);
+ BSP_mve_enable_irqs(sc->mp);
+ mve_unlock( sc, "daemon (xit)" );
+static void
+release_tx_mbuf(void *user_buf, void *closure, int error_on_tx_occurred)
+struct mbuf *mb = (struct mbuf*)user_buf;
+ if ( error_on_tx_occurred ) {
+ if_inc_counter( ifp, IFCOUNTER_OERRORS, 1 );
+ } else {
+ if_inc_counter( ifp, IFCOUNTER_OPACKETS, 1 );
+ if_inc_counter( ifp, IFCOUNTER_OBYTES, mb->m_pkthdr.len );
+ m_freem(mb);
+static void *
+alloc_rx_mbuf(int *p_size, uintptr_t *p_data)
+struct mbuf *m;
+unsigned long l,o;
+ if ( m ) {
+ o = mtod(m, unsigned long);
+ l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
+ /* align start of buffer */
+ m->m_data += l;
+ /* reduced length */
+ l = MCLBYTES - l;
+ m->m_len = m->m_pkthdr.len = l;
+ *p_size = m->m_len;
+ *p_data = mtod(m, uintptr_t);
+ return (void*) m;
+static void
+consume_rx_mbuf(void *user_buf, void *closure, int len)
+struct mbuf *m = (struct mbuf*)user_buf;
+ if ( len <= 0 ) {
+ if_inc_counter( ifp, IFCOUNTER_IQDROPS, 1 );
+ if ( len < 0 ) {
+ if_inc_counter( ifp, IFCOUNTER_IERRORS, 1 );
+ m_freem(m);
+ } else {
+ m->m_len = m->m_pkthdr.len = len - ETH_RX_OFFSET - ETH_CRC_LEN;
+ m->m_data += ETH_RX_OFFSET;
+ m->m_pkthdr.rcvif = ifp;
+ if_inc_counter( ifp, IFCOUNTER_IPACKETS, 1 );
+ if_inc_counter( ifp, IFCOUNTER_IBYTES, m->m_pkthdr.len );
+ if (0) {
+ /* Low-level debugging */
+ int i;
+ for (i=0; i<m->m_len; i++) {
+ if ( !(i&15) )
+ printk("\n");
+ printk("0x%02x ",mtod(m,char*)[i]);
+ printk("\n");
+ mve_unlock( sc, "rx_cleanup" );
+ (*ifp->if_input)(ifp, m);
+ mve_lock( sc, "rx_cleanup" );
+/* Translate IFFLAGS to low-level driver representation */
+static int
+int lowLevelFlags = 0;
+int msk = IFM_AVALID | IFM_ACTIVE;
+ if ( (mid->mii_media_status & msk) == msk ) {
+ lowLevelFlags |= MV643XX_MEDIA_LINK;
+ if ( IFM_OPTIONS( mid->mii_media_active ) & IFM_FDX ) {
+ lowLevelFlags |= MV643XX_MEDIA_FD;
+ switch ( IFM_ETHER_SUBTYPE_GET( mid->mii_media_active ) ) {
+ default:
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"xlateMediaFlags: UNKNOWN SPEED\n");
+#endif
+ break; /* UNKNOWN -- FIXME */
+ case IFM_10_T:
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"xlateMediaFlags: 10baseT\n");
+#endif
+ lowLevelFlags |= MV643XX_MEDIA_10;
+ break;
+ case IFM_100_TX:
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"xlateMediaFlags: 100baseT\n");
+#endif
+ lowLevelFlags |= MV643XX_MEDIA_100;
+ break;
+ case IFM_1000_T:
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"xlateMediaFlags: 1000baseT\n");
+#endif
+ lowLevelFlags |= MV643XX_MEDIA_1000;
+ break;
+ } else {
+#ifdef MVETH_DEBUG
+ printk(DRVNAME"xlateMediaFlags: NO LINK\n");
+#endif
+ return lowLevelFlags;
+static void
+mve_init_unlocked(struct mve_enet_softc *sc)
