[PATCH rtems 01/18] Broke low-level parts of mv643xx_eth driver into separate files
Chris Johns
chrisj at rtems.org
Tue Mar 30 02:16:24 UTC 2021
Hi,
Thanks for bring this to our attention.
I have pinged Till via github about the patches.
There is no point adding these to master because the legacy stack has moved so
appling the to the legacy stack repo is fine.
I see on github they are for the 5 branch and I feel they hsould be fine on that
branch. They are specific to a BSP and that BSP has not really worked on 5 until
recently. I think it would be good to have this driver supported on 5.
On 30/3/21 12:27 pm, Vijay Kumar Banerjee wrote:
> From: till straumann <till.straumann at alumni.tu-berlin.de>
> Update #4344
> bsps/powerpc/beatnik/headers.am | 1 +
> .../powerpc/beatnik/include/bsp/mv643xx_eth.h | 111 +
> bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c | 1162 +-----
> .../beatnik/net/if_mve/mv643xx_eth_bsdnet.c | 3519 +++++++++++++++++
> c/src/lib/libbsp/powerpc/beatnik/Makefile.am | 4 +-
> 5 files changed, 3659 insertions(+), 1138 deletions(-)
> create mode 100644 bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
> create mode 100644 bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
> diff --git a/bsps/powerpc/beatnik/headers.am b/bsps/powerpc/beatnik/headers.am
> index 36df3cd759..8416bbd626 100644
> --- a/bsps/powerpc/beatnik/headers.am
> +++ b/bsps/powerpc/beatnik/headers.am
> @@ -20,3 +20,4 @@ include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_em_
> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h
> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/if_mve_pub.h
> include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/irq.h
> +include_bsp_HEADERS += ../../../../../../bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
> diff --git a/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
> new file mode 100644
> index 0000000000..eefca62603
> --- /dev/null
> +++ b/bsps/powerpc/beatnik/include/bsp/mv643xx_eth.h
> @@ -0,0 +1,111 @@
> +#ifndef MV643XX_LOWLEVEL_DRIVER_H
> +#define MV643XX_LOWLEVEL_DRIVER_H
> +struct mveth_private;
> +/* Clear multicast filters */
> +void
> +BSP_mve_mcast_filter_clear(struct mveth_private *mp);
> +void
> +BSP_mve_mcast_filter_accept_all(struct mveth_private *mp);
> +void
> +BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr);
> +void
> +BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr);
> +/* Stop hardware and clean out the rings */
> +void
> +BSP_mve_stop_hw(struct mveth_private *mp);
> +struct mveth_private *
> +BSP_mve_setup_1(
> + struct mveth_private*,
> + int unit,
> + void (*isr)(void *isr_arg),
> + void *isr_arg,
> + void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
> + void *cleanup_txbuf_arg,
> + void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
> + void (*consume_rxbuf)(void *user_buf, void *closure, int len),
> + void *consume_rxbuf_arg,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> +/* MAIN RX-TX ROUTINES
> + * BSP_mve_swipe_tx(): descriptor scavenger; releases mbufs
> + * BSP_mve_send_buf(): xfer mbufs from IF to chip
> + * BSP_mve_swipe_rx(): enqueue received mbufs to interface
> + * allocate new ones and yield them to the
> + * chip.
> +/* clean up the TX ring freeing up buffers */
> +int
> +BSP_mve_swipe_tx(struct mveth_private *mp);
> +int
> +BSP_mve_send_buf_raw(
> + struct mveth_private *mp,
> + void *head_p,
> + int h_len,
> + void *data_p,
> + int d_len);
> +/* send received buffers upwards and replace them
> + * with freshly allocated ones;
> + * ASSUMPTION: buffer length NEVER changes and is set
> + * when the ring is initialized.
> + * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
> +int
> +BSP_mve_swipe_rx(struct mveth_private *mp);
> +rtems_id
> +BSP_mve_get_tid(struct mveth_private *mp);
> +int
> +BSP_mve_detach(struct mveth_private *mp);
> +/* Fire up the low-level driver
> + * - make sure hardware is halted
> + * - enable cache snooping
> + * - clear address filters
> + * - clear mib counters
> + * - reset phy
> + * - initialize (or reinitialize) descriptor rings
> + * - check that the firmware has set up a reasonable mac address.
> + * - generate unicast filter entry for our mac address
> + * - write register config values to the chip
> + * - start hardware (serial port and SDMA)
> +void
> +BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr);
> +/* read ethernet address from hw to buffer */
> +void
> +BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr);
> +void
> +BSP_mve_enable_irqs(struct mveth_private *mp);
> +void
> +BSP_mve_disable_irqs(struct mveth_private *mp);
> +uint32_t
> +BSP_mve_ack_irqs(struct mveth_private *mp);
> +void
> +BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask);
> +uint32_t
> +BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask);
> +uint32_t
> +BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask);
> +void
> +BSP_mve_dump_stats(struct mveth_private *mp, FILE *f);
> +unsigned
> +BSP_mve_mii_read(struct mveth_private *mp, unsigned addr);
> +unsigned
> +BSP_mve_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
> +#endif
> diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
> index 85ab038bf5..d002fd52ce 100644
> --- a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
> +++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
> @@ -74,12 +74,14 @@
> * further down...
> #ifndef KERNEL
> #define KERNEL
> #endif
> #ifndef _KERNEL
> #define _KERNEL
> #endif
> #include <rtems.h>
> #include <rtems/bspIo.h>
> @@ -88,44 +90,12 @@
> #include <bsp/irq.h>
> #include <bsp/gtreg.h>
> #include <libcpu/byteorder.h>
> -#include <sys/param.h>
> -#include <sys/proc.h>
> -#include <sys/socket.h>
> -#include <sys/sockio.h>
> -#include <dev/mii/mii.h>
> -#include <net/if_var.h>
> -#include <net/if_media.h>
> -/* Not so nice; would be more elegant not to depend on C library but the
> - * RTEMS-specific ioctl for dumping statistics needs stdio anyways.
> -/*#define NDEBUG effectively removes all assertions
> - * If defining NDEBUG, MAKE SURE assert() EXPRESSION HAVE NO SIDE_EFFECTS!!
> - * This driver DOES have side-effects, so DONT DEFINE NDEBUG
> - * Performance-critical assertions are removed by undefining MVETH_TESTING.
> -#undef NDEBUG
> #include <assert.h>
> #include <stdio.h>
> #include <errno.h>
> #include <inttypes.h>
> -#include <rtems/rtems_bsdnet.h>
> -#include <sys/mbuf.h>
> -#include <net/ethernet.h>
> -#include <net/if.h>
> -#include <netinet/in.h>
> -#include <netinet/if_ether.h>
> -#include <rtems/rtems_mii_ioctl.h>
> -#include <bsp/early_enet_link_status.h>
> -#include <bsp/if_mve_pub.h>
> +#include <bsp/mv643xx_eth.h>
> /* CONFIGURABLE PARAMETERS */
> @@ -777,41 +747,11 @@ struct mveth_private {
> } mc_refcnt;
> -/* stuff needed for bsdnet support */
> -struct mveth_bsdsupp {
> - int oif_flags; /* old / cached if_flags */
> -struct mveth_softc {
> - struct arpcom arpcom;
> - struct mveth_bsdsupp bsd;
> - struct mveth_private pvt;
> /* GLOBAL VARIABLES */
> #ifdef MVETH_DEBUG_TX_DUMP
> int mveth_tx_dump = 0;
> #endif
> -/* THE array of driver/bsdnet structs */
> -/* If detaching/module unloading is enabled, the main driver data
> - * structure must remain in memory; hence it must reside in its own
> - * 'dummy' module...
> -#ifdef MVETH_DETACH_HACK
> -extern
> -#else
> -STATIC
> -#endif
> -struct mveth_softc theMvEths[MV643XXETH_NUM_DRIVER_SLOTS]
> -#ifndef MVETH_DETACH_HACK
> -= {{{{0}},}}
> -#endif
> -/* daemon task id */
> -STATIC rtems_id mveth_tid = 0;
> /* register access protection mutex */
> STATIC rtems_id mveth_mtx = 0;
> #define REGLOCK() do { \
> @@ -861,7 +801,6 @@ static const char *mibfmt[] = {
> /* forward decls + implementation for IRQ API funcs */
> static void mveth_isr(rtems_irq_hdl_param unit);
> -static void mveth_isr_1(rtems_irq_hdl_param unit);
> static void noop(const rtems_irq_connect_data *unused) {}
> static int noop1(const rtems_irq_connect_data *unused) { return 0; }
> @@ -892,40 +831,6 @@ static rtems_irq_connect_data irq_data[MAX_NUM_SLOTS] = {
> -/* MII Ioctl Interface */
> -STATIC unsigned
> -mveth_mii_read(struct mveth_private *mp, unsigned addr);
> -STATIC unsigned
> -mveth_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
> -/* mdio / mii interface wrappers for rtems_mii_ioctl API */
> -static int mveth_mdio_r(int phy, void *uarg, unsigned reg, uint32_t *pval)
> - if ( phy > 1 )
> - return -1;
> - *pval = mveth_mii_read(uarg, reg);
> - return 0;
> -static int mveth_mdio_w(int phy, void *uarg, unsigned reg, uint32_t val)
> - if ( phy > 1 )
> - return -1;
> - mveth_mii_write(uarg, reg, val);
> - return 0;
> -static struct rtems_mdio_info mveth_mdio = {
> - mdio_r: mveth_mdio_r,
> - mdio_w: mveth_mdio_w,
> - has_gmii: 1,
> /* LOW LEVEL SUPPORT ROUTINES */
> /* Software Cache Coherency */
> @@ -1094,16 +999,7 @@ register uint32_t x,xe,p;
> static void mveth_isr(rtems_irq_hdl_param arg)
> -unsigned unit = (unsigned)arg;
> - mveth_disable_irqs(&theMvEths[unit].pvt, -1);
> - theMvEths[unit].pvt.stats.irqs++;
> - rtems_bsdnet_event_send( theMvEths[unit].pvt.tid, 1<<unit );
> -static void mveth_isr_1(rtems_irq_hdl_param arg)
> -struct mveth_private *mp = &theMvEths[unit].pvt;
> +struct mveth_private *mp = (struct mveth_private*) arg;
> mp->stats.irqs++;
> mp->isr(mp->isr_arg);
> @@ -1172,8 +1068,8 @@ uint32_t x;
> * If non-bsd drivers are running on a subset of IFs proper
> * locking of all shared registers must be implemented!
> -STATIC unsigned
> +unsigned
> unsigned v;
> unsigned wc = 0;
> @@ -1198,8 +1094,8 @@ unsigned wc = 0;
> return (wc<<16) | (v & 0xffff);
> -STATIC unsigned
> +unsigned
> unsigned wc = 0;
> @@ -1256,56 +1152,7 @@ uint32_t active_q;
> /* update serial port settings from current link status */
> -static void
> -mveth_update_serial_port(struct mveth_private *mp, int media)
> -int port = mp->port_num;
> -uint32_t old, new;
> - new = old = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(port));
> - /* mask speed and duplex settings */
> - new &= ~( MV643XX_ETH_SET_GMII_SPEED_1000
> - | MV643XX_ETH_SET_MII_SPEED_100
> - | MV643XX_ETH_SET_FULL_DUPLEX );
> - if ( IFM_FDX & media )
> - new |= MV643XX_ETH_SET_FULL_DUPLEX;
> - switch ( IFM_SUBTYPE(media) ) {
> - default: /* treat as 10 */
> - break;
> - case IFM_100_TX:
> - new |= MV643XX_ETH_SET_MII_SPEED_100;
> - break;
> - case IFM_1000_T:
> - new |= MV643XX_ETH_SET_GMII_SPEED_1000;
> - break;
> - if ( new != old ) {
> - if ( ! (MV643XX_ETH_SERIAL_PORT_ENBL & new) ) {
> - /* just write */
> - MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), new);
> - } else {
> - uint32_t were_running;
> - were_running = mveth_stop_tx(port);
> - old &= ~MV643XX_ETH_SERIAL_PORT_ENBL;
> - MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), old);
> - /* linux driver writes twice... */
> - if ( were_running ) {
> - MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_TX_START(0));
> -/* Clear multicast filters */
> void
> @@ -1519,34 +1366,6 @@ register uint8_t *d = to, *s = fro;
> #endif
> -/* Assign values (buffer + user data) to a tx descriptor slot */
> -static int
> -mveth_assign_desc(MvEthTxDesc d, struct mbuf *m, unsigned long extra)
> -int rval = (d->byte_cnt = m->m_len);
> -#ifdef MVETH_TESTING
> - assert( !d->mb );
> - assert( m->m_len );
> -#endif
> - /* set CRC on all descriptors; seems to be necessary */
> - d->cmd_sts = extra | (TDESC_GEN_CRC | TDESC_ZERO_PAD);
> -#ifdef ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
> - /* The buffer must be 64bit aligned if the payload is <8 (??) */
> - if ( rval < 8 && ((mtod(m, uintptr_t)) & 7) ) {
> - d->buf_ptr = CPUADDR2ENET( d->workaround );
> - memcpy((void*)d->workaround, mtod(m, void*), rval);
> - } else
> -#endif
> - d->buf_ptr = CPUADDR2ENET( mtod(m, unsigned long) );
> - d->l4i_chk = 0;
> - return rval;
> static int
> mveth_assign_desc_raw(MvEthTxDesc d, void *buf, int len, unsigned long extra)
> @@ -1660,6 +1479,7 @@ MvEthTxDesc d;
> static struct mveth_private *
> mve_setup_internal(
> int unit,
> rtems_id tid,
> void (*isr)(void*isr_arg),
> @@ -1675,21 +1495,12 @@ mve_setup_internal(
> -struct mveth_private *mp;
> -struct ifnet *ifp;
> int InstallISRSuccessful;
> if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
> printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
> return 0;
> - ifp = &theMvEths[unit-1].arpcom.ac_if;
> - if ( ifp->if_init ) {
> - printk(DRVNAME": instance %i already attached.\n", unit);
> - return 0;
> if ( rx_ring_size < 0 && tx_ring_size < 0 )
> return 0;
> @@ -1714,8 +1525,6 @@ int InstallISRSuccessful;
> - mp = &theMvEths[unit-1].pvt;
> memset(mp, 0, sizeof(*mp));
> mp->port_num = unit-1;
> @@ -1742,6 +1551,7 @@ int InstallISRSuccessful;
> if ( mp->xbuf_count < 0 )
> mp->xbuf_count = 0;
> +#ifdef BSDBSD
> /* allocate ring area; add 1 entry -- room for alignment */
> assert( !mp->ring_area );
> mp->ring_area = malloc(
> @@ -1750,18 +1560,17 @@ int InstallISRSuccessful;
> M_DEVBUF,
> M_WAIT );
> assert( mp->ring_area );
> +#endif
> BSP_mve_stop_hw(mp);
> if ( irq_mask ) {
> - irq_data[mp->port_num].hdl = tid ? mveth_isr : mveth_isr_1;
> + irq_data[mp->port_num].hdl = mveth_isr;
> + irq_data[mp->port_num].handle = (rtems_irq_hdl_param)mp;
> InstallISRSuccessful = BSP_install_rtems_irq_handler( &irq_data[mp->port_num] );
> assert( InstallISRSuccessful );
> - /* mark as used */
> - ifp->if_init = (void*)(-1);
> if ( rx_ring_size < 0 )
> irq_mask &= ~ MV643XX_ETH_IRQ_RX_DONE;
> if ( tx_ring_size < 0 )
> @@ -1778,38 +1587,9 @@ int InstallISRSuccessful;
> return mp;
> -BSP_mve_setup(
> - int unit,
> - rtems_id tid,
> - void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
> - void *cleanup_txbuf_arg,
> - void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
> - void (*consume_rxbuf)(void *user_buf, void *closure, int len),
> - void *consume_rxbuf_arg,
> - int rx_ring_size,
> - int tx_ring_size,
> - int irq_mask
> - if ( irq_mask && 0 == tid ) {
> - printk(DRVNAME": must supply a TID if irq_msk not zero\n");
> - return 0;
> - return mve_setup_internal(
> - unit,
> - tid,
> - 0, 0,
> - cleanup_txbuf, cleanup_txbuf_arg,
> - alloc_rxbuf,
> - consume_rxbuf, consume_rxbuf_arg,
> - rx_ring_size, tx_ring_size,
> - irq_mask);
> BSP_mve_setup_1(
> int unit,
> void *isr_arg,
> @@ -1829,6 +1609,7 @@ BSP_mve_setup_1(
> + mp,
> unit,
> 0,
> isr, isr_arg,
> @@ -1848,17 +1629,24 @@ BSP_mve_get_tid(struct mveth_private *mp)
> int
> +#ifdef BSDBSD
> int unit = mp->port_num;
> +#endif
> if ( mp->irq_mask || mp->xirq_mask ) {
> if ( !BSP_remove_rtems_irq_handler( &irq_data[mp->port_num] ) )
> return -1;
> +#ifdef BSDBSD
> +#warning FIXME
> free( (void*)mp->ring_area, M_DEVBUF );
> +#endif
> __asm__ __volatile__("":::"memory");
> /* mark as unused */
> +#ifdef BSDBSD
> theMvEths[unit].arpcom.ac_if.if_init = 0;
> +#endif
> return 0;
> @@ -1904,236 +1692,6 @@ register MvEthTxDesc d;
> return rval;
> -/* allocate a new cluster and copy an existing chain there;
> - * old chain is released...
> -static struct mbuf *
> -repackage_chain(struct mbuf *m_head)
> -struct mbuf *m;
> - MGETHDR(m, M_DONTWAIT, MT_DATA);
> - if ( !m ) {
> - goto bail;
> - MCLGET(m, M_DONTWAIT);
> - if ( !(M_EXT & m->m_flags) ) {
> - m_freem(m);
> - m = 0;
> - goto bail;
> - m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
> - m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
> -bail:
> - m_freem(m_head);
> - return m;
> -/* Enqueue a mbuf chain or a raw data buffer for transmission;
> - * RETURN: #bytes sent or -1 if there are not enough descriptors
> - * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
> - * OTOH, a raw data packet may be send (non-BSD driver) by pointing
> - * m_head to the start of the data and passing 'len' > 0.
> - * Comments: software cache-flushing incurs a penalty if the
> - * packet cannot be queued since it is flushed anyways.
> - * The algorithm is slightly more efficient in the normal
> - * case, though.
> -int
> -BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len)
> -int rval;
> -register MvEthTxDesc l,d,h;
> -register struct mbuf *m1;
> -int nmbs;
> -int ismbuf = (len <= 0);
> -/* Only way to get here is when we discover that the mbuf chain
> - * is too long for the tx ring
> -startover:
> - rval = 0;
> - assert(m_head);
> -#endif
> - /* if no descriptor is available; try to wipe the queue */
> - if ( (mp->avail < 1) && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
> - /* Maybe TX is stalled and needs to be restarted */
> - mveth_start_tx(mp);
> - return -1;
> - h = mp->d_tx_h;
> - assert( !h->buf_ptr );
> - assert( !h->mb );
> -#endif
> - if ( ! (m1 = m_head) )
> - return 0;
> - if ( ismbuf ) {
> - /* find first mbuf with actual data */
> - while ( 0 == m1->m_len ) {
> - if ( ! (m1 = m1->m_next) ) {
> - /* end reached and still no data to send ?? */
> - m_freem(m_head);
> - return 0;
> - /* Don't use the first descriptor yet because BSP_mve_swipe_tx()
> - * needs mp->d_tx_h->buf_ptr == NULL as a marker. Hence, we
> - * start with the second mbuf and fill the first descriptor
> - * last.
