[PATCH rtems-docs] common/latex.py: use distro module for python3.5 and up
Vijay Kumar Banerjee
vijay at rtems.org
Tue Mar 30 15:30:21 UTC 2021
On Tue, Mar 30, 2021 at 8:01 AM Gedare Bloom <gedare at rtems.org> wrote:
> Go ahead; platform.dist is deprecated/removed, and this is the right
> replacement to make with backward compat to 2 via
> platform.linux_distribution().
Yes, I have also tested with 2 to ensure it's building. Thanks for the
review. Pushed it.
> On Mon, Mar 29, 2021 at 7:43 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > Hi,
> > Sorry for too many pings at once :)
> > Thanks.
> > On Tue, Mar 23, 2021 at 2:05 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> > > common/latex.py | 7 +++++--
> > > 1 file changed, 5 insertions(+), 2 deletions(-)
> > > diff --git a/common/latex.py b/common/latex.py
> > > index a042510..a1b3917 100644
> > > --- a/common/latex.py
> > > +++ b/common/latex.py
> > > @@ -3,8 +3,11 @@
> > > import os
> > > -import platform
> > > import re
> > > +try:
> > > + from distro import linux_distribution
> > > +except:
> > > + from platform import linux_distribution
> > > package_test_preamble = ['\\newif\\ifsphinxKeepOldNames \\sphinxKeepOldNamestrue',
> > > '\documentclass[a4paper,11pt,english]{report}']
> > > @@ -82,7 +85,7 @@ def tex_test(test):
> > > def host_name():
> > > uname = os.uname()
> > > if uname[0] == 'Linux':
> > > - distro = platform.dist()
> > > + distro = linux_distribution()
> > > name = '%s/%s' % (uname[0], distro[0])
> > > version = distro[1]
> > > else:
> > > 2.26.2
> > devel mailing list
> > devel at rtems.org