+int lowLevelMediaStatus = 0;
+int promisc;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_init (entering)\n");
+#endif
+ if ( sc->mii_softc ) {
+ lowLevelMediaStatus = xlateMediaFlags( sc->mii_softc );
+ if ( (lowLevelMediaStatus & MV643XX_MEDIA_LINK) ) {
+ } else {
+ if_setdrvflagbits(ifp, IFF_DRV_OACTIVE, 0);
+ promisc = !! (if_getdrvflags(ifp) & IFF_PROMISC);
+ BSP_mve_init_hw(sc->mp, promisc, if_getlladdr(ifp), lowLevelMediaStatus);
+ /* if promiscuous then there is no need to change */
+ if ( ! promisc ) {
+ mve_set_filters(ifp);
+ if_setdrvflagbits(ifp, IFF_DRV_RUNNING, 0);
+static void
+mve_init(void *arg)
+struct mve_enet_softc *sc = (struct mve_enet_softc*)arg;
+ mve_lock( sc, "mve_init" );
+ mve_init_unlocked( sc );
+ mve_unlock( sc, "mve_init" );
+static void
+mve_start_unlocked(struct ifnet *ifp)
+ mve_send_event( sc, TX_EVENT );
+static void
+mve_start(struct ifnet *ifp)
+ mve_lock( sc, "mve_start" );
+ mve_start_unlocked( ifp );
+ mve_unlock( sc, "mve_start" );
+static int
+mve_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
+struct ifreq *ifr = (struct ifreq *)data;
+int err = 0;
+int f, df;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_ioctl (entering)\n");
+#endif
+ mve_lock( sc, "mve_ioctl" );
+ switch ( cmd ) {
+ case SIOCSIFFLAGS:
+ f = if_getflags( ifp );
+ df = if_getdrvflags( ifp );
+ if ( (f & IFF_UP) ) {
+ if ( ! ( df & IFF_DRV_RUNNING ) ) {
+ mve_init_unlocked(sc);
+ } else {
+ if ( (f & IFF_PROMISC) != (sc->oif_flags & IFF_PROMISC) ) {
+ /* FIXME: other flag changes are ignored/unimplemented */
+ } else {
+ if ( df & IFF_DRV_RUNNING ) {
+ mve_stop(sc);
+ sc->oif_flags = f;
+ break;
+ case SIOCGIFMEDIA:
+ case SIOCSIFMEDIA:
+ err = ifmedia_ioctl( ifp, ifr, &sc->mii_softc->mii_media, cmd );
+ } else {
+ err = EINVAL;
+ break;
+ case SIOCADDMULTI:
+ case SIOCDELMULTI:
+ if ( if_getdrvflags( ifp ) & IFF_DRV_RUNNING ) {
+ break;
+ case SIO_RTEMS_SHOW_STATS:
+ BSP_mve_dump_stats(sc->mp, stdout);
+ break;
+ default:
+ err = ether_ioctl(ifp, cmd, data);
+ break;
+ mve_unlock( sc, "mve_ioctl" );
+ return err;
+ * Used to update speed settings in the hardware
+ * when the phy setup changes.
+ * ASSUME: caller holds lock
+static void
+struct mii_data *mii = sc->mii_softc;
+int lowLevelMediaStatus;
+ if ( !mii )
+ return;
+ lowLevelMediaStatus = xlateMediaFlags( mii );
+ BSP_mve_update_serial_port( sc->mp, lowLevelMediaStatus );
+ if_setdrvflagbits( sc->ifp, 0, IFF_DRV_OACTIVE );
+ mve_start_unlocked( sc->ifp );
+ } else {
+ if_setdrvflagbits( sc->ifp, IFF_DRV_OACTIVE, 0 );
+/* Callback from ifmedia_ioctl()
+ * Caller probably holds the lock already but
+ * since it is recursive we may as well make sure
+ * in case there are other possible execution paths.
