[PATCH rtems-libbsd 3/5] mv643xx_nexus.c: removed 'repackage_chain()'.
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 30 01:30:13 UTC 2021
From: till straumann <till.straumann at alumni.tu-berlin.de>
Testing (TCP with larger amounts of data while MVETH_TESTING
was defined which reduces the ring sizes to very small numbers)
revealed that the BSD stack honours the 'sendqlen' and
never hands us chains exceeding the ring size.
Update #4345
 rtemsbsd/sys/dev/mve/mv643xx_nexus.c | 33 ++--------------------------
 1 file changed, 2 insertions(+), 31 deletions(-)
diff --git a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
index 3b443583..5edcdea4 100644
--- a/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
+++ b/rtemsbsd/sys/dev/mve/mv643xx_nexus.c
@@ -95,8 +95,9 @@
 /* Define default ring sizes */
-#ifdef MVETH_TESTING
+#undef  MVETH_TESTING
+#ifdef  MVETH_TESTING
 /* hard and small defaults */
 #define MV643XX_RX_RING_SIZE	2
 #define MV643XX_TX_QUEUE_SIZE   4
@@ -116,9 +117,6 @@
 #endif /* MVETH_TESTING */
 /* NOTE: tx ring size MUST be > max. # of fragments / mbufs in a chain;
- *       in 'TESTING' mode, special code is compiled in to repackage
- *		 chains that are longer than the ring size. Normally, this is
- *		 disabled for sake of speed.
  *		 I observed chains of >17 entries regularly!
 #define MV643XX_TX_RING_SIZE	((MV643XX_TX_QUEUE_SIZE) * (MV643XX_BD_PER_PACKET))
@@ -240,25 +238,6 @@ mve_probe(device_t dev)
 	return err;
-/* allocate a new cluster and copy an existing chain there;
- * old chain is released...
-static struct mbuf *
-repackage_chain(struct mbuf *m_head)
-struct mbuf *m;
-	m = m_getcl(M_NOWAIT, MT_DATA, M_PKTHDR);
-	if ( m ) {
-		m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
-		m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
-	m_freem(m_head);
-	return m;
  * starting at 'm' scan the buffer chain until we
  * find a non-empty buffer (which we return)
@@ -328,8 +307,6 @@ mve_send_mbuf( struct mve_enet_softc *sc, struct mbuf *m_head )
 MveMbufIter iter;
 int         rval;
-startover:
 	if ( ! m_head ) {
 		return 0;
@@ -342,12 +319,6 @@ startover:
 	rval = BSP_mve_send_buf_chain( sc->mp, nextBuf, &iter.it );
-	if ( -2 == rval ) {
-		/* would never fit (too many fragments) */
-		m_head = repackage_chain( m_head );
-		goto startover;
 	return rval;
2.26.2