> - l = h;
> - d = NEXT_TXD(h);
> - mp->avail--;
> - nmbs = 1;
> - if ( ismbuf ) {
> - register struct mbuf *m;
> - for ( m=m1->m_next; m; m=m->m_next ) {
> - if ( 0 == m->m_len )
> - continue; /* skip empty mbufs */
> - nmbs++;
> - if ( mp->avail < 1 && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
> - /* Maybe TX was stalled - try to restart */
> - /* not enough descriptors; cleanup...
> - * the first slot was never used, so we start
> - * at mp->d_tx_h->next;
> - for ( l = NEXT_TXD(h); l!=d; l=NEXT_TXD(l) ) {
> - assert( l->mb == 0 );
> -#endif
> - l->buf_ptr = 0;
> - l->cmd_sts = 0;
> - mp->avail++;
> - mp->avail++;
> - if ( nmbs > TX_AVAILABLE_RING_SIZE(mp) ) {
> - /* this chain will never fit into the ring */
> - if ( nmbs > mp->stats.maxchain )
> - mp->stats.maxchain = nmbs;
> - mp->stats.repack++;
> - if ( ! (m_head = repackage_chain(m_head)) ) {
> - /* no cluster available */
> - mp->stats.odrops++;
> - return 0;
> - goto startover;
> - return -1;
> - mp->avail--;
> - assert( d != h );
> - assert( !d->buf_ptr );
> -#endif
> - /* fill this slot */
> - rval += mveth_assign_desc(d, m, TDESC_DMA_OWNED);
> - FLUSH_BUF(mtod(m, uint32_t), m->m_len);
> - l = d;
> - d = NEXT_TXD(d);
> - FLUSH_DESC(l);
> - /* fill first slot - don't release to DMA yet */
> - rval += mveth_assign_desc(h, m1, TDESC_FRST);
> - FLUSH_BUF(mtod(m1, uint32_t), m1->m_len);
> - } else {
> - /* fill first slot with raw buffer - don't release to DMA yet */
> - rval += mveth_assign_desc_raw(h, data_p, len, TDESC_FRST);
> - FLUSH_BUF( (uint32_t)data_p, len);
> - /* tag last slot; this covers the case where 1st==last */
> - l->cmd_sts |= TDESC_LAST | TDESC_INT_ENA;
> - /* mbuf goes into last desc */
> - l->u_buf = m_head;
> - FLUSH_DESC(l);
> - /* Tag end; make sure chip doesn't try to read ahead of here! */
> - l->next->cmd_sts = 0;
> - FLUSH_DESC(l->next);
> -#ifdef MVETH_DEBUG_TX_DUMP
> - if ( (mveth_tx_dump & (1<<mp->port_num)) ) {
> - int ll,kk;
> - if ( ismbuf ) {
> - struct mbuf *m;
> - for ( kk=0, m=m_head; m; m=m->m_next) {
> - for ( ll=0; ll<m->m_len; ll++ ) {
> - printf("%02X ",*(mtod(m,char*) + ll));
> - if ( ((++kk)&0xf) == 0 )
> - printf("\n");
> - } else {
> - for ( ll=0; ll<len; ) {
> - printf("%02X ",*((char*)data_p + ll));
> - if ( ((++ll)&0xf) == 0 )
> - printf("\n");
> - printf("\n");
> -#endif
> - membarrier();
> - /* turn over the whole chain by flipping ownership of the first desc */
> - h->cmd_sts |= TDESC_DMA_OWNED;
> - FLUSH_DESC(h);
> - membarrier();
> - /* notify the device */
> - /* Update softc */
> - mp->stats.packet++;
> - /* remember new head */
> - mp->d_tx_h = d;
> - return rval; /* #bytes sent */
> int
> @@ -2490,12 +2048,15 @@ static int inited = 0;
> v |= mveth_serial_ctrl_config_val;
> MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
> +#ifdef BSDMII
> +#warning FIXME
> i = IFM_MAKEWORD(0, 0, 0, 0);
> if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
> if ( (IFM_LINK_OK & i) ) {
> mveth_update_serial_port(mp, i);
> +#endif
> /* enable serial port */
> v = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
> @@ -2560,26 +2121,6 @@ unsigned char buf[6], *eaddr;
> -int
> -BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg)
> -int rval;
> - /* alias cmd == 0,1 */
> - switch ( cmd ) {
> - case 0: cmd = SIOCGIFMEDIA;
> - break;
> - case 1: cmd = SIOCSIFMEDIA;
> - case SIOCGIFMEDIA:
> - case SIOCSIFMEDIA:
> - break;
> - default: return -1;
> - REGLOCK();
> - rval = rtems_mii_ioctl(&mveth_mdio, mp, cmd, parg);
> - REGUNLOCK();
> - return rval;
> void
> @@ -2617,132 +2158,6 @@ BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask)
> return mveth_ack_irqs(mp, mask);
> -int
> -BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
> -int media = IFM_MAKEWORD(0,0,0,0);
> - if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
> - if ( IFM_LINK_OK & media ) {
> - mveth_update_serial_port(mp, media);
> - /* If TX stalled because there was no buffer then whack it */
> - if ( pmedia )
> - *pmedia = media;
> - return 0;
> - return -1;
> -/* BSDNET SUPPORT/GLUE ROUTINES */
> -static void
> -mveth_set_filters(struct ifnet *ifp);
> -STATIC void
> -mveth_stop(struct mveth_softc *sc)
> - BSP_mve_stop_hw(&sc->pvt);
> - sc->arpcom.ac_if.if_timer = 0;
> -/* allocate a mbuf for RX with a properly aligned data buffer
> - * RETURNS 0 if allocation fails
> -static void *
> -alloc_mbuf_rx(int *psz, uintptr_t *paddr)
> -struct mbuf *m;
> -unsigned long l,o;
> - if ( !m )
> - return 0;
> - if ( ! (m->m_flags & M_EXT) ) {
> - m_freem(m);
> - return 0;
> - o = mtod(m, unsigned long);
> - l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
> - /* align start of buffer */
> - m->m_data += l;
> - /* reduced length */
> - l = MCLBYTES - l;
> - m->m_len = m->m_pkthdr.len = l;
> - *psz = m->m_len;
> - *paddr = mtod(m, uintptr_t);
> - return (void*) m;
> -static void consume_rx_mbuf(void *buf, void *arg, int len)
> -struct ifnet *ifp = arg;
> -struct mbuf *m = buf;
> - if ( len <= 0 ) {
> - ifp->if_iqdrops++;
> - if ( len < 0 ) {
> - ifp->if_ierrors++;
> - if ( m )
> - m_freem(m);
> - } else {
> - struct ether_header *eh;
> - eh = (struct ether_header *)(mtod(m, unsigned long) + ETH_RX_OFFSET);
> - m->m_len = m->m_pkthdr.len = len - sizeof(struct ether_header) - ETH_RX_OFFSET - ETH_CRC_LEN;
> - m->m_data += sizeof(struct ether_header) + ETH_RX_OFFSET;
> - m->m_pkthdr.rcvif = ifp;
> - ifp->if_ipackets++;
> - ifp->if_ibytes += m->m_pkthdr.len;
> - if (0) {
> - /* Low-level debugging */
> - int i;
> - for (i=0; i<13; i++) {
> - printf("%02X:",((char*)eh)[i]);
> - printf("%02X\n",((char*)eh)[i]);
> - for (i=0; i<m->m_len; i++) {
> - if ( !(i&15) )
> - printf("\n");
> - printf("0x%02x ",mtod(m,char*)[i]);
> - printf("\n");
> - if (0) {
> - /* Low-level debugging/testing without bsd stack */
> - m_freem(m);
> - } else {
> - /* send buffer upwards */
> - ether_input(ifp, eh, m);
> -static void release_tx_mbuf(void *buf, void *arg, int err)
> -struct mbuf *mb = buf;
> - if ( err ) {
> - ifp->if_oerrors++;
> - } else {
> - ifp->if_opackets++;
> - ifp->if_obytes += mb->m_pkthdr.len;
> - m_freem(mb);
> static void
> dump_update_stats(struct mveth_private *mp, FILE *f)
> @@ -2789,530 +2204,3 @@ BSP_mve_dump_stats(struct mveth_private *mp, FILE *f)
> dump_update_stats(mp, f);
> -/* BSDNET DRIVER CALLBACKS */
> -static void
> -mveth_init(void *arg)
> -struct mveth_softc *sc = arg;
> -struct ifnet *ifp = &sc->arpcom.ac_if;
> -int media;
> - BSP_mve_init_hw(&sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
> - media = IFM_MAKEWORD(0, 0, 0, 0);
> - if ( 0 == BSP_mve_media_ioctl(&sc->pvt, SIOCGIFMEDIA, &media) ) {
> - if ( (IFM_LINK_OK & media) ) {
> - ifp->if_flags &= ~IFF_OACTIVE;
> - } else {
> - ifp->if_flags |= IFF_OACTIVE;
> - /* if promiscuous then there is no need to change */
> - if ( ! (ifp->if_flags & IFF_PROMISC) )
> - mveth_set_filters(ifp);
> - ifp->if_flags |= IFF_RUNNING;
> -/* bsdnet driver entry to start transmission */
> -static void
> -mveth_start(struct ifnet *ifp)
> -struct mveth_softc *sc = ifp->if_softc;
> -struct mbuf *m = 0;
> - while ( ifp->if_snd.ifq_head ) {
> - IF_DEQUEUE( &ifp->if_snd, m );
> - if ( BSP_mve_send_buf(&sc->pvt, m, 0, 0) < 0 ) {
> - IF_PREPEND( &ifp->if_snd, m);
> - break;
> - /* need to do this really only once
> - * but it's cheaper this way.
> - ifp->if_timer = 2*IFNET_SLOWHZ;
> -/* bsdnet driver entry; */
> -static void
> -mveth_watchdog(struct ifnet *ifp)
> - printk(DRVNAME"%i: watchdog timeout; resetting\n", ifp->if_unit);
> - mveth_init(sc);
> - mveth_start(ifp);
> -static void
> -uint32_t v;
> - v = MV_READ(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num));
> - if ( ifp->if_flags & IFF_PROMISC )
> - v |= MV643XX_ETH_UNICAST_PROMISC_MODE;
> - else
> - v &= ~MV643XX_ETH_UNICAST_PROMISC_MODE;
> - MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num), v);
> - if ( ifp->if_flags & (IFF_PROMISC | IFF_ALLMULTI) ) {
> - BSP_mve_mcast_filter_accept_all(&sc->pvt);
> - } else {
> - struct ether_multi *enm;
> - struct ether_multistep step;
> - BSP_mve_mcast_filter_clear( &sc->pvt );
> - ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
> - while ( enm ) {
> - if ( memcmp(enm->enm_addrlo, enm->enm_addrhi, ETHER_ADDR_LEN) )
> - assert( !"Should never get here; IFF_ALLMULTI should be set!" );
> - BSP_mve_mcast_filter_accept_add(&sc->pvt, enm->enm_addrlo);
> - ETHER_NEXT_MULTI(step, enm);
> -/* bsdnet driver ioctl entry */
> -static int
> -mveth_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
> -struct ifreq *ifr = (struct ifreq *)data;
> -int error = 0;
> -int f;
> - switch ( cmd ) {
> - case SIOCSIFFLAGS:
> - f = ifp->if_flags;
> - if ( f & IFF_UP ) {
> - if ( ! ( f & IFF_RUNNING ) ) {
> - mveth_init(sc);
> - } else {
> - if ( (f & IFF_PROMISC) != (sc->bsd.oif_flags & IFF_PROMISC) ) {
> - /* Note: in all other scenarios the 'promisc' flag
> - * in the low-level driver [which affects the way
> - * the multicast filter is setup: accept none vs.
> - * accept all in promisc mode] is eventually
> - * set when the IF is brought up...
> - sc->pvt.promisc = (f & IFF_PROMISC);
> - /* FIXME: other flag changes are ignored/unimplemented */
> - } else {
> - if ( f & IFF_RUNNING ) {
> - mveth_stop(sc);
> - ifp->if_flags &= ~(IFF_RUNNING | IFF_OACTIVE);
> - sc->bsd.oif_flags = ifp->if_flags;
> - break;
> - error = BSP_mve_media_ioctl(&sc->pvt, cmd, &ifr->ifr_media);
> - break;
> - case SIOCADDMULTI:
> - case SIOCDELMULTI:
> - error = (cmd == SIOCADDMULTI)
> - ? ether_addmulti(ifr, &sc->arpcom)
> - : ether_delmulti(ifr, &sc->arpcom);
> - if (error == ENETRESET) {
> - if (ifp->if_flags & IFF_RUNNING) {
> - error = 0;
> - break;
> - break;
> - case SIO_RTEMS_SHOW_STATS:
> - dump_update_stats(&sc->pvt, stdout);
> - break;
> - default:
> - error = ether_ioctl(ifp, cmd, data);
> - break;
> - return error;
> -/* DRIVER TASK */
> -/* Daemon task does all the 'interrupt' work */
> -static void mveth_daemon(void *arg)
> -struct mveth_softc *sc;
> -struct ifnet *ifp;
> -rtems_event_set evs;
> - for (;;) {
> - rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
> - evs &= 7;
> - for ( sc = theMvEths; evs; evs>>=1, sc++ ) {
> - if ( (evs & 1) ) {
> - register uint32_t x;
> - ifp = &sc->arpcom.ac_if;
> - if ( !(ifp->if_flags & IFF_UP) ) {
> - mveth_stop(sc);
> - ifp->if_flags &= ~(IFF_UP|IFF_RUNNING);
> - continue;
> - if ( !(ifp->if_flags & IFF_RUNNING) ) {
> - /* event could have been pending at the time hw was stopped;
> - * just ignore...
> - continue;
> - x = mveth_ack_irqs(&sc->pvt, -1);
> - if ( MV643XX_ETH_EXT_IRQ_LINK_CHG & x ) {
> - /* phy status changed */
> - int media;
> - if ( 0 == BSP_mve_ack_link_chg(&sc->pvt, &media) ) {
> - mveth_start(ifp);
> - } else {
> - /* stop sending */
> - /* free tx chain */
> - if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(&sc->pvt) ) {
> - if ( TX_AVAILABLE_RING_SIZE(&sc->pvt) == sc->pvt.avail )
> - ifp->if_timer = 0;
> - mveth_start(ifp);
> - if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
> - BSP_mve_swipe_rx(&sc->pvt);
> - mveth_enable_irqs(&sc->pvt, -1);
> -static int mveth_detach(struct mveth_softc *sc);
> -#endif
> -/* PUBLIC RTEMS BSDNET ATTACH FUNCTION */
> -int
> -rtems_mve_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching)
> -char *unitName;
> -int unit,i,cfgUnits;
> -struct ifnet *ifp;
> - unit = rtems_bsdnet_parse_driver_name(ifcfg, &unitName);
> - if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
> - printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
> - return 1;
> - sc = &theMvEths[unit-1];
> - sc->pvt.port_num = unit-1;
> - sc->pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*sc->pvt.port_num)) & 0x1f;
> - if ( attaching ) {
> - return -1;
> - for ( i=cfgUnits = 0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
> - if ( theMvEths[i].arpcom.ac_if.if_init )
> - cfgUnits++;
> - cfgUnits++; /* this new one */
> - /* lazy init of TID should still be thread-safe because we are protected
> - * by the global networking semaphore..
> - if ( !mveth_tid ) {
> - /* newproc uses the 1st 4 chars of name string to build an rtems name */
> - mveth_tid = rtems_bsdnet_newproc("MVEd", 4096, mveth_daemon, 0);
> - if ( !BSP_mve_setup( unit,
> - mveth_tid,
> - release_tx_mbuf, ifp,
> - alloc_mbuf_rx,
> - consume_rx_mbuf, ifp,
> - ifcfg->rbuf_count,
> - ifcfg->xbuf_count,
> - BSP_MVE_IRQ_TX | BSP_MVE_IRQ_RX | BSP_MVE_IRQ_LINK) ) {
> - return -1;
> - if ( nmbclusters < sc->pvt.rbuf_count * cfgUnits + 60 /* arbitrary */ ) {
> - printk(DRVNAME"%i: (mv643xx ethernet) Your application has not enough mbuf clusters\n", unit);
> - printk( " configured for this driver.\n");
> - return -1;
> - if ( ifcfg->hardware_address ) {
> - memcpy(sc->arpcom.ac_enaddr, ifcfg->hardware_address, ETHER_ADDR_LEN);
> - } else {
> - /* read back from hardware assuming that MotLoad already had set it up */
> - BSP_mve_read_eaddr(&sc->pvt, sc->arpcom.ac_enaddr);
> - ifp->if_softc = sc;
> - ifp->if_unit = unit;
> - ifp->if_name = unitName;
> - ifp->if_mtu = ifcfg->mtu ? ifcfg->mtu : ETHERMTU;
> - ifp->if_init = mveth_init;
> - ifp->if_ioctl = mveth_ioctl;
> - ifp->if_start = mveth_start;
> - ifp->if_output = ether_output;
> - * While nonzero, the 'if->if_timer' is decremented
> - * (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
> - * is called when it expires.
> - * If either of those fields is 0 the feature is disabled.
> - ifp->if_watchdog = mveth_watchdog;
> - sc->bsd.oif_flags = /* ... */
> - ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
> - * if unset, this set to 10Mbps by ether_ifattach; seems to be unused by bsdnet stack;
> - * could be updated along with phy speed, though...
> - ifp->if_baudrate = 10000000;
> - /* NOTE: ether_output drops packets if ifq_len >= ifq_maxlen
> - * but this is the packet count, not the fragment count!
> - ifp->if_snd.ifq_maxlen = sc->pvt.xbuf_count;
> - ifp->if_snd.ifq_maxlen = ifqmaxlen;
> - if ( !ifp->if_addrlist ) /* do only the first time [reattach hack] */
> -#endif
> - if_attach(ifp);
> - ether_ifattach(ifp);
> - } else {
> - if ( !ifp->if_init ) {
> - printk(DRVNAME": instance %i not attached.\n", unit);
> - return -1;
> - return mveth_detach(sc);
> -#else
> - printk(DRVNAME": interface detaching not implemented\n");
> - return -1;
> -#endif
> - return 0;
> -/* EARLY PHY ACCESS */
> -static int
> -mveth_early_init(int idx)
> - if ( idx < 0 || idx >= MV643XXETH_NUM_DRIVER_SLOTS )
> - return -1;
> - /* determine the phy */
> - theMvEths[idx].pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*idx)) & 0x1f;
> - return 0;
> -static int
> -mveth_early_read_phy(int idx, unsigned reg)
> -int rval;
> - return -1;
> - rval = mveth_mii_read(&theMvEths[idx].pvt, reg);
> - return rval < 0 ? rval : rval & 0xffff;
> -static int
> -mveth_early_write_phy(int idx, unsigned reg, unsigned val)
> - return -1;
> - mveth_mii_write(&theMvEths[idx].pvt, reg, val);
> - return 0;
> -rtems_bsdnet_early_link_check_ops
> -rtems_mve_early_link_check_ops = {
> - init: mveth_early_init,
> - read_phy: mveth_early_read_phy,
> - write_phy: mveth_early_write_phy,
> - name: DRVNAME,
> - num_slots: MAX_NUM_SLOTS
> -/* DEBUGGING */
> -#ifdef MVETH_DEBUG
> -/* Display/dump descriptor rings */
> -int
> -mveth_dring(struct mveth_softc *sc)
> -int i;
> -if (1) {
> -MvEthRxDesc pr;
> -printf("RX:\n");
> - for (i=0, pr=sc->pvt.rx_ring; i<sc->pvt.rbuf_count; i++, pr++) {
> -#ifndef ENABLE_HW_SNOOPING
> - /* can't just invalidate the descriptor - if it contains
> - * data that hasn't been flushed yet, we create an inconsistency...