+static int
+struct mve_enet_softc *sc = (struct mve_enet_softc *)ifp->if_softc;
+int err;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_media_change\n");
+#endif
+ if ( ! mii ) {
+ return ENXIO;
+ err = mii_mediachg( mii );
+ return err;
+static void
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_media_status\n");
+#endif
+ if ( mii ) {
+ mii_pollstat( mii );
+ ifmr->ifm_active = mii->mii_media_active;
+ ifmr->ifm_status = mii->mii_media_status;
+static int
+mve_attach(device_t dev)
+struct mve_enet_softc *sc;
+struct ifnet *ifp;
+uint8_t hwaddr[ETHER_ADDR_LEN];
+struct mveth_private *mp;
+int unit = device_get_unit(dev);
+int tx_ring_size = MV643XX_TX_RING_SIZE;
+int rx_ring_size = MV643XX_RX_RING_SIZE;
+int tx_q_size = MV643XX_TX_QUEUE_SIZE;
+ sc = device_get_softc( dev );
+ sc->dev = dev;
+ sc->ifp = ifp = if_alloc(IFT_ETHER);
+ sc->daemonTid = 0;
+ sc->mii_softc = 0;
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_attach (entering)\n");
+#endif
+ mtx_init( &sc->mtx, device_get_nameunit( sc->dev ), MTX_NETWORK_LOCK, MTX_RECURSE );
+ callout_init_mtx( &sc->wdCallout, &sc->mtx, 0 );
+ ifp->if_softc = sc;
+ if_initname(ifp, device_get_name(dev), unit);
+ ifp->if_init = mve_init;
+ ifp->if_ioctl = mve_ioctl;
+ ifp->if_start = mve_start;
+ if_setflags(ifp, (IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX) );
+ sc->oif_flags = if_getflags(ifp);
+ if_setsendqlen( ifp, tx_q_size );
+ if_setsendqready( ifp );
+ mp = BSP_mve_create(
+ unit + 1, /* low-level driver' unit numbers are 1-based */
+ 0,
+ mve_isr, (void*)sc,
+ release_tx_mbuf, (void*)sc,
+ alloc_rx_mbuf,
+ consume_rx_mbuf, (void*)sc,
+ rx_ring_size,
+ tx_ring_size,
+ ( MV643XX_ETH_IRQ_RX_DONE
+ | MV643XX_ETH_EXT_IRQ_TX_DONE
+ | MV643XX_ETH_EXT_IRQ_LINK_CHG));
+ if ( ! mp ) {
+ rtems_panic("Unable to create mv643xx low-level driver");
+ sc->mp = mp;
+ BSP_mve_read_eaddr( mp, hwaddr );
+ if ( 0 == mii_attach( sc->dev,
+ &sc->miibus,
+ ifp,
+ mve_media_change,
+ mve_media_status,
+ BMSR_DEFCAPMASK,
+ MVE643XX_DUMMY_PHY,
+ MII_OFFSET_ANY,
+ 0 ) ) {
+ sc->mii_softc = device_get_softc( sc->miibus );
+ sc->daemonTid = rtems_bsdnet_newproc("MVE", 4096, mve_daemon, (void*)sc);
+ ether_ifattach( ifp, hwaddr );
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_attach (leaving)\n");
+#endif
+ return 0;
+static int
+mve_miibus_read_reg(device_t dev, int phy, int reg)
+struct mve_enet_softc *sc = (struct mve_enet_softc*) device_get_softc(dev);
+ /* low-level driver knows what phy to use; ignore arg */
+ return (int) BSP_mve_mii_read( sc->mp, reg );
+static int
+mve_miibus_write_reg(device_t dev, int phy, int reg, int val)
+ BSP_mve_mii_write( sc->mp, reg, val );
+ return 0;
+static void
+mve_miibus_statchg(device_t dev)
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_miibus_statchg\n");
+#endif
+ /* assume this ends up being called either from the ioctl or the driver
+ * task -- either of which holds the lock.
+ mve_ack_link_change( sc );
+static void
+mve_miibus_linkchg(device_t dev)
+#ifdef MVETH_DEBUG
+ printk(DRVNAME": mve_miibus_linkchg\n");
+#endif
+static device_method_t mve_methods[] = {
+ DEVMETHOD(device_probe, mve_probe ),
+ DEVMETHOD(device_attach, mve_attach),
+ DEVMETHOD(miibus_readreg, mve_miibus_read_reg ),
+ DEVMETHOD(miibus_writereg, mve_miibus_write_reg),
+ DEVMETHOD(miibus_statchg , mve_miibus_statchg ),
+ DEVMETHOD(miibus_linkchg , mve_miibus_linkchg ),
+ DEVMETHOD_END
+static driver_t mve_nexus_driver = {
+ "mve",
+ mve_methods,
+ sizeof( struct mve_enet_softc )
+static devclass_t mve_devclass;
+DRIVER_MODULE(mve, nexus, mve_nexus_driver, mve_devclass, 0, 0);
+DRIVER_MODULE(miibus, mve, miibus_driver, miibus_devclass, 0, 0);
+MODULE_DEPEND(mve, nexus, 1, 1, 1);
+MODULE_DEPEND(mve, ether, 1, 1, 1);
+#endif
2.26.2
