[PATCH rtems-libbsd 2/5] mv643xx_nexus.c: removed unlocked mve_init(), mve_start()
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 01:30:12 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
The recursive lock takes care of this...
Update #4345
rtemsbsd/sys/dev/mve/mv643xx_nexus.c | 37 +++++++---------------------
1 file changed, 9 insertions(+), 28 deletions(-)
diff --git a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
index 804c3e7f..3b443583 100644
--- a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
+++ b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
@@ -23,13 +23,13 @@
* This software (mv643xx ethernet driver for RTEMS) was
* created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
- * Stanford Linear Accelerator Center, Stanford University.
+ * Stanford Linear Accelerator Center, Stanford University.
* Acknowledgement of sponsorship
* The 'mv643xx ethernet driver for RTEMS' was produced by
* the Stanford Linear Accelerator Center, Stanford University,
- * under Contract DE-AC03-76SFO0515 with the Department of Energy.
+ * under Contract DE-AC03-76SFO0515 with the Department of Energy.
* Government disclaimer of liability
@@ -615,9 +615,10 @@ int msk = IFM_AVALID | IFM_ACTIVE;
static void
-mve_init_unlocked(struct mve_enet_softc *sc)
+mve_init(void *arg)
-struct ifnet *ifp = sc->ifp;
+struct mve_enet_softc *sc = (struct mve_enet_softc*)arg;
+struct ifnet *ifp = sc->ifp;
int lowLevelMediaStatus = 0;
int promisc;
@@ -625,7 +626,6 @@ int promisc;
printk(DRVNAME": mve_init (entering)\n");
#endif
if ( sc->mii_softc ) {
mii_pollstat( sc->mii_softc );
lowLevelMediaStatus = xlateMediaFlags( sc->mii_softc );
@@ -649,33 +649,16 @@ int promisc;
if_setdrvflagbits(ifp, IFF_DRV_RUNNING, 0);
-static void
-mve_init(void *arg)
-struct mve_enet_softc *sc = (struct mve_enet_softc*)arg;
- mve_lock( sc, "mve_init" );
- mve_init_unlocked( sc );
- mve_unlock( sc, "mve_init" );
-static void
-mve_start_unlocked(struct ifnet *ifp)
-struct mve_enet_softc *sc = (struct mve_enet_softc*)ifp->if_softc;
- if_setdrvflagbits(ifp, IFF_DRV_OACTIVE, 0);
- mve_send_event( sc, TX_EVENT );
static void
mve_start(struct ifnet *ifp)
mve_lock( sc, "mve_start" );
- mve_start_unlocked( ifp );
+ if_setdrvflagbits(ifp, IFF_DRV_OACTIVE, 0);
mve_unlock( sc, "mve_start" );
+ mve_send_event( sc, TX_EVENT );
static int
mve_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
@@ -696,7 +679,7 @@ int f, df;
df = if_getdrvflags( ifp );
if ( (f & IFF_UP) ) {
if ( ! ( df & IFF_DRV_RUNNING ) ) {
- mve_init_unlocked(sc);
+ mve_init( (void*)sc );
} else {
if ( (f & IFF_PROMISC) != (sc->oif_flags & IFF_PROMISC) ) {
mve_set_filters(ifp);
@@ -761,7 +744,7 @@ int lowLevelMediaStatus;
if ( (lowLevelMediaStatus & MV643XX_MEDIA_LINK) ) {
BSP_mve_update_serial_port( sc->mp, lowLevelMediaStatus );
if_setdrvflagbits( sc->ifp, 0, IFF_DRV_OACTIVE );
- mve_start_unlocked( sc->ifp );
+ mve_start( sc->ifp );
} else {
if_setdrvflagbits( sc->ifp, IFF_DRV_OACTIVE, 0 );
@@ -808,7 +791,6 @@ struct mii_data *mii = sc->mii_softc;
ifmr->ifm_active = mii->mii_media_active;
ifmr->ifm_status = mii->mii_media_status;
static int
@@ -865,7 +847,6 @@ int tx_q_size = MV643XX_TX_QUEUE_SIZE;
sc->mp = mp;
BSP_mve_read_eaddr( mp, hwaddr );
if ( 0 == mii_attach( sc->dev,
2.26.2