> - rtems_bsdnet_semaphore_obtain();
> - INVAL_DESC(pr);
> -#endif
> - printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
> - pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
> - rtems_bsdnet_semaphore_release();
> -#endif
> -if (1) {
> -MvEthTxDesc pt;
> -printf("TX:\n");
> - for (i=0, pt=sc->pvt.tx_ring; i<sc->pvt.xbuf_count; i++, pt++) {
> - INVAL_DESC(pt);
> -#endif
> - printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
> - pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
> - (uint32_t)pt->mb);
> -#endif
> - return 0;
> -#endif
> -/* DETACH HACK DETAILS */
> -int
> -_cexpModuleFinalize(void *mh)
> -int i;
> - for ( i=0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
> - if ( theMvEths[i].arpcom.ac_if.if_init ) {
> - printf("Interface %i still attached; refuse to unload\n", i+1);
> - return -1;
> - /* delete task; since there are no attached interfaces, it should block
> - * for events and hence not hold the semaphore or other resources...
> - rtems_task_delete(mveth_tid);
> - return 0;
> -/* ugly hack to allow unloading/reloading the driver core.
> - * needed because rtems' bsdnet release doesn't implement
> - * if_detach(). Therefore, we bring the interface down but
> - * keep the device record alive...
> -static void
> -ether_ifdetach_pvt(struct ifnet *ifp)
> - ifp->if_flags = 0;
> - ifp->if_ioctl = 0;
> - ifp->if_start = 0;
> - ifp->if_watchdog = 0;
> - ifp->if_init = 0;
> -static int
> -mveth_detach(struct mveth_softc *sc)
> - if ( ifp->if_flags & (IFF_UP | IFF_RUNNING) ) {
> - printf(DRVNAME"%i: refuse to detach; interface still up\n",sc->pvt.port_num+1);
> - return -1;
> - mveth_stop(sc);
> -/* not implemented in BSDnet/RTEMS (yet) but declared in header */
> -#define ether_ifdetach ether_ifdetach_pvt
> - ether_ifdetach(ifp);
> - free( (void*)sc->pvt.ring_area, M_DEVBUF );
> - sc->pvt.ring_area = 0;
> - sc->pvt.tx_ring = 0;
> - sc->pvt.rx_ring = 0;
> - sc->pvt.d_tx_t = sc->pvt.d_tx_h = 0;
> - sc->pvt.d_rx_t = 0;
> - sc->pvt.avail = 0;
> - /* may fail if ISR was not installed yet */
> - BSP_remove_rtems_irq_handler( &irq_data[sc->pvt.port_num] );
> - return 0;
> -#ifdef MVETH_DEBUG
> -struct rtems_bsdnet_ifconfig mveth_dbg_config = {
> - name: DRVNAME"1",
> - attach: rtems_mve_attach,
> - ip_address: "192.168.2.10", /* not used by rtems_bsdnet_attach */
> - ip_netmask: "255.255.255.0", /* not used by rtems_bsdnet_attach */
> - hardware_address: 0, /* (void *) */
> - ignore_broadcast: 0, /* TODO driver should honour this */
> - mtu: 0,
> - rbuf_count: 0, /* TODO driver should honour this */
> - xbuf_count: 0, /* TODO driver should honour this */
> -#endif
> -#endif
> diff --git a/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
> index 0000000000..a2efdce8e1
> --- /dev/null
> +++ b/bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
> @@ -0,0 +1,3519 @@
> +/* RTEMS driver for the mv643xx gigabit ethernet chip */
> +/* Acknowledgement:
> + * Valuable information for developing this driver was obtained
> + * from the linux open-source driver mv643xx_eth.c which was written
> + * by the following people and organizations:
> + * Matthew Dharm <mdharm at momenco.com>
> + * rabeeh at galileo.co.il
> + * PMC-Sierra, Inc., Manish Lachwani
> + * Ralf Baechle <ralf at linux-mips.org>
> + * MontaVista Software, Inc., Dale Farnsworth <dale at farnsworth.org>
> + * Steven J. Hill <sjhill1 at rockwellcollins.com>/<sjhill at realitydiluted.com>
> + * Note however, that in spite of the identical name of this file
> + * (and some of the symbols used herein) this file provides a
> + * new implementation and is the original work by the author.
> + * Authorship
> + * This software (mv643xx ethernet driver for RTEMS) was
> + * created by Till Straumann <strauman at slac.stanford.edu>, 2005-2007,
> + * Stanford Linear Accelerator Center, Stanford University.
> + * Acknowledgement of sponsorship
> + * The 'mv643xx ethernet driver for RTEMS' was produced by
> + * the Stanford Linear Accelerator Center, Stanford University,
> + * under Contract DE-AC03-76SFO0515 with the Department of Energy.
> + * Government disclaimer of liability
> + * Neither the United States nor the United States Department of Energy,
> + * nor any of their employees, makes any warranty, express or implied, or
> + * assumes any legal liability or responsibility for the accuracy,
> + * completeness, or usefulness of any data, apparatus, product, or process
> + * disclosed, or represents that its use would not infringe privately owned
> + * rights.
> + * Stanford disclaimer of liability
> + * Stanford University makes no representations or warranties, express or
> + * implied, nor assumes any liability for the use of this software.
> + * Stanford disclaimer of copyright
> + * Stanford University, owner of the copyright, hereby disclaims its
> + * copyright and all other rights in this software. Hence, anyone may
> + * freely use it for any purpose without restriction.
> + * Maintenance of notices
> + * In the interest of clarity regarding the origin and status of this
> + * SLAC software, this and all the preceding Stanford University notices
> + * are to remain affixed to any copy or derivative of this software made
> + * or distributed by the recipient and are to be affixed to any copy of
> + * software made or distributed by the recipient that contains a copy or
> + * derivative of this software.
> + * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
> + * NOTE: Some register (e.g., the SMI register) are SHARED among the
> + * three devices. Concurrent access protection is provided by
> + * the global networking semaphore.
> + * If other drivers are running on a subset of IFs then proper
> + * locking of all shared registers must be implemented!
> + * Some things I learned about this hardware can be found
> + * further down...
> +#ifndef KERNEL
> +#define KERNEL
> +#endif
> +#ifndef _KERNEL
> +#define _KERNEL
> +#endif
> +#include <rtems.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/error.h>
> +#include <bsp.h>
> +#include <bsp/irq.h>
> +#include <bsp/gtreg.h>
> +#include <libcpu/byteorder.h>
> +#include <assert.h>
> +#include <stdio.h>
> +#include <errno.h>
> +#include <inttypes.h>
> +#ifdef BSDBSD
> +#include <sys/param.h>
> +#include <sys/proc.h>
> +#include <sys/socket.h>
> +#include <sys/sockio.h>
> +#include <dev/mii/mii.h>
> +#include <net/if_var.h>
> +#include <net/if_media.h>
> +/* Not so nice; would be more elegant not to depend on C library but the
> + * RTEMS-specific ioctl for dumping statistics needs stdio anyways.
> +/*#define NDEBUG effectively removes all assertions
> + * If defining NDEBUG, MAKE SURE assert() EXPRESSION HAVE NO SIDE_EFFECTS!!
> + * This driver DOES have side-effects, so DONT DEFINE NDEBUG
> + * Performance-critical assertions are removed by undefining MVETH_TESTING.
> +#undef NDEBUG
> +#include <rtems/rtems_bsdnet.h>
> +#include <sys/mbuf.h>
> +#include <net/ethernet.h>
> +#include <net/if.h>
> +#include <netinet/in.h>
> +#include <netinet/if_ether.h>
> +#endif /* BSDBSD */
> +#ifdef BSDBSD
> +#include <rtems/rtems_mii_ioctl.h>
> +#include <bsp/early_enet_link_status.h>
> +#include <bsp/if_mve_pub.h>
> +/* CONFIGURABLE PARAMETERS */
> +/* Enable Hardware Snooping; if this is disabled (undefined),
> + * cache coherency is maintained by software.
> +#undef ENABLE_HW_SNOOPING
> +/* Compile-time debugging features */
> +/* Enable paranoia assertions and checks; reduce # of descriptors to minimum for stressing */
> +#undef MVETH_TESTING
> +/* Enable debugging messages and some support routines (dump rings etc.) */
> +#undef MVETH_DEBUG
> +/* Hack for driver development; rtems bsdnet doesn't implement detaching an interface :-(
> + * but this hack allows us to unload/reload the driver module which makes development
> + * a lot less painful.
> +#undef MVETH_DETACH_HACK
> +/* Ring sizes */
> +#ifdef MVETH_TESTING
> +/* hard and small defaults */
> +#undef MV643XX_RX_RING_SIZE
> +#define MV643XX_RX_RING_SIZE 2
> +#undef MV643XX_TX_RING_SIZE
> +#define MV643XX_TX_RING_SIZE 4
> +#else /* MVETH_TESTING */
> +/* Define default ring sizes, allow override from bsp.h, Makefile,... and from ifcfg->rbuf_count/xbuf_count */
> +#ifndef MV643XX_RX_RING_SIZE
> +#define MV643XX_RX_RING_SIZE 40 /* attached buffers are always 2k clusters, i.e., this
> + * driver - with a configured ring size of 40 - constantly
> + * locks 80k of cluster memory - your app config better
> + * provides enough space!
> +#endif
> +#ifndef MV643XX_TX_RING_SIZE
> +/* NOTE: tx ring size MUST be > max. # of fragments / mbufs in a chain;
> + * in 'TESTING' mode, special code is compiled in to repackage
> + * chains that are longer than the ring size. Normally, this is
> + * disabled for sake of speed.
> + * I observed chains of >17 entries regularly!
> + * Also, TX_NUM_TAG_SLOTS (1) must be left empty as a marker, hence
> + * the ring size must be > max. #frags + 1.
> +#define MV643XX_TX_RING_SIZE 200 /* these are smaller fragments and not occupied when
> + * the driver is idle.
> +#endif
> +#endif /* MVETH_TESTING */
> +/* How many instances to we support (bsp.h could override) */
> +#ifndef MV643XXETH_NUM_DRIVER_SLOTS
> +#define MV643XXETH_NUM_DRIVER_SLOTS 2
> +#endif
> +#define TX_NUM_TAG_SLOTS 1 /* leave room for tag; must not be 0 */
> +/* This is REAL; chip reads from 64-bit down-aligned buffer
> + * if the buffer size is < 8 !!! for buffer sizes 8 and upwards
> + * alignment is not an issue. This was verified using the
> + * 'mve_smallbuf_test.c'
> +#define ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
> +/* Chip register configuration values */
> +#define MVETH_PORT_CONFIG_VAL (0 \
> + | MV643XX_ETH_DFLT_RX_Q(0) \
> + | MV643XX_ETH_DFLT_RX_ARP_Q(0) \
> + | MV643XX_ETH_DFLT_RX_TCP_Q(0) \
> + | MV643XX_ETH_DFLT_RX_UDP_Q(0) \
> + | MV643XX_ETH_DFLT_RX_BPDU_Q(0) \
> +#define MVETH_PORT_XTEND_CONFIG_VAL 0
> +#ifdef OLDCONFIGVAL
> +#define MVETH_SERIAL_CTRL_CONFIG_VAL (0 \
> + | MV643XX_ETH_FORCE_LINK_PASS \
> + | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL \
> + | MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL \
> + | MV643XX_ETH_BIT9_UNKNOWN \
> + | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE \
> + | MV643XX_ETH_SC_MAX_RX_1552 \
> + | MV643XX_ETH_SET_FULL_DUPLEX \
> + | MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD \
> +#endif
> +/* If we enable autoneg (duplex, speed, ...) then it seems
> + * that the chip automatically updates link settings
> + * (correct link settings are reflected in PORT_STATUS_R).
> + * However, when we disable aneg in the PHY then things
> + * can get messed up and the port doesn't work anymore.
> + * => we follow the linux driver in disabling all aneg
> + * in the serial config reg. and manually updating the
> + * speed & duplex bits when the phy link status changes.
> + * FIXME: don't know what to do about pause/flow-ctrl.
> + * It is best to just use ANEG anyways!!!
> + | MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX \
> + | MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII \
> +#define MVETH_SERIAL_CTRL_CONFIG_MSK (0 \
> + | MV643XX_ETH_SERIAL_PORT_ENBL \
> + | MV643XX_ETH_SC_MAX_RX_MASK \
> +#ifdef __PPC__
> +#define MVETH_SDMA_CONFIG_VAL (0 \
> + | MV643XX_ETH_RX_BURST_SZ_4_64BIT \
> + | MV643XX_ETH_TX_BURST_SZ_4_64BIT \
> +#else
> + | MV643XX_ETH_RX_BURST_SZ_16_64BIT \
> + | MV643XX_ETH_TX_BURST_SZ_16_64BIT \
> +#endif
> +/* minimal frame size we accept */
> +#define MVETH_MIN_FRAMSZ_CONFIG_VAL 40
> +/* END OF CONFIGURABLE SECTION */
> + * Here's stuff I learned about this chip:
> + * RX interrupt flags:
> + * broadcast packet RX: 0x00000005
> + * last buf: 0x00000c05
> + * overrun: 0x00000c00
> + * unicast packet RX: 0x00000005
> + * bad CRC received: 0x00000005
> + * clearing 0x00000004 -> clears 0x00000001
> + * clearing 0x00000400 -> clears 0x00000800
> + * --> 0x0801 are probably some sort of summary bits.
> + * TX interrupt flags:
> + * broadcast packet in 1 buf: xcause: 0x00000001 (cause 0x00080000)
> + * into disconn. link: " "
> + * in some cases, I observed xcause: 0x00000101 (reason for 0x100 unknown
> + * but the linux driver accepts it also).
> + * Here a few more ugly things about this piece of hardware I learned
> + * (painfully, painfully; spending many many hours & nights :-()
> + * a) Especially in the case of 'chained' descriptors, the DMA keeps
> + * clobbering 'cmd_sts' long after it cleared the OWNership flag!!!
> + * Only after the whole chain is processed (OWN cleared on the
> + * last descriptor) it is safe to change cmd_sts.
> + * However, in the case of hardware snooping I found that the
> + * last descriptor in chain has its cmd_sts still clobbered *after*
> + * checking ownership!, I.e.,
> + * if ( ! OWN & cmd_sts ) {
> + * cmd_sts = 0;
> + * --> sometimes, cmd_sts is STILL != 0 here
> + * b) Sometimes, the OWNership flag is *not cleared*.
> + * c) Weird things happen if the chip finds a descriptor with 'OWN'
> + * still set (i.e., not properly loaded), i.e., corrupted packets
> + * are sent [with OK checksum since the chip calculates it].
> + * Combine a+b+c and we end up with a real mess.
> + * The fact that the chip doesn't reliably reset OWN and that OTOH,
> + * it can't be reliably reset by the driver and still, the chip needs
> + * it for proper communication doesn't make things easy...
> + * Here the basic workarounds:
> + * - In addition to check OWN, the scavenger compares the "currently
> + * served desc" register to the descriptor it tries to recover and
> + * ignores OWN if they do not match. Hope this is OK.
> + * Otherwise, we could scan the list of used descriptors and proceed
> + * recycling descriptors if we find a !OWNed one behind the target...
> + * - Always keep an empty slot around to mark the end of the list of
> + * jobs. The driver clears the descriptor ahead when enqueueing a new
> + * packet.
> +#define DRVNAME "mve"
> +#define MAX_NUM_SLOTS 3
> +#if MV643XXETH_NUM_DRIVER_SLOTS > MAX_NUM_SLOTS
> +#error "mv643xxeth: only MAX_NUM_SLOTS supported"
> +#endif
> +#ifdef NDEBUG
> +#error "Driver uses assert() statements with side-effects; MUST NOT define NDEBUG"
> +#endif
> +#ifdef MVETH_DEBUG
> +#define STATIC
> +#else
> +#define STATIC static
> +#endif
> +void
> +void
> +void
> +void
> +void
> +BSP_mve_setup(
> + int unit,
> + rtems_id tid,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> +BSP_mve_setup_1(
> + int unit,
> + void *isr_arg,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> + * chip.
> +int
> +int
> + void *head_p,
> + int h_len,
> + void *data_p,
> + int d_len);
> +int
> +rtems_id
> +int
> + * - reset phy
> +void
> +void
> +void
> +void
> +uint32_t
> +void
> +uint32_t
> +uint32_t
> +void
> +unsigned
> +mveth_mii_read(struct mveth_private *mp, unsigned addr);
> +unsigned
> +mveth_mii_write(struct mveth_private *mp, unsigned addr, unsigned v);
> +#define TX_AVAILABLE_RING_SIZE(mp) ((mp)->xbuf_count - (TX_NUM_TAG_SLOTS))
> +/* macros for ring alignment; proper alignment is a hardware req; . */
> +#ifdef ENABLE_HW_SNOOPING
> +#define RING_ALIGNMENT 16
> +/* rx buffers must be 64-bit aligned (chip requirement) */
> +#define RX_BUF_ALIGNMENT 8
> +#else /* ENABLE_HW_SNOOPING */
> +/* Software cache management */
> +#ifndef __PPC__
> +#error "Dont' know how to deal with cache on this CPU architecture"
> +#endif
> +/* Ring entries are 32 bytes; coherency-critical chunks are 16 -> software coherency
> + * management works for cache line sizes of 16 and 32 bytes only. If the line size
> + * is bigger, the descriptors could be padded...
> +#if PPC_CACHE_ALIGMENT != 16 && PPC_CACHE_ALIGNMENT != 32
> +#error "Cache line size must be 16 or 32"
> +#else
> +#define RING_ALIGNMENT PPC_CACHE_ALIGNMENT
> +#define RX_BUF_ALIGNMENT PPC_CACHE_ALIGNMENT
> +#endif
> +#endif /* ENABLE_HW_SNOOPING */
> +/* HELPER MACROS */
> +/* Align base to alignment 'a' */
> +#define MV643XX_ALIGN(b, a) ((((uint32_t)(b)) + (a)-1) & (~((a)-1)))
> +#define NOOP() do {} while(0)
> +/* Function like macros */
> +#define MV_READ(off) \
> + ld_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)))
> +#define MV_WRITE(off, data) \
> + st_le32((volatile uint32_t *)(BSP_MV64x60_BASE + (off)), ((unsigned)data))
> +/* ENET window mapped 1:1 to CPU addresses by our BSP/MotLoad
> + * -- if this is changed, we should think about caching the 'next' and 'buf' pointers.
