[PATCH rtems-docs] common/latex.py: use distro module for python3.5 and up
Gedare Bloom
gedare at rtems.org
Tue Mar 30 14:01:42 UTC 2021
Go ahead; platform.dist is deprecated/removed, and this is the right
replacement to make with backward compat to 2 via
platform.linux_distribution().
On Mon, Mar 29, 2021 at 7:43 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> Hi,
> Sorry for too many pings at once :)
> Thanks.
> On Tue, Mar 23, 2021 at 2:05 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > common/latex.py | 7 +++++--
> > 1 file changed, 5 insertions(+), 2 deletions(-)
> > diff --git a/common/latex.py b/common/latex.py
> > index a042510..a1b3917 100644
> > --- a/common/latex.py
> > +++ b/common/latex.py
> > @@ -3,8 +3,11 @@
> > import os
> > -import platform
> > import re
> > +try:
> > + from distro import linux_distribution
> > +except:
> > + from platform import linux_distribution
> > package_test_preamble = ['\\newif\\ifsphinxKeepOldNames \\sphinxKeepOldNamestrue',
> > '\documentclass[a4paper,11pt,english]{report}']
> > @@ -82,7 +85,7 @@ def tex_test(test):
> > def host_name():
> > uname = os.uname()
> > if uname[0] == 'Linux':
> > - distro = platform.dist()
> > + distro = linux_distribution()
> > name = '%s/%s' % (uname[0], distro[0])
> > version = distro[1]
> > else:
> > 2.26.2
> devel mailing list
> devel at rtems.org