> +#define CPUADDR2ENET(a) ((Dma_addr_t)(a))
> +#define ENET2CPUADDR(a) (a)
> +#if 1 /* Whether to automatically try to reclaim descriptors when enqueueing new packets */
> +#define MVETH_CLEAN_ON_SEND(mp) (BSP_mve_swipe_tx(mp))
> +#else
> +#define MVETH_CLEAN_ON_SEND(mp) (-1)
> +#endif
> +#define NEXT_TXD(d) (d)->next
> +#define NEXT_RXD(d) (d)->next
> +/* REGISTER AND DESCRIPTOR OFFSET AND BIT DEFINITIONS */
> +/* Descriptor Definitions */
> +/* Rx descriptor */
> +#define RDESC_ERROR (1<< 0) /* Error summary */
> +/* Error code (bit 1&2) is only valid if summary bit is set */
> +#define RDESC_CRC_ERROR ( 1)
> +#define RDESC_OVERRUN_ERROR ( 3)
> +#define RDESC_MAX_FRAMELENGTH_ERROR ( 5)
> +#define RDESC_RESOURCE_ERROR ( 7)
> +#define RDESC_LAST (1<<26) /* Last Descriptor */
> +#define RDESC_FRST (1<<27) /* First Descriptor */
> +#define RDESC_INT_ENA (1<<29) /* Enable Interrupts */
> +#define RDESC_DMA_OWNED (1<<31)
> +/* Tx descriptor */
> +#define TDESC_ERROR (1<< 0) /* Error summary */
> +#define TDESC_ZERO_PAD (1<<19)
> +#define TDESC_LAST (1<<20) /* Last Descriptor */
> +#define TDESC_FRST (1<<21) /* First Descriptor */
> +#define TDESC_GEN_CRC (1<<22)
> +#define TDESC_INT_ENA (1<<23) /* Enable Interrupts */
> +#define TDESC_DMA_OWNED (1<<31)
> +/* Register Definitions */
> +#define MV643XX_ETH_PHY_ADDR_R (0x2000)
> +#define MV643XX_ETH_SMI_R (0x2004)
> +#define MV643XX_ETH_SMI_BUSY (1<<28)
> +#define MV643XX_ETH_SMI_VALID (1<<27)
> +#define MV643XX_ETH_SMI_OP_WR (0<<26)
> +#define MV643XX_ETH_SMI_OP_RD (1<<26)
> +#define MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port) (0x2448 + ((port)<<10))
> +#define MV643XX_ETH_TX_START(queue) (0x0001<<(queue))
> +#define MV643XX_ETH_TX_STOP(queue) (0x0100<<(queue))
> +#define MV643XX_ETH_TX_START_M(queues) ((queues)&0xff)
> +#define MV643XX_ETH_TX_STOP_M(queues) (((queues)&0xff)<<8)
> +#define MV643XX_ETH_TX_STOP_ALL (0xff00)
> +#define MV643XX_ETH_TX_ANY_RUNNING (0x00ff)
> +#define MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(port) (0x2680 + ((port)<<10))
> +#define MV643XX_ETH_RX_START(queue) (0x0001<<(queue))
> +#define MV643XX_ETH_RX_STOP(queue) (0x0100<<(queue))
> +#define MV643XX_ETH_RX_STOP_ALL (0xff00)
> +#define MV643XX_ETH_RX_ANY_RUNNING (0x00ff)
> +#define MV643XX_ETH_CURRENT_SERVED_TX_DESC(port) (0x2684 + ((port)<<10))
> +/* The chip puts the ethernet header at offset 2 into the buffer so
> + * that the payload is aligned
> +#define ETH_RX_OFFSET 2
> +#define ETH_CRC_LEN 4 /* strip FCS at end of packet */
> +#define MV643XX_ETH_INTERRUPT_CAUSE_R(port) (0x2460 + ((port)<<10))
> +/* not fully understood; RX seems to raise 0x0005 or 0x0c05 if last buffer is filled and 0x0c00
> + * if there are no buffers
> +#define MV643XX_ETH_ALL_IRQS (0x0007ffff)
> +#define MV643XX_ETH_KNOWN_IRQS (0x00000c05)
> +#define MV643XX_ETH_IRQ_EXT_ENA (1<<1)
> +#define MV643XX_ETH_IRQ_RX_DONE (1<<2)
> +#define MV643XX_ETH_IRQ_RX_NO_DESC (1<<10)
> +#define MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(port) (0x2464 + ((port)<<10))
> +/* not fully understood; TX seems to raise 0x0001 and link change is 0x00010000
> +#define MV643XX_ETH_ALL_EXT_IRQS (0x0011ffff)
> +#define MV643XX_ETH_KNOWN_EXT_IRQS (0x00010101)
> +#define MV643XX_ETH_EXT_IRQ_TX_DONE (1<<0)
> +#define MV643XX_ETH_EXT_IRQ_LINK_CHG (1<<16)
> +#define MV643XX_ETH_INTERRUPT_ENBL_R(port) (0x2468 + ((port)<<10))
> +#define MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(port) (0x246c + ((port)<<10))
> +/* port configuration */
> +#define MV643XX_ETH_PORT_CONFIG_R(port) (0x2400 + ((port)<<10))
> +#define MV643XX_ETH_UNICAST_PROMISC_MODE (1<<0)
> +#define MV643XX_ETH_DFLT_RX_Q(q) ((q)<<1)
> +#define MV643XX_ETH_DFLT_RX_ARP_Q(q) ((q)<<4)
> +#define MV643XX_ETH_REJ_BCAST_IF_NOT_IP_OR_ARP (1<<7)
> +#define MV643XX_ETH_REJ_BCAST_IF_IP (1<<8)
> +#define MV643XX_ETH_REJ_BCAST_IF_ARP (1<<9)
> +#define MV643XX_ETH_TX_AM_NO_UPDATE_ERR_SUMMARY (1<<12)
> +#define MV643XX_ETH_CAPTURE_TCP_FRAMES_ENBL (1<<14)
> +#define MV643XX_ETH_CAPTURE_UDP_FRAMES_ENBL (1<<15)
> +#define MV643XX_ETH_DFLT_RX_TCP_Q(q) ((q)<<16)
> +#define MV643XX_ETH_DFLT_RX_UDP_Q(q) ((q)<<19)
> +#define MV643XX_ETH_DFLT_RX_BPDU_Q(q) ((q)<<22)
> +#define MV643XX_ETH_PORT_CONFIG_XTEND_R(port) (0x2404 + ((port)<<10))
> +#define MV643XX_ETH_CLASSIFY_ENBL (1<<0)
> +#define MV643XX_ETH_SPAN_BPDU_PACKETS_AS_NORMAL (0<<1)
> +#define MV643XX_ETH_SPAN_BPDU_PACKETS_2_Q7 (1<<1)
> +#define MV643XX_ETH_PARTITION_DISBL (0<<2)
> +#define MV643XX_ETH_PARTITION_ENBL (1<<2)
> +#define MV643XX_ETH_SDMA_CONFIG_R(port) (0x241c + ((port)<<10))
> +#define MV643XX_ETH_SDMA_RIFB (1<<0)
> +#define MV643XX_ETH_RX_BURST_SZ_1_64BIT (0<<1)
> +#define MV643XX_ETH_RX_BURST_SZ_2_64BIT (1<<1)
> +#define MV643XX_ETH_RX_BURST_SZ_4_64BIT (2<<1)
> +#define MV643XX_ETH_RX_BURST_SZ_8_64BIT (3<<1)
> +#define MV643XX_ETH_RX_BURST_SZ_16_64BIT (4<<1)
> +#define MV643XX_ETH_SMDA_BLM_RX_NO_SWAP (1<<4)
> +#define MV643XX_ETH_SMDA_BLM_TX_NO_SWAP (1<<5)
> +#define MV643XX_ETH_SMDA_DESC_BYTE_SWAP (1<<6)
> +#define MV643XX_ETH_TX_BURST_SZ_1_64BIT (0<<22)
> +#define MV643XX_ETH_TX_BURST_SZ_2_64BIT (1<<22)
> +#define MV643XX_ETH_TX_BURST_SZ_4_64BIT (2<<22)
> +#define MV643XX_ETH_TX_BURST_SZ_8_64BIT (3<<22)
> +#define MV643XX_ETH_TX_BURST_SZ_16_64BIT (4<<22)
> +#define MV643XX_ETH_RX_MIN_FRAME_SIZE_R(port) (0x247c + ((port)<<10))
> +#define MV643XX_ETH_SERIAL_CONTROL_R(port) (0x243c + ((port)<<10))
> +#define MV643XX_ETH_SERIAL_PORT_ENBL (1<<0) /* Enable serial port */
> +#define MV643XX_ETH_FORCE_LINK_PASS (1<<1)
> +#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_DUPLEX (1<<2)
> +#define MV643XX_ETH_DISABLE_AUTO_NEG_FOR_FLOWCTL (1<<3)
> +#define MV643XX_ETH_ADVERTISE_SYMMETRIC_FLOWCTL (1<<4)
> +#define MV643XX_ETH_FORCE_FC_MODE_TX_PAUSE_DIS (1<<5)
> +#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX (1<<7)
> +#define MV643XX_ETH_FORCE_BP_MODE_JAM_TX_ON_RX_ERR (1<<8)
> +#define MV643XX_ETH_BIT9_UNKNOWN (1<<9) /* unknown purpose; linux sets this */
> +#define MV643XX_ETH_FORCE_LINK_FAIL_DISABLE (1<<10)
> +#define MV643XX_ETH_RETRANSMIT_FOREVER (1<<11) /* limit to 16 attempts if clear */
> +#define MV643XX_ETH_DISABLE_AUTO_NEG_SPEED_GMII (1<<13)
> +#define MV643XX_ETH_DTE_ADV_1 (1<<14)
> +#define MV643XX_ETH_AUTO_NEG_BYPASS_ENBL (1<<15)
> +#define MV643XX_ETH_RESTART_AUTO_NEG (1<<16)
> +#define MV643XX_ETH_SC_MAX_RX_1518 (0<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_1522 (1<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_1552 (2<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_9022 (3<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_9192 (4<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_9700 (5<<17) /* Limit RX packet size */
> +#define MV643XX_ETH_SC_MAX_RX_MASK (7<<17) /* bitmask */
> +#define MV643XX_ETH_SET_EXT_LOOPBACK (1<<20)
> +#define MV643XX_ETH_SET_FULL_DUPLEX (1<<21)
> +#define MV643XX_ETH_ENBL_FLOWCTL_TX_RX_IN_FD (1<<22) /* enable flow ctrl on rx and tx in full-duplex */
> +#define MV643XX_ETH_SET_GMII_SPEED_1000 (1<<23) /* 10/100 if clear */
> +#define MV643XX_ETH_SET_MII_SPEED_100 (1<<24) /* 10 if clear */
> +#define MV643XX_ETH_PORT_STATUS_R(port) (0x2444 + ((port)<<10))
> +#define MV643XX_ETH_PORT_STATUS_MODE_10_BIT (1<<0)
> +#define MV643XX_ETH_PORT_STATUS_LINK_UP (1<<1)
> +#define MV643XX_ETH_PORT_STATUS_FDX (1<<2)
> +#define MV643XX_ETH_PORT_STATUS_FC (1<<3)
> +#define MV643XX_ETH_PORT_STATUS_1000 (1<<4)
> +#define MV643XX_ETH_PORT_STATUS_100 (1<<5)
> +/* PSR bit 6 unknown */
> +#define MV643XX_ETH_PORT_STATUS_TX_IN_PROGRESS (1<<7)
> +#define MV643XX_ETH_PORT_STATUS_ANEG_BYPASSED (1<<8)
> +#define MV643XX_ETH_PORT_STATUS_PARTITION (1<<9)
> +#define MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY (1<<10)
> +#define MV643XX_ETH_MIB_COUNTERS(port) (0x3000 + ((port)<<7))
> +#define MV643XX_ETH_NUM_MIB_COUNTERS 32
> +#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO (0)
> +#define MV643XX_ETH_MIB_GOOD_OCTS_RCVD_HI (1<<2)
> +#define MV643XX_ETH_MIB_BAD_OCTS_RCVD (2<<2)
> +#define MV643XX_ETH_MIB_INTERNAL_MAC_TX_ERR (3<<2)
> +#define MV643XX_ETH_MIB_GOOD_FRAMES_RCVD (4<<2)
> +#define MV643XX_ETH_MIB_BAD_FRAMES_RCVD (5<<2)
> +#define MV643XX_ETH_MIB_BCAST_FRAMES_RCVD (6<<2)
> +#define MV643XX_ETH_MIB_MCAST_FRAMES_RCVD (7<<2)
> +#define MV643XX_ETH_MIB_FRAMES_64_OCTS (8<<2)
> +#define MV643XX_ETH_MIB_FRAMES_65_127_OCTS (9<<2)
> +#define MV643XX_ETH_MIB_FRAMES_128_255_OCTS (10<<2)
> +#define MV643XX_ETH_MIB_FRAMES_256_511_OCTS (11<<2)
> +#define MV643XX_ETH_MIB_FRAMES_512_1023_OCTS (12<<2)
> +#define MV643XX_ETH_MIB_FRAMES_1024_MAX_OCTS (13<<2)
> +#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO (14<<2)
> +#define MV643XX_ETH_MIB_GOOD_OCTS_SENT_HI (15<<2)
> +#define MV643XX_ETH_MIB_GOOD_FRAMES_SENT (16<<2)
> +#define MV643XX_ETH_MIB_EXCESSIVE_COLL (17<<2)
> +#define MV643XX_ETH_MIB_MCAST_FRAMES_SENT (18<<2)
> +#define MV643XX_ETH_MIB_BCAST_FRAMES_SENT (19<<2)
> +#define MV643XX_ETH_MIB_UNREC_MAC_CTRL_RCVD (20<<2)
> +#define MV643XX_ETH_MIB_FC_SENT (21<<2)
> +#define MV643XX_ETH_MIB_GOOD_FC_RCVD (22<<2)
> +#define MV643XX_ETH_MIB_BAD_FC_RCVD (23<<2)
> +#define MV643XX_ETH_MIB_UNDERSIZE_RCVD (24<<2)
> +#define MV643XX_ETH_MIB_FRAGMENTS_RCVD (25<<2)
> +#define MV643XX_ETH_MIB_OVERSIZE_RCVD (26<<2)
> +#define MV643XX_ETH_MIB_JABBER_RCVD (27<<2)
> +#define MV643XX_ETH_MIB_MAC_RX_ERR (28<<2)
> +#define MV643XX_ETH_MIB_BAD_CRC_EVENT (29<<2)
> +#define MV643XX_ETH_MIB_COLL (30<<2)
> +#define MV643XX_ETH_MIB_LATE_COLL (31<<2)
> +#define MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(port) (0x3400+((port)<<10))
> +#define MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(port) (0x3500+((port)<<10))
> +#define MV643XX_ETH_DA_FILTER_UNICAST_TBL(port) (0x3600+((port)<<10))
> +#define MV643XX_ETH_NUM_MCAST_ENTRIES 64
> +#define MV643XX_ETH_NUM_UNICAST_ENTRIES 4
> +#define MV643XX_ETH_BAR_0 (0x2200)
> +#define MV643XX_ETH_SIZE_R_0 (0x2204)
> +#define MV643XX_ETH_BAR_1 (0x2208)
> +#define MV643XX_ETH_SIZE_R_1 (0x220c)
> +#define MV643XX_ETH_BAR_2 (0x2210)
> +#define MV643XX_ETH_SIZE_R_2 (0x2214)
> +#define MV643XX_ETH_BAR_3 (0x2218)
> +#define MV643XX_ETH_SIZE_R_3 (0x221c)
> +#define MV643XX_ETH_BAR_4 (0x2220)
> +#define MV643XX_ETH_SIZE_R_4 (0x2224)
> +#define MV643XX_ETH_BAR_5 (0x2228)
> +#define MV643XX_ETH_SIZE_R_5 (0x222c)
> +#define MV643XX_ETH_NUM_BARS 6
> +/* Bits in the BAR reg to program cache snooping */
> +#define MV64360_ENET2MEM_SNOOP_NONE 0x0000
> +#define MV64360_ENET2MEM_SNOOP_WT 0x1000
> +#define MV64360_ENET2MEM_SNOOP_WB 0x2000
> +#define MV64360_ENET2MEM_SNOOP_MSK 0x3000
> +#define MV643XX_ETH_BAR_ENBL_R (0x2290)
> +#define MV643XX_ETH_BAR_DISABLE(bar) (1<<(bar))
> +#define MV643XX_ETH_BAR_DISBL_ALL 0x3f
> +#define MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(port) (0x260c+((port)<<10))
> +#define MV643XX_ETH_RX_Q1_CURRENT_DESC_PTR(port) (0x261c+((port)<<10))
> +#define MV643XX_ETH_RX_Q2_CURRENT_DESC_PTR(port) (0x262c+((port)<<10))
> +#define MV643XX_ETH_RX_Q3_CURRENT_DESC_PTR(port) (0x263c+((port)<<10))
> +#define MV643XX_ETH_RX_Q4_CURRENT_DESC_PTR(port) (0x264c+((port)<<10))
> +#define MV643XX_ETH_RX_Q5_CURRENT_DESC_PTR(port) (0x265c+((port)<<10))
> +#define MV643XX_ETH_RX_Q6_CURRENT_DESC_PTR(port) (0x266c+((port)<<10))
> +#define MV643XX_ETH_RX_Q7_CURRENT_DESC_PTR(port) (0x267c+((port)<<10))
> +#define MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(port) (0x26c0+((port)<<10))
> +#define MV643XX_ETH_TX_Q1_CURRENT_DESC_PTR(port) (0x26c4+((port)<<10))
> +#define MV643XX_ETH_TX_Q2_CURRENT_DESC_PTR(port) (0x26c8+((port)<<10))
> +#define MV643XX_ETH_TX_Q3_CURRENT_DESC_PTR(port) (0x26cc+((port)<<10))
> +#define MV643XX_ETH_TX_Q4_CURRENT_DESC_PTR(port) (0x26d0+((port)<<10))
> +#define MV643XX_ETH_TX_Q5_CURRENT_DESC_PTR(port) (0x26d4+((port)<<10))
> +#define MV643XX_ETH_TX_Q6_CURRENT_DESC_PTR(port) (0x26d8+((port)<<10))
> +#define MV643XX_ETH_TX_Q7_CURRENT_DESC_PTR(port) (0x26dc+((port)<<10))
> +#define MV643XX_ETH_MAC_ADDR_LO(port) (0x2414+((port)<<10))
> +#define MV643XX_ETH_MAC_ADDR_HI(port) (0x2418+((port)<<10))
> +/* TYPE DEFINITIONS */
> +/* just to make the purpose explicit; vars of this
> + * type may need CPU-dependent address translation,
> + * endian conversion etc.
> +typedef uint32_t Dma_addr_t;
> +typedef volatile struct mveth_rx_desc {
> +#ifndef __BIG_ENDIAN__
> +#error "descriptor declaration not implemented for little endian machines"
> +#endif
> + uint16_t byte_cnt;
> + uint16_t buf_size;
> + uint32_t cmd_sts; /* control and status */
> + Dma_addr_t next_desc_ptr; /* next descriptor (as seen from DMA) */
> + Dma_addr_t buf_ptr;
> + /* fields below here are not used by the chip */
> + void *u_buf; /* user buffer */
> + volatile struct mveth_rx_desc *next; /* next descriptor (CPU address; next_desc_ptr is a DMA address) */
> + uint32_t pad[2];
> +} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthRxDescRec, *MvEthRxDesc;
> +typedef volatile struct mveth_tx_desc {
> +#endif
> + uint16_t l4i_chk;
> + uint32_t workaround[2]; /* use this space to work around the 8byte problem (is this real?) */
> + volatile struct mveth_tx_desc *next; /* next descriptor (CPU address; next_desc_ptr is a DMA address) */
> +} __attribute__(( aligned(RING_ALIGNMENT) )) MvEthTxDescRec, *MvEthTxDesc;
> +/* Assume there are never more then 64k aliasing entries */
> +typedef uint16_t Mc_Refcnt[MV643XX_ETH_NUM_MCAST_ENTRIES*4];
> +/* driver private data and bsdnet interface structure */
> +struct mveth_private {
> + MvEthRxDesc rx_ring; /* pointers to aligned ring area */
> + MvEthTxDesc tx_ring; /* pointers to aligned ring area */
> + MvEthRxDesc ring_area; /* allocated ring area */
> + int rbuf_count, xbuf_count; /* saved ring sizes from ifconfig */
> + int port_num;
> + int phy;
> + MvEthRxDesc d_rx_t; /* tail of the RX ring; next received packet */
> + MvEthTxDesc d_tx_t, d_tx_h;
> + uint32_t rx_desc_dma, tx_desc_dma; /* ring address as seen by DMA; (1:1 on this BSP) */
> + int avail;
> + void (*isr)(void*);
> + void *isr_arg;
> + /* Callbacks to handle buffers */
> + void (*cleanup_txbuf)(void*, void*, int); /* callback to cleanup TX buffer */
> + void *cleanup_txbuf_arg;
> + void *(*alloc_rxbuf)(int *psize, uintptr_t *paddr); /* allocate RX buffer */
> + void (*consume_rxbuf)(void*, void*, int); /* callback to consume RX buffer */
> + void *consume_rxbuf_arg;
> + rtems_id tid;
> + uint32_t irq_mask; /* IRQs we use */
> + uint32_t xirq_mask;
> + int promisc;
> + struct {
> + unsigned irqs;
> + unsigned maxchain;
> + unsigned repack;
> + unsigned packet;
> + unsigned odrops; /* no counter in core code */
> + struct {
> + uint64_t good_octs_rcvd; /* 64-bit */
> + uint32_t bad_octs_rcvd;
> + uint32_t internal_mac_tx_err;
> + uint32_t good_frames_rcvd;
> + uint32_t bad_frames_rcvd;
> + uint32_t bcast_frames_rcvd;
> + uint32_t mcast_frames_rcvd;
> + uint32_t frames_64_octs;
> + uint32_t frames_65_127_octs;
> + uint32_t frames_128_255_octs;
> + uint32_t frames_256_511_octs;
> + uint32_t frames_512_1023_octs;
> + uint32_t frames_1024_max_octs;
> + uint64_t good_octs_sent; /* 64-bit */
> + uint32_t good_frames_sent;
> + uint32_t excessive_coll;
> + uint32_t mcast_frames_sent;
> + uint32_t bcast_frames_sent;
> + uint32_t unrec_mac_ctrl_rcvd;
> + uint32_t fc_sent;
> + uint32_t good_fc_rcvd;
> + uint32_t bad_fc_rcvd;
> + uint32_t undersize_rcvd;
> + uint32_t fragments_rcvd;
> + uint32_t oversize_rcvd;
> + uint32_t jabber_rcvd;
> + uint32_t mac_rx_err;
> + uint32_t bad_crc_event;
> + uint32_t coll;
> + uint32_t late_coll;
> + } mib;
> + } stats;
> + struct {
> + Mc_Refcnt specl, other;
> + } mc_refcnt;
> +/* stuff needed for bsdnet support */
> +#ifdef BSDBSD
> +struct mveth_bsdsupp {
> + int oif_flags; /* old / cached if_flags */
> +#endif /*BSDBSD*/
> +struct mveth_softc {
> +#ifdef BSDBSD
> + struct arpcom arpcom;
> + struct mveth_bsdsupp bsd;
> +#endif /*BSDBSD*/
> + struct mveth_private pvt;
> +/* GLOBAL VARIABLES */
> +#ifdef MVETH_DEBUG_TX_DUMP
> +int mveth_tx_dump = 0;
> +#endif
> +/* THE array of driver/bsdnet structs */
> +/* If detaching/module unloading is enabled, the main driver data
> + * structure must remain in memory; hence it must reside in its own
> + * 'dummy' module...
> +#ifdef MVETH_DETACH_HACK
> +extern
> +#else
> +STATIC
> +#endif
> +struct mveth_softc theMvEths[MV643XXETH_NUM_DRIVER_SLOTS]
> +#ifndef MVETH_DETACH_HACK
> += {{{{0}},}}
> +#endif
> +#ifdef BSDBSD
> +/* daemon task id */
> +STATIC rtems_id mveth_tid = 0;
> +#endif /*BSDBSD*/
> +/* register access protection mutex */
> +STATIC rtems_id mveth_mtx = 0;
> +#define REGLOCK() do { \
> + if ( RTEMS_SUCCESSFUL != rtems_semaphore_obtain(mveth_mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT) ) \
> + rtems_panic(DRVNAME": unable to lock register protection mutex"); \
> + } while (0)
> +#define REGUNLOCK() rtems_semaphore_release(mveth_mtx)
> +/* Format strings for statistics messages */
> +static const char *mibfmt[] = {
> + " GOOD_OCTS_RCVD: %"PRIu64"\n",
> + 0,
> + " BAD_OCTS_RCVD: %"PRIu32"\n",
> + " INTERNAL_MAC_TX_ERR: %"PRIu32"\n",
> + " GOOD_FRAMES_RCVD: %"PRIu32"\n",
> + " BAD_FRAMES_RCVD: %"PRIu32"\n",
> + " BCAST_FRAMES_RCVD: %"PRIu32"\n",
> + " MCAST_FRAMES_RCVD: %"PRIu32"\n",
> + " FRAMES_64_OCTS: %"PRIu32"\n",
> + " FRAMES_65_127_OCTS: %"PRIu32"\n",
> + " FRAMES_128_255_OCTS: %"PRIu32"\n",
> + " FRAMES_256_511_OCTS: %"PRIu32"\n",
> + " FRAMES_512_1023_OCTS:%"PRIu32"\n",
> + " FRAMES_1024_MAX_OCTS:%"PRIu32"\n",
> + " GOOD_OCTS_SENT: %"PRIu64"\n",
> + 0,
> + " GOOD_FRAMES_SENT: %"PRIu32"\n",
> + " EXCESSIVE_COLL: %"PRIu32"\n",
> + " MCAST_FRAMES_SENT: %"PRIu32"\n",
> + " BCAST_FRAMES_SENT: %"PRIu32"\n",
> + " UNREC_MAC_CTRL_RCVD: %"PRIu32"\n",
> + " FC_SENT: %"PRIu32"\n",
> + " GOOD_FC_RCVD: %"PRIu32"\n",
> + " BAD_FC_RCVD: %"PRIu32"\n",
> + " UNDERSIZE_RCVD: %"PRIu32"\n",
> + " FRAGMENTS_RCVD: %"PRIu32"\n",
> + " OVERSIZE_RCVD: %"PRIu32"\n",
> + " JABBER_RCVD: %"PRIu32"\n",
> + " MAC_RX_ERR: %"PRIu32"\n",
> + " BAD_CRC_EVENT: %"PRIu32"\n",
> + " COLL: %"PRIu32"\n",
> + " LATE_COLL: %"PRIu32"\n",
> +/* Interrupt Handler Connection */
> +/* forward decls + implementation for IRQ API funcs */
> +static void mveth_isr(rtems_irq_hdl_param unit);
> +static void mveth_isr_1(rtems_irq_hdl_param unit);
> +static void noop(const rtems_irq_connect_data *unused) {}
> +static int noop1(const rtems_irq_connect_data *unused) { return 0; }
> +static rtems_irq_connect_data irq_data[MAX_NUM_SLOTS] = {
> + BSP_IRQ_ETH0,
> + 0,
> + (rtems_irq_hdl_param)0,
> + noop,
> + noop,
> + noop1
> + BSP_IRQ_ETH1,
> + 0,
> + (rtems_irq_hdl_param)1,
> + noop,
> + noop,
> + noop1
> + BSP_IRQ_ETH2,
> + 0,
> + (rtems_irq_hdl_param)2,
> + noop,
> + noop,
> + noop1
> +/* MII Ioctl Interface */
> +#ifdef BSDMII
> +/* mdio / mii interface wrappers for rtems_mii_ioctl API */
> +static int mveth_mdio_r(int phy, void *uarg, unsigned reg, uint32_t *pval)
> + if ( phy > 1 )
> + return -1;
> + *pval = mveth_mii_read(uarg, reg);
> + return 0;
> +static int mveth_mdio_w(int phy, void *uarg, unsigned reg, uint32_t val)
> + if ( phy > 1 )
> + return -1;
> + mveth_mii_write(uarg, reg, val);
> + return 0;
> +static struct rtems_mdio_info mveth_mdio = {
> + mdio_r: mveth_mdio_r,
> + mdio_w: mveth_mdio_w,
> + has_gmii: 1,
> +/* LOW LEVEL SUPPORT ROUTINES */
> +/* Software Cache Coherency */
> +#ifndef ENABLE_HW_SNOOPING
> +#ifndef __PPC__
> +#error "Software cache coherency maintenance is not implemented for your CPU architecture"
> +#endif
> +static inline unsigned INVAL_DESC(volatile void *d)
> +typedef const char cache_line[PPC_CACHE_ALIGNMENT];
> + asm volatile("dcbi 0, %1":"=m"(*(cache_line*)d):"r"(d));
> + return (unsigned)d; /* so this can be used in comma expression */
> +static inline void FLUSH_DESC(volatile void *d)
> + asm volatile("dcbf 0, %0"::"r"(d),"m"(*(cache_line*)d));
> +static inline void FLUSH_BARRIER(void)
> + asm volatile("eieio");
> +/* RX buffers are always cache-line aligned
> + * ASSUMPTIONS:
> + * - 'addr' is cache aligned
> + * - len is a multiple >0 of cache lines
> +static inline void INVAL_BUF(register uintptr_t addr, register int len)
> +typedef char maxbuf[2048]; /* more than an ethernet packet */
> + do {
> + len -= RX_BUF_ALIGNMENT;
> + asm volatile("dcbi %0, %1"::"b"(addr),"r"(len));
> + } while (len > 0);
> + asm volatile("":"=m"(*(maxbuf*)addr));
> +/* Flushing TX buffers is a little bit trickier; we don't really know their
> + * alignment but *assume* adjacent addresses are covering 'ordinary' memory
> + * so that flushing them does no harm!
> +static inline void FLUSH_BUF(register uintptr_t addr, register int len)
> + asm volatile("":::"memory");
> + len = MV643XX_ALIGN(len, RX_BUF_ALIGNMENT);
> + do {
> + asm volatile("dcbf %0, %1"::"b"(addr),"r"(len));
> + } while ( len >= 0 );
> +#else /* hardware snooping enabled */
> +/* inline this to silence compiler warnings */
> +static inline int INVAL_DESC(volatile void *d)
> +{ return 0; }
> +#define FLUSH_DESC(d) NOOP()
> +#define INVAL_BUF(b,l) NOOP()
> +#define FLUSH_BUF(b,l) NOOP()
> +#define FLUSH_BARRIER() NOOP()
> +#endif /* cache coherency support */
> +/* Synchronize memory access */
> +#ifdef __PPC__
> +static inline void membarrier(void)
> + asm volatile("sync":::"memory");
> +#else
> +#error "memory barrier instruction not defined (yet) for this CPU"
> +#endif
> +/* Enable and disable interrupts at the device */
> +static inline void
> +mveth_enable_irqs(struct mveth_private *mp, uint32_t mask)
> +rtems_interrupt_level l;
> +uint32_t val;
> + rtems_interrupt_disable(l);
> + val = MV_READ(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num));
> + val = (val | mask | MV643XX_ETH_IRQ_EXT_ENA) & mp->irq_mask;
> + MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), val);
> + val = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
> + val = (val | mask) & mp->xirq_mask;
> + MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), val);
> + rtems_interrupt_enable(l);
> +static inline uint32_t
> +mveth_disable_irqs(struct mveth_private *mp, uint32_t mask)
> +uint32_t val,xval,tmp;
> + tmp = ( (val & ~mask) | MV643XX_ETH_IRQ_EXT_ENA ) & mp->irq_mask;
> + MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), tmp);
> + xval = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num));
> + tmp = (xval & ~mask) & mp->xirq_mask;
> + MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), tmp);
> + return (val | xval);
> +/* This should be safe even w/o turning off interrupts if multiple
> + * threads ack different bits in the cause register (and ignore
> + * other ones) since writing 'ones' into the cause register doesn't
> + * 'stick'.
> +mveth_ack_irqs(struct mveth_private *mp, uint32_t mask)
> +register uint32_t x,xe,p;
> + p = mp->port_num;
> + /* Get cause */
> + x = MV_READ(MV643XX_ETH_INTERRUPT_CAUSE_R(p));
> + /* Ack interrupts filtering the ones we're interested in */
> + /* Note: EXT_IRQ bit clears by itself if EXT interrupts are cleared */
> + MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(p), ~ (x & mp->irq_mask & mask));
> + /* linux driver tests 1<<1 as a summary bit for extended interrupts;
> + * the mv64360 seems to use 1<<19 for that purpose; for the moment,
> + * I just check both.
> + * Update: link status irq (1<<16 in xe) doesn't set (1<<19) in x!
> + if ( 1 /* x & 2 */ )
> + xe = MV_READ(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p));
> + MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(p), ~ (xe & mp->xirq_mask & mask));
> + } else {
> + xe = 0;
> + if ( ((x & MV643XX_ETH_ALL_IRQS) & ~MV643XX_ETH_KNOWN_IRQS)
> + || ((xe & MV643XX_ETH_ALL_EXT_IRQS) & ~MV643XX_ETH_KNOWN_EXT_IRQS) ) {
> + fprintf(stderr, "Unknown IRQs detected; leaving all disabled for debugging:\n");
> + fprintf(stderr, "Cause reg was 0x%08x, ext cause 0x%08x\n", x, xe);
> + mp->irq_mask = 0;
> + mp->xirq_mask = 0;
> +#endif
> + /* luckily, the extended and 'normal' interrupts we use don't overlap so
> + * we can just OR them into a single word
> + return (xe & mp->xirq_mask) | (x & mp->irq_mask);
> +static void mveth_isr(rtems_irq_hdl_param arg)
> +unsigned unit = (unsigned)arg;
> + mveth_disable_irqs(&theMvEths[unit].pvt, -1);
> + theMvEths[unit].pvt.stats.irqs++;
> +#ifdef BSDBSD
> +#warning FIXME
> + rtems_bsdnet_event_send( theMvEths[unit].pvt.tid, 1<<unit );
> +#endif
> +static void mveth_isr_1(rtems_irq_hdl_param arg)
> +struct mveth_private *mp = &theMvEths[unit].pvt;
> + mp->stats.irqs++;
> + mp->isr(mp->isr_arg);
> +static void
> +mveth_clear_mib_counters(struct mveth_private *mp)
> +register int i;
> +register uint32_t b;
> + /* reading the counters resets them */
> + b = MV643XX_ETH_MIB_COUNTERS(mp->port_num);
> + for (i=0; i< MV643XX_ETH_NUM_MIB_COUNTERS; i++, b+=4)
> + (void)MV_READ(b);
> +/* Reading a MIB register also clears it. Hence we read the lo
> + * register first, then the hi one. Correct reading is guaranteed since
> + * the 'lo' register cannot overflow after it is read since it had
> + * been reset to 0.
> +static unsigned long long
> +read_long_mib_counter(int port_num, int idx)
> +unsigned long lo;
> +unsigned long long hi;
> + lo = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
> + idx++;
> + hi = MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
> + return (hi<<32) | lo;
> +static inline unsigned long
> +read_mib_counter(int port_num, int idx)
> + return MV_READ(MV643XX_ETH_MIB_COUNTERS(port_num)+(idx<<2));
> +/* write ethernet address from buffer to hardware (need to change unicast filter after this) */
> +static void
> +mveth_write_eaddr(struct mveth_private *mp, unsigned char *eaddr)
> +int i;
> +uint32_t x;
> + /* build hi word */
> + for (i=4,x=0; i; i--, eaddr++) {
> + x = (x<<8) | *eaddr;
> + MV_WRITE(MV643XX_ETH_MAC_ADDR_HI(mp->port_num), x);
> + /* build lo word */
> + for (i=2,x=0; i; i--, eaddr++) {
> + MV_WRITE(MV643XX_ETH_MAC_ADDR_LO(mp->port_num), x);
> +/* PHY/MII Interface
> + * Read/write a PHY register;
> + * NOTE: The SMI register is shared among the three devices.
> + * Protection is provided by the global networking semaphore.
> + * If non-bsd drivers are running on a subset of IFs proper
> +unsigned
> +unsigned v;
> +unsigned wc = 0;
> + addr &= 0x1f;
> + /* wait until not busy */
> + do {
> + v = MV_READ(MV643XX_ETH_SMI_R);
> + wc++;
> + } while ( MV643XX_ETH_SMI_BUSY & v );
> + MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_RD );
> + do {
> + wc++;
> + if (wc>0xffff)
> + wc = 0xffff;
> + return (wc<<16) | (v & 0xffff);
> +unsigned
> +unsigned wc = 0;
> + addr &= 0x1f;
> + v &= 0xffff;
> + /* busywait is ugly but not preventing ISRs or high priority tasks from
> + * preempting us
> + while ( MV643XX_ETH_SMI_BUSY & MV_READ(MV643XX_ETH_SMI_R) )
> + wc++ /* wait */;
> + MV_WRITE(MV643XX_ETH_SMI_R, (addr <<21 ) | (mp->phy<<16) | MV643XX_ETH_SMI_OP_WR | v );
> + return wc;
> +/* MID-LAYER SUPPORT ROUTINES */
> +/* Start TX if descriptors are exhausted */
> +static __inline__ void
> +mveth_start_tx(struct mveth_private *mp)
> +uint32_t running;
> + if ( mp->avail <= 0 ) {
> + running = MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num));
> + if ( ! (running & MV643XX_ETH_TX_START(0)) ) {
> + MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_TX_START(0));
> +/* Stop TX and wait for the command queues to stop and the fifo to drain */
> +static uint32_t
> +mveth_stop_tx(int port)
> +uint32_t active_q;
> + active_q = (MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) & MV643XX_ETH_TX_ANY_RUNNING);
> + if ( active_q ) {
> + /* Halt TX and wait for activity to stop */
> + MV_WRITE(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port), MV643XX_ETH_TX_STOP_ALL);
> + while ( MV643XX_ETH_TX_ANY_RUNNING & MV_READ(MV643XX_ETH_TRANSMIT_QUEUE_COMMAND_R(port)) )
> + /* poll-wait */;
> + /* Wait for Tx FIFO to drain */
> + while ( ! (MV643XX_ETH_PORT_STATUS_R(port) & MV643XX_ETH_PORT_STATUS_TX_FIFO_EMPTY) )
> + /* poll-wait */;
> + return active_q;
> +/* update serial port settings from current link status */
> +#ifdef BSDMII
> +static void
> +mveth_update_serial_port(struct mveth_private *mp, int media)
> +int port = mp->port_num;
> +uint32_t old, new;
> + new = old = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(port));
> + /* mask speed and duplex settings */
> + new &= ~( MV643XX_ETH_SET_GMII_SPEED_1000
> + | MV643XX_ETH_SET_MII_SPEED_100
> + | MV643XX_ETH_SET_FULL_DUPLEX );
> + if ( IFM_FDX & media )
> + new |= MV643XX_ETH_SET_FULL_DUPLEX;
> + switch ( IFM_SUBTYPE(media) ) {
> + default: /* treat as 10 */
> + break;
> + case IFM_100_TX:
> + new |= MV643XX_ETH_SET_MII_SPEED_100;
> + break;
> + case IFM_1000_T:
> + new |= MV643XX_ETH_SET_GMII_SPEED_1000;
> + break;
> + if ( new != old ) {
> + if ( ! (MV643XX_ETH_SERIAL_PORT_ENBL & new) ) {
> + /* just write */
> + MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), new);
> + } else {
> + uint32_t were_running;
> + were_running = mveth_stop_tx(port);
> + old &= ~MV643XX_ETH_SERIAL_PORT_ENBL;
> + MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(port), old);
> + /* linux driver writes twice... */
> + if ( were_running ) {
> +#endif /*BSDMII*/
> +void
> +BSP_mve_mcast_filter_clear(struct mveth_private *mp)
> +int i;
> +register uint32_t s,o;
> +uint32_t v = mp->promisc ? 0x01010101 : 0x00000000;
> + s = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
> + o = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
> + for (i=0; i<MV643XX_ETH_NUM_MCAST_ENTRIES; i++) {
> + MV_WRITE(s,v);
> + MV_WRITE(o,v);
> + s+=4;
> + o+=4;
> + for (i=0; i<sizeof(mp->mc_refcnt.specl)/sizeof(mp->mc_refcnt.specl[0]); i++) {
> + mp->mc_refcnt.specl[i] = 0;
> + mp->mc_refcnt.other[i] = 0;
> +void
> +BSP_mve_mcast_filter_accept_all(struct mveth_private *mp)
> +int i;
> + MV_WRITE(s,0x01010101);
> + MV_WRITE(o,0x01010101);
> + s+=4;
> + o+=4;
> + /* Not clear what we should do with the reference count.
> + * For now just increment it.
> + mp->mc_refcnt.specl[i]++;
> + mp->mc_refcnt.other[i]++;
> +static void add_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
> +uint32_t val;
> +uint32_t slot = hash & 0xfc;
> + if ( 0 == (*refcnt)[hash]++ ) {
> + val = MV_READ(off+slot) | ( 1 << ((hash&3)<<3) );
> + MV_WRITE(off+slot, val);
> +static void del_entry(uint32_t off, uint8_t hash, Mc_Refcnt *refcnt)
> +uint32_t val;
> + if ( (*refcnt)[hash] > 0 && 0 == --(*refcnt)[hash] ) {
> + val = MV_READ(off+slot) & ~( 1 << ((hash&3)<<3) );
> +void
> +BSP_mve_mcast_filter_accept_add(struct mveth_private *mp, unsigned char *enaddr)
> +uint32_t hash;
> +static const char spec[]={0x01,0x00,0x5e,0x00,0x00};
> +static const char bcst[]={0xff,0xff,0xff,0xff,0xff,0xff};
> +uint32_t tabl;
> +Mc_Refcnt *refcnt;
> + if ( ! (0x01 & enaddr[0]) ) {
> + /* not a multicast address; ignore */
> + return;
> + if ( 0 == memcmp(enaddr, bcst, sizeof(bcst)) ) {
> + /* broadcast address; ignore */
> + return;
> + if ( 0 == memcmp(enaddr, spec, sizeof(spec)) ) {
> + hash = enaddr[5];
> + tabl = MV643XX_ETH_DA_FILTER_SPECL_MCAST_TBL(mp->port_num);
> + refcnt = &mp->mc_refcnt.specl;
> + } else {
> + uint32_t test, mask;
> + int i;
> + /* algorithm used by linux driver */
> + for ( hash=0, i=0; i<6; i++ ) {
> + hash = (hash ^ enaddr[i]) << 8;
> + for ( test=0x8000, mask=0x8380; test>0x0080; test>>=1, mask>>=1 ) {
> + if ( hash & test )
> + hash ^= mask;
> + tabl = MV643XX_ETH_DA_FILTER_OTHER_MCAST_TBL(mp->port_num);
> + refcnt = &mp->mc_refcnt.other;
> + add_entry(tabl, hash, refcnt);
> +void
> +BSP_mve_mcast_filter_accept_del(struct mveth_private *mp, unsigned char *enaddr)
> +uint32_t hash;
> +uint32_t tabl;
> +Mc_Refcnt *refcnt;
> + return;
> + return;
> + hash = enaddr[5];
> + } else {
> + int i;
> + hash ^= mask;
> + del_entry(tabl, hash, refcnt);
> +/* Clear all address filters (multi- and unicast) */
> +static void
> +mveth_clear_addr_filters(struct mveth_private *mp)
> +register int i;
> +register uint32_t u;
> + u = MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num);
> + for (i=0; i<MV643XX_ETH_NUM_UNICAST_ENTRIES; i++) {
> + MV_WRITE(u,0);
> + u+=4;
> + BSP_mve_mcast_filter_clear(mp);
> +/* Setup unicast filter for a given MAC address (least significant nibble) */
> +static void
> +mveth_ucfilter(struct mveth_private *mp, unsigned char mac_lsbyte, int accept)
> +unsigned nib, slot, bit;
> +uint32_t val;
> + /* compute slot in table */
> + nib = mac_lsbyte & 0xf; /* strip nibble */
> + slot = nib & ~3; /* (nibble/4)*4 */
> + bit = (nib & 3)<<3; /* 8*(nibble % 4) */
> + val = MV_READ(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot);
> + if ( accept ) {
> + val |= 0x01 << bit;
> + } else {
> + val &= 0x0e << bit;
> + MV_WRITE(MV643XX_ETH_DA_FILTER_UNICAST_TBL(mp->port_num) + slot, val);
> +#if defined( ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM ) && 0
> +/* Currently unused; small unaligned buffers seem to be rare
> + * so we just use memcpy()...
> +/* memcpy for 0..7 bytes; arranged so that gcc
> + * optimizes for powerpc...
> +static inline void memcpy8(void *to, void *fr, unsigned x)
> +register uint8_t *d = to, *s = fro;
> + d+=l; s+=l;
> + if ( l & 1 ) {
> + *--d=*--s;
> + if ( l & 2 ) {
> + /* pre-decrementing causes gcc to use auto-decrementing
> + * PPC instructions (lhzu rx, -2(ry))
> + d-=2; s-=2;
> + /* use memcpy; don't cast to short -- accessing
> + * misaligned data as short is not portable
> + * (but it works on PPC).
> + __builtin_memcpy(d,s,2);
> + if ( l & 4 ) {
> + d-=4; s-=4;
> + /* see above */
> + __builtin_memcpy(d,s,4);
> +#endif
> +#ifdef BSDBSD
> +/* Assign values (buffer + user data) to a tx descriptor slot */
> +static int
> +mveth_assign_desc(MvEthTxDesc d, struct mbuf *m, unsigned long extra)
> +int rval = (d->byte_cnt = m->m_len);
> + assert( !d->mb );
> + assert( m->m_len );
> +#endif
> + /* set CRC on all descriptors; seems to be necessary */
> + d->cmd_sts = extra | (TDESC_GEN_CRC | TDESC_ZERO_PAD);
> +#ifdef ENABLE_TX_WORKAROUND_8_BYTE_PROBLEM
> + /* The buffer must be 64bit aligned if the payload is <8 (??) */
> + if ( rval < 8 && ((mtod(m, uintptr_t)) & 7) ) {
> + d->buf_ptr = CPUADDR2ENET( d->workaround );
> + memcpy((void*)d->workaround, mtod(m, void*), rval);
> + } else
> +#endif
> + d->buf_ptr = CPUADDR2ENET( mtod(m, unsigned long) );
> + d->l4i_chk = 0;
> + return rval;
> +#endif /*BSDBSD*/
> +static int
> +mveth_assign_desc_raw(MvEthTxDesc d, void *buf, int len, unsigned long extra)
> +int rval = (d->byte_cnt = len);
> + assert( !d->u_buf );
> + assert( len );
> +#endif
> + if ( rval < 8 && ( ((uintptr_t)buf) & 7) ) {
> + memcpy((void*)d->workaround, buf, rval);
> + } else
> +#endif
> + d->buf_ptr = CPUADDR2ENET( (unsigned long)buf );
> + d->l4i_chk = 0;
> + return rval;
> + * Ring Initialization
> + * ENDIAN ASSUMPTION: DMA engine matches CPU endianness (???)
> + * Linux driver discriminates __LITTLE and __BIG endian for re-arranging
> + * the u16 fields in the descriptor structs. However, no endian conversion
> + * is done on the individual fields (SDMA byte swapping is disabled on LE).
> +STATIC int
> +mveth_init_rx_desc_ring(struct mveth_private *mp)
> +int i,sz;
> +MvEthRxDesc d;
> +uintptr_t baddr;
> + memset((void*)mp->rx_ring, 0, sizeof(*mp->rx_ring)*mp->rbuf_count);
> + mp->rx_desc_dma = CPUADDR2ENET(mp->rx_ring);
> + for ( i=0, d = mp->rx_ring; i<mp->rbuf_count; i++, d++ ) {
> + d->u_buf = mp->alloc_rxbuf(&sz, &baddr);
> + assert( d->u_buf );
> + /* could reduce the area to max. ethernet packet size */
> + INVAL_BUF(baddr, sz);
> +#endif
> + d->buf_size = sz;
> + d->byte_cnt = 0;
> + d->cmd_sts = RDESC_DMA_OWNED | RDESC_INT_ENA;
> + d->next = mp->rx_ring + (i+1) % mp->rbuf_count;
> + d->buf_ptr = CPUADDR2ENET( baddr );
> + d->next_desc_ptr = CPUADDR2ENET(d->next);
> + FLUSH_DESC(d);
> + FLUSH_BARRIER();
> + mp->d_rx_t = mp->rx_ring;
> + /* point the chip to the start of the ring */
> + MV_WRITE(MV643XX_ETH_RX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->rx_desc_dma);
> + return i;
> +STATIC int
> +mveth_init_tx_desc_ring(struct mveth_private *mp)
> +int i;
> +MvEthTxDesc d;
> + memset((void*)mp->tx_ring, 0, sizeof(*mp->tx_ring)*mp->xbuf_count);
> + /* DMA and CPU live in the same address space (rtems) */
> + mp->tx_desc_dma = CPUADDR2ENET(mp->tx_ring);
> + mp->avail = TX_AVAILABLE_RING_SIZE(mp);
> + for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++,d++ ) {
> + d->l4i_chk = 0;
> + d->byte_cnt = 0;
> + d->cmd_sts = 0;
> + d->buf_ptr = 0;
> + d->next = mp->tx_ring + (i+1) % mp->xbuf_count;
> + FLUSH_DESC(d);
> + FLUSH_BARRIER();
> + mp->d_tx_h = mp->d_tx_t = mp->tx_ring;
> + MV_WRITE(MV643XX_ETH_TX_Q0_CURRENT_DESC_PTR(mp->port_num),mp->tx_desc_dma);
> + return i;
> +/* PUBLIC LOW-LEVEL DRIVER ACCESS */
> +static struct mveth_private *
> +mve_setup_internal(
> + int unit,
> + rtems_id tid,
> + void (*isr)(void*isr_arg),
> + void *isr_arg,
> + void (*cleanup_txbuf)(void *user_buf, void *closure, int error_on_tx_occurred),
> + void *cleanup_txbuf_arg,
> + void *(*alloc_rxbuf)(int *p_size, uintptr_t *p_data_addr),
> + void (*consume_rxbuf)(void *user_buf, void *closure, int len),
> + void *consume_rxbuf_arg,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> +struct mveth_private *mp;
> +#ifdef BSDBSD
> +struct ifnet *ifp;
> +#endif
> +int InstallISRSuccessful;
> + if ( unit <= 0 || unit > MV643XXETH_NUM_DRIVER_SLOTS ) {
> + printk(DRVNAME": Bad unit number %i; must be 1..%i\n", unit, MV643XXETH_NUM_DRIVER_SLOTS);
> + return 0;
> +#ifdef BSDBSD
> +#warning FIXME
> + ifp = &theMvEths[unit-1].arpcom.ac_if;
> + if ( ifp->if_init ) {
> + printk(DRVNAME": instance %i already attached.\n", unit);
> + return 0;
> +#endif
> + if ( rx_ring_size < 0 && tx_ring_size < 0 )
> + return 0;
> + if ( MV_64360 != BSP_getDiscoveryVersion(0) ) {
> + printk(DRVNAME": not mv64360 chip\n");
> + return 0;
> + /* lazy init of mutex (non thread-safe! - we assume 1st initialization is single-threaded) */
> + if ( ! mveth_mtx ) {
> + rtems_status_code sc;
> + sc = rtems_semaphore_create(
> + rtems_build_name('m','v','e','X'),
> + 1,
> + RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY | RTEMS_DEFAULT_ATTRIBUTES,
> + 0,
> + &mveth_mtx);
> + if ( RTEMS_SUCCESSFUL != sc ) {
> + rtems_error(sc,DRVNAME": creating mutex\n");
> + rtems_panic("unable to proceed\n");
> + mp = &theMvEths[unit-1].pvt;
> + memset(mp, 0, sizeof(*mp));
> + mp->port_num = unit-1;
> + mp->phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*mp->port_num)) & 0x1f;
> + mp->tid = tid;
> + mp->isr = isr;
> + mp->isr_arg = isr_arg;
> + mp->cleanup_txbuf = cleanup_txbuf;
> + mp->cleanup_txbuf_arg = cleanup_txbuf_arg;
> + mp->alloc_rxbuf = alloc_rxbuf;
> + mp->consume_rxbuf = consume_rxbuf;
> + mp->consume_rxbuf_arg = consume_rxbuf_arg;
> + mp->rbuf_count = rx_ring_size ? rx_ring_size : MV643XX_RX_RING_SIZE;
> + mp->xbuf_count = tx_ring_size ? tx_ring_size : MV643XX_TX_RING_SIZE;
> + if ( mp->xbuf_count > 0 )
> + mp->xbuf_count += TX_NUM_TAG_SLOTS;
> + if ( mp->rbuf_count < 0 )
> + mp->rbuf_count = 0;
> + if ( mp->xbuf_count < 0 )
> + mp->xbuf_count = 0;
> +#ifdef BSDBSD
> + /* allocate ring area; add 1 entry -- room for alignment */
> + assert( !mp->ring_area );
> + mp->ring_area = malloc(
> + sizeof(*mp->ring_area) *
> + (mp->rbuf_count + mp->xbuf_count + 1),
> + M_DEVBUF,
> + M_WAIT );
> + assert( mp->ring_area );
> +#endif
> + BSP_mve_stop_hw(mp);
> + if ( irq_mask ) {
> + irq_data[mp->port_num].hdl = tid ? mveth_isr : mveth_isr_1;
> + InstallISRSuccessful = BSP_install_rtems_irq_handler( &irq_data[mp->port_num] );
> + assert( InstallISRSuccessful );
> +#ifdef BSDBSD
> +#warning fixme
> + /* mark as used */
> + ifp->if_init = (void*)(-1);
> +#endif
> + if ( rx_ring_size < 0 )
> + irq_mask &= ~ MV643XX_ETH_IRQ_RX_DONE;
> + if ( tx_ring_size < 0 )
> + irq_mask &= ~ MV643XX_ETH_EXT_IRQ_TX_DONE;
> + mp->irq_mask = (irq_mask & MV643XX_ETH_IRQ_RX_DONE);
> + if ( (irq_mask &= (MV643XX_ETH_EXT_IRQ_TX_DONE | MV643XX_ETH_EXT_IRQ_LINK_CHG)) ) {
> + mp->irq_mask |= MV643XX_ETH_IRQ_EXT_ENA;
> + mp->xirq_mask = irq_mask;
> + } else {
> + return mp;
> +BSP_mve_setup(
> + int unit,
> + rtems_id tid,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> +struct ifnet *ifp;
> +struct mveth_private *mp,
> + return 0;
> + if ( irq_mask && 0 == tid ) {
> + printk(DRVNAME": must supply a TID if irq_msk not zero\n");
> + return 0;
> + return 0;
> + if ( 0 == mve_setup_internal(
> + mp,
> + unit,
> + tid,
> + 0, 0,
> + cleanup_txbuf, cleanup_txbuf_arg,
> + alloc_rxbuf,
> + consume_rxbuf, consume_rxbuf_arg,
> + rx_ring_size, tx_ring_size,
> + irq_mask) ) {
> + return 0;
> + return mp;
> +BSP_mve_setup_1(
> + int unit,
> + void (*isr)(void *isr_arg),
> + void *isr_arg,
> + int rx_ring_size,
> + int tx_ring_size,
> + int irq_mask
> + if ( irq_mask && 0 == isr ) {
> + printk(DRVNAME": must supply an ISR if irq_msk not zero\n");
> + return 0;
> + return mve_setup_internal(
> + unit,
> + 0,
> + isr, isr_arg,
> + alloc_rxbuf,
> + irq_mask);
> +rtems_id
> +BSP_mve_get_tid(struct mveth_private *mp)
> + return mp->tid;
> +int
> +BSP_mve_detach(struct mveth_private *mp)
> +#ifdef BSDBSD
> +int unit = mp->port_num;
> +#endif
> + if ( mp->irq_mask || mp->xirq_mask ) {
> + if ( !BSP_remove_rtems_irq_handler( &irq_data[mp->port_num] ) )
> + return -1;
> +#ifdef BSDBSD
> +#warning FIXME
> + free( (void*)mp->ring_area, M_DEVBUF );
> +#endif
> + __asm__ __volatile__("":::"memory");
> + /* mark as unused */
> +#ifdef BSDBSD
> + theMvEths[unit].arpcom.ac_if.if_init = 0;
> +#endif
> + return 0;
> +/* MAIN RX-TX ROUTINES
> + * BSP_mve_swipe_tx(): descriptor scavenger; releases mbufs
> + * BSP_mve_send_buf(): xfer mbufs from IF to chip
> + * BSP_mve_swipe_rx(): enqueue received mbufs to interface
> + * allocate new ones and yield them to the
> + * chip.
> +/* clean up the TX ring freeing up buffers */
> +int
> +BSP_mve_swipe_tx(struct mveth_private *mp)
> +int rval = 0;
> +register MvEthTxDesc d;
> + for ( d = mp->d_tx_t; d->buf_ptr; d = NEXT_TXD(d) ) {
> + INVAL_DESC(d);
> + if ( (TDESC_DMA_OWNED & d->cmd_sts)
> + && (uint32_t)d == MV_READ(MV643XX_ETH_CURRENT_SERVED_TX_DESC(mp->port_num)) )
> + break;
> + /* d->u_buf is only set on the last descriptor in a chain;
> + * we only count errors in the last descriptor;
> + if ( d->u_buf ) {
> + mp->cleanup_txbuf(d->u_buf, mp->cleanup_txbuf_arg, (d->cmd_sts & TDESC_ERROR) ? 1 : 0);
> + d->u_buf = 0;
> + d->buf_ptr = 0;
> + rval++;
> + mp->d_tx_t = d;
> + mp->avail += rval;
> + return rval;
> +#ifdef BSDBSD
> +/* allocate a new cluster and copy an existing chain there;
> + * old chain is released...
> +static struct mbuf *
> +repackage_chain(struct mbuf *m_head)
> +struct mbuf *m;
> + MGETHDR(m, M_DONTWAIT, MT_DATA);
> + if ( !m ) {
> + goto bail;
> + MCLGET(m, M_DONTWAIT);
> + if ( !(M_EXT & m->m_flags) ) {
> + m_freem(m);
> + m = 0;
> + goto bail;
> + m_copydata(m_head, 0, MCLBYTES, mtod(m, caddr_t));
> + m->m_pkthdr.len = m->m_len = m_head->m_pkthdr.len;
> +bail:
> + m_freem(m_head);
> + return m;
> +/* Enqueue a mbuf chain or a raw data buffer for transmission;
> + * RETURN: #bytes sent or -1 if there are not enough descriptors
> + * If 'len' is <=0 then 'm_head' is assumed to point to a mbuf chain.
> + * OTOH, a raw data packet may be send (non-BSD driver) by pointing
> + * m_head to the start of the data and passing 'len' > 0.
> + * Comments: software cache-flushing incurs a penalty if the
> + * packet cannot be queued since it is flushed anyways.
> + * The algorithm is slightly more efficient in the normal
> + * case, though.
> +int
> +BSP_mve_send_buf(struct mveth_private *mp, void *m_head, void *data_p, int len)
> +int rval;
> +register MvEthTxDesc l,d,h;
> +register struct mbuf *m1;
> +int nmbs;
> +int ismbuf = (len <= 0);
> +/* Only way to get here is when we discover that the mbuf chain
> + * is too long for the tx ring
> +startover:
> + rval = 0;
> + assert(m_head);
> +#endif
> + /* if no descriptor is available; try to wipe the queue */
> + if ( (mp->avail < 1) && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
> + /* Maybe TX is stalled and needs to be restarted */
> + mveth_start_tx(mp);
> + return -1;
> + h = mp->d_tx_h;
> + assert( !h->buf_ptr );
> + assert( !h->mb );
> +#endif
> + if ( ! (m1 = m_head) )
> + return 0;
> + if ( ismbuf ) {
> + /* find first mbuf with actual data */
> + while ( 0 == m1->m_len ) {
> + if ( ! (m1 = m1->m_next) ) {
> + /* end reached and still no data to send ?? */
> + m_freem(m_head);
> + return 0;
> + /* Don't use the first descriptor yet because BSP_mve_swipe_tx()
> + * needs mp->d_tx_h->buf_ptr == NULL as a marker. Hence, we
> + * start with the second mbuf and fill the first descriptor
> + * last.
> + l = h;
> + d = NEXT_TXD(h);
> + mp->avail--;
> + nmbs = 1;
> + if ( ismbuf ) {
> + register struct mbuf *m;
> + for ( m=m1->m_next; m; m=m->m_next ) {
> + if ( 0 == m->m_len )
> + continue; /* skip empty mbufs */
> + nmbs++;
> + if ( mp->avail < 1 && MVETH_CLEAN_ON_SEND(mp)<=0 ) {
> + /* Maybe TX was stalled - try to restart */
> + /* not enough descriptors; cleanup...
> + * the first slot was never used, so we start
> + * at mp->d_tx_h->next;
> + for ( l = NEXT_TXD(h); l!=d; l=NEXT_TXD(l) ) {
> + assert( l->mb == 0 );
> +#endif
> + l->buf_ptr = 0;
> + l->cmd_sts = 0;
> + mp->avail++;
> + mp->avail++;
> + if ( nmbs > TX_AVAILABLE_RING_SIZE(mp) ) {
> + /* this chain will never fit into the ring */
> + if ( nmbs > mp->stats.maxchain )
> + mp->stats.maxchain = nmbs;
> + mp->stats.repack++;
> + if ( ! (m_head = repackage_chain(m_head)) ) {
> + /* no cluster available */
> + mp->stats.odrops++;
> + return 0;
> + goto startover;
> + return -1;
> + mp->avail--;
> + assert( d != h );
> + assert( !d->buf_ptr );
> +#endif
> + /* fill this slot */
> + rval += mveth_assign_desc(d, m, TDESC_DMA_OWNED);
> + FLUSH_BUF(mtod(m, uint32_t), m->m_len);
> + l = d;
> + d = NEXT_TXD(d);
> + FLUSH_DESC(l);
> + /* fill first slot - don't release to DMA yet */
> + rval += mveth_assign_desc(h, m1, TDESC_FRST);
> + FLUSH_BUF(mtod(m1, uint32_t), m1->m_len);
> + } else {
> + /* fill first slot with raw buffer - don't release to DMA yet */
> + rval += mveth_assign_desc_raw(h, data_p, len, TDESC_FRST);
> + FLUSH_BUF( (uint32_t)data_p, len);
> + /* tag last slot; this covers the case where 1st==last */
> + l->cmd_sts |= TDESC_LAST | TDESC_INT_ENA;
> + /* mbuf goes into last desc */
> + l->u_buf = m_head;
> + FLUSH_DESC(l);
> + /* Tag end; make sure chip doesn't try to read ahead of here! */
> + l->next->cmd_sts = 0;
> + FLUSH_DESC(l->next);
> + if ( (mveth_tx_dump & (1<<mp->port_num)) ) {
> + int ll,kk;
> + if ( ismbuf ) {
> + struct mbuf *m;
> + for ( kk=0, m=m_head; m; m=m->m_next) {
> + for ( ll=0; ll<m->m_len; ll++ ) {
> + printf("%02X ",*(mtod(m,char*) + ll));
> + if ( ((++kk)&0xf) == 0 )
> + printf("\n");
> + } else {
> + for ( ll=0; ll<len; ) {
> + printf("%02X ",*((char*)data_p + ll));
> + if ( ((++ll)&0xf) == 0 )
> + printf("\n");
> + printf("\n");
> +#endif
> + membarrier();
> + /* turn over the whole chain by flipping ownership of the first desc */
> + h->cmd_sts |= TDESC_DMA_OWNED;
> + FLUSH_DESC(h);
> + membarrier();
> + /* notify the device */
> + /* Update softc */
> + mp->stats.packet++;
> + /* remember new head */
> + mp->d_tx_h = d;
> + return rval; /* #bytes sent */
> +int
> +BSP_mve_send_buf_raw(
> + struct mveth_private *mp,
> + void *head_p,
> + int h_len,
> + void *data_p,
> + int d_len)
> +int rval;
> +int needed;
> +void *frst_buf;
> +int frst_len;
> + rval = 0;
> + assert(header || data);
> +#endif
> + needed = head_p && data_p ? 2 : 1;
> + if ( ( mp->avail < needed )
> + && ( MVETH_CLEAN_ON_SEND(mp) <= 0 || mp->avail < needed ) ) {
> + /* Maybe TX was stalled and needs a restart */
> + return -1;
> + h = mp->d_tx_h;
> + assert( !h->mb );
> +#endif
> + /* find the 'first' user buffer */
> + if ( (frst_buf = head_p) ) {
> + frst_len = h_len;
> + } else {
> + frst_buf = data_p;
> + frst_len = d_len;
> + * start with the second (optional) slot and fill the first
> + * descriptor last.
> + l = h;
> + d = NEXT_TXD(h);
> + mp->avail--;
> + if ( needed > 1 ) {
> + mp->avail--;
> + assert( d != h );
> +#endif
> + rval += mveth_assign_desc_raw(d, data_p, d_len, TDESC_DMA_OWNED);
> + FLUSH_BUF( (uint32_t)data_p, d_len );
> + d->u_buf = data_p;
> + l = d;
> + d = NEXT_TXD(d);
> + FLUSH_DESC(l);
> + rval += mveth_assign_desc_raw(h, frst_buf, frst_len, TDESC_FRST);
> + FLUSH_BUF( (uint32_t)frst_buf, frst_len);
> + /* first buffer of 'chain' goes into last desc */
> + l->u_buf = frst_buf;
> + FLUSH_DESC(l);
> + membarrier();
> + FLUSH_DESC(h);
> + membarrier();
> + if ( needed > mp->stats.maxchain )
> + mp->stats.maxchain = needed;
> + mp->d_tx_h = d;
> +/* send received buffers upwards and replace them
> + * with freshly allocated ones;
> + * ASSUMPTION: buffer length NEVER changes and is set
> + * when the ring is initialized.
> + * TS 20060727: not sure if this assumption is still necessary - I believe it isn't.
> +int
> +BSP_mve_swipe_rx(struct mveth_private *mp)
> +int rval = 0, err;
> +register MvEthRxDesc d;
> +void *newbuf;
> +int sz;
> +uintptr_t baddr;
> + for ( d = mp->d_rx_t; ! (INVAL_DESC(d), (RDESC_DMA_OWNED & d->cmd_sts)); d=NEXT_RXD(d) ) {
> + assert(d->u_buf);
> +#endif
> + err = (RDESC_ERROR & d->cmd_sts);
> + if ( err || !(newbuf = mp->alloc_rxbuf(&sz, &baddr)) ) {
> + /* drop packet and recycle buffer */
> + newbuf = d->u_buf;
> + mp->consume_rxbuf(0, mp->consume_rxbuf_arg, err ? -1 : 0);
> + } else {
> + assert( d->byte_cnt > 0 );
> +#endif
> + mp->consume_rxbuf(d->u_buf, mp->consume_rxbuf_arg, d->byte_cnt);
> +#endif
> + d->u_buf = newbuf;
> + d->buf_ptr = CPUADDR2ENET(baddr);
> + d->buf_size = sz;
> + FLUSH_DESC(d);
> + membarrier();
> + FLUSH_DESC(d);
> + rval++;
> + MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_START(0));
> + mp->d_rx_t = d;
> + return rval;
> +/* Stop hardware and clean out the rings */
> +void
> +BSP_mve_stop_hw(struct mveth_private *mp)
> +MvEthTxDesc d;
> +MvEthRxDesc r;
> +int i;
> + mveth_disable_irqs(mp, -1);
> + mveth_stop_tx(mp->port_num);
> + /* cleanup TX rings */
> + if (mp->d_tx_t) { /* maybe ring isn't initialized yet */
> + for ( i=0, d=mp->tx_ring; i<mp->xbuf_count; i++, d++ ) {
> + /* should be safe to clear ownership */
> + d->cmd_sts &= ~TDESC_DMA_OWNED;
> + FLUSH_DESC(d);
> + FLUSH_BARRIER();
> + BSP_mve_swipe_tx(mp);
> + assert( mp->d_tx_h == mp->d_tx_t );
> +#endif
> + MV_WRITE(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num), MV643XX_ETH_RX_STOP_ALL);
> + while ( MV643XX_ETH_RX_ANY_RUNNING & MV_READ(MV643XX_ETH_RECEIVE_QUEUE_COMMAND_R(mp->port_num)) )
> + /* poll-wait */;
> + /* stop serial port */
> + MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num),
> + MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num))
> + & ~( MV643XX_ETH_SERIAL_PORT_ENBL | MV643XX_ETH_FORCE_LINK_FAIL_DISABLE | MV643XX_ETH_FORCE_LINK_PASS)
> + /* clear pending interrupts */
> + MV_WRITE(MV643XX_ETH_INTERRUPT_CAUSE_R(mp->port_num), 0);
> + MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_CAUSE_R(mp->port_num), 0);
> + /* cleanup RX rings */
> + if ( mp->rx_ring ) {
> + for ( i=0, r=mp->rx_ring; i<mp->rbuf_count; i++, r++ ) {
> + /* should be OK to clear ownership flag */
> + r->cmd_sts = 0;
> + FLUSH_DESC(r);
> + mp->consume_rxbuf(r->u_buf, mp->consume_rxbuf_arg, 0);
> + r->u_buf = 0;
> + FLUSH_BARRIER();
> +uint32_t mveth_serial_ctrl_config_val = MVETH_SERIAL_CTRL_CONFIG_VAL;
> +/* Fire up the low-level driver
> + * - make sure hardware is halted
> + * - enable cache snooping
> + * - clear address filters
> + * - clear mib counters
> + * - reset phy
> + * - initialize (or reinitialize) descriptor rings
> + * - check that the firmware has set up a reasonable mac address.
> + * - generate unicast filter entry for our mac address
> + * - write register config values to the chip
> + * - start hardware (serial port and SDMA)
> +void
> +BSP_mve_init_hw(struct mveth_private *mp, int promisc, unsigned char *enaddr)
> +int i;
> +uint32_t v;
> +static int inited = 0;
> +#ifdef MVETH_DEBUG
> + printk(DRVNAME"%i: Entering BSP_mve_init_hw()\n", mp->port_num+1);
> +#endif
> + /* since enable/disable IRQ routine only operate on select bitsets
> + * we must make sure everything is masked initially.
> + MV_WRITE(MV643XX_ETH_INTERRUPT_ENBL_R(mp->port_num), 0);
> + MV_WRITE(MV643XX_ETH_INTERRUPT_EXTEND_ENBL_R(mp->port_num), 0);
> + memset(&mp->stats, 0, sizeof(mp->stats));
> + mp->promisc = promisc;
> + /* MotLoad has cache snooping disabled on the ENET2MEM windows.
> + * Some comments in (linux) indicate that there are errata
> + * which cause problems which would be a real bummer.
> + * We try it anyways...
> + if ( !inited ) {
> + unsigned long disbl, bar;
> + inited = 1; /* FIXME: non-thread safe lazy init */
> + disbl = MV_READ(MV643XX_ETH_BAR_ENBL_R);
> + /* disable all 6 windows */
> + MV_WRITE(MV643XX_ETH_BAR_ENBL_R, MV643XX_ETH_BAR_DISBL_ALL);
> + /* set WB snooping on enabled bars */
> + for ( i=0; i<MV643XX_ETH_NUM_BARS*8; i+=8 ) {
> + if ( (bar = MV_READ(MV643XX_ETH_BAR_0 + i)) && MV_READ(MV643XX_ETH_SIZE_R_0 + i) ) {
> + MV_WRITE(MV643XX_ETH_BAR_0 + i, bar | MV64360_ENET2MEM_SNOOP_WB);
> +#else
> + MV_WRITE(MV643XX_ETH_BAR_0 + i, bar & ~MV64360_ENET2MEM_SNOOP_MSK);
> +#endif
> + /* read back to flush fifo [linux comment] */
> + (void)MV_READ(MV643XX_ETH_BAR_0 + i);
> + /* restore/re-enable */
> + MV_WRITE(MV643XX_ETH_BAR_ENBL_R, disbl);
> + mveth_clear_mib_counters(mp);
> + mveth_clear_addr_filters(mp);
> +/* Just leave it alone...
> + reset_phy();
> + if ( mp->rbuf_count > 0 ) {
> + mp->rx_ring = (MvEthRxDesc)MV643XX_ALIGN(mp->ring_area, RING_ALIGNMENT);
> + mveth_init_rx_desc_ring(mp);
> + if ( mp->xbuf_count > 0 ) {
> + mp->tx_ring = (MvEthTxDesc)mp->rx_ring + mp->rbuf_count;
> + mveth_init_tx_desc_ring(mp);
> + if ( enaddr ) {
> + /* set ethernet address from arpcom struct */
> +#ifdef MVETH_DEBUG
> + printk(DRVNAME"%i: Writing MAC addr ", mp->port_num+1);
> + for (i=5; i>=0; i--) {
> + printk("%02X%c", enaddr[i], i?':':'\n');
> +#endif
> + mveth_write_eaddr(mp, enaddr);
> + /* set mac address and unicast filter */
> + uint32_t machi, maclo;
> + maclo = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
> + machi = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
> + /* ASSUME: firmware has set the mac address for us
> + * - if assertion fails, we have to do more work...
> + assert( maclo && machi && maclo != 0xffffffff && machi != 0xffffffff );
> + mveth_ucfilter(mp, maclo&0xff, 1/* accept */);
> + /* port, serial and sdma configuration */
> + v = MVETH_PORT_CONFIG_VAL;
> + if ( promisc ) {
> + /* multicast filters were already set up to
> + * accept everything (mveth_clear_addr_filters())
> + v |= MV643XX_ETH_UNICAST_PROMISC_MODE;
> + } else {
> + v &= ~MV643XX_ETH_UNICAST_PROMISC_MODE;
> + MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(mp->port_num),
> + v);
> + MV_WRITE(MV643XX_ETH_PORT_CONFIG_XTEND_R(mp->port_num),
> + MVETH_PORT_XTEND_CONFIG_VAL);
> + v = MV_READ(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num));
> + v &= ~(MVETH_SERIAL_CTRL_CONFIG_MSK);
> + v |= mveth_serial_ctrl_config_val;
> + MV_WRITE(MV643XX_ETH_SERIAL_CONTROL_R(mp->port_num), v);
> +#ifdef BSDMII
> +#warning FIXME
> + i = IFM_MAKEWORD(0, 0, 0, 0);
> + if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &i) ) {
> + if ( (IFM_LINK_OK & i) ) {
> + mveth_update_serial_port(mp, i);
> +#endif
> + /* enable serial port */
> + v | MV643XX_ETH_SERIAL_PORT_ENBL);
> +#error "byte swapping needs to be disabled for little endian machines"
> +#endif
> + MV_WRITE(MV643XX_ETH_SDMA_CONFIG_R(mp->port_num), MVETH_SDMA_CONFIG_VAL);
> + /* allow short frames */
> + MV_WRITE(MV643XX_ETH_RX_MIN_FRAME_SIZE_R(mp->port_num), MVETH_MIN_FRAMSZ_CONFIG_VAL);
> + /* TODO: set irq coalescing */
> + /* enable Rx */
> + mveth_enable_irqs(mp, -1);
> +#ifdef MVETH_DEBUG
> + printk(DRVNAME"%i: Leaving BSP_mve_init_hw()\n", mp->port_num+1);
> +#endif
> +/* read ethernet address from hw to buffer */
> +void
> +BSP_mve_read_eaddr(struct mveth_private *mp, unsigned char *oeaddr)
> +int i;
> +uint32_t x;
> +unsigned char buf[6], *eaddr;
> + eaddr = oeaddr ? oeaddr : buf;
> + eaddr += 5;
> + x = MV_READ(MV643XX_ETH_MAC_ADDR_LO(mp->port_num));
> + /* lo word */
> + for (i=2; i; i--, eaddr--) {
> + *eaddr = (unsigned char)(x & 0xff);
> + x>>=8;
> + x = MV_READ(MV643XX_ETH_MAC_ADDR_HI(mp->port_num));
> + /* hi word */
> + for (i=4; i; i--, eaddr--) {
> + x>>=8;
> + if ( !oeaddr ) {
> + printf("%02X",buf[0]);
> + for (i=1; i<sizeof(buf); i++)
> + printf(":%02X",buf[i]);
> + printf("\n");
> +#ifdef BSDMII
> +int
> +BSP_mve_media_ioctl(struct mveth_private *mp, int cmd, int *parg)
> +int rval;
> + /* alias cmd == 0,1 */
> + switch ( cmd ) {
> + case 0: cmd = SIOCGIFMEDIA;
> + break;
> + case 1: cmd = SIOCSIFMEDIA;
> + case SIOCGIFMEDIA:
> + case SIOCSIFMEDIA:
> + break;
> + default: return -1;
> + REGLOCK();
> + rval = rtems_mii_ioctl(&mveth_mdio, mp, cmd, parg);
> + REGUNLOCK();
> + return rval;
> +#endif
> +void
> +BSP_mve_enable_irqs(struct mveth_private *mp)
> +void
> +BSP_mve_disable_irqs(struct mveth_private *mp)
> +uint32_t
> +BSP_mve_ack_irqs(struct mveth_private *mp)
> + return mveth_ack_irqs(mp, -1);
> +void
> +BSP_mve_enable_irq_mask(struct mveth_private *mp, uint32_t mask)
> + mveth_enable_irqs(mp, mask);
> +uint32_t
> +BSP_mve_disable_irq_mask(struct mveth_private *mp, uint32_t mask)
> + return mveth_disable_irqs(mp, mask);
> +uint32_t
> +BSP_mve_ack_irq_mask(struct mveth_private *mp, uint32_t mask)
> + return mveth_ack_irqs(mp, mask);
> +#ifdef BSDMII
> +int
> +BSP_mve_ack_link_chg(struct mveth_private *mp, int *pmedia)
> +int media = IFM_MAKEWORD(0,0,0,0);
> + if ( 0 == BSP_mve_media_ioctl(mp, SIOCGIFMEDIA, &media)) {
> + if ( IFM_LINK_OK & media ) {
> + mveth_update_serial_port(mp, media);
> + /* If TX stalled because there was no buffer then whack it */
> + if ( pmedia )
> + *pmedia = media;
> + return 0;
> + return -1;
> +#endif
> +#ifdef BSDBSD
> +/* BSDNET SUPPORT/GLUE ROUTINES */
> +static void
> +mveth_set_filters(struct ifnet *ifp);
> +STATIC void
> +mveth_stop(struct mveth_softc *sc)
> + BSP_mve_stop_hw(&sc->pvt);
> + sc->arpcom.ac_if.if_timer = 0;
> +/* allocate a mbuf for RX with a properly aligned data buffer
> + * RETURNS 0 if allocation fails
> +static void *
> +alloc_mbuf_rx(int *psz, uintptr_t *paddr)
> +struct mbuf *m;
> +unsigned long l,o;
> + if ( !m )
> + return 0;
> + if ( ! (m->m_flags & M_EXT) ) {
> + m_freem(m);
> + return 0;
> + o = mtod(m, unsigned long);
> + l = MV643XX_ALIGN(o, RX_BUF_ALIGNMENT) - o;
> + /* align start of buffer */
> + m->m_data += l;
> + /* reduced length */
> + l = MCLBYTES - l;
> + m->m_len = m->m_pkthdr.len = l;
> + *psz = m->m_len;
> + *paddr = mtod(m, uintptr_t);
> + return (void*) m;
> +static void consume_rx_mbuf(void *buf, void *arg, int len)
> +struct ifnet *ifp = arg;
> +struct mbuf *m = buf;
> + if ( len <= 0 ) {
> + ifp->if_iqdrops++;
> + if ( len < 0 ) {
> + ifp->if_ierrors++;
> + if ( m )
> + m_freem(m);
> + } else {
> + struct ether_header *eh;
> + eh = (struct ether_header *)(mtod(m, unsigned long) + ETH_RX_OFFSET);
> + m->m_len = m->m_pkthdr.len = len - sizeof(struct ether_header) - ETH_RX_OFFSET - ETH_CRC_LEN;
> + m->m_data += sizeof(struct ether_header) + ETH_RX_OFFSET;
> + m->m_pkthdr.rcvif = ifp;
> + ifp->if_ipackets++;
> + ifp->if_ibytes += m->m_pkthdr.len;
> + if (0) {
> + /* Low-level debugging */
> + int i;
> + for (i=0; i<13; i++) {
> + printf("%02X:",((char*)eh)[i]);
> + printf("%02X\n",((char*)eh)[i]);
> + for (i=0; i<m->m_len; i++) {
> + if ( !(i&15) )
> + printf("\n");
> + printf("0x%02x ",mtod(m,char*)[i]);
> + printf("\n");
> + if (0) {
> + /* Low-level debugging/testing without bsd stack */
> + m_freem(m);
> + } else {
> + /* send buffer upwards */
> + ether_input(ifp, eh, m);
> +static void release_tx_mbuf(void *buf, void *arg, int err)
> +struct mbuf *mb = buf;
> + if ( err ) {
> + ifp->if_oerrors++;
> + } else {
> + ifp->if_opackets++;
> + ifp->if_obytes += mb->m_pkthdr.len;
> + m_freem(mb);
> +#endif /*BSDBSD*/
> +static void
> +dump_update_stats(struct mveth_private *mp, FILE *f)
> +int p = mp->port_num;
> +int idx;
> +uint32_t v;
> + if ( !f )
> + f = stdout;
> + fprintf(f, DRVNAME"%i Statistics:\n", mp->port_num + 1);
> + fprintf(f, " # IRQS: %i\n", mp->stats.irqs);
> + fprintf(f, " Max. mbuf chain length: %i\n", mp->stats.maxchain);
> + fprintf(f, " # repacketed: %i\n", mp->stats.repack);
> + fprintf(f, " # packets: %i\n", mp->stats.packet);
> + fprintf(f, "MIB Counters:\n");
> + for ( idx = MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2;
> + idx < MV643XX_ETH_NUM_MIB_COUNTERS;
> + idx++ ) {
> + switch ( idx ) {
> + case MV643XX_ETH_MIB_GOOD_OCTS_RCVD_LO>>2:
> + mp->stats.mib.good_octs_rcvd += read_long_mib_counter(p, idx);
> + fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_rcvd);
> + idx++;
> + break;
> + case MV643XX_ETH_MIB_GOOD_OCTS_SENT_LO>>2:
> + mp->stats.mib.good_octs_sent += read_long_mib_counter(p, idx);
> + fprintf(f, mibfmt[idx], mp->stats.mib.good_octs_sent);
> + idx++;
> + break;
> + default:
> + v = ((uint32_t*)&mp->stats.mib)[idx] += read_mib_counter(p, idx);
> + fprintf(f, mibfmt[idx], v);
> + break;
> + fprintf(f, "\n");
> +void
> +BSP_mve_dump_stats(struct mveth_private *mp, FILE *f)
> + dump_update_stats(mp, f);
> +#ifdef BSDBSD
> +/* BSDNET DRIVER CALLBACKS */
> +static void
> +mveth_init(void *arg)
> +struct mveth_softc *sc = arg;
> +struct ifnet *ifp = &sc->arpcom.ac_if;
> +int media;
> + BSP_mve_init_hw(&sc->pvt, ifp->if_flags & IFF_PROMISC, sc->arpcom.ac_enaddr);
> + media = IFM_MAKEWORD(0, 0, 0, 0);
> + if ( 0 == BSP_mve_media_ioctl(&sc->pvt, SIOCGIFMEDIA, &media) ) {
> + if ( (IFM_LINK_OK & media) ) {
> + ifp->if_flags &= ~IFF_OACTIVE;
> + } else {
> + ifp->if_flags |= IFF_OACTIVE;
> + /* if promiscuous then there is no need to change */
> + if ( ! (ifp->if_flags & IFF_PROMISC) )
> + mveth_set_filters(ifp);
> + ifp->if_flags |= IFF_RUNNING;
> +/* bsdnet driver entry to start transmission */
> +static void
> +mveth_start(struct ifnet *ifp)
> +struct mveth_softc *sc = ifp->if_softc;
> +struct mbuf *m = 0;
> + while ( ifp->if_snd.ifq_head ) {
> + IF_DEQUEUE( &ifp->if_snd, m );
> + if ( BSP_mve_send_buf(&sc->pvt, m, 0, 0) < 0 ) {
> + IF_PREPEND( &ifp->if_snd, m);
> + break;
> + /* need to do this really only once
> + * but it's cheaper this way.
> + ifp->if_timer = 2*IFNET_SLOWHZ;
> +/* bsdnet driver entry; */
> +static void
> +mveth_watchdog(struct ifnet *ifp)
> + printk(DRVNAME"%i: watchdog timeout; resetting\n", ifp->if_unit);
> + mveth_init(sc);
> + mveth_start(ifp);
> +static void
> +uint32_t v;
> + v = MV_READ(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num));
> + if ( ifp->if_flags & IFF_PROMISC )
> + else
> + MV_WRITE(MV643XX_ETH_PORT_CONFIG_R(sc->pvt.port_num), v);
> + if ( ifp->if_flags & (IFF_PROMISC | IFF_ALLMULTI) ) {
> + BSP_mve_mcast_filter_accept_all(&sc->pvt);
> + } else {
> + struct ether_multi *enm;
> + struct ether_multistep step;
> + BSP_mve_mcast_filter_clear( &sc->pvt );
> + ETHER_FIRST_MULTI(step, (struct arpcom *)ifp, enm);
> + while ( enm ) {
> + if ( memcmp(enm->enm_addrlo, enm->enm_addrhi, ETHER_ADDR_LEN) )
> + assert( !"Should never get here; IFF_ALLMULTI should be set!" );
> + BSP_mve_mcast_filter_accept_add(&sc->pvt, enm->enm_addrlo);
> + ETHER_NEXT_MULTI(step, enm);
> +/* bsdnet driver ioctl entry */
> +static int
> +mveth_ioctl(struct ifnet *ifp, ioctl_command_t cmd, caddr_t data)
> +struct ifreq *ifr = (struct ifreq *)data;
> +int error = 0;
> +int f;
> + switch ( cmd ) {
> + case SIOCSIFFLAGS:
> + f = ifp->if_flags;
> + if ( f & IFF_UP ) {
> + if ( ! ( f & IFF_RUNNING ) ) {
> + mveth_init(sc);
> + } else {
> + if ( (f & IFF_PROMISC) != (sc->bsd.oif_flags & IFF_PROMISC) ) {
> + /* Note: in all other scenarios the 'promisc' flag
> + * in the low-level driver [which affects the way
> + * the multicast filter is setup: accept none vs.
> + * accept all in promisc mode] is eventually
> + * set when the IF is brought up...
> + sc->pvt.promisc = (f & IFF_PROMISC);
> + /* FIXME: other flag changes are ignored/unimplemented */
> + } else {
> + if ( f & IFF_RUNNING ) {
> + mveth_stop(sc);
> + ifp->if_flags &= ~(IFF_RUNNING | IFF_OACTIVE);
> + sc->bsd.oif_flags = ifp->if_flags;
> + break;
> + error = BSP_mve_media_ioctl(&sc->pvt, cmd, &ifr->ifr_media);
> + break;
> + case SIOCADDMULTI:
> + case SIOCDELMULTI:
> + error = (cmd == SIOCADDMULTI)
> + ? ether_addmulti(ifr, &sc->arpcom)
> + : ether_delmulti(ifr, &sc->arpcom);
> + if (error == ENETRESET) {
> + if (ifp->if_flags & IFF_RUNNING) {
> + error = 0;
> + break;
> + break;
> + case SIO_RTEMS_SHOW_STATS:
> + dump_update_stats(&sc->pvt, stdout);
> + break;
> + default:
> + error = ether_ioctl(ifp, cmd, data);
> + break;
> + return error;
> +/* DRIVER TASK */
> +/* Daemon task does all the 'interrupt' work */
> +static void mveth_daemon(void *arg)
> +struct mveth_softc *sc;
> +struct ifnet *ifp;
> +rtems_event_set evs;
> + for (;;) {
> + rtems_bsdnet_event_receive( 7, RTEMS_WAIT | RTEMS_EVENT_ANY, RTEMS_NO_TIMEOUT, &evs );
> + evs &= 7;
> + for ( sc = theMvEths; evs; evs>>=1, sc++ ) {
> + if ( (evs & 1) ) {
> + register uint32_t x;
> + ifp = &sc->arpcom.ac_if;
> + if ( !(ifp->if_flags & IFF_UP) ) {
> + mveth_stop(sc);
> + ifp->if_flags &= ~(IFF_UP|IFF_RUNNING);
> + continue;
> + if ( !(ifp->if_flags & IFF_RUNNING) ) {
> + /* event could have been pending at the time hw was stopped;
> + * just ignore...
> + continue;
> + x = mveth_ack_irqs(&sc->pvt, -1);
> + if ( MV643XX_ETH_EXT_IRQ_LINK_CHG & x ) {
> + /* phy status changed */
> + int media;
> + if ( 0 == BSP_mve_ack_link_chg(&sc->pvt, &media) ) {
> + mveth_start(ifp);
> + } else {
> + /* stop sending */
> + /* free tx chain */
> + if ( (MV643XX_ETH_EXT_IRQ_TX_DONE & x) && BSP_mve_swipe_tx(&sc->pvt) ) {
> + if ( TX_AVAILABLE_RING_SIZE(&sc->pvt) == sc->pvt.avail )
> + ifp->if_timer = 0;
> + mveth_start(ifp);
> + if ( (MV643XX_ETH_IRQ_RX_DONE & x) )
> + BSP_mve_swipe_rx(&sc->pvt);
> + mveth_enable_irqs(&sc->pvt, -1);
> +static int mveth_detach(struct mveth_softc *sc);
> +#endif
> +/* PUBLIC RTEMS BSDNET ATTACH FUNCTION */
> +int
> +rtems_mve_attach(struct rtems_bsdnet_ifconfig *ifcfg, int attaching)
> +char *unitName;
> +int unit,i,cfgUnits;
> +struct ifnet *ifp;
> + unit = rtems_bsdnet_parse_driver_name(ifcfg, &unitName);
> + return 1;
> + sc = &theMvEths[unit-1];
> + sc->pvt.port_num = unit-1;
> + sc->pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*sc->pvt.port_num)) & 0x1f;
> + if ( attaching ) {
> + return -1;
> + for ( i=cfgUnits = 0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
> + if ( theMvEths[i].arpcom.ac_if.if_init )
> + cfgUnits++;
> + cfgUnits++; /* this new one */
> + /* lazy init of TID should still be thread-safe because we are protected
> + * by the global networking semaphore..
> + if ( !mveth_tid ) {
> + /* newproc uses the 1st 4 chars of name string to build an rtems name */
> + mveth_tid = rtems_bsdnet_newproc("MVEd", 4096, mveth_daemon, 0);
> + if ( !BSP_mve_setup( unit,
> + mveth_tid,
> + release_tx_mbuf, ifp,
> + alloc_mbuf_rx,
> + consume_rx_mbuf, ifp,
> + ifcfg->rbuf_count,
> + ifcfg->xbuf_count,
> + BSP_MVE_IRQ_TX | BSP_MVE_IRQ_RX | BSP_MVE_IRQ_LINK) ) {
> + return -1;
> + if ( nmbclusters < sc->pvt.rbuf_count * cfgUnits + 60 /* arbitrary */ ) {
> + printk(DRVNAME"%i: (mv643xx ethernet) Your application has not enough mbuf clusters\n", unit);
> + printk( " configured for this driver.\n");
> + return -1;
> + if ( ifcfg->hardware_address ) {
> + memcpy(sc->arpcom.ac_enaddr, ifcfg->hardware_address, ETHER_ADDR_LEN);
> + } else {
> + /* read back from hardware assuming that MotLoad already had set it up */
> + BSP_mve_read_eaddr(&sc->pvt, sc->arpcom.ac_enaddr);
> + ifp->if_softc = sc;
> + ifp->if_unit = unit;
> + ifp->if_name = unitName;
> + ifp->if_mtu = ifcfg->mtu ? ifcfg->mtu : ETHERMTU;
> + ifp->if_init = mveth_init;
> + ifp->if_ioctl = mveth_ioctl;
> + ifp->if_start = mveth_start;
> + ifp->if_output = ether_output;
> + * While nonzero, the 'if->if_timer' is decremented
> + * (by the networking code) at a rate of IFNET_SLOWHZ (1hz) and 'if_watchdog'
> + * is called when it expires.
> + * If either of those fields is 0 the feature is disabled.
> + ifp->if_watchdog = mveth_watchdog;
> + sc->bsd.oif_flags = /* ... */
> + ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
> + * if unset, this set to 10Mbps by ether_ifattach; seems to be unused by bsdnet stack;
> + * could be updated along with phy speed, though...
> + ifp->if_baudrate = 10000000;
> + /* NOTE: ether_output drops packets if ifq_len >= ifq_maxlen
> + * but this is the packet count, not the fragment count!
> + ifp->if_snd.ifq_maxlen = sc->pvt.xbuf_count;
> + ifp->if_snd.ifq_maxlen = ifqmaxlen;
> + if ( !ifp->if_addrlist ) /* do only the first time [reattach hack] */
> +#endif
> + if_attach(ifp);
> + ether_ifattach(ifp);
> + } else {
> + if ( !ifp->if_init ) {
> + printk(DRVNAME": instance %i not attached.\n", unit);
> + return -1;
> + return mveth_detach(sc);
> +#else
> + printk(DRVNAME": interface detaching not implemented\n");
> + return -1;
> +#endif
> + return 0;
> +/* EARLY PHY ACCESS */
> +static int
> +mveth_early_init(int idx)
> + if ( idx < 0 || idx >= MV643XXETH_NUM_DRIVER_SLOTS )
> + return -1;
> + /* determine the phy */
> + theMvEths[idx].pvt.phy = (MV_READ(MV643XX_ETH_PHY_ADDR_R) >> (5*idx)) & 0x1f;
> + return 0;
> +static int
> +mveth_early_read_phy(int idx, unsigned reg)
> +int rval;
> + return -1;
> + rval = mveth_mii_read(&theMvEths[idx].pvt, reg);
> + return rval < 0 ? rval : rval & 0xffff;
> +static int
> +mveth_early_write_phy(int idx, unsigned reg, unsigned val)
> + return -1;
> + mveth_mii_write(&theMvEths[idx].pvt, reg, val);
> + return 0;
> +rtems_bsdnet_early_link_check_ops
> +rtems_mve_early_link_check_ops = {
> + init: mveth_early_init,
> + read_phy: mveth_early_read_phy,
> + write_phy: mveth_early_write_phy,
> + name: DRVNAME,
> + num_slots: MAX_NUM_SLOTS
> +/* DEBUGGING */
> +#endif /*BSDBSD*/
> +#ifdef MVETH_DEBUG
> +/* Display/dump descriptor rings */
> +int
> +mveth_dring(struct mveth_softc *sc)
> +int i;
> +if (1) {
> +MvEthRxDesc pr;
> +printf("RX:\n");
> + for (i=0, pr=sc->pvt.rx_ring; i<sc->pvt.rbuf_count; i++, pr++) {
> + /* can't just invalidate the descriptor - if it contains
> + * data that hasn't been flushed yet, we create an inconsistency...
> + rtems_bsdnet_semaphore_obtain();
> + INVAL_DESC(pr);
> +#endif
> + printf("cnt: 0x%04x, size: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x\n",
> + pr->byte_cnt, pr->buf_size, pr->cmd_sts, (uint32_t)pr->next_desc_ptr, pr->buf_ptr);
> + rtems_bsdnet_semaphore_release();
> +#endif
> +if (1) {
> +MvEthTxDesc pt;
> +printf("TX:\n");
> + for (i=0, pt=sc->pvt.tx_ring; i<sc->pvt.xbuf_count; i++, pt++) {
> + INVAL_DESC(pt);
> +#endif
> + printf("cnt: 0x%04x, stat: 0x%08x, next: 0x%08x, buf: 0x%08x, mb: 0x%08x\n",
> + pt->byte_cnt, pt->cmd_sts, (uint32_t)pt->next_desc_ptr, pt->buf_ptr,
> + (uint32_t)pt->mb);
> +#endif
> + return 0;
> +#endif
> +/* DETACH HACK DETAILS */
> +int
> +_cexpModuleFinalize(void *mh)
> +int i;
> + for ( i=0; i<MV643XXETH_NUM_DRIVER_SLOTS; i++ ) {
> + if ( theMvEths[i].arpcom.ac_if.if_init ) {
> + printf("Interface %i still attached; refuse to unload\n", i+1);
> + return -1;
> + /* delete task; since there are no attached interfaces, it should block
> + * for events and hence not hold the semaphore or other resources...
> + rtems_task_delete(mveth_tid);
> + return 0;
> +/* ugly hack to allow unloading/reloading the driver core.
> + * needed because rtems' bsdnet release doesn't implement
> + * if_detach(). Therefore, we bring the interface down but
> + * keep the device record alive...
> +static void
> +ether_ifdetach_pvt(struct ifnet *ifp)
> + ifp->if_flags = 0;
> + ifp->if_ioctl = 0;
> + ifp->if_start = 0;
> + ifp->if_watchdog = 0;
> + ifp->if_init = 0;
> +static int
> +mveth_detach(struct mveth_softc *sc)
> + if ( ifp->if_flags & (IFF_UP | IFF_RUNNING) ) {
> + printf(DRVNAME"%i: refuse to detach; interface still up\n",sc->pvt.port_num+1);
> + return -1;
> + mveth_stop(sc);
> +/* not implemented in BSDnet/RTEMS (yet) but declared in header */
> +#define ether_ifdetach ether_ifdetach_pvt
> + ether_ifdetach(ifp);
> + free( (void*)sc->pvt.ring_area, M_DEVBUF );
> + sc->pvt.ring_area = 0;
> + sc->pvt.tx_ring = 0;
> + sc->pvt.rx_ring = 0;
> + sc->pvt.d_tx_t = sc->pvt.d_tx_h = 0;
> + sc->pvt.d_rx_t = 0;
> + sc->pvt.avail = 0;
> + /* may fail if ISR was not installed yet */
> + BSP_remove_rtems_irq_handler( &irq_data[sc->pvt.port_num] );
> + return 0;
> +#ifdef MVETH_DEBUG
> +struct rtems_bsdnet_ifconfig mveth_dbg_config = {
> + name: DRVNAME"1",
> + attach: rtems_mve_attach,
> + ip_address: "192.168.2.10", /* not used by rtems_bsdnet_attach */
> + ip_netmask: "255.255.255.0", /* not used by rtems_bsdnet_attach */
> + hardware_address: 0, /* (void *) */
> + ignore_broadcast: 0, /* TODO driver should honour this */
> + mtu: 0,
> + rbuf_count: 0, /* TODO driver should honour this */
> + xbuf_count: 0, /* TODO driver should honour this */
> +#endif
> +#endif
> diff --git a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
> index 10c3652f97..6cc419966d 100644
> --- a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
> +++ b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
> @@ -84,13 +84,15 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/pci/motload_fixu
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/shared/pci/pcifinddevice.c
> #network
> +# low-level driver
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
> if HAS_NETWORKING
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em_hw.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_em/if_em_rtems.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_gfe/if_gfe.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c
> -librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/if_mve/mv643xx_eth_bsdnet.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/support/bsp_attach.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/powerpc/beatnik/net/support/early_link_status.c
> endif
